View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124
  1. Engine: C Cab with 63 lark engine and trans Help please
  2. Electrical: '64-66 Daytona - pink ignition wire resistance
  3. Engine: 1964 259 engine problems.
  4. Speedo/Tach/Gauges Need Photo of 36-39 Coupe Express Speedometer/Dash
  5. Interior: Good source for vinyl & other interior stuff?
  6. Body: 63' Avanti Glass
  7. Fuel System: Fuel Sending Unit
  8. Electrical: Tach sending unit repair
  9. Engine: Engine is Out - What to Replace? [59 Hawk V8]
  10. Transmission: Overdrive problem
  11. Fuel System: 52 Champion Carter
  12. Body: Modifing (Lark) sedan doors to hardtop doors??
  13. Engine: "Pulley & Steering Clearance Issue"
  14. Electrical: Dash ground wire
  15. Engine: valve spring shims
  16. Fuel System: Accelerator Pedal Rod needed - 57 Hawk Auto.
  17. Cool/Heat: What lower radiator hose?
  18. Electrical: 1939 commander horn????
  19. Electrical: 1939 commander horn????
  20. Engine: 55 pickup ignition issue
  21. Engine: Spark plug wires- '51 Champion
  22. Electrical: Six-volt Fuel Pump Question
  23. Body: Hawk Sub Floor Torque Box
  24. Other: 64 Wagonaire side mouldings
  25. Interior: Headliner for Wagonaire- PICTURE REQUEST
  26. Body: Rear window rubber for Wagonaire?
  27. Clutch/Torque Converter: Flywheel size?
  28. Engine: Coolant leak
  29. Steering Spring Repairs
  30. Other: Help with Vin Decoding Can't Identify this car
  31. Steering Wrong King pins?
  32. Rear Axle: and brakes / identification
  33. Engine: Starter, Stick vs. Auto
  34. Electrical: 63 Hawk starter
  35. Other: Turning Wheels article -Avanti 2 or 84 & 85's
  36. Speedo/Tach/Gauges Dash and guages of a 52
  37. Other: Hawk Gas Lid/Door Springs
  38. Other: Rey-keying locks?
  39. Wheels 1956 1-ton duals
  40. Body: '55 C-K cowl seals
  41. Fuel System: A better fuel pump
  42. Electrical: Ignition electrical question
  43. Wheels need replacement wheels
  44. Other: starter issue.
  45. Brakes: Question on new brakes on 48 Champion
  46. Interior: Help needed with the AC-2302 rear seat speaker grill
  47. Clutch/Torque Converter: Brake Fluid vs Hydraulic Fluid
  48. Electrical: 8-Volt Battery?
  49. Engine: What is this part?
  50. Electrical: Distributor Gasket
  51. Electrical: Bad gas gauge
  52. Other: '59 Lark VI engine compartment
  53. Engine: Oil Filter - 170CI 6cyl in line 6 1950 Champion
  54. Brakes: Unbelivable problem
  55. Engine: supercharger
  56. Body: Door Bottom Repair
  57. Other: Replacement Antenna Mast for Avanti
  58. Speedo/Tach/Gauges Temperature gauge and sending unit 1957 silver hawk
  59. Cool/Heat: Radiator under driver seat
  60. Frame/Springs vin# location?
  61. Electrical: No High Speed Heater Blower and Wipers
  62. Other: parts washer solvent
  63. Electrical: Ignition switch troubles...
  64. Engine: Kickdown hookup trouble, 1966 with 4 barrel
  65. Electrical: Headlamp Bulbs 6012 versus 6014
  66. Body: Glass installation problem
  67. Electrical: horn installation
  68. Other: stude and Packard parts ID
  69. Electrical: 50 Champion horn.
  70. Engine: AFB intake maifold.
  71. Engine: Motor Reninstallation - Need PICS
  72. Brakes: Brake hoses
  73. Electrical: I need a part number for the 1950's 2r11 truck tail lights bracket and lights.
  74. Other: Books
  75. Electrical: 6V Battery Kaput, where to buy?
  76. Body: J.I.S. screwdrivers
  77. Rear Axle: ISO 2 speed rear axle
  78. Cool/Heat: 53 - 54 Climatizer and Defroster hose Clamps and Clips
  79. Electrical: Battery Specs; From Historical post
  80. Brakes: '64 Cruiser brake rehab
  81. Frame/Springs Tilting truck
  82. Engine: Lark cylinder Heads
  83. Cool/Heat: Coolant hose lube?
  84. Transmission: Transmission Install
  85. Engine: Parts book for 1955 commander 259 v-8
  86. Body: Windlace question
  87. Body: Installing vent window seals.
