View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. Did Studebaker use the Hydrovac with dual master cylinders?
  2. Rear axle housing bumper
  3. Interpreting line setting production order
  4. Brake lines for '65 Cruiser
  5. How to lower compression on R1 Avanti (?)
  6. Stromberg Carb installation pictures
  7. Rod & Main Bearings...
  8. General stupid question..oil level
  9. Cleaning my clock
  10. switch to floor shift
  11. F/S: CORRECTION, Lower Price. 1963-64 Avanti and other Stude Wheel Paint (Quart)
  12. factory exhaust tips - facade ?
  13. '51 Trunk lid
  14. M Series Truck Dash Gauges
  15. Quick steering arm
  16. headlight dont work properly
  17. Lark Brake/Clutch Pedal Question
  18. replace 232with 289 ?
  19. toe in adjustment
  20. Front brake anchor block-57 Silver hawk
  21. Advice needed: 63 Champ clutch repair
  22. Supension rebuild
  23. 63 V-8 into 51 Champion 4 door
  24. Valve stem seals - can you tell me the make & model of these upgraded seals
  25. Avanti windshield washer system
  26. The steering column on my '62 Champ has come apart AGAIN!!
  27. ? on an oil filter
  28. steering wheel restoration
  29. Alternator
  30. Clutch/brake pedals
  31. Dash (instrument board) support
  32. nut sleeeve 6/32 bolt size
  33. 53 Steering column assembly picture?
  34. V8 Rocker Arm Geometry
  35. Power steering hissing noise
  36. Gas Gauge Trouble
  37. poverty hubcaps
  38. Reproduction 1958 Scotsman Decals are now available
  39. Fuel Gauge Design
  40. 64 hawk
  41. Help Please! New Pinion Seal looks different than oem and don't know what to reuse. 52 Land Cruser
  42. Removing gas tank anti-theft spring from 1966 Cruiser
  43. Throw-out bearing noise.....squeal ?
  44. Hard to roll up and down -windows
  45. FOM Overfill - how much fluid to drain?
  46. Milky White Window Glass Edges
  47. 48 commander starlight coup
  48. 57 Hawk passenger side vent to blower adapter- need help.
  49. Cam Installation Question
  50. Wiper motor problems
  51. Air Cleaner for Edelbrock 1406 Carb
  52. Power Steering Assist Adjustment
  53. Power steering box
  54. How to: Fuel Filler Hose Replacement
  55. 1966 Cruiser fuel pump and plumbing questions
  56. Still working on brakes
  57. 60 Hawk Air Cleaner Options
  58. Axle U bolts
  59. Avanti Engine ID help
  60. year long rear drum removal HELP
  61. Mechanical Brake Light Switch (Underfloor Pedals)
  62. threads fine or course
  63. Golden Hawk flapper location and engine paint
  64. wagonaire tent
  65. Stude V8 3 Tube Headers - $50 Starting Bid - California
  66. New Shocks for our 82 Avanti II
  67. Cork gaskets. Dressing or not?
  68. Avanti PS pump
  69. Tach connection
  70. 1960 Lark questions....
  71. 31 President Front Seat Back removal
  72. what month and year TW on the 57 Golden Hawks???
  73. Need HELP removing various trim pieces
  74. Champ Pickup Front End
  75. Paint code help
  76. Clutch crossover
  77. '51 hubcaps
  78. I am looking for a radio....
  79. 62 GT Hawk tranny, need cooling?
  80. '59 Lark Brake Drums
  81. Window rubber gasket
  82. 4 speed specific starter?
  83. 1950 Commander engine block clean out.
  84. 6 Quart V8 Oil Pan/Dipstick?
  85. Introduction
  86. looinig for m5 pickup hubcaps
  87. Fuel Sending Unit Access
  88. Brake hoses
  89. Bourke's autograph on ebay..
  90. McKinnon 283 flexplate, will it fit a 700R4?
  91. R2 Carburetor altitude Adjustments
  92. Motor mounts
  93. Shaking
  94. Interior Door Arm Rests 1950 Champion Where to find ?
  95. Tire & Rim Recommendation
  96. master cyclinder fittings
  97. 1950 Champion lower rear - Stainless Steel cover plate
  98. Weatherstrip ID
  99. Power Steering Opinion
  100. M15A-20 Truck Rim Some split, Some Not
  101. StudeRich: can you help on "X-Standard" part numbers?
  102. prop rod clip
  103. Paxton Supercharger experienced rebuilder referral
  104. T-86 floor shift
  105. Shop Manual (Truck)
  106. Another oil pressure problem
  107. AnotherResource
  108. AD Transmission interchange
  109. Hood Adjustment
  110. Gas tank sending unit
  111. T-10 4-spd slip yoke needed for '64 GT Hawk
  112. Intake manifold question
  113. 3 sp. tranny vs. 4sp. tranny... in a 62 Champ.
