View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Cool/Heat: Radiator Cap
  2. Wheels I need the wheel size adn bolt pattern for a 1959 1/2 ton pickup truck.
  3. Interior: 1931 President Door Handle Removal
  4. Engine: Rear 289 Motor Mount Installation question
  5. Engine: Clevite main bearing number question?
  6. Body: 59 Parts
  7. Ok - hub drum puller!
  8. Body: 53 Grill bar rpoblem
  9. Control Arm Spreader Tool
  10. Cool/Heat: York compressor parts and gaskets, where can you get them
  11. Cool/Heat: Radiator
  12. Drawmatic lighter in '51 champ.
  13. Speedo/Tach/Gauges Tach sender questions
  14. 1963 Avanti will not start.
  15. Transmission: 1960 automatic with bell housing
  16. Brakes: disc brake conversion in 63 lark
  17. Rear Axle: 1950 2R Pickup rear end conversion
  18. Other: Bob Johnstone's parts interchange pages
  19. Front Axle: Question about removing leaf springs
  20. Radio Speaker Fade Switch
  21. Cool/Heat: 56 Commander Defrost Motor ??
  22. Engine: Starter motor removal on 57 Silver Hawk
  23. Body: Vent Window Differences
  24. NOTE: thread prefixes are mandatory!
  25. Engine: Rear engine support replacement
  26. Engine: Avanti pistons
  27. Transmission: How do I select the right trans to have rebuilt?
  28. Little toot by turning my steering wheel
  29. Wheels Lug Nuts
  30. Interior: 31 President window Crank Handles
  31. Other: 64 Cruiser and 62 Hawk GT weight
  32. Electrical: Where to find an overdrive wiring harness for a 1955 commander (Late) No lockout switch.
  33. Engine: Camshaft installation
  34. Where to obtain an alternator bracket
  35. Brakes: Turner Brake conversion
  36. Transmission: Transmission overhaul kit
  37. Electrical: wiring harness needed
  38. Engine: 259 crankcase ventilation question
  39. Body: paint code
  40. Rear Axle: Anyone running a 700R4 GM Trans?
  41. Speedo/Tach/Gauges Champ PU Aux. Gauges
  42. Not an engine swap but a body swap
  43. Thermostat/Water Outlet Housing for '63 289 V8
  44. Body: Champ grill for trade!!
  45. side glass
  46. Interior: 53 rear seat back
  47. Body: hood clearanc R series, 56 to 49
  48. Brakes: brake shoes
  49. Clutch/Torque Converter: Avanti Clutch
  50. Fuel System: Carburator sin !
  51. Fuel System: Studebaker on Ethanol
  52. CONVERTING 59 Silver Hawk Trim to Older Models [PICS]
  53. Smell-o-vision
  54. Steering Power steering for a 51?
  55. Engine: Camsaft Gear 1554426
  56. Body: '53 C/K Hoods
  57. Engine Paint.
  58. Body: ratling and loose window
  59. Transmission: Transmission value query?
  60. Engine: TypeSblood
  61. Cool/Heat: Vintage Air Compressor Bracket?
  62. Engine: V8 Trust Shim Placement
  63. Rear Axle: Bearing sources
  64. Inertia Seatbelts install
  65. Speedo/Tach/Gauges Electronic Speedometer
  66. Fuel System: Carb question?
  67. Interior: Need advice on sill panels and front door sill plate.
  68. Engine: Cam grinding - I had my 259 V8 cam ground by Oregon Cam - I was impressed by service & price
  69. Transmission: Transmission Mount
  70. What are these parts called?
  71. Paint: CASO wants to paint the winter beater.....!
  72. Engine: 1964 Studebaker Commander 259 questions.
  73. Engine: Crankshaft End Play
  74. Electrical: Avanti r2- distributor
  75. Electrical: Signal Stat 900 Pilot Light on a Positive Ground System
  76. Body: Interchangability Of Bumpers?
  77. Rear Axle: Ford differential in a 56 Hawk
  78. Fuel System: R2 AFB Carb temp substitute
  79. Engine: Flat 6 rebuild
  80. Other: How To Open Avanti Trunk
  81. Frame/Springs 53 Coupe driveshaft support cross member
  82. Electrical: Needed: turn signal switch plate
  83. Wheels 64 commander wheels
  84. Rear Axle: Replacing M5 Rear End
  85. Rear Axle: Flanged axles 65-66
  86. Interior: Red Vinyl Interior - 60 Hawk
