View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Brakes: Question re Parking Brake Mechanism
  2. Wheels Lug torque
  3. Engine: 51 Champion, running rough under load.
  4. Electrical: Turn Signal Switch
  5. Body: front grill bolts
  6. Brakes: Bendix Remote Power Booster
  7. Transmission: transmission or engine/carburetor?
  8. Engine: Crankshaft Straightening & Grinding Today
  9. Other: Wiper Washers
  10. Rear Axle: gearing
  11. Engine: Connecting Rod Magnafluxing & Boring
  12. Paint: Is this the correct engine color for a Victory Six in 1955?
  13. Electrical: FLAPS OHV-6 plug wire set?
  14. Cool/Heat: 62 GT Hawk gets hot.
  15. Steering Cross Post: Ross Steering Box Oil/Lube
  16. Brakes: Brake Pads
  17. Speedo/Tach/Gauges How to Adapt Speedometer Cable
  18. Fuel System: '41 Champion fuel gauge
  19. Transmission: Great buy...
  20. Engine: Stude 259 coming out; SBC going into my 1962 Lark
  21. Engine: Connecting Rod True Testing
  22. Wheels 1962 Lark: what wheels will fit to clear future disc brakes?
  23. Cool/Heat: Evans Coolant?
  24. Steering 63 Avanti Power Steering Pump
  25. Engine: Searching for 169 champ valve lifter springs
  26. Steering Bump Steer?
  27. Engine: Broken Con Rod
  28. Interior: Carpet
  29. Body: License plate lamp wire
  30. Engine: Flywheel Resurfacing and Ring Gear Replace
  31. Engine: Tune up
  32. Electrical: 1962 Lark V8 starter is dead
  33. Body: recommendation for Mig solid wire size for Stude floor and rocker panels?
  34. Paint: Newbie with What Color question
  35. Transmission: Transmission swap
  36. Electrical: Avanti starts when ignition switch is fully engaged
  37. Engine: What is the blue canister on top of my Carberator??
  38. Brakes: 1962 Lark master cylinder and possible booster questions
  39. Clutch/Torque Converter: Noisy clutch 50 Commander
  40. Steering Cross Post: Reach Rod Design
  41. Electrical: Avanti ground
  42. Engine: V8 Oil Circuits
  43. Transmission: Difficult shifting
  44. Body: 1964 Studebaker Daytona convertible top
  45. Transmission: Just listed my Avanti PowerShift Auto Trans for sale on eBay
  46. Paint: reducer and cleaner
  47. Electrical: Where is it?
  48. Paint: Quote
  49. Engine: Longevity
  50. Engine: Engine Prefix #s
  51. Brakes: Brake Light Sticking
  52. Interior: steering wheel restore
  53. Front Axle: straight axle for a 60 lark?
  54. Wheels anyone running lark with P21575r15
  55. Interior: Lark Seats: Are they all the same size?
  56. Engine: Max Head Shave
  57. Engine: Connecting Rod Balancing (Pictures the rebuilder's sent me)
  58. Front Axle: Tierod rubber covers.
  59. Brakes: Is there a way to tell if brake fluid in a car is silicone or not?
  60. Frame/Springs Bolt together hog throughs?
  61. Transmission: Transmission buzzing sound
  62. Brakes: 63 gt hawk brakes
  63. Speedo/Tach/Gauges 12volt tach on 6 volt system
  64. Exhaust valve clearance
  65. Paint: Glyptal Paint Question....
  66. Wheels 1 ton wheel/tire questions
  67. Engine: Crankshaft Quality
  68. Engine: 1960 lark 2dr sd (red) 6 cylinder oil leaks
  69. Engine: Vacuum gage diaignosis
  70. Engine: Mpg
  71. Body: need some help!
  72. Engine: Fuel delivery problems
  73. Transmission: Decisions, decisions, decisions. 1962 Lark receiving a 350 Chevy; what are my tranny options?
  74. Brakes: rotors
  75. Front Axle: Cross Post: King Pin Install
  76. Body: adjusting rear quarter windows on 53 starliner
  77. Fuel System: Floods when shut down once it is warmed up
  78. Transmission: 3 speed O.D.
  79. Brakes: M/C for disc brake cars
  80. Body: Seal for floor at pedals
  81. Fuel System: Stromberg WW 6-117B carb
  82. Body: Door seals
  83. Interior: trim piece
  84. Interior: Interior door handle removal on 1950 Commander
  85. Brakes: Banjo Bolt For Disc Brake Conversion
  86. Engine: building a stude 289
  87. Drive Shaft double driveshaft vibration issues revisited.
  88. Engine: Question About OE Engine Paint (1962)
  89. Engine: Cylinder head porting WTTW...
