View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. '64 body/trunk leak
  2. Shock interchages for 51 V8 cars?
  3. commander transmission jumps out of first gear
  4. Tunnel and Driveshaft Offsets
  5. Avanti will not start when it is below 40 degrees
  6. What is this thing?
  7. vin number plate
  8. '55 Commander Strombug carburetor accelerator linkage
  9. under seat heater (Hawk)
  10. Horn goes on when making turns
  11. Removing window glass
  12. Help identify leak
  13. RUMOR or NOT
  14. Looking for a pair of door checks
  15. front shocks 63 hawk
  16. Power Steering Conversion 63 Avanti R2
  17. Need some info please
  18. Adjusting the valves
  19. 52 Champion Clunking Noise
  20. What distributor is this?
  21. 1962 Lark Electrical Issues
  22. 1950 Champion radio antenna
  23. NICE HOLIDAY GIFT F/S: Avanti Welcome Sign and Hat Pin
  24. where to find Metzger article about converting Flightomatic to 1st gear start?
  25. Help on 53 coupe Windlace
  26. Whats the word on new clutch and pressure plate for V8
  27. Lubricant for overdrives----Pictures
  28. 1950 Champion Fuses
  29. Does higher octane help with vapor-lock?
  30. 1957 silver hawk --Round hole in trunk floor?
  31. Reproduction parts
  32. More than you ever wanted to know about oil
  33. 54' K body sheet metal
  34. Engine: Jet Thrust Engine
  35. Gas with ethanol
  36. Need a photo of '60 Lark/Champ truck speedo face
  37. Piston troubles
  38. Performer vs AVS Carb's
  39. 1964 dash pads
  40. engines
  41. info on crank needed
  42. 60 Hawk Stuck Front Wheel
  43. Engine Breather vent tube (Champion)
  44. Wheel Stud Bolt
  45. Cams, valve lash, idle, and vacuum
  46. Pinion seal replacement - '55 President with pictures
  47. Underdash A/C 62' Lark with 6 Cyl 170 OHV
  48. 63' V8 OD checks troubleshooting
  49. Tires and the 1950 Champion
  50. Glass replacement on a Champion
  51. 59 Lark VI , 3 speed, OD - rear end ratio questions
  52. Anyone ever see an NOS instrument cluster plate ...
  53. T-BOW carb rebuild
  54. 57 Silverhawk tail light cap
  55. replacing an automatic with a 3 speed OD on a '64 289..
  56. front suspension tool
  57. edelbrock 1405 conversion
  58. Dana 44
  59. windlace
  60. Driving Lights for a 89 coupe
  61. which spark plugs for 224 ?
  62. 63 hawk A/C
  63. McCulloch Supercharger
  64. What master cylinder to get?
  65. 41 coupe I.D.?
  66. Brakes: dual master cylinder for brakes--questions
  67. tire sizes 63 hawk
  68. '51 Land Cruiser 289 exhaust system
  69. Rod pinch bolts
  70. Linkage Insulator ???
  71. Wagonaire rear window removal
  72. Additional Electronic Fuel Pump
  73. Pilot bushing problem
  74. Wiper Motor
  75. 64 Cruiser steering column question?
  76. 62' Lark Temp Gauge
  77. Flightomatic Rebuild update
  78. '51 hood latch control wire
  79. Hinge rehabilitation
  80. Champion Timing Help
  81. 1955 commander stripped axle nut
  82. removing radiator mount
  83. 57 Hawk Generator Puzzlement
  84. Hawk Wiper Motor
  85. Adjusting timing by vacuum
  86. Electric fuel pump
  87. Avanti inner fender brace- Does anyone have a photo?
  88. Studebaker 289 with automatic transmission--What fluids to use
  89. torque
  90. Replacement Air Cleaner Avanti
  91. Cylinder Head Flow using FP-1
  92. '48 Champion Starlight back window
  93. edelbrock 1405 conversion
  94. Axle Shaft thread size?
  95. KEN-RENDA This is for you
  96. Ohm readings for stock fuel sender- 53 champion
  97. ignition lock cylinder
  98. avanti rubber
  99. '51 DG Auto trans leak
  100. Budd wheel replacements
  101. edelbrock 1405 conversion---again
  102. float setting on 48 commander starlite stromberg bxov-26
  103. 47-52 fender/hood interchange.
  104. Capacitive Ignition for 6V
  105. Flightomatic help!
  106. Valve cover install
  107. 1925 EQ sports roadster interior
  108. Shimming a Prestolite Distributer
  109. Improving Lark handling
  110. Champ crankshafts
  111. Body: Replace rusty hawk floorpans need your experienced help
  112. Rebuilt Engine Stuck, Dist. won't sit
  113. Dual master cylinder adapter for 51
  114. 1931 Commander running!....wait, maybe not
  115. Steering Shaft swap or repair? 57 Ross unit..
  116. Pertronix 1584
  117. 1946 Skyway Coupe Restoration - this is my first Studebaker off the frame resto
  118. Fuel & Oil additives?
  119. hole in intake
  120. 12v fuel sender options for 53 stude?
