View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
  1. Clutch waer measurement
  2. Rambling Newbie questions...53 trim & tailights
  3. Avanti Vent Handle
  4. 1948 Land Cruiser Parts Needed
  5. Hawk gas tank support
  6. 53 rear fender spears
  7. Camshaft blues
  8. How close is close?
  9. 57 Hawk Main Wiring Harness replacement question
  10. Is it possible?
  11. pulling 289 from '57GH: pull with tranny or without?
  12. Hill Holder.........
  13. Run-out on drive-shafts; anyone checked theirs?
  14. 1962 Champ OD
  15. 6 Volt fuel sending unit
  16. looking for Lark washer nozzles
  17. gas tank sending unit mounting
  18. 51 Champion Gas Tank Mounting Bolt?
  19. Front coil springs, '63 Lark w/259
  20. C/K Door Hinge Pins
  21. Transmission Mount
  22. 6 volt fuel sending units WILL A 47-48 SENDER WORK FOR A 49-52 CHAMPION ?
  23. Gas tank sender
  24. How can you identify which torque converter you have?
  25. how do you id a studie v8?
  26. Carburetor Questions
  27. Turning the air blue...
  28. Wheels Again
  29. The Black Bart Special is running!
  30. Turner brake question
  31. New to you forum member with a New to me 63 Champ Pickup and Questions
  32. 57 Supercharger solenoid purpose
  33. Ford (FOM?) vs Stude Flightomatic photos
  34. what is this switch? (by Pitman arm)
  35. My 65 Wagonaire needs to be converted to power brakes
  36. Tranny makes buzzing noise in Park and Reverse
  37. bezel tool
  38. Avanti engine block numbers
  39. Fueling issues... ?
  40. Lighting Problem
  41. Carburetor repair 57 hawk
  42. 259 / 289 block difference?
  43. Interior Code help; T 5775A GOV 25
  44. 85 Avanti upper rad hoses
  45. What grounds the horn ring to make horn work?
  46. Automatic transmission swap
  47. 6V Dash Blinkers 52 Champion
  48. Trunk spring 53 Coupe
  49. 57 Golden Hawk Identification Plate and matching numbers
  50. Wires found in Water Passages- 1950 245 cid
  51. Back-up Light Switch on 63 Hawk
  52. Studebaker Flasher
  53. GT Hawk fan shroud interchangeability with other models?
  54. Avanti carb & tranny mods- info needed
  55. new Bead-blasting cabinet; how much pre-cleaning of parts makes sense?
  56. floorboard rust
  57. removing the bell housing and tranny
  58. Engine: Torn...
  59. Pillar A and pillar support / front-body support question
  60. Lark Front Seat
  61. sloppy dial in symptoms
  62. Front Coil Springs. ' 63 Lark w/259 3 spd.
  63. Gas-gauge sending unit questions (57GH)
  64. Frame suggestions for Daytona
  65. HELP PCV Specs
  66. Oil pump idler gear. What is the right position?
  67. When to rebuild vs overhaul
  68. w/strip
  69. Evapo rust: yet another miricle useage you should know
  70. Engine and transmission swap
  71. R2 fuel pump
  72. Avanti R1 cold air intake
  73. Mule
  74. Rear Axle: Dana 44 pinion seal replacement
  75. New Gauge Bezel Source and Installation?
  76. how do i know the size of my clutch disc/plate?
  77. New owner here with a question or two
  78. inside door and window handles
  79. Studebaker V8 head nominal dimension check
  80. Late lark front sway bar same as GT hawk?
  81. Smelly car
  82. fiberglass rear springs
  83. Fuel Pump Issues
  84. Info tag on fire wall, what does it mean?
  85. studebaker overdrive
  86. Antifreeze!!
  87. Turner Rear Disc Brakes
  88. Shift lever rebuild
  89. Edelbrok 500
  90. 4 bolt champion brake drums needed
  91. Overdrive bearing number
  92. steering box lube
  93. studebaker overdrive
  94. ballast resistor
  95. Mallory Unilite Ignition, Cleveland engine
  96. window hardware, 57 Silver Hawk
  97. Need a part number - PLEASE
  98. Curious about J,C. Whitney parts
  99. Need Help re headliner bows-57 Silver Hawk
  100. Where can I find...
  101. Distributor Cap wire order 6 cylinder Champ
  102. Oily film on PCV & hose
  103. How to inspect front end of 48 commander
  104. Which carb port for PCV ?
  105. Getting an old 259 going...
  106. Stock Tire Size?
  107. Golden Hawk Brakes
  108. dana 44 axle shims
  109. F/S: Fuel Filters for installing return line to gas tank
  110. Dash Lighting
  111. distributor 180 degrees off.
  112. Hawk iinstrument light switch
  113. gas door
  114. turn signal wiring
  115. V-8 Water pumps
  116. Retrofitting a later swinging pedal assembly on an early Lark?
  117. Ford 9 inch in a Studebaker 6 cylinder model?
  118. Need help on brakes
  119. leaking head
  120. F/S: Avanti Welcome Sign and Hat Pin
  121. fuse box location
  122. 1940 champ starter
  123. Hawk grease fittings...how many are there???
  124. Head swap???
  125. Studebaker
  126. First attemp to start
  127. Avanti Hood Ornament
  128. R1 Dist postion @ TDC... And how'd I get here?
  129. Compression/vacuum readings - McKinnon 283
  130. 1952 Stude Champ-brakes-HELP!
