View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Body: Hood Latch
  2. Other: Avanti Horn Switch in steering column
  3. Engine: White smoke???
  4. Electrical: Ignition electrical question
  5. Body: Chrome Plating Recommendation
  6. Fuel System: Gas Cap
  7. Engine: Another oil question
  8. Body: Avanti 63R1406 R2 Update - Door hinge question
  9. Fuel System: Fuel pump mystery
  10. Transmission: 64 cruiser AT shift lever problem
  11. Interior: Substitute?
  12. Engine: Fuel Injected Avanti Part Deux
  13. Other: Convertible Top on a 1963
  14. Wheels Wider wheels that will allow "baby" stude caps
  15. Fuel System: Stranger then strange Fuel Problem
  16. Brakes: Residual valve problem?
  17. Cool/Heat: 64V 289 Radiator hose choices?
  18. Body: What gauge was the steel for the bodies in 1951?
  19. Brakes: New but soft and spongy brakes
  20. Body: polishing stainlees on the car
  21. Body: Chorme Polish
  22. Frame/Springs Possible donor chassis for Transtar project? ('51 Ford F-150)
  23. Interior: Avanti Seats
  24. Body: Adjusting the trunk lid on a '48 Starlight coupe
  25. Electrical: tachometer stops and holds at 2100
  26. Fuel System: electric fuel pump
  27. Brakes: Master Cylinder on ebay.
  28. Steering Installation of rack and pinion and headers for stainless Avanti frame.
  29. Engine: Edmunds Aluminum Head and Dual Carb manifold value?
  30. Body: '65 hood torsion rods
  31. Electrical: Amber Rear Turn Signal Mod '64 Lark Type
  32. Fuel System: R2AFB rod measurement for 1560338 Carter 16-263
  33. Steering Steering Wheel puller
  34. Electrical: Rear seat speaker cable 54 Land Cruiser
  35. Fuel System: Is the problem vapor lock or fuel pressure??
  36. Fuel System: R-4 Engine
  37. Electrical: Avanti (2) Distributor
  38. Cool/Heat: how much room in front of engine in 50 commander?
  39. Transmission: 1950 automatic remote cooler for transmission
  40. Electrical: Autolite spring clips?
  41. Body: Hinge Help
  42. Engine: Replacing timing cover seal
  43. Body: 70's repro Strato-Vue AC3310 mirror: Swivel is loose: How to fix?
  44. Frame/Springs torque spec for crossmember?
  45. Engine: Need some rubber mounts for my engine.
  46. Electrical: License plate lamp wire
  47. Fuel System: Choke Heater Tube
  48. Body: Trunk floor pan
  49. Body: Trunk floor pan
  50. Wheels Bolt on, replacement wheels for Hawk
  51. Wheels Original tire size & white wall size
  52. Transmission: Anyone done a 200-4R swap behind their Stude V-8?
  53. Engine: Head bolt torque sttings...'49 Commander
  54. Speedo/Tach/Gauges clock for my 62 Lark 8
  55. Engine: Converting the road draft tube to pcv
  56. Interior: 63 R2 Interior
  57. Electrical: Negative amp gauge reading after engine shut off
  58. Brakes: Adjusting the Anchor points
  59. Steering Reach Rod
  60. Cool/Heat: Duracool Refrigerant
  61. Clutch/Torque Converter: Clutch Cross Shaft Bushing Needed
  62. Steering Front Toe-in
  63. Transmission: 3 speed with O.D.
  64. Body: ATTN all hot rod and custom builders; I got a few questions on building a convertible...
  65. Electrical: OD kickdown switch wiring help
  66. Engine: Installing a new head gasket
  67. Transmission: popping out second gear
  68. Transmission: T10 front bearing retainer is bad
  69. Engine: Lark 63, maximum speed?
  70. Speedo/Tach/Gauges Temperature gauge.
  71. Electrical: Can't start my 37 Dictator
  72. Engine: Two new ZDDP oils
  73. Frame/Springs long spring
  74. Rear Axle: Oh no - Slipping rear axle? Then working again? How?
  75. Frame/Springs Springs for 1/2 ton pickup
  76. Electrical: Electronic ignition
  77. Electrical: No front right turn lamp - '65 Wagonaire [now solved!]
  78. Paint: Cowl to fender rubber
  79. Transmission: Summit Racing Universal 4 speed shifter
  80. Transmission: FOM bellcrank stop adjustment
  81. Transmission: Recent 700R installation
  82. Paint: 1958 golden hawk trunk paint scheme
  83. Cool/Heat: how to remove stovepipe from Climatizer pan in '57 GH?
