View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113
  1. Brakes: Swing pedals in GT Hawk
  2. Brakes: Brakes "locking"... M/C or Hydrovac?
  3. Fuel System: Suggestions for air cleaner on Edelbrock carburetor...
  4. Brakes: Hard Brake Lining
  5. Engine: Oil/Zink
  6. Fuel System: Combatting Ethanol
  7. Engine: Excessive oil consumption
  8. Wheels THE BEST Steel Wheel size for a 64 Cruiser
  9. Fuel System: About the Carter 32 RBS. You might want to know that.
  10. Brakes: Brake Rotors on a 1978 Avanti II
  11. Engine: Water out of last head bolt hole.
  12. Engine: Stude V8 Engine Number Decode
  13. Fuel System: My 1962 Lark 259 has a Rochester 2G carb on it, NOT the Stromberg unit.
  14. Electrical: Total and complete idiot (me) strikes again
  15. Engine: Studebaker roller cams available at a reasonable cost
  16. Electrical: Starter rotates slow
  17. Transmission: Stude/Borg Warner T86E questions
  18. Engine: 66 Cruser V/8
  19. Speedo/Tach/Gauges Need Help wiring R-series Tach ASAP
  20. Engine: How many blades on a fan blade?? Will too few cause overheating??
  21. Exhaust New SS Exhaust System for M15A-20
  22. Transmission: 1962 Lark V8 3spd/OD; low gear doesn't always engage.........
  23. Electrical: 62 Hawk electrical problem
  24. Engine: PCV Valve Part Number/ Where to purchase
  25. Electrical: Need help locating a Tung- Sol A229S signal flasher fuse.--2 Prong
  26. Electrical: coil shorted problem
  27. Brakes: Can you interchange 1954-up backing plates onto 1950 Champion?
  28. Engine: I have three blocks need help Identifying..
  29. Electrical: Gas gauge
  30. Fuel System: 65 studebaker 1 barrel carb
  31. Body: Door Location
  32. Fuel System: Carter WE Carb
  33. Electrical: Floor Starter Switch on 1950 Champion
  34. Body: C-K windshield gasket-rubber-seal
  35. Other: Questions about 1940 Commanders
  36. Transmission: 57 SilverHawk OD cable
  37. Engine: Swap a Golden Hawk motorinto a Speedster
  38. Other: Which is the better vacuum port?
  39. Transmission: Need some help Trouble shooting my 49 2R10
  40. Interior: Shoulder belts been installed by anybody?
  41. Engine: Does a 283 V8 really take only 4 quarts of oil?
  42. Transmission: That Nice Green Color?
  43. Brakes: calipers
  44. Speedo/Tach/Gauges R3 Tach wiring
  45. Body: door latch oin? what is it called?
  46. Transmission: T-86 gearratios
  47. Transmission: BW Overdrive
  48. Brakes: 65 commander power brakes
  49. Other: Alternator / AC Compressor Install photos
  50. Other: Trunk light install in 64 Cruiser
  51. Electrical: What black wire goes where on the light switch on our 1960 Lark V-8 convertible w/auto & p/steering?
  52. Transmission: Ford now using the "Powershift" transmission name...
  53. Fuel System: Stromberg WW 2 bbl with an old problem.
  54. Fuel System: Super Charger gaskets and seals
  55. Body: Body Trim, Korean Chrome, Unatainium 1952 Starliner Belt-line
  56. Engine: Flexible Oil Lines
  57. Brakes: '66 parking brake
  58. Brakes: Turner master bracket
  59. Frame/Springs '51 LandCruiser suspension Bushings
  60. Body: Rear Window Removal??
  61. Interior: Hawk Seat covers
  62. Wheels Left Hand Threads
  63. Other: Interchange list
  64. Speedo/Tach/Gauges 63/64 Avanti Pressure/Vacuum Gauge
  65. Rear Axle: Rear End for '49 Stude 3/4 Ton Truck
  66. Body: A one man C/K back window install???
  67. Transmission: 1955 Speedster DG250 seals, AC install and parts wanted
  68. Fuel System: Carb question on 52 Champion
  69. Wheels P185/65/15 R on stock rims??? 1965.. did i find the perfect tire??? could it be??
  70. Engine: 289 valve timing second opinion wanted ....problem solved!
  71. Transmission: Heart transplant
  72. Other: Front bushings squeak: Fix ?
  73. Body: 50 Rear Inner Fender Wells & Fuel Filler Mount
  74. Engine: SBC Swap Problems In A Hawk
  75. Transmission: Throttle valve likage adjustment.
  76. Engine: Crankshaft & Flywheel Balancing (Pictures the rebuilder's sent me)
  77. Engine: Those of you wanting a roller camshaft.....