  121. Avanti Supercharger - what would you do? Clumsy mechanic asks...
  122. Fabbing up a rear sway bar for a Lark
  123. V-8 Cylinder Head Chamber Volume Question
  124. 289 intake gasket
  125. Molybdate Vs ZDDP
  126. Aluminum radiator for 1954 Coupe
  127. Clark in SD I respectfully request some info from you
  128. Anyone ever try intall of a hydraulic clutch kit
  129. '51 Champion oil pressure bypass valve
  130. 49 Champion Overdrive
  131. Need Rear Motor Mount M15-20 Replacement Help
  132. Tree Sapp
  133. V-8 Head Re-Torqueing
  134. '49 2R10 choke caable
  135. Wheels Ford wheels on '64 Studebaker
  136. Hose clamps for 1958 Stude?
  137. Where to find??
  138. HELP (again)
  139. Abbie-Normal Engine Mount Bracket
  140. Coned-steel plates for Flightomatic- update/correction
  141. does anyone know their Flightomatic serial numbers for '57 Golden Hawk Flightomatics?
  142. Leather interiors
  143. Edelbrock 1405 conversion---again
  144. Question about custom chopping?
  145. How I fixed my broken clutch bell crank and "support bracket" : 1963 Avanti
  146. 64 hawk vinyl..
  147. one man windshield and backlight install
  148. Dana 44 TT thrust block roll pin
  149. 1948 M15A-20 Wipers
  150. 1963 golden hawk rear brake drums
  151. Next Head-Scratcher -- Valve Adjustment
  152. 1959 Lark 170 6 cyl rebuild parts info needed
  153. 6" Gusher from the top of the head
  154. Color Engine Compartment Pictures for 56 Power Hawk
  155. Dana 44 pinion spline count?
  156. '48 Champion Starlight trunk floor
  157. V-8 Valve Guides
  158. just purchased 1948 m5 looking for parts
  159. V8 Oil Galley Plugs
  160. Hawk Interior Questions
  161. Vent rubber
  162. Valve Lifters
  163. Electric Fuel Pump, a different view
  164. Power Window Adapter for any Studebaker
  165. Converting to 7004R but what about the shifter?
  166. Removing Headliner
  167. In search of brighter dashboard lighting
  168. Stromburg WW Replacement
  169. My Rear End is all messed up!
  170. Measuring a Driveshaft???
  171. 63 avanti rear engine-transmission support bracket replacement
  172. 232 piston rings
  173. A-Arm bushing installation tool - no removal needed
  174. 1955 Commander Brake Job
  175. Two things For Now
  176. need m5 gas tank and cheap solution to front wheel cylinders
  177. Ford 9" in 53 Coupe..emergency brake cables.
  178. specs
  179. vintage air
  180. camp overdrive
  181. Staring a 170 six on a test stand
  182. 1950 Champion convertible frame or parts wanted.
  183. console quetion
  184. Avanti R2 - Air Conditioning?
  185. weight savings- V8 engine
  186. R1 Fuel Pump / Power Steering Pump Clash!
  187. Front Seat for 1957 Silver Hawk
  188. Electrical glitch
  189. 289 V8 Freeze Plug
  190. 259 V-8 Harmonic Dampener problems
  191. Center button on 1948 Champion radio
  192. The imfamas.....oil topic
  193. avanti front seats
  194. 1950-ish packard 3 speed manual all synchro ??
  195. CASO Alert: Carburetor question
  196. Skybolt Six ?
  197. Where does it go???? 1960 Lark
  198. Hog Trough Styles - One Piece or multiple
  199. Steering Power Steering
  200. R1 Vibration Damper Needs A Press
  201. neoprene cat whisker
  202. Champion 6 Filter Hook-up
  203. Gran Turismo Drip Rail Moulding - ??
  204. Pulley(s) Help
  205. cork floats
  206. Champ truck 6e7
  207. NOS Master Cylinder......prep ?
  208. Silver Hawk 57 rear quarter window
  209. Bottom of Door Repair
  210. Timken Rear End (M15A-20)
  211. avanti judging standards
  212. New floors in a "58 Packard
  213. Flightomatic- reassemble! :-)
  214. know your V-8 engines ?
  215. Will It Clear?
  216. 1948 m5 hubcaps
  217. Engine Assembly
  218. Aluminum Cam gears.
  219. Engine: 232" V8 cam and lifter tech info
  220. 31 President Front Seat Back Removal
  221. 53 Coupe Gas Tank
  222. Radimeter Repair?
  223. 11" truck clutch, into a Lark? Would it be the same flywheel?
  224. Who Has a Blog?
  225. Spring bushings install 53 coupe
  226. Update AC belt 85 Avanti
  227. Does a 51 automatic transmission have an ignition lock?
  228. Brake job problems
  229. Full-flow V8: owner's manual vs. actual crankcase capacity
  230. Drain plug magnet?
  231. engine number
  232. More spring questions
  233. Engine: Oil Leak question
  234. spring shackle bolts
  235. 1934 Commander Straight 8 Engine Help
  236. 31 President Front Seat back Removal?
  237. 53-54 CK rear seat upgrade
  238. Thank you for the " pulley(s) help" help and a new question about after market steering wheels
  239. 5-40 Oil, I know it is a no-no....
  240. 48 Champion Engine rear support cross member needed
  241. Paint Forumla
  242. Breakerless Ignition Installation on Champion 6
  243. RS1084 R1 or R2
  244. 62 Lark Ammeter
  245. Turns over but won't run
  246. What goes in these holes? '54 C heater tube.
  247. 1964 Bordeaux Rec paint code
  248. Filler block and thread inserts
  249. '60 Lark new brake linings won't stop well
  250. A arm bushings
