View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Cool/Heat: Radiator fan blade
  2. Steering Steering wheel tilted
  3. Brakes: 1952 Champ Light Bulb Parts Confusion and Looking for Rear Shoes
  4. Body: Were all Studebakers autographed?
  5. Cool/Heat: Radiator Hose 57 Golden Hawk
  6. Engine: Windage tray
  7. Wheels More questions about rims
  8. Brakes: Hydrovac
  9. Transmission: FLuids
  10. Brakes: 59-60 Lark Brake shoes
  11. Electrical: 1960 Lark, 6 cylinder no start
  12. Engine: Electronic ignition plug and gap - 289 GT Hawk
  13. Cool/Heat: Which water pump is correct for R2 Lark?
  14. Fuel System: Avanti Starting/Running Problem
  15. Other: Speedometer Cable.
  16. Engine: Thanks to Gary Ash
  17. Steering Ford E150, etc. power steering for a Stude?
  18. Cool/Heat: 57 Commander Heater
  19. Wheels 4 lug wheel
  20. Body: 63 Avanti Door issue?
  21. Engine: Never before.
  22. Body: 1950 Champion Hood Release
  23. Cool/Heat: A/c sealer
  24. Brakes: Silicone brake fluid color
  25. Interior: Simple Question
  26. Steering The key to a modern PS swap on a Stude car is a reverse rotation gearbox
  27. Body: Removal of exterior windshield stainless from a '62 GT Hawk
  28. Engine: Lark Engine Change
  29. Speedo/Tach/Gauges Water temp gauge
  30. Cool/Heat: Is this possible??
  31. Fuel System: 1955 Studebaker President Coupe
  32. Electrical: Tach Sending Units W/ Pertronix Ignitor & Coil
  33. Electrical: Fried: Lark VI
  34. Electrical: How does one check a voltage regulator ??
  35. Brakes: Brake booster
  36. Engine: Avanti Engine, identification
  37. Transmission: T10 to a '63 corvette bell housing
  38. Engine: Value of a 1960 Lark V8 engine?
  39. Engine: What's the best motor oil for R series engines?
  40. Engine: Water baffle reproduction for 1929-37 straight 8 - want one?
  41. Brakes: Brake fluid recommendation?
  42. Engine: Rough running need help
  43. Electrical: 6v to 12v conversion 1950 champion
  44. Engine: 289 heads on 232 engine?
  45. Fuel System: Avanti gas tank connections
  46. Electrical: Where is external resistor??
  47. Transmission: Parking pawl in flightomatic
  48. Engine: 2 bbl carb and/or distributor fix???
  49. Steering Bench Test
  50. Engine: Oil filter optional?
  51. Body: '60 Lark VI four-door: Are there stock-looking side view mirrors that upgrade the originals?
  52. Body: Missing hood springs
  53. Steering 1950 2R10 Worn Kingpins and Worn Spindle under Outer Bearing Inner Race
  54. Engine: Red Line
  55. Drive Shaft Non Stude drive shaft/U-joints
  56. Brakes: Anchor Point adjustment
  57. Engine: 1951 Champion Engine Color
  58. Wheels where to get tire stem
  59. Other: Lark VIII Wagon Tailgate issue
  60. Brakes: Back to Square ONE
  61. Cool/Heat: Coolant Troubles with my 61 Lark
  62. Engine: Champion lifter information needed
  63. Frame/Springs Coil Springs
  64. Rear Axle: brand X rear axle
  65. Frame/Springs Lark frame flexing issues?
  66. Other: Ignition switch
  67. Frame/Springs Lark Front Spring Question. Is it Worn out?
  68. Other: Looking for Hydrualic lines and piece for connection to convertible top cylinder
  69. Engine: Need Vacuum advance
  70. Other: 1964 AM Radio Fade switch under dash question
  71. Engine: 289 Swap
  72. Wheels Question about 205/75/r15 tires
  73. Electrical: Update on Fried Lark
  74. Cool/Heat: 62 Hawk Radiator - who has them?
  75. Clutch/Torque Converter: Clutch not releasing
  76. Cool/Heat: Radiators and gas tanks for Larks..........are they available repop?
  77. Engine: low commpression on one cylinder
  78. Clutch/Torque Converter: Clutch release bearing
  79. Brakes: Brake upgrade
  80. Engine: Breather caps
  81. Engine: 62 Lark, two questions if you please
  82. Engine: DoubleCheck spark plugs
  83. Rear Axle: Loose spring bolts
