View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Saginaw Power Steering
  2. Whatdaya do with old gas?
  3. Gas neck filler on 1950 Studebaker. How is it attachted to inner fender?
  4. 51 1 1/2 ton stude
  5. Whats the purpose of the J hook?
  6. 62 lark transmission
  7. Anyone need an aluminum flywheel for their 56J Golden Hawk?
  8. 6 volt battery
  9. Caddy to Stude intake
  10. Strange smoke from the block (not running)
  11. Carter AFB (63) Rebuild
  12. Stereo in Avanti Glove Box
  13. inlet/oulet oil pressue points 289v8
  14. Hydrovac oil
  15. "59 Lark, hood won't open
  16. 259 cam change?
  17. c'mon guys...help me out here
  18. M5 Spare Tire Carrier
  19. rear brake drums, how to pull? ('57 Golden Hawk)
  20. Body: door won't open: '57 Golden Hawk
  21. Here's a tricky question for the Stude gurus.
  22. Nascent 53
  23. I have a question about main bearings.
  24. hill climber hook up?
  25. Convertible problems 2nd request for help
  26. need a picture, 1963 Lark cowl
  27. Gas Tank Hole: repair vs replacement advice?
  28. Need help identifying a few small parts from 56 Hawk
  29. Fender rust prevention
  30. 64 Wagonaire tailgate
  31. Valve Spring Compressor
  32. Carburetor parts
  33. Head Gasket Leaks?
  34. Head Gasket Leaks Continued
  35. Draw Tite Trailer Hitch part numbers for Studebakers
  36. Rear Axle Options ??
  37. Need to check OD connections to Solenoid: 63' V8 OD
  38. yet another post on tire size; '57 Golden Hawk w/ 4.5" rims; current radial options?
  39. how can I tell if I have the T/T Positraction rear-end on my '57GH?
  40. For you hot rodders out there
  41. Floor panel finishes
  42. 51 champion wiring
  43. Milling 289 Head Limits
  44. Hawk blower motor
  45. '51 Champion Starlight: C-4 vs AOD trans
  46. 1963 Avanti front disks tolerances
  47. E-12 Ethanol Proponets Seek To Deny Request To Up Ethanol Content
  48. H4 E-Code Lights with "City Beams"?
  49. Leather interiors
  50. Miss Fire, The next installment (pertronix problems)
  51. what transmission...
  52. pin striping 2R5 wheels for colour code P-2202
  53. Front brake drums for a '64 Cruiser
  54. M90 Supercharger
  55. 1950 Champ question
  56. J-5472-1 Installation tool dimension
  57. Just passing on wheel info
  58. 1965 cruiser upgrades
  59. mystery part and mystery window
  60. Truck Heater vs wiper arms
  61. T-Cab Engine Part
  62. wiring question
  63. Advise on rear end gear change..3:31 vs. 3:73
  64. Length of power steering belt?
  65. 6014 Rating
  66. 85 Avanti belts,etc;
  67. '50 Champ/Commander hood "eyebrow"
  68. Engine removal - 60 Hawk
  69. Stromberg WW Carb Needed for 54 Commander
  70. Champion Oversize Intake photos
  71. do brake drums need to be replaced in pairs? ('57 GH)
  72. What is the preferred (most efficient?) sequence of restoration, (body, chassis, engine,....???)
  73. Avanti Hog troughs
  74. opinions wanted: keep the floor starter switch?
  75. '49 2E5 - 1 horn or 2???
  76. 63 3 speed overdrive
  77. Stupid question-'52 Commander
  78. Rear window trim install on Hawk
  79. 50 Champ normal idle speed.
  80. Need year model I.D. of Unmarked Champion 6 Engine
  81. Brake pedal bushings
  82. New Avanti Owner- Some questions
  83. going from horn button to horn ring... installation tips?
  84. Motor oil
  85. Delco distributor repro detail part
  86. #&@*@^!) instrument cluster!!!
  87. Thrust block twin traction axle
  88. J-5472 and other Bushing Installation tool Replacements
  89. Need a four bolt break drum for a 1950 Studebaker Champion.
  90. Disk Brake Pedal to Lever Pushrod
  91. water pump drip
  92. transmission troubles, vacancy in vacuum
  93. Differential
  94. hydralic clutch problem, how do I bleed it to make it work?
  95. Need fin strip for my 57 hawk
  96. Help! I am looking for some parts!
  97. anybody who was at Hudson, WI swap meet Sep18th? Looking for a vendor
  98. Avanti Bodies
  99. Stuck Eccentrics!!!
  100. Attaching Houdaille shock arm to the frame
  101. Adjusting the Trunk on a 49 Coupe
  102. Cigarette lighter location.
  103. Tect. tip #1.
  104. 1948 Starlight Commander Coupe
  105. Towing a 48 Commander
  106. Electrical questions for a '52 Land Cruiser
  107. right and left drum-hubs; why is there a difference??