  84. Body: 63' Avanti Repaint
  85. Engine: burping oil
  86. Engine: 62 gt timing marks
  87. Brakes: Brake line flaring tools, recommendations?
  88. Brakes: Brake drums!!
  89. Engine: Too much oil going into oil fill pipe.
  90. Fuel System: Surging carb at idle
  91. Frame/Springs S10 or 1978-88 G Body front frame clip to replace the Stude one?
  92. Frame/Springs Where to order front springs
  93. Electrical: Is it the VR, or the alternator
  94. Body: Help! Photo needed of 57-58 Comm/Pres trunk seal
  95. Engine: Questions and more questions- and one answer
  96. Engine: Valve cover gaskets
  97. Fuel System: '53-'55 carb linkages question
  98. Fuel System: Oil Pump lines
  99. Front Axle: Outer Control Arm Bushings
  100. Brakes: New 1942 M16 truck owner looking for good references on totally rebuilding brakes
  101. Electrical: Turn signal indicator problem
  102. Engine: Champion performance!
  103. Body: 63 avanti frame off
  104. Brakes: 64 Hawk Master Cylinder for Disk Brakes
  105. Body: Door Check
  106. Front Axle: Excessive camber; is this normal for completely defunct shocks and springs?
  107. Body: Does new floor pan go UNDER cowl post or what? (see photo)
  108. Body: Mesh for Cowl fresh-air vent- how to remove?
  109. Engine: Fires but won't start.
  110. Engine: 1957 engine color
  111. Other: A rant if I may.....
  112. Brakes: 10" jeep rear drums
  113. Fuel System: Will an M2211S rebuild kit work in my M970 fuel pump?
  114. Engine: Aceeptable Tolerances for Bell Housing Dial in?
  115. Cool/Heat: Aluminum radiator for 61 Lark
  116. Paint: Patina Preservation (crazy talk here)
  117. Other: Thanks!
  118. Cool/Heat: Fan shroud. Parts missing? 55K 259
  119. Electrical: My ammeter jumps all over 1951 Champion
  120. Transmission: 5 speed overdrive ident.
  121. Electrical: Battery switch wanted
  122. Speedo/Tach/Gauges Temperature gauge needed
  123. Rear Axle: How to identify Twin Trac axle
  124. Engine: Finding TDC - doing a rebuild
  125. Electrical: All Studes with ALE-5003 Alternators
  126. Engine: PCV location//1966 283?
  127. Brakes: Brake shoes 1941
  128. Electrical: electric fuel pump
  129. Engine: morgan 6 cylinder speed equipment
  130. Electrical: terrific battery for late model Studes
  131. Frame/Springs 53-55 Spring Arch
  132. Engine: Need help with stalling problem
  133. Engine: R1 to R3
  134. Speedo/Tach/Gauges Speedo cable issues
  135. Engine: Got the new 66 Cruiser running!
  136. Engine: Missing a Piece -Road Draft Tube
  137. Fuel System: Paxton SN60 High Output Impeller
  138. Engine: R1 head with piston 1558178
  139. Engine: 64 air cleaner
  140. Body: general weatherstrip advice needed for transtar
  141. Transmission: Shifting poorly 55 Commander
  142. Transmission: Flightomatic adjustment tools?
  143. Front Axle: Still hopping wheel
  144. Interior: 1948 champion
  145. Fuel System: 63 Avanti Gas Tank Vent
  146. Steering slick street stuff rack and pinion installation
  147. Steering Spec for alignment
  148. Drive Shaft Universal joint
  149. Fuel System: Supercharger question 63 Avanti R2
  150. Engine: 232 and 259 Crankshaft interchange ???
  151. Fuel System: Airtex fuel pumps
  152. Frame/Springs Moog CC655 springs in the Febuary 2011 Co Operator question.....
  153. Body: A Little Tint On My '55 Tail lights...
  154. Transmission: 60 overdrive problem
  155. Body: Were the V8 ornaments chromed in 51?
  156. Interior: Installing new window runs in 1950 4-door sedan
  157. Interior: Tool to remove Nut on dash toggle switch
  158. Steering I am going to broach Borgeson on them making integral PS gears for 1951+ Stude cars.
  159. Speedo/Tach/Gauges Red Light Bulbs - R2 Hawk
  160. Rear Axle: Timken Differential Adjustments
  161. Frame/Springs Upper Control Arm Bumper install
  162. Electrical: Ignition Points
  163. Speedo/Tach/Gauges Dash lights
  164. Steering 54 Power Steering
  165. Rear Axle: Bearing Removal
  166. Cool/Heat: Cooling and AC questions