  78. Electrical: Wiring diagram for a 51 turn signal.
  79. Engine: 1963 Champ 6 with ruined head - options?
  80. Engine: Another quick dumb question
  81. Wheels Relacement Rims for a 56 Transtar 1 ton
  82. Engine: What a difference a working vacuum advance makes.....
  83. Electrical: Avanti altinator
  84. Electrical: Distributor problem 259
  85. Brakes: Brake pull
  86. Electrical: Ignition Switch 62 Hawk
  87. Engine: Starter issue.
  88. Engine: Oil Pan Gaskets
  89. Interior: sill plate ID needed
  90. Electrical: Amp gauge question
  91. Fuel System: Carb Rebuild on Carter WCFB
  92. Front Axle: King Pin Removal
  93. Engine: Jack Vines, other 259 rebuilders - HELP!
  94. Engine: Crank & Backing Plate Install (Pictures the rebuilder's sent me)
  95. Speedo/Tach/Gauges Dead speed head in a 1962 Lark
  96. Engine: Block Ribs Question
  97. Transmission: Bell crank to transmission rod
  98. Electrical: Electric Brake Light Switch How To....
  99. Other: windshield
  100. Electrical: heater blower motor and fans
  101. Engine: Clutch Install (Pictures the rebuilder's sent me)
  102. Cool/Heat: Clutch fan bolts
  103. Electrical: Wiring Harness
  104. Engine: 56 Golden Hawk engine swap
  105. Clutch/Torque Converter: Clutch Shaft Busshings
  106. Clutch/Torque Converter: Clutch Shaft Busshings
  107. Body: 1950 Champion Rocker Trim
  108. Electrical: front lights on 64 hawk both head & parking lights not working
  109. Electrical: Strange Avanti Electrical Problem
  110. Cool/Heat: Avanti fan clutch
  111. Electrical: plug wires recommendation.
  112. Interior: Correct Headliner for 1963 Lark F6
  113. Wheels Uneven tire wear on an original 1948 Land Cruiser
  114. Engine: Engine ID
  115. Engine: A new project!
  116. Electrical: Avanti 63R1406 R2 Update Status
  117. Cool/Heat: Radiator cradle question
  118. Transmission: Floor Shift Conversion 50 Champ
  119. Brakes: Napa brake hoses
  120. Electrical: Coil and coil wire problem
  121. Engine: Oil usage?
  122. Frame/Springs Removing front coil springs
  123. Engine: valve train noise
  124. Frame/Springs Light Duty Rear Springs Wanted for 1950 2R10
  125. Fuel System: 4-Bbl Carb For 259 V8
  126. Paint: Prepping an Avanti for Paint.
  127. Shocks '66 Commander
  128. Engine: Oil change place recommendation.
  129. Body: Rear panel 63 Gran Tran Hawk
  130. Body: 63 Hawk
  131. Electrical: 1948 studebaker dashboard lights
  132. Electrical: Interior light problems
  133. Paint: Phoenix
  134. Shocks Avanti Rear Shock Modification
  135. Fuel System: 57 Golden Hawk SC belt
  136. Engine: LS2 in a 54 champion coupe
  137. Engine: Carter carb
  138. Body: Leaky windshield
  139. Engine: Bob Palma's 1971 article on repowering a '53 to '60 Stude
  140. Electrical: Avanti A/C Schematic
  141. Engine: Engine Swap with a 3.8 GM
  142. Engine: ATI Damper Hub
  143. Engine: 259 and 289 Heads Interchangability
  144. Body: Bondo, Bondo everywhere !!
  145. Rear Axle: Dana 44 pinion shaft nut thread direction
  146. Fuel System: Fuel pump for the Studebaker 6s
  147. Paint: Stude engine colors
  148. Electrical: What starters work with 259 / auto
  149. Brakes: Chevelle master cylinder on a 65/66 booster pics
  150. Brakes: 1968 Mustang power disc MC on a 1962 Lark, what booster will work?
  151. Brakes: Modifying rear drums to separate from the hub?
  152. Engine: Can't match engine number to spec chart
  153. Engine: Starter Idea
  154. Frame/Springs Upper A-arm bumper
  155. Brakes: Hill holder parts for 50 Champion wanted
  156. Frame/Springs I now need rear leaf springs
  157. Engine: Early hemi to stude
  158. Body: M5 fender bolts
  159. Fuel System: Edelbrock carb cold starting issue.
  160. Fuel System: Need '64 gas tank...
  161. Fuel System: '51 Commander Fuel Pump....
  162. Transmission: NP A-833 bench build
  163. Exhaust 350 Chevy into a 1962 Lark: exhaust system options?
  164. Engine: 57 Supercharger air bonnet
  165. Steering Power Steering Pump Interchange
  166. Transmission: Transmission Grinding into 2nd gear