  90. Other: Mechanical BOZO needs much help
  91. Electrical: Pertronix Elect. Ignition
  92. Transmission: OD trouble
  93. Brakes: hill holder repair
  94. Engine: Zddp
  95. Engine: 1965-66 Chevybaker specific parts: looking for them for my 1962 Lark
  96. Fuel System: need a carterAS 1 barrel and other parts for my 1960 6 cylinder lark
  97. Electrical: 1955 Studebaker President Cpe horn question
  98. Engine: Serial #
  99. Frame/Springs Cross Over Parts
  100. Transmission: HURST Shift Rods
  101. Brakes: Anyone have a picture of correct Avanti primary and secondary linings on the shoes?
  102. Engine: Stude newbie. HELP!!
  103. Engine: Champion Front Felt Seal
  104. Engine: I need Your Advice on Hopping up a Champion Six
  105. Electrical: Braided Steel vs Insulated Copper Ground Cables?
  106. Body: 1951 Bumper assembly questions
  107. Cool/Heat: Radiator question
  108. Interior: 63 Avanti Kick Panel
  109. Brakes: remote resviour/ dual master/ Turner bracket
  110. Transmission: Three Speed Overdrive Transmissions
  111. Clutch/Torque Converter: Modified clutch pedal for hydraulic clutch
  112. Interior: Window controller / Hurst shifter
  113. Front Axle: Suspension Parts for a 50 Champ
  114. Other: What kind of lube is this?
  115. Frame/Springs Batwing to APost Clearance
  116. Electrical: 6 Volt Alternators
  117. Engine: Aluminum Intake & Vaporlock
  118. Transmission: DG Automatic Identification
  119. Steering GM 625 steering box?
  120. Engine: Can I safely mill a Champion Six head by .050" without hitting valves?
  121. Engine: Post Mortem
  122. Wheels Wheelcovers
  123. Engine: R2 Water Pump and Alternator
  124. Transmission: 1956 J... Borg Warner column shift conversion to floor shift ...anyone with experience doing so ?
  125. Transmission: Transmission insulator needed!
  126. Engine: Thinking About Doing An Engine or Frame Swap On a Studebaker?
  127. Engine: Oil Pan Cleanliness and Piston Balancing (Pictures the rebuilder's sent me)
  128. Electrical: What should the gap be set on 6v o/d solenoid contacts?
  129. Frame/Springs New Chassis?
  130. Engine: Block Cracks Pinned & Pressure Tested, Head Resurfaced, & Coarse Bored
  131. Electrical: Redmond Motor
  132. Body: 1962 Lark: going from quad headlights to dual ones?
  133. Engine: Engine swap
  134. Wheels 4 lug swap to 5
  135. Engine: Had my starter rebuilt on my 1962 Lark; the 259 will stay for a while...........
  136. Engine: As per another thread here; I got my 1962 Lark 259 running, now I want to (mildly) hop it up........
  137. Transmission: Dipstick tube replacement?
  138. Electrical: Maybe there will be a GM style HEI ignition for Stude V8 engines............
  139. Drive Shaft Shutter at Launch
  140. Brakes: Hill Holder needed for 1955 commander
  141. Engine: replaceing motor mounts
  142. Cool/Heat: GT overheats
  143. Brakes: Flush Brake System on 64 Champ Pickup
  144. Other: '56 President and '57 Champion interchange
  145. Brakes: 1 ton rear brake removal
  146. Engine: truck manifold question
  147. Fuel System: Review this video to diagnose pressure from fuel pump
  148. Engine: 62 Lark Engine.
  149. Interior: Interior replacement
  150. Engine: Any interest in a 185ci Champion block/head?
  151. Engine: 259 Studebaker engine boring
  152. Steering 1931 President Steering Box
  153. Electrical: Where to get new wiring harness
  154. Electrical: Hot Coil
  155. Electrical: Altenator Mounting
  156. Interior: Steering wheel repair
  157. Steering Bushings
  158. Fuel System: Fuel pump/gas cap, 1957 Silver Hawk 289.
  159. Steering Front End Bushings
  160. Engine: Removing Old Valve Seats & Installing Stellite Seats (Pictures the rebuilder's sent me)
  161. Exhaust Which are better?
  162. Transmission: Overdrive: converting 6V to 12V
  163. Front Axle: Help removing Tapered Pin
  164. Engine: overheating?
  165. Engine: Champion 6 in a M 15A
  166. Brakes: Rear Brake/Axle dilema
  167. Fuel System: 51 Commander fuel tank?
  168. Electrical: what bulb number is this? thanks