  167. Transmission: balky 2nd gear, T-90
  168. Electrical: 1961 Lark Taillight Lens Installation Help Needed
  169. Electrical: Car shuts off after I drive it a mile or so
  170. Interior: Avanti Rear Seat Needed
  171. Electrical: I Need a Tach Sending Unit...
  172. Interior: 57 Silverhawk interior panels questions?
  173. Fuel System: Jetting an Edelbrock 1403
  174. Transmission: dip stick length for 1966
  175. Speedo/Tach/Gauges 51 Champion - Gas gauge replacement
  176. Exhaust Blocking off Heat Stove
  177. Transmission: Dexron or Type F?
  178. Body: 1962 down Stude Lark vs. 1963-66; was the body integrity better on the older ones?
  179. Clutch/Torque Converter: Harmonic balancer
  180. Fuel System: '51 Commander Question #1
  181. Electrical: Converted 6V generator to 12V
  182. Electrical: source for remanuf. generators
  183. Electrical: 6 or 12 volt coil on 58 golden hawk
  184. Engine: Cylinder Head Compression Ratio
  185. Exhaust Split exhaust header for OHV 6?
  186. Engine: I successfully adjusted my valves today
  187. Engine: New owner, new member
  188. Engine: How do I convert it to a full flow oil filter
  189. Body: Started rust Repair on Elsie
  190. Electrical: 6 volt battery cable upgrade to 2/0 gauge, car starts much better
  191. Cool/Heat: 61 Lark A/C install
  192. Transmission: Gear lube
  193. Steering Power steering
  194. Speedo/Tach/Gauges Lube a Speedometer Cable
  195. Fuel System: Permatex the fuel sending unit to tank?
  196. Engine: Oil Filter piping
  197. Frame/Springs Powder coating the Springs
  198. Brakes: Mastercylinder on a 41 Commander
  199. Exhaust 64 Daytona (Chevy engine) - making room for exhaust upgrade
  200. Interior: Door panels
  201. Cool/Heat: mechanical heat guage for 63 super hawk
  202. Fuel System: 63 lark carb or fuel pump problems
  203. Speedo/Tach/Gauges Correcting Speedometer Reading
  204. Fuel System: WCFB Adjustment Instructions
  205. Electrical: Automatic Windshield washer
  206. Other: need measurement on 64 Daytona convertible
  207. Engine: Oil pump driveshaft
  208. Cool/Heat: Aluminum Radiator conversion
  209. Interior: Dash Wood Graining
  210. Brakes: Master cylinder question
  211. Rear Axle: Rear drum puller. Windshield replace-52 Champ.
  212. Steering 1964 Wagonaire Bellcrank
  213. Other: Bob Johnstone Studebaker Site
  214. Engine: Here we go again!!!
  215. Rear Axle: I know I have done something wrong.......
  216. Engine: Trying to set timing
  217. Electrical: 6v to 12 v
  218. Cool/Heat: 48 Champ heater
  219. Transmission: Flightomatic diagnosis needed
  220. Frame/Springs twisty ride
  221. Fuel System: Fill Tube Removal
  222. Other: 1961 Stude Lark police package?
  223. Other: Convertible Top Switch 1987 Avanti.
  224. Paint: engine bay color
  225. Brakes: Same old hub puller problems
  226. Speedo/Tach/Gauges 1950 champion gauge hook-up
  227. Body: Bumper Bolts
  228. Paint: 59 Lark Paint
  229. Engine: where is the oil going?
  230. Electrical: 51 Champion Brake Light Switch Terminals
  231. Front Axle: Polyurethane or Delrin suspension bushings
  232. Fuel System: carb questions
  233. Clutch/Torque Converter: Clutch Size
  234. Transmission: 1956 studebaker president, automatic transmission, no reverse
  235. Transmission: 1960 lark 3 speed shift problems
  236. Front Axle: Need king pins for '28-'32 Pres./Commander
  237. Paint: cowl to fender seal
  238. Electrical: Avanti Battery
  239. Body: 56-61 Hawk grille
  240. Body: How to remove exterior passenger door handle for 1946 Studebaker?
  241. Fuel System: 1966 194 Carb Question.
  242. Fuel System: Gas mileage problem
  243. Interior: Cleaning seat belts
  244. Body: 59-60 Lark Hood hinge question
  245. Brakes: Conversation to disc brakes
  246. Cool/Heat: Water pump Q on OHV 6
  247. Engine: R1 and road draft/vs PVC
  248. Rear Axle: Do I have the correct axle ?
  249. Steering Modern power steering (again) on a Stude.........
  250. Cool/Heat: Radiator fan blade