  84. Cool/Heat: Temp Sender-56 Prez
  85. Wheels disc brake wheels
  86. Engine: Stupid Question time on 232 Paint
  87. Electrical: What OHMs is for ballast resistor?
  88. Engine: Help!!
  89. Body: sealer for the front header
  90. Clutch/Torque Converter: Clutch Cables?
  91. Brakes: M/C cap gasket
  92. Steering Converting manual box to power steering- UPDATE 7/21
  93. Body: Busted door skin weld - how to fix?
  94. Body: 55Commander Hardtop door trim
  95. Fuel System: 500CFM or 600CFM on 289 V8
  96. Steering Leather boots
  97. Transmission: Distance to bellhousing
  98. Brakes: brake conversion on a 60 lark
  99. Interior: Tips for putting rear window in
  100. Transmission: loud gears
  101. Frame/Springs rear spring bushings
  102. Clutch/Torque Converter: DG-200 Torque Converter - Sealed Unit, Source?
  103. Steering Power Steering hydraulic Arm
  104. Steering Steering Rebuild Recommendation
  105. Frame/Springs 48 Champ rear spring bushings
  106. Fuel System: Starving for gas on grades (1963 Lark 259)
  107. Engine: Proper hook up of remote starter switch
  108. Engine: Water leak
  109. Front Axle: Replacement Grease seals for Control Arms
  110. Transmission: 1963 hawk
  111. Paint: Interior Color
  112. Cool/Heat: '56 Commander radiator: _seriously_ dumb question
  113. Clutch/Torque Converter: Ring gear wear and old wives tales
  114. Electrical: Truck Battery Cables
  115. Transmission: Transmission main shaft ID
  116. Brakes: hillholder rebuild
  117. Body: Door Lock
  118. Electrical: tach not working
  119. Engine: dont know why the car runs hot or wont start in hot weather very good
  120. Frame/Springs Which coil spring?
  121. Drive Shaft How are they measured?
  122. Interior: Need buckets seats for a '62 GT Hawk
  123. Body: Avanti Headlight Seals
  124. Brakes: Idle changes when using the power brakes
  125. Brakes: Need a bleeder system
  126. Engine: '81 Avanti & plug wires
  127. Shocks lever action shocks
  128. Steering Chevy Astro reverse PS gearbox swap ideas.
  129. Cool/Heat: Running Hot or Too Hot to Run
  130. Wheels beauty/trim rings for a....
  131. Electrical: Did something get fried?
  132. Body: Hood interchange
  133. Electrical: Radio static
  134. Engine: In need of a Starter SOLENOID 50 commander
  135. Electrical: 6v alternator bracket for 51 Champion 6 HELP needed
  136. Fuel System: Fuel Tank Options
  137. Transmission: Tranny swap for M16
  138. Transmission: Truck Shift Linkage Binding
  139. Brakes: Looking for Opinions on my Plan for my Lark Brake Upgrade.
  140. Clutch/Torque Converter: 63 Wagonaire clutch application question, 259 3 spd O/D
  141. Brakes: Can electricity engage the brakes?
  142. Interior: bench seat covers
  143. Transmission: 1952 Champion what gear ratio, rear end and transmission do I have? also, what fluids should I use.
  144. Electrical: Braided flat ground strap?
  145. Front Axle: Why do you need to spread the A-arms??
  146. Transmission: More tranny questions
  147. Other: 1956 President 2 Dr. 56H rear window glass
  148. Rear Axle: 54 CK rear end swap
  149. Electrical: '51 Champion horn honks!
  150. Engine: Head Numbers
  151. Wheels 64 GT wheel color
  152. Cool/Heat: Avanti radiator and fan question
  153. Electrical: Avanti Radio Suppressor Question
  154. Transmission: Transmission swap for M16
  155. Engine: R1 heads on an R2 block
  156. Brakes: How do you remove this drum?
  157. Other: install wipers on 1946 m truck
  158. Transmission: How to replace transmission mount on a 1953 2R5
  159. Electrical: automatic starter interchange
  160. Brakes: master cylinder swap?
  161. Cool/Heat: 2R-6 radiator
  162. Frame/Springs replacement springs moog cc655
  163. Engine: engine color for 1960
  164. Cool/Heat: Radiator REPLACEMENT FOR A 51 STARLITE COUPE W/350 CHEV