  108. Pertronix on Lark VI ?
  109. AFB float information needed
  110. Time to Rebuild Steering
  111. Changing shift shaft seals on T-86
  112. 53 commander brakes
  113. Rebuilding a Hurst dual pattern 3 speed shifter
  114. chasing headers
  115. Eaton power steering pump seal
  116. Temperature gauge;
  117. bench testing tempature guage
  118. Lots of blue smoke
  119. brake upgrade for 50 champ
  120. V/8 Bell housing & adapter ID help!
  121. "Seasoned" Blocks
  122. removing caked-on oil, grease, and crud
  123. R water pump info needed
  124. fuel line cleaning
  125. Can't get it in reverse
  126. Champion cruising speed
  127. Mounting a Winch On Pat's Trailer
  128. props for marvel oil
  129. engine/trans mount points
  130. valve question
  131. 1959 studebaker silver hawk brakes
  132. What is this part called?
  133. 62 Lark Help
  134. What do you know about welders?
  135. Can someone give me the specs.
  136. 1927 Dictator>>???s
  137. Stude rear fender trim
  138. PCV valve
  139. Grille
  140. 63/64 avanti R2 exhaust manifold
  141. Inner "A" Arm Bushing Dimension
  142. '57 Golden Hawk Trim
  143. Headers for Lark w/sbc
  144. Avanti Polyurethane Sway Bar Bushing Conversion
  145. need transmission AS2-7A for '57 Golden Hawk
  146. 62 GT Hawk Grille
  147. what other Stude transmission would be most-comparable for a '57GoldenHawk?
  148. Advice wanted on AFB Rebuild
  149. Carb pictures please
  150. 289 valve guide clearance
  151. Pinion paper seal
  152. Brake shoe alternatives/cross-reference
  153. What does the color label codes say?
  154. Companion flange install
  155. 51 Champion Rear End and Auto Trans ID
  156. 51 Champion: What's Involved in Changing to 11-Inch Brakes?
  157. Gas tank plug
  158. The Black Bart Special; I've really, finally started to put it in!
  159. flow thru fuel pumps
  160. Avanti Painting Pictures
  161. SeaFoam and Marvel Mystery Oil
  162. Water pump, what does it fit?
  163. Coupe <-> Hardtop Switch
  164. '55 Sedan sway bar in a '57 2 door President
  165. anyone in Mpls/St.Paul area who can come over and give some tips on frame/body welding work?
  166. Oil pressure problem, Help needed
  167. Is it good?
  168. "Dressing" points.
  169. Input shaft length for Commander 245 and 259 V8
  170. May help with percolating fuel
  171. 1962 Champ and Commander 245
  172. Avanti engine oil leak
  173. Starter Problems
  174. motor ID help
  175. Rear Axle: Traction Master update-Photos
  176. 62' champ oil type
  177. 47-48-409 Champion
  178. Replacement for 16-inch Split-Rim Wheels on a 1949 2R10
  179. Ash tray
  180. Re-wire a 49 Coupe
  181. Front Suspension Swap 60 -61
  182. Elcetrical Issue 55 Champion
  183. Is it common?
  184. Cylinder head, leaf springs, tires & shocks for Avanti R2
  185. Ezibleed for Studebaker brakes
  186. Replacing body mounts
  187. 2 questions: OD and turn signals
  188. 55 speedster dg250 transmission
  189. Non working gas gauge in 6V 52 Champion
  190. Should I have turned?
  191. Should I get a new fan?
  192. Need help in identifying my dash
  193. For sale: 1964 Studebaker 289 or 259... Out of 1964 Commander. Complete Engine and trans.
  194. Special tools for Flight-o-matic rebuild?
  195. 1963 Avanti Questions
  196. Fan idea's?
  197. 1952 Studebaker Commander with a v6?
  198. 52 Commander Truck Lock
  199. Delrin bushings.
  200. 1952 Studebaker Champion Wiring harness?
  201. body coming off---suggestions ???
  202. power for dash gauges?
  203. Shocked by Distributor
  204. R Series Oil Pans
  205. SAE 75-90/80-90 versus SAE 90 gear oil for tranny/OD
  206. Is there such a thing as too much lube?
  207. Trans question?
  208. 12 Volt Overdrive Relay Info Needed
  209. Avanti, tire size and pressure settings
  210. How to Connect 2 terminal regulator for '63 Avanti?
  211. Engine Lift
  212. 53 Trunk lid advice for
  213. How often is often enough?
  214. Oil Leaks Crankcase Vent. System
  215. Mopar Spark conversion for Studes?
  216. rear axle shims
  217. V8 heads question
  218. clutch problem... inspection plate in floor?
  219. Avanti Rim sizes?
  220. Avanti Battery Replacement
  221. Don Simmons ss Exhaust........
  222. Power Steering Hose Fitting Does Not Fit
  223. 57 Hawk turn signals
  224. Engine: Paxton/McCulloch on a 54 Hardtop
  225. Wheels or Rims
  226. 55 President mystery fuse block
  227. topshifter and T86 V-8 trans
  228. Boiled Linseed Oil for rust prevention?
  229. Need Master Cylinder for a 1966 Commander. Anyone have one for sale?
  230. V8 ignition problem
  231. New Edelbrock products that might work for a Stude...
  232. King Pin Rebuild Questions
  233. Transmission: Tremec T45RS 5 speed swap questions
  234. 62 Champ Steering Box
  235. Problems with 12v starter sullionid
  236. Slight leak around thermostat housing
  237. '51 2 door sedan fuel tank issues
  238. Hey guys, Need some car part help
  239. 63 Hawk - Correct heater, etc. box? Is blower fan connection to that box correctly located?
  240. 51 Champion Fuel Line Routing Question
  241. 51 Champion Carb
  242. Axle bearing
  243. re-keying door locks to ignition key...? suggested vendors?
  244. 1959 Lark 8 automatic
  245. Champion Head Milling
  246. drive shaft u-joint replacement needed
  247. '50 Land Cruiser for sale
  248. rear axle i.d.
  249. Ring Gear Replacement
  250. Clutch waer measurement
