View Full Version : Tech Talk
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. 1961 hawk emergency cable +backup switch
  2. Suspicious Dip Stick
  3. V-8 Piston Identification
  4. Engine - How far to go?
  5. stainless and clips
  6. '41 Commander Drum to Discs??
  7. Speedster hubcaps
  8. power steering gear box
  9. Parts needed
  10. another tire ?
  11. Radio knob/buttons repair??
  12. 195 75R15 Tires
  13. C/K Front Sway Bar Upgrade
  14. Spark Plug Wires
  15. Air shocks on a 65 Cruiser
  16. plug wires
  17. tail light assembly swapping
  18. engine swap
  19. headlights
  20. jet recommendations? (AFB)
  21. Glove box light switch
  22. 259 cu. tune up questions...
  23. Removing a broken tapered axle
  24. rearend width
  25. Good news, bad news, need suggestions
  26. Fiberglass Fenders
  27. commander hood problem
  28. M5 pickup
  29. Avanti Bumper Bracket Color & Glass Source
  30. 62 hawk air conditioner panel
  31. Alternator/Regulator
  32. One Wire Alternator Conversion Schematic
  33. help
  34. 1950 2R10
  35. Champ Front End
  36. knob
  37. Polarzation
  38. First gear start valve body For Sale
  39. Power Steeing for Champ PU
  40. Setting the valves on a 1949 Studebaker truck
  41. Speedster Wiring Question
  42. Reputable Carb Rebuilders?
  43. Why go breakerless?
  44. 4 barrel swap problems
  45. 61 Light Switch Wiring
  46. Engine wanted
  47. Torque Converter Question
  48. restoration help
  49. Press Kit
  50. '64 GT Hawks in Avanti Maroon
  51. 55 Electricals
  52. engine
  53. Tech Talk
  54. 259 i.d. number help needed
  55. Installing SBC Engine
  56. Studebaker 259 V8
  57. 1952 2R-6 transmission question
  58. Revive old rubber?
  59. 1956 Transtar Colors
  60. LESSON LEARNED
  61. selling
  62. 1961 HAWK SUNVISORS
  63. 1955 president speedster
  64. electric wiper motor conversion
  65. mylar inserts
  66. 1938 GRILL REPAIR
  67. Salt to Salt
  68. picked up
  69. hmm
  70. Is Roof the Same on '53 Commander & Champion 2dht
  71. 57, 58 Hawk Wieand intake manifold?
  72. Stock wheel bolt pattern for 37 Dictator??
  73. Single piston
  74. 51 V8 Oil Pan
  75. Power Brake Remote Booster for Stude
  76. 6 & 8 cyl 12 volt starters
  77. Export Hawk
  78. Dipstick in 1960 Hawk
  79. Tires size for my 50 champ
  80. Oil galley plug left out of new engine
  81. Gear oil for my transmission
  82. minor misfiring
  83. Hydovac cores needed
  84. R3/R4 Crankshafts
  85. 259 numbers
  86. Ground Cable
  87. 12 Volt Overdrive Components
  88. Stroked 232?
  89. Six Volt Electronic Ignition
  90. phenolic
  91. steering wheel removal
  92. Avanti II Frame Rail Availability
  93. Parking Pawl, Speedster
  94. Another stupid question
  95. Replacing headlight bucket
  96. I broke my speedometer
  97. Door panel trim needed
  98. Studebaker V8's
  99. Dana 44 axle interchange
  100. Oil leakimg Hawk
  101. Mechanical Stoplight Switch
  102. Power Brakes
  103. studebaker tranny to sbc
  104. Mike Aldana Chrome Plating?
  105. Dana/Spicer 41 Axle Question
  106. 8 &6 cyl.auto transmissions
  107. 289 engine color
  108. Hawk with Novi or Procharger Blower
  109. Champ overdrive
  110. Will a 50's car inside mirror fit a C-Cab?
  111. Edmonds Tripower
  112. 53 K tail light help please.
  113. ????