  131. Valve cover with no oil holes
  132. No Brakes - 63 GT Hawk
  133. Changing Parking Light Lens to Amber
  134. Avanti Engine
  135. 51 Champion carb rebuild
  136. Brake Question
  137. Hawk dash switch rebuilding
  138. weatherstripping for 89 coupe
  139. RHD Power Steering Ram Required 1963 GT Hawk
  140. Need E brake info
  141. Ball joint spindles fitted to Lower control arm
  142. 232 engine removal
  143. 289 rear seal replacement
  144. 51 front end rebuild Q
  145. 52 Champion 6V Autolite Voltage Regulator
  146. 63-64 Avanti brake booster chack valve
  147. brake pedal question
  148. Lark Seat Belt Installation
  149. Torque Converter: rebuild?
  150. F/S: New Firestone 721 Tire, in case you need a spare
  151. In trouble already
  152. power mirro switch for an 89 coupe
  153. Coil over shocks?
  154. Oil Pressure Relief Valve
  155. F/S: Avanti and Avanti II parts
  156. Lube rear axle's
  157. Removing '51 Champion Oil Pan
  158. No Oil Pressure. HELP!
  159. Just wondering what they were thinking?
  160. Installing the wrist pin pinch bolt
  161. Avanti with no brakes
  162. Electronic Ignition info needed.
  163. '50 Champion dash switches (heater fan, headlight, etc)
  164. quick question about a 47 champion
  165. 1953 232 engine and trans colors
  166. Tachometer
  167. Cam Gear Type
  168. Automatic transmission advice; new bearings, linings and bushings?
  169. 63 hawk interior colors
  170. Vin#
  171. Front Braike Noise
  172. Stewart Warner gas tank senders
  173. Flex Plate; reuse or buy a new one?
  174. cooling lines for transmission cooler ('57 Golden Hawk Flightomatic); where to buy?
  175. Manifold Heat Riser 1948 Studebaker Commander
  176. Just Starting?
  177. Oil Filter hoses - from where to where?
  178. Spring question
  179. Throw out bearing retainer spring
  180. 1948 Studebaker Manifold Heat Riser
  181. Replacing Fuel Lines
  182. compression or flair fitting?
  183. Engine Identification
  184. Underseat Heater help needed
  185. Question About Possible Disc Brake Conversion
  186. Removing rust from the inside of an Intake Manifold.
  187. Power stroke/timing 259
  188. difference in clutch packs (missing teeth?)
  189. Transmission install malfunction. need ideas!
  190. Cloth vs plastic wiring when?
  191. Release Bearing, Collar wear plate
  192. What lowered the '58s?
  193. New Gas being hard on the Carbs. Is there a needle and seat that will hold up?
  194. brake lines
  195. Avanti radiator ?????
  196. Help on T-86 3-speed O/D
  197. Old School Anti-Freeze........
  198. gasket material
  199. Trunk Lid Emblem Retainer
  200. 12V wiper conversion
  201. Upper a arm rubber bumper
  202. Can anyone verify the exact wheelbase of the m5
  203. Hawk floor replacement
  204. Bushing/Bearing Press: how many ton is useful?
  205. Installing aftermarket air conditioning
  206. Anyone know anything about these brake lines?
  207. correct size battery
  208. Lark VI exhaust question
  209. Flightomatic Frustration
  210. Looking for pics of SB Fire Dept. Studes.
  211. 51 Champion Auto Transmission Linkage
  212. Wheel Bearing Dust Caps
  213. 2,3 or 4 row core?
  214. Antifreeze (again) Now I'm confused
  215. 1950 Land Cruiser wheels - bolt pattern
  216. anyone repair '57 Golden Hawk fuel-gauge tank sending unit?
  217. Possible Alternator Issues Avanti '63
  218. CASO Dynamat
  219. Aren't all OD relays created equal?
  220. Has any body updated the flathead 6 clylinder with a later model transmision
  221. need body alignment help.
  222. Putting a Edelbrock 500 CFM on my 62 GT Hawk question
  223. 2 cases of 30 yearold oil
  224. Fuel Sending Unit Gasket Sealant
  225. headers on a '76 avanti ii
  226. Avanti R1 AFB metering rods
  227. the big 2,000
  228. VS57/SN60 interchangeable parts ?
  229. Dictator 1930 4 door 8 cylinder
  230. Replacing stock bench seat with buckets, need bracket info?
  231. Steering wheel hub
  232. A great product!
  233. V-8 Rocker Arm Shaft
  234. '62-64 Studebaker V8 full-flow blocks versus '51-62 by-pass filter blocks - a discussion
  235. L-head to OHV swap question
  236. '51 Champion gas tank
  237. 82 Avanti II oil pan removal
  238. Hard to start AFB R1 Avanti
  239. Champ Wheels
  240. Items needed to rebuild 289 to R1 specs
  241. Vapor Lock - Gas vapor bypass
  242. Rust Products?
  243. Rebuilding a 51 front end and brakes Q.
  244. Timken 2 speed rear with mechanical shift
  245. Motor oil / engine failures
  246. twin traction lube
  247. R1 63" Avanti top speed
  248. 51 Champion Molding - How to mount?
  249. Champion 6 Oil Pump Help
  250. Body seals