  169. Engine: Grinding Valve Seats & Resurfacing the Block (Pictures the rebuilder's sent me)
  170. Cool/Heat: Thinking about a sealed coolng system.
  171. Body: There's rust under my leaded seams!
  172. Speedo/Tach/Gauges speedo gear for Hawk 4 speed
  173. Interior: 1966 parking brake warning light
  174. Frame/Springs Interesting Rear Suspension (link).. For Your Perusal...
  175. Transmission: 700R4 Trans
  176. Body: A question about trunk lids
  177. Engine: Mechanical Bozo is back ( got carb farts )
  178. Electrical: We're trying to start the engine
  179. Frame/Springs Front sway bar
  180. Electrical: Wiring Dilemma
  181. Transmission: Powershift Trans ?
  182. Electrical: Need help removing the ignition switch.
  183. Engine: supercharger belt position
  184. Engine: 289 tune up
  185. Body: 53 Grill script install question
  186. Body: C/k fender vent gaskets etc.
  187. Transmission: od trouble
  188. Brakes: Mechanical Bozo III stoping not so good
  189. Brakes: Avanti Master Cylinder Cover?
  190. Engine: R2 in a 53-54 C/K
  191. Other: Trunk Overlay
  192. Engine: 1935 president 8
  193. Steering need help on power cylinder seals for power steering
  194. Body: Start and stop dates of the 16G8F1/16G8F2 for 1955
  195. Front Axle: Noise problem and I'm Stuck
  196. Brakes: Master Cyl.
  197. Speedo/Tach/Gauges LED instrument lights
  198. Electrical: Turn Signal Switch Cancelling Too Far
  199. Body: Inner fender patched now prime and seam sealer or seam and prime???
  200. Brakes: Preferred electric and wire corp. Hill Holder
  201. Electrical: Electronic voltage regulator
  202. Engine: Oil Fill Cap 62 Hawk
  203. Fuel System: Gas Guage does'nt work
  204. Other: ID/Referral
  205. Brakes: Master Cylinder Piston ???
  206. Engine: Honing Complete (Pictures the rebuilder's sent me)
  207. Engine: Helping my buddy restore his dad's Studey Truck
  208. Engine: difference between 26 and 29 big six engine?????
  209. Engine: Roller Hydraulic Camshaft
  210. Brakes: Master Cylinder Cap
  211. Cool/Heat: Identify Studebaker radiator by Modine number?
  212. Cool/Heat: Water Pump Pulley Alignment 63 Avanti
  213. Engine: Block Washing (Pictures the rebuilder's sent me)
  214. Engine: need some help
  215. Engine: Harmonic Balancer, New Oil Pump, & Release Bearing (Pictures the rebuilder's sent me)
  216. Engine: Need Correct Engine Colors
  217. Exhaust Heater valve thermostatic coil
  218. Body: Stuck window 56 Hawk
  219. Brakes: Brake Question
  220. Brakes: problems removing rear drums
  221. Other: S-10 Chassis for Champ pickups
  222. Engine: Need Cam Thrust Plate
  223. Frame/Springs Coil springs heavey duty for 1961 Lark convert.
  224. Speedo/Tach/Gauges Dead speedo
  225. Cool/Heat: 53 C/K radiator: re-core or hunt down a used one?
  226. Wheels yet another tire question... more about wheel covers. i am so confused!!
  227. Speedo/Tach/Gauges Original speedo/tach to chevy engine/trans
  228. Brakes: Hard pedal
  229. Body: 1955 Studebaker Side Molding Kits
  230. Wheels one last wheel question.. I promise!!!!
  231. Engine: Beginning Engine Reassembly (Pictures the rebuilder's sent me)
  232. Body: 60 hawk raditator to hood seal
  233. Brakes: rear brake drums
  234. Electrical: Brake Light Question
  235. Brakes: Is anyone familiar with the Master Power Brakes company
  236. Electrical: 1956 President 289 V8
  237. Transmission: 3-speed O.D. trans I.D. and problem
  238. Electrical: Front Park Lights and Turn Signals on 1950 Champion
  239. Body: Rocker trim 62 hawk
  240. Engine: Timing lesson-Who'd of thought?
  241. Wheels Horrible vibration, (Cross post from the Studebaker Truck Farmers.)
  242. Engine: SI valves
  243. Body: Studebaker curse of the front fender trailing edge.....
  244. Brakes: Disc Brake conversion
  245. Electrical: Bob Johnston
  246. Rear Axle: dana 44
  247. Engine: Head Bolt Question
  248. Paint: '64 GT wheel covers
  249. Engine: Mystery at higher RPMs
  250. Brakes: Swing pedals in GT Hawk