  114. More 6 Volt Battery and Charging Questions
  115. T-86(?) shift pattern question
  116. Window replacement
  117. timing cover bolts
  118. Alternators
  119. lower control arm
  120. Voltage regulator
  121. valve adj
  122. Lark Bench Seat
  123. Welded-on rear fenders-'53 C/K
  124. SCRATCHES ON 58 HAWK DASH
  125. starter is acting weird
  126. Broken rear drum
  127. testing Hydrovac unit
  128. Flightomatic transmission pan
  129. Production Order Decoding - `64 Hawk
  130. Paint & prep suggestions for door/window molding?
  131. window regulator
  132. 1963 Canadian GT Hubcap Colours
  133. Speedster Gauges
  134. Speedster Hubcaps
  135. M5 Dash Gauges
  136. 65 Daytona conversion
  137. taillight interchange
  138. DEFROSTER FAN ASSEMBLY REMOVAL
  139. my rear end
  140. 2R10-22-C2 W/ build date of 1949
  141. How do I determine if a 289 is full flow or not?
  142. Avanti header question
  143. Overcharging GT
  144. Clutch Froze
  145. I need a part number..
  146. Hawk Power Steering addition
  147. E mail problems
  148. Parts for sale
  149. spark plugs
  150. Rear Door Window Removal
  151. Studebakers for Towing?
  152. AC change to R-134
  153. '55 President 6V windshield wiper motor
  154. 51 Champion Speedometer problems
  155. Hawk dash removal
  156. Engine mount for hawk
  157. 1949 VIN / modern engine and frame for 1949 body
  158. 1957 hawk brake lights
  159. power steering
  160. heated seats
  161. where can I find parts - '61 Hawk?
  162. 2bbl Stromberg XX Question
  163. Dual heater setup
  164. Kingpins
  165. 56 vin plate metal
  166. Carb adj/ deep throat sound
  167. Engine Color?
  168. '55 President Oil Pump
  169. Lark Sheetmetal Thickness
  170. 1948 M5 Speedometer hookup
  171. Kent-Moore tool identification
  172. engine color
  173. '55 President Heater Motor vs. Defroster Motor
  174. 1961 Hawk emergeecy brake & exh routing info
  175. Speedometer cable question
  176. 51 Champion Steering Wheel
  177. oil release valve
  178. oil filter
  179. got gas!
  180. Avanti issues w/new owner...HELP!
  181. Ford Bendix Power Assist
  182. Avanti R2 De-Carbonizing Tips
  183. How difficult is replacing a headliner?
  184. GT Hawk hood props
  185. Seat Installation - 57 Hawk
  186. Supercharging
  187. '61 Hawk & '62 GT Hawk, same trunk lid?
  188. Help! - 1954 Studebaker Commander Coupe
  189. How to replace V8 valve guides?
  190. Engine conversion
  191. noob question on 289 & a hello
  192. Front End Overhaul '63 GT Hawk
  193. studebaker jacks
  194. Stude tech 94-04 'Stang disc brake adapters return
  195. 1951 CHAMP-1960 LARK
  196. Starter Problem, 50 Champ
  197. Converting a 6v syst. to a 12v?
  198. Frankinstude revisited
  199. Oil burning '63 Lark 6
  200. WOW check it out !
  201. Studebakers Maine
  202. 16" wheels?
  203. Frame question
  204. Intake valve Oil deposit
  205. Chevy 194 pistons in a 259?
  206. 50-52 automatic column shift , 50 body parts
  207. Flathead six - oil getting into my coolant
  208. Spline count on tapered axles
  209. please help with my brakes
  210. Dana 27 Axle Vs 44 Axle
  211. Emergency brake cable question
  212. Lark Seat Swap
  213. Oil Fill Location on 259
  214. Exterior Paint Color Question
  215. Dana 44 posi unit..C clips?
  216. Hawk Gt
  217. Stude 224 V-8
  218. R2 carb change
  219. Tachometer Installation
  220. hitch in my get-along,,,
  221. Rear End Ratio Suggestions....
  222. Original looking repaint
  223. pertronix ignitor #1584
  224. 1934 Dictator horn button
  225. Auto trans band adjustment
  226. Carpet,seat covers etc?
  227. 64 Daytona hub cap
  228. Do I need to replace 1955 fuel sending unit?
  229. Help Needed - 4bbl intake ID
  230. V-8 Rotation?
  231. 1955 PRESIDENT 259 ENGINE - HELP!
  232. Air-conditioning a 1963 R-2 Avanti
  233. 55-57 pick up/350 chevy motor
  234. engine color
  235. Dumb Question about Engine Number
  236. brake shoe lining - where to purchase?
  237. CORRECT PAINT COLORS 61 HAWK ..PLEASE HELP
  238. Saginaw P/S rebuild?
  239. Headliner advice
  240. Hesitation getting into gear
  241. Carter WE metering rod spring
  242. Blowing Oil. Cause?
  243. Avanti front turn signal irregularity
  244. Help with Stalling
  245. Golden Hawk Carb question
  246. cylinder head numbers
  247. 50 Champion wont start
  248. wheel/tire question
  249. Body tag # ID
  250. pcv on 1960 Lark v-8
