View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113
  1. First time I bled my own brakes
  2. 1960 Hawk (289hp 3 speed) radiator cap pressure?
  3. Transmission question
  4. Alternator for sale, not Prestolite
  5. 51 Champion Circuit Breaker Wiring on Speedometer
  6. fender skrits
  7. Door hinge cage nuts, how are they constructed?
  8. Suggestions for cleaning up truck firewall
  9. Upholsterers: Can you identify this weave?
  10. 185 crank OHV six
  11. 51 Champion Circuit Breaker Installatino
  12. R-1 spark plugs
  13. V8 Engine timing
  14. 61 Hawk part numbers
  15. 53 rear spring urethane bushings
  16. A new first in my many years of losing battles while working on Studebakers
  17. M5 Pickup: How do I remove the lock on the passenger door?
  18. How Do I Tighten Strato-Vue Mirror?
  19. Engine Knock, maybe
  20. Oil Drain Plug
  21. Big troubles with Avanti engine rebuild
  22. E-brake handle replacement
  23. ignition transister
  24. pressure plate interchange question
  25. Steering 64 Cruiser Steering wheel scraping noise
  26. Leaking Valve cover
  27. What should I look at next. Charging system
  28. Is this REALLY just for the passenger side?
  29. Blade suspension 2R5 : question on assembly
  30. Radiatore Presssure
  31. body to frame pads/spacers
  32. Will a '55 trunk lock fit a '53?
  33. 1953 Commander Air Cleaner
  34. C-cab hold down bolts, springs, sleeves and spacers question
  35. Window Mechanism Studebaker 1949 2R5
  36. 170 ohv, t5 swap? adapter?
  37. Smokybaker - cured
  38. Transmission question
  39. 55 president...the work never ends...
  40. 63 Lark Cigarette Lighter Question
  41. Moulding clip
  42. Power steering high pressure hose
  43. Cltuch Pedal Spring
  44. 53 Hood brace
  45. which gasket set for '63 T-86 w/overdrive?
  46. '63 Gran Turismo Fuel problem.
  47. No low beams; only high. HUH?
  48. Homebuilt ohv manifold interior cleanup or fun with grinder W/picture now.
  49. What's this
  50. Relocated, what are the new dangers regarding rust?
  51. Type S steering box rebuild. W/pictures
  52. Bleeding Packard Hawk Brakes
  53. Fuel gage calibration?
  54. Bell Housings
  55. Front suspension questions
  56. Brake light switch for use with silicone brake fluid (DOT 5)
  57. Have a 2R5 Frame Question
  58. New Federal-Mogul Piston (oil) Ring
  59. 232 to 289 ?