  87. Engine: Fresh rebuild, low oil pressure
  88. Other: Electronic Distributor
  89. Rear Axle: rear axles options
  90. Engine: Engine runs then dies ??????
  91. Transmission: Need dimensions.
  92. Drive Shaft '53 Commander Coupe - driveshaft is not the Beach Boys "Good Vibrations"
  93. Brakes: Backing plates/brakes
  94. Fuel System: Carter WCFB model differences?
  95. Fuel System: Regular Vs. Oil bath air cleaner
  96. Fuel System: Looking for 4 used sidedraft carbs
  97. Transmission: what trans works?
  98. Clutch/Torque Converter: Bellhousing and other questions
  99. Speedo/Tach/Gauges Speedometer repair
  100. Fuel System: Dissapearing Fuel (II)
  101. Engine: Timing gear cover colour
  102. Engine: 1949 6 Cyl and 3 speed trans for sale
  103. Steering champ pickup tie rods
  104. Electrical: Starter motor
  105. Engine: 55 Speedster Engine ID
  106. Body: Vin # ID
  107. Paint: Paint cracking
  108. Rear Axle: Lark rear ID and length
  109. Engine: How to identify intake/exhaust valves
  110. Engine: Flex plate question?
  111. Engine: Engine crossover woes
  112. Body: Rear Wheelwell Radius For Slicks......
  113. Engine: Exhaust Valve Mishap
  114. Other: Car Show Bellville Tx.
  115. Cool/Heat: All new HD V-8 Super Lark/Hawk water pump ??
  116. Body: Front clip removal on a '60 Lark
  117. Other: Compatibility
  118. Body: Pot-Metal Chrome
  119. Cool/Heat: Heater Control Valve
  120. Brakes: Started disk brake install
  121. Electrical: Swapping alternator with an Honda model
  122. Speedo/Tach/Gauges In trouble again-gas gauge problem
  123. Engine: flat top 289 pistons
  124. Shocks Air Shocks
  125. Clutch/Torque Converter: any tips before i attempt taking apart my clutch?
  126. Body: '60 Lark Fenders
  127. Transmission: Trans swap.
  128. Electrical: Fifth Avenue alternator on a V8?
  129. Transmission: 62 gran turismo 259 v8
  130. Interior: M-Series Arm Rest/handle
  131. Body: Need Driver's Side Window for my 51' Champion Coupe
  132. Brakes: rear hub availability, 53 C/K Champion
  133. Cool/Heat: '47 Commander Radiator Hoses
  134. Transmission: Odd markings on truck tranny...
  135. Engine: engine sling
  136. Transmission: Overdrive again
  137. Transmission: OD on a T-10
  138. Frame/Springs Front Crossmember crack/weld, photos and request for suggestions
  139. Other: wiper arm spring and hood latch spring... where to get/what to get?
  140. Fuel System: fule pump
  141. Engine: Replacing OHV- 6 with a 289 V-8
  142. Brakes: Turner disc and dual master setup. Pedal effort question
  143. Engine: who has sbc conversion mounts?
  144. Cool/Heat: I got my '51 Champion started last night!
  145. Transmission: 3sp floor shifter
  146. Engine: Thermostat Operation
  147. Electrical: Ignition Switch 63 Lark
  148. Steering Adding Power Steering to a 58 Sedan.
  149. Electrical: 1941 Tailights?
  150. Engine: 1949 Commander spark plug info wanted
  151. Electrical: Replacement Spark Plug Wires
  152. Engine: Camshaft Identification
  153. Body: hood latch stuck
  154. Engine: LIL' hitch 2 my Getalong
  155. Wheels Orignial Rims Problem?
  156. Engine: distributor
  157. Engine: Bummer....head or gasket ??? SUCCESS ! !
  158. Other: WTB: Studebaker Batteries Advertising Clock
  159. Engine: April TW-- New style main Brg. Seal
  160. Body: 62 Hawk Trunk
  161. Shocks Looking for a set of Koni Shocks
  162. Engine: It's Beggining!
  163. Body: mounting lower air dam, 53 coupe
  164. Body: 1962 studebaker champ
  165. Steering King Pin Rebuild
  166. Body: Door handle interchange
  167. Speedo/Tach/Gauges Temp gauge not working
  168. Frame/Springs Need a good frame welder reference in Mpls/St.Paul area; any suggestions?
  169. Wheels Mustang Wheels on Avanti
  170. Engine: What engine do I have?
  171. Transmission: Shift Linkage Champ Pickup 3 Speed