  88. Transmission: Overdrive
  89. Transmission: transmission/ignition safety feature
  90. Speedo/Tach/Gauges 61 Lark Auxiliary Gauges Installation
  91. Interior: Lark 63 , which color for the car seats?
  92. Electrical: Need help with speaker wiring for a studebaker/philco radio-AC2302 / S5528
  93. Shocks need B6 HD Bilsteins
  94. Cool/Heat: Coolant Capacity 289 Hawk?
  95. Electrical: Cigar Lighter Replacement
  96. Steering Steering Wheel help needed
  97. Engine: '51 Champion Oil Filter
  98. Interior: Seat belts
  99. Body: C/K Trunk weather stripping
  100. Other: Where's D. Thibeault ??
  101. Engine: 289 casting number identification
  102. Other: diagnose vacuum wiper trouble
  103. Body: Where Does This Part Go? [PIC]
  104. Transmission: Kickdown adjustment
  105. Electrical: starter for a 63 lark ?
  106. Engine: "Bench test" an engine
  107. Engine: My Lark has no pep or get up and go!
  108. Fuel System: New Edelbrock 4 Bbl Carb Flooding Problem
  109. Body: M 16 Running Boards
  110. Engine: 57 Hawk running First time in YEARS!!
  111. Body: Conestoga hood latch question
  112. Other: F/S: STP Key Ring, with Mini-Crescent Wrench
  113. Electrical: Converting a1950 Champion to 12 volts
  114. Interior: Avanti 63R1406 - A couple of questions regarding Carpet/Interior Trim and some update info
  115. Electrical: C-Cab radio antenna
  116. Engine: Need help with point gap and dwell
  117. Engine: oil blow back from oil fill tube?
  118. Body: Hood to cowl fitment
  119. Frame/Springs 57 golden hawks frame substitution
  120. Fuel System: Running out of gas resolved, you won't believe it!
  121. Fuel System: Carb Guru
  122. Steering 62 GT Hawk steering wheel - need PIC
  123. Transmission: 51 Champion DG-200 Automatic - More Questions
  124. Cool/Heat: 57 Golden Hawk Air Conditioning?
  125. Cool/Heat: Radiator Cowl Help?
  126. Fuel System: This is an indication of?
  127. Rear Axle: How to determine rear end ratio?
  128. Fuel System: All-time dumb gas tank damage...
  129. Engine: What carb is used on this Champion manifold?
  130. Cool/Heat: Adding A/C to 1950 Champion w/ 6cylinder
  131. Body: Interesting Observation At car Show....Avanti
  132. Exhaust Never saw this after hibernation
  133. Engine: Frozen/Locked engine (Champion 6)
  134. Engine: 6 cyl. engine dressings
  135. Electrical: No Turn Signals & No Brake Lights
  136. Other: Transporting an Avanti
  137. Engine: 47 m Series Starter
  138. Front Axle: Spacer on Spring
  139. Electrical: Bench test a gas gauge
  140. Interior: rose mist
  141. Brakes: CASO question
  142. Engine: R2/truck cylinder heads - what casting numbers?
  143. Speedo/Tach/Gauges How to Bench Test Temperature Gauge
  144. Brakes: Hooking up hil holder
  145. Body: ebay rocker panels
  146. Body: Unobtainium? C/K body vent window frame
  147. Electrical: Backup lights on '63 Avanti don't work
  148. Transmission: Bell-housing Dowels
  149. Transmission: automatic trans pan
  150. Paint: Eastwood Chassis Paint
  151. Electrical: Turn signals out on left side only??
  152. Transmission: 3 speed o/d oil
  153. Speedo/Tach/Gauges Sending unit 38 Coupe Express
  154. Engine: Oil Pressure Found
  155. Interior: Door hand and window handle spring
  156. Brakes: I guess I am a Scaredy Cat
  157. Engine: 1949 Studebacker truck motor
  158. Electrical: Installed new wires, what part number is the light connector
  159. Body: Need the PN for these body clips
  160. Brakes: 2R-15 brake cylinder interchanges?
  161. Brakes: Turner or Factory?
  162. Other: 1951 Champion manuals on CD -- Where do I get this?
  163. Brakes: Leaky Disc Brakes
  164. Steering Bell crank shims
  165. Engine: Valve Spring Micrometer
  166. Transmission: 63 GT Hawk needs tranny updated
  167. Electrical: Turn signal improvement for 51 Champion
  168. Engine: dampner install tool