  167. Transmission: Free Wheling, Dictator 1931
  168. Clutch/Torque Converter: Clutch replacement
  169. Cool/Heat: C K heater blower motor & fan wheel
  170. Engine: Crankshaft and Flywheel Balancing (Pictures the rebuilder's sent me)
  171. Body: 74 Avanti hog trough - roll bar bolt removal
  172. Body: Sheet metal thickness
  173. Engine: Putting a CHevy 350 and TH350 into my 1962 Lark
  174. Engine: 1963 R2 GT Bogs When Floored
  175. Engine: Porting heads possibly damaging?
  176. Brakes: Finned rear drums
  177. Other: 1957 commander T-handles on dash what are their functions? I am a newbie
  178. Engine: Oil Issue
  179. Engine: Removing a stubborn head
  180. Cool/Heat: freeze plugs
  181. Body: Welding Shield Visability
  182. Engine: Bracket and Pulley system to fit in 56J compatment for LS1 swap
  183. Body: 1956 Hawk hood, or any year that will fit
  184. Engine: 1965-66 Stude 283 engine pedestals and my 1962 Lark?
  185. Engine: Champion Manifold
  186. Engine: Engine Tuning for dummies
  187. Transmission: T90 top load on T86
  188. Transmission: DG-200 Shift Question
  189. Body: Fenders etc.
  190. Electrical: Clocks
  191. Shocks Shock Absorbers for 1962-'64 GT Hawk
  192. Body: Trunk Hinge Spacer
  193. Brakes: master cylinder for disc brake conversion.
  194. Brakes: "Norol" repair question - 1940 President Stude
  195. Transmission: Handle for the Overdrive release/engagement
  196. Transmission: Looking for a Bell Housing, Flywheel and Starter
  197. Fuel System: Gas smell
  198. Brakes: soft pedal
  199. Frame/Springs MOOG CC655 coil springs
  200. Drive Shaft One piece or two piece?
  201. Wheels 1964 wheels with disc brakes
  202. Body: Lark Door Latch and Handle
  203. Engine: Size and Year
  204. Engine: Chevy 350 in my 1962 Lark: ran into some problems.
  205. Cool/Heat: C Cab Vintage Air unit
  206. Engine: No vacumn .
  207. Engine: Been sitting for >30 years. No compression on cylinder 3
  208. Rear Axle: Replace the rear end with an S10?
  209. Cool/Heat: 1962 Lark/350 Chevy. electric fan?
  210. Electrical: Starter cable length?
  211. Rear Axle: Axle end play
  212. Steering 53 Commander steering rebuild
  213. Electrical: Sudden battery death: potential causes?
  214. Brakes: parking brake cable boot NLA?
  215. Cool/Heat: 63 Avanti A/C Rat-a-Tat loud noise.
  216. Electrical: Ignition cable set question.
  217. Interior: Where to find pink vinyl ?
  218. Other: Parts for free
  219. Engine: Avanti R2
  220. Engine: Valve & Piston Install (Pictures the rebuilder's sent me)
  221. Body: Avanti (Fiberglass) Bonding Adhesive???
  222. Speedo/Tach/Gauges Radioluminescent
  223. Engine: Oil Galley Drawings
  224. Frame/Springs Hawk Frame Dimensions
  225. Body: Hood Dovetail length (Hawk)
  226. Electrical: R1 starter bendix
  227. Frame/Springs Coil springs for a 54 Starliner
  228. Electrical: Electrical connectors.
  229. Steering Center Point Steering
  230. Rear Axle: 1949 Champion - unsticking the rear axle
  231. Electrical: Batteries haven't really evolved very far, have they?
  232. Speedo/Tach/Gauges Odometer Stuck
  233. Electrical: Instrument lights - none
  234. Body: Window and door seals.
  235. Body: are the 53 hardtop fenders compatible with the 55 model
  236. Speedo/Tach/Gauges looking for a six volt tachometer
  237. Engine: Optional R3 Parts
  238. Steering Sloppy steering on a 64 Hawk with power steering
  239. Fuel System: Brass float for sending unit...
  240. Fuel System: How do I install fuel pump heat shield ? PICS?
  241. Cool/Heat: C/K order of Climatizer assembly.
  242. Frame/Springs Engine swap in a 1946
  243. Steering 1950 steering safety issues?
  244. Frame/Springs Still Looking for Factory Light Duty Rear Springs for 1950 2R10 or 11
  245. Frame/Springs Moog CC655, Again
  246. Rear Axle: Wanting to swap out Dana 27 with a Dana 44
  247. Other: Front end question - uneven tire wear
  248. Body: Identify 1515-Dash-C Deck Sealing Cement?
  249. Electrical: 57 distributor questions
  250. Steering Power Steering