  172. Body: How bad is it going to be???
  173. Body: To remove doors or not? ('57 Golden Hawk)
  174. Other: VIN question
  175. Engine: Oil breather caps.
  176. Steering Routing of Bendix power steering hoses on a 64 GT Hawk?
  177. Fuel System: Need a Recommendation
  178. Other: Weights of Avanti components
  179. Transmission: 48 O/D trans
  180. Electrical: One Wire Alternator with Ammeter ?
  181. Steering Looking for an automatic steering column for a 51.
  182. Transmission: T9 Backup Light Switch
  183. Body: How to remove front door moulding/trim stips WITHOUT breaking the clips????!!!
  184. Body: Avanti Vent Window Removal
  185. Transmission: T9 Gear wear?
  186. Body: Gold Script
  187. Body: '60 Lark Door alignments
  188. Engine: R1 R2 R3 ????? What's it all about Alfie?
  189. Engine: Piston Ring Gap
  190. Other: what trim/moulding clips and springs are NOT available and should be carefully saved for reuse?
  191. Wheels Tube that won't hold air...
  192. Body: M5 window channel clips
  193. Engine: Champion - Pulling Oil Pump Gear
  194. Transmission: OverDrive to Gear Box seal?
  195. Steering Front spindle interchange
  196. Cool/Heat: Upgraded my A/C, pics
  197. Body: Angle of Champ Sheet metal over back window
  198. Brakes: Backing Plates
  199. Electrical: Rewire under dash
  200. Transmission: Cooler Lines
  201. Interior: 64 commander window problems
  202. Exhaust Manifold Flange Studs
  203. Cool/Heat: Replacement radiator
  204. Steering Ross steering box seal needed
  205. Steering 65 commander pitman arm
  206. Engine: Freeze Plugs
  207. Cool/Heat: Upper radiator hose neck size
  208. Engine: Hardened valve seats - I have a problem - Jack, Mike help!!
  209. Wheels tire width to wheel width question.
  210. Steering sloppy steering
  211. Transmission: 62 lark overdrive issues!!
  212. Transmission: 4 speed speedometer drive gear
  213. Engine: stuck engine, have i missed something?
  214. Engine: water pump pulley size
  215. Steering 1948 champion steering wheel removal
  216. Transmission: shifting problems
  217. Other: '64 Daytona Windshield Needed
  218. Other: Towing capacity of a 1949 half ton truck
  219. Electrical: Avanti Horn wire
  220. Clutch/Torque Converter: Flywheel/crank bolts.
  221. Engine: 1966 Avanti II firing order and engine number
  222. Transmission: 65' Commander Flexplate Compatibility
  223. Paint: '57 Packard paint question.....
  224. Transmission: tranny oil from speedo cable, 28 Pres
  225. Wheels Tire Selection for M15A-20
  226. Steering Steering Gear for a '53 Commander, 3-speed stick shift on the column
  227. Engine: 289 V-8 vs. a Straight 6- 1962 Champ
  228. Transmission: Flightomatic downshift
  229. Engine: What oil filter
  230. Engine: fill up oil, add gas
  231. Body: HELP! 1955 Studebaker Commander 2 door Sedan- Script location needed.
  232. Engine: Holley HP Avenger EFI Observations
  233. Engine: Need confirmation of engine size
  234. Engine: Polished Aluminum Studebaker script valve covers.
  235. Body: Need help with splash aprons and door corner seal--
  236. Steering Avanti Alignment specs
  237. Brakes: E-Brake Tranny mounted lining replacement (M15A)
  238. Electrical: Wiring Harness
  239. Brakes: 53 C/K self adjusting mechanism
  240. Engine: Exhaust valve clearance on 1964 commander 259
  241. Fuel System: Dry air cleaner support needed.
  242. Electrical: '65-'66 Daytona starter wiring (high torque -missing wire)
  243. Engine: Has anyone had this break befor?
  244. Other: needed door sill plates for 53 c coupe
  245. Other: M5 tire size change - so it can go faster
  246. Rear Axle: Is there a way to tell....
  247. Engine: Oil pressure (again)
  248. Transmission: Flightomatic 123 shift
  249. Body: 55 sedan front fenders
  250. Electrical: no spark