  165. Body: Truck Quarter Panel Attachment
  166. Interior: Seat springs shifted
  167. Electrical: electric windows
  168. Interior: GT Hawk seat dimensions
  169. Other: V/8 distributor drive gear pin question?
  170. Other: New to me!
  171. Electrical: parking and turn signal light socket
  172. Wheels F/S: Quart of Studebaker and Avanti Wheel Paint
  173. Engine: mounting v8 to engine stand
  174. Other: 56 President vin & rear window
  175. Other: wiper blades
  176. Engine: S. W. Sparrow - the early days
  177. Body: 62 Lark wagon tail lamp lens
  178. Steering quicken the steering on a lark?
  179. Electrical: 12 or 6 volt lark?
  180. Body: 53 hood
  181. Fuel System: Mechanical Fuel pump - am I missing something?
  182. Body: Window Repair
  183. Body: Need advice on Mysterious Floor Blobs
  184. Other: Lark Starter
  185. Cool/Heat: Thermal Clutch Fan
  186. Other: Outer Control Arm Bushings
  187. Transmission: transmisson leak in 53 c coupe with a 700r4 trans
  188. Interior: 63 Avanti Interior
  189. Wheels Getting a 1946 Champion Home
  190. Brakes: Dumb Question (maybe?)
  191. Transmission: T-5 Conversion
  192. Transmission: hydrovac question
  193. Brakes: Please help
  194. Transmission: crashbox?
  195. Other: what size tires are best
  196. Engine: Need advice for broken stud in head - 1960 Lark V8
  197. Clutch/Torque Converter: Clutch problems
  198. Cool/Heat: Right turn noise
  199. Interior: headliner attatching rail
  200. Paint: 56' Power Hawk Engine Compartment
  201. Steering Saginaw Power Steering Unit Adjustments
  202. Exhaust Stainless -Steel Exhaust
  203. Engine: 1951 Commander Cranks, but won't start
  204. Body: Rust
  205. Brakes: first trip to work in commander
  206. Paint: Two paint questions: '37 Dictator and '37 Coupe-Express
  207. Body: windshield gasket
  208. Transmission: '51 Champion clutch
  209. Fuel System: first trip to work in commander
  210. Transmission: speedometer
  211. Engine: Tranny/Motor interchange's.
  212. Transmission: Overdrive transmission
  213. Cool/Heat: Overheating or not?
  214. Transmission: T86 Transmission Swap
  215. Front Axle: Transplanting Avanti II suspension to '53 Commander K
  216. Body: Replacing body mounts
  217. Transmission: Tranny Gasket
  218. Body: Authenticity
  219. Cool/Heat: A/C
  220. Engine: Colors?
  221. Other: What IS this part?
  222. Body: arm rest
  223. Transmission: Puddle under the Lark...seals bad or???
  224. Engine: rear of 6 cyl oil leak
  225. Engine: Water manifold baffles for 1929-37 small straight 8 now available
  226. Body: hit and run victim-seeking replacement parts
  227. Steering Interchangeable king pins?
  228. Engine: I was working on my '53 (not Frick) Studelac today.
  229. Fuel System: Oil bath air cleaner
  230. Transmission: Need to locate an overdrive governor for my 1955 studebaker commander.
  231. Transmission: 4 Speed Transmission
  232. Frame/Springs Frame Issue
  233. Wheels Putting Radial Tires on a '50 Commander?
  234. Fuel System: How should my throttle springs hook up ?
  235. Fuel System: Hard starting in hot weather
  236. Electrical: Coil 1948 Studebaker Commander
  237. Engine: Cross post: Champion Engine Re-manufacture
  238. Steering Replacing steering gearbox and shaft
  239. Engine: Need a V-8 Cylinder Head.
  240. Cool/Heat: Cooling system capability ?
  241. Cool/Heat: heater control valve repair
  242. Steering Cross Post: Ross Steering Box Bushings
  243. Cool/Heat: Engine temp/timing advance
  244. Engine: Why I like bench testing. My two cents.
  245. Fuel System: Fuel problems, engine operating temperature
  246. Transmission: overdrive questions 1960 6 cylinder (red) Lark
  247. Wheels Tires??
  248. Other: Which Champion do I have ?
  249. Brakes: Brake self adjusters
  250. Engine: 58 Hawk 6 to 8 cylinder swap