  114. Any Experts on Cragar Wheels?
  115. Bearing Tool
  116. Bad gas? (Not my wife's cooking)
  117. Engine number
  118. Noisy
  119. 1948 Studebaker Parts
  120. Avanti clutch linkage fixes??
  121. Tremec 5 speed in a GT hawk
  122. engine rebuild- dies out will not stay running
  123. avanti ll info
  124. T9 Backup Light
  125. Avanti Master Cylinder Replacement Number
  126. Valve seals
  127. Disappearing Fuel
  128. Clutch adjustment on '40 Champion
  129. Rebuilding diferential
  130. This Chevy aint got no belly button!
  131. Carburetor Questions
  132. GM OD Transmission to Stude engine-- bolts too short for flexplate/flywheel!
  133. Rearching dimensions - rear springs - 59 Lark wagon
  134. 350chev in to 63 lark
  135. Inferior engineering?
  136. Stromberg Carbureter leaks......
  137. brake issues 1963 Super Hawk
  138. M Series Starter Button
  139. Stromberg WW Carburetor Question
  140. 1403 edelbrock carb quick question
  141. paint code for 49 c cab pickup
  142. Modified 57 Silverhawk brake pedal,master/booster assembly.
  143. Computer cobtrolled Avanti ?
  144. Headers, 64 Daytona with Chevy engine
  145. Spark plugs
  146. Where to buy sheetmetal...if at all?
  147. Wheel Cylinders at Rock Auto, has anyone tried them?
  148. Transmission shift points
  149. Carb icing.
  150. 60 Lark heater hose question
  151. 1951 2 Dr Champion Brake Part Numbers?
  152. 63 Avanti Wire Wheels
  153. Another paint code question
  154. Transmission: Powershift Automatic
  155. Update on 63 R1406
  156. '49 Commander engine assembly questions
  157. Exhaust manifold broken stud help
  158. champion 6 flywheel, 6v or 12 v ? clutch and pressure plate? Transmission?
  159. ISO 63 Avanti headlight lens
  160. Engine: New engine losing coolant
  161. Automatic transmission test
  162. Fuel gauge problem
  163. door/window flippers
  164. 259 crankshaft journal & rod bore diameters needed. Thank you for your help.
  165. York PA Show
  166. Rebuilt P/S pump questions
  167. 55 headlight trim
  168. 1939 comander
  169. Vacuum port on OHV six intake manifold, every use it?
  170. A couple of Questions.
  171. Clutch/brake linkage help!!
  172. Cable for my "60 Lark"
  173. radiator removal from 56 Power Hawk
  174. What kind of oil for my Lark 63
  175. 1561612 fan drive kit
  176. 53 grill bar brackets needed.
  177. M5 gastank top looks like swiss cheese
  178. headlight help
  179. Removing the Radiator Frame on an Avanti - 1963
  180. Avanti hood release cable needed...
  181. Need help with trans ID
  182. authenticity guide?
  183. Which ZDDP?
  184. 6V and 12V Stude's Flywheels and Ring Gears
  185. start up old truck and parts
  186. Roll-up anntenna
  187. From column to floor shifter
  188. Power Window Retrofit Kit - Looks Nice!
  189. Body: Fiberglass Grill Surrounds?
  190. OD Wiring Help: 1963 V8
  191. m-15 brake drum removal
  192. Electrical: 51 Turn Signal Indicator Bulb & Sockets
  193. Rod bolts and PAL nuts
  194. Avanti Steering wheel
  195. Single vs. Dual Action?
  196. Rookie doing an engine swap
  197. Fuseible link location
  198. Oil pan gasket
  199. Tie rod ends
  200. TT lubricant
  201. Stuck Sun Visors
  202. Help to I.D. trans
  203. question on saginaw steering
  204. Vacuum Choke Piston
  205. Body: Body to crossmember joint space. '54 Coupe
  206. Back seat hard to get in( 1953 thru 1955 c,k models)
  207. Brake cylinder plumger removal?
  208. Tail Light Lens Gaskets for '53/'54 Sedans?
  209. Overdrive Control Cable
  210. 1963 Stromberg WW carby questions
  211. Autolite OD relay interchange?
  212. Running rough - will not idle
  213. springs
  214. Spark plug removal
  215. Electrical Problem
  216. Bore size for stock Lark master cylinder
  217. Brakes: 1963 Super Hawk with power brakes that won't stop well at all
  218. Hawk steel wheel assistance needed
  219. Rear sway bars
  220. Engine: New member
  221. Electrical: 1985 Avanti wiring diagram? no back up lights??
  222. floorshift conversion revisited
  223. Back seat hold down issue..
  224. Red Bow Restorations
  225. T9 Replacement Compatibility
  226. 41 Commander wheel cylinders
  227. '51 Champion tire height
  228. Old interor cloth
  229. Engine Parts ID
  230. Convert to 12 volt system
  231. Wheels and Caps . com
  232. 12V V8 Distributor question
  233. M-Series Dome Light Switch Location
  234. Other: welding machine
  235. Spring squeak
  236. Engine: '63 Cruiser -289 crankshaft
  237. 57 Hawk-Leaking heater control valve.
  238. Body: trunk lock
  239. Body: trunk lock
  240. Fuel System: Update on T-Cab's carb woes
  241. Transmission: '53 Commander auto trans problem
  242. Interior: Sound deadening material....
  243. Engine: Oil leak under my Lark
  244. Wiper motor removal on 53 Commander
  245. Engine: weight of a 289
  246. Clutch/Torque Converter: SBC hydraulic throwout bearing ideas?
  247. Interior: Headliner bows and "clips"
  248. Brakes: M15A - rear brake drum puller
  249. M15A - rear brake puller
  250. Clutch/Torque Converter: I'm so frustrated with this throw-out bearing...