  169. Steering read first, I wish i would have
  170. Rear Axle: Help Decipher Axle Markings 51 Champion
  171. Body: 53 - 54 C/K bumpers?
  172. Rear Axle: Rear axle bearing interchange?
  173. Steering Contol Valve
  174. Transmission: Overdrive Governor
  175. Other: Need window motor gears
  176. Steering Avanti ll Steering box Removal
  177. Engine: Supercharging a 259?
  178. Engine: Lubricant for distributor
  179. Brakes: Master cylinder blown?
  180. Other: Are SAE 90 Gearbox and SAE 50 Engine Oil identical?
  181. Brakes: New Master Cylinder decisions for Turner Brake System
  182. Transmission: No Reverse
  183. Body: 1949 Commander bumpers
  184. Brakes: Dual Master Cylinder Conversion
  185. Frame/Springs Sway Bar Adapter Plates
  186. Engine: to rebuild or replace
  187. Engine: Generator Pulley Half Gone!
  188. Fuel System: My mystery of the day
  189. Fuel System: Carburetor seized - suggestions?
  190. Electrical: M-Series Fuel Gauge Fix?
  191. Engine: 289 Engine Mods
  192. Engine: Edelbrock Carb, no kickdown
  193. Electrical: '52 2R-5 harness
  194. Body: 51 Champion: Removing Stainless Windshield Trim & Drip Rail Questions
  195. Body: Champion Hood Same As Commander Hood?
  196. Transmission: 50 champion
  197. Frame/Springs Front Spring - When to replace?
  198. Electrical: Ignition ID
  199. Cool/Heat: Radiator repair vs. swap
  200. Frame/Springs Stabilizer Bars, Sway Bars and Anti-Roll Bars. Studebaker directed but only somewhat Studebaker
  201. Electrical: Automatic transmission safety switch
  202. Fuel System: Flooding going uphill - 6 cyl Lark wagon
  203. Clutch/Torque Converter: '37 Dictator clutch operating shaft
  204. Transmission: Location of shift linkage lube port?
  205. Brakes: Brake fluid dot 3 vs dot 5
  206. Engine: champion 6 cylinder rebuild
  207. Engine: Spark plug gap
  208. Body: Commander Hood Match? Please help!
  209. Fuel System: Gas
  210. Brakes: Converting 1962 Hawk to Power Brakes
  211. Speedo/Tach/Gauges My next problem "Speedometer"
  212. Engine: Engine Rebuilders
  213. Fuel System: Stromberg carb ID
  214. Fuel System: Edelbrock Model 1403
  215. Electrical: Running Stereo HU off Generator
  216. Electrical: 1948 horn sponge push ring
  217. Electrical: Too much dwell
  218. Engine: Need Help!
  219. Body: Remove serial plate without wrecking it?
  220. Body: Where does the Lug Wrench Mount on a Hawk
  221. Cool/Heat: what kind of heater is this?
  222. Wheels New tires PSI question (pic)
  223. Electrical: horn location 51 Champion
  224. Engine: 8.0:1 compression head for 1960 170 flathead 6 part# 1549218
  225. Speedo/Tach/Gauges 66 Dash question.
  226. Engine: Lark VI Oil Filter Installation
  227. Paint: 58 g hawk "parchment white" chip and paint formula doesn't match.
  228. Other: 33-36 parts and a few 1941 overland commander parts
  229. Brakes: Parking Brake Question...
  230. Electrical: Avanti Horn & Tach Wiring
  231. Electrical: 66 Headlight switch vs instrument light, & heater switches?
  232. Engine: Good Machine shop in NC
  233. Fuel System: Need fuel tank
  234. Electrical: Next problem to repair-Ignition switch
  235. Cool/Heat: Parts exhange
  236. Engine: Avant will not start.
  237. Steering Wagonaire Steering
  238. Rear Axle: '49 Champ rear axle
  239. Starting problem
  240. Fuel System: Sorted out a problem with my 63 Daytona
  241. Fuel System: Raising Fuel Boiling Point
  242. Electrical: Brake Light Switch (Universal?)
  243. Electrical: Worn out light socket
  244. Fuel System: Worth saving?
  245. Brakes: Original steel brake lines. Can they be successfully acid dipped and re-used?
  246. Paint: About those little traces of red paint
  247. Brakes: Brake Lines... simple question...
  248. Fuel System: Stromberg runs rich when warm.
  249. Speedo/Tach/Gauges 1954 Fuel Sender Ohms?
  250. Transmission: Trans. oil for overdrive?