  60. 1954 232 V-8 WW carb
  61. A/C Crank Pulley running idle
  62. Camaro front shocks
  63. How do you remove scripts/emblems?
  64. New Process 5 Speed too noisy/ what gear lube nowdays?
  65. trim removal
  66. Sandpaper or Wire Brush
  67. Radiator
  68. 57 - Stock 289 ceramic fuel filter question
  69. 51 R17 1 1/2 ton studebaker
  70. What Axle Ratio for 2R10 3/4 Ton Pickup?
  71. Flathead six head identification
  72. Intake/exhaust manifold Id Need help
  73. Hill holder
  74. crossmember question
  75. Hawk Driveshaft
  76. Where is the oil coming from????
  77. Sticky crankshaft
  78. Question on body ground for 1953 coupe
  79. I'm on the Road In Harrisburg PA with a problem
  80. Avanti Brakes
  81. How do you prime a 6 ohv oil pump ?
  82. Almost ready to test start the Champion engine
  83. Dunlop tires fitted new 9/1963: Blackwall? Whitewall?
  84. Low end knock
  85. V8 Y Pipe Issue
  86. I need a front batwing frame support for my 50 stude
  87. 63 Hawk Fuel Gauge
  88. how do you set the alignment on the front end of a 57 hawk
  89. champion air filter
  90. No brake light on a 63 avanti
  91. What year engine?
  92. Coil Temperature
  93. Need Manual & Parts for 1957 Silver Hawk.
  94. My passenger's wiper won't... wipe.
  95. Wipers
  96. 64 champ clutch
  97. Oil Galley and Water Jacket Plug Removal
  98. Flipping the upper inner rods
  99. Rebuilding the Carburetor
  100. Problem with horn relay
  101. Tilt Steering
  102. 3 Tone Horn
  103. Wheel Vintiques would like our help!
  104. 61 Hawk manual Trans and Overdrive oil
  105. 62 hawk aluminum trunk trim
  106. Carb problem 41 champion
  107. New to the Stude
  108. Generator/alternator
  109. Chains and terminals
  110. Master cylinder
  111. back engine plate fastener ID
  112. Need a measurement & a couple of used parts....
  113. Is the frame from
  114. Replacing R2 Accelerator Shaft Seal
  115. Tach troubles
  116. started on first turn!
  117. help with 56 Hawk overdrive
  118. Halibrand wheels for studebaker 1963/64 .
  119. Lower outer pin locking pin
  120. Balance Weights
  121. Master cylinder location
  122. Original '53 2R License Plate Holder
  123. poor braking - Turner Brake conversion 62 Hawk
  124. 63 Lark Windshield gaskets
  125. Vacuum advance
  126. best place/way to get flat glass replacement
  127. '63 Avanti Alternator/Regulator
  128. distributor cam lube
  129. Replacing Pinion Seal on 1950 2R10 Timken Rear Axle
  130. Upper outer Pin Bushing Torque issue
  131. C Cab interior part, what is it?
  132. Electrical Gremlins - was V8 Y-pipe
  133. R-2 Accelerator Pump Seal
  134. air cleaner 2 barrel
  135. is the directional switch in the shop manual?
  136. Stock disc brake problem....
  137. golden hawk that runs for 8 minutes then dies
  138. Heater Control Valve
  139. Needed - 63 Avanti driver side Manual window regulator
  140. Guess I'm needing new motor mounts...
  141. 53 Parking light sockets
  142. No gas from a full gas tank
  143. need help and parts for 51 champion (nOOb)
  144. WooHoo! Bell housing dial in is DONE! (almost)
  145. Wanted:352 service crank
  146. techtips,specs and data
  147. '54 C Door Hinge screw/bolt size
  148. Barn Studebaker Runs Again
  149. The point of points
  150. Avanti A pillar...Rust?
  151. Today's gasoline
  152. Aluminum radiator anyone??
  153. Windlace modification help-57 Silver Hawk
  154. Commander windows
  155. Permatex for new valve cover gaskets?
  156. 1950 Champion 2-door sedan window rattles
  157. 60 Lark Upholstry Question
  158. Aluminum radiator for C Cab truck?
  159. 6V Alternator
  160. 63 Avanti Door Window Lift Channel Repair
  161. Sending unit for a 1931 Commander?
  162. 51-52 rocker panels and floors
  163. brake light problems,,, any advice on brake light wireing??
  164. Engine bay cables and tubes
  165. How do you install new window fuzzies?
  166. Paint source
  167. shocker - gas gauge works
  168. FS My 1963 Lark Regal V-8 2 door
  169. 50 9g horns
  170. Hawk bucket seats
  171. R-2 Carburetor Problem, no slow idle
  172. My Hawk has taken on a Backfire
  173. Body work advice - Use of POR-15
  174. Traction bar bushings solution?
  175. radiator cap
  176. Transmission cleaning advice
  177. First Gear Grind
  178. clutch parts needed 64 champ
  179. power steering fluid
  180. Upper control arm needed
  181. 1962 Hawk Wirring
  182. 51 windows and brakes! (and locks?)
  183. It pays to grease.....!
  184. Vintage Air in late Lark ('64) What fits under the dash?
  185. Thermostat orientation
  186. Oil issue please help
  187. 1950 9G-Q1 How many were produced?
  188. 185 Piston .040 (#522112)
  189. 64 Champ Idler Lever question
  190. best size tire?
  191. Grinding first gear
  192. 40's Studebaker Overall Dimensions
  193. Seiberling II Tires
  194. Update-What is a ideal air fuel mixture in a R2?
  195. Correct intake manifold gaskets for 64 Lark R2 ?
  196. clock conversion to quartz
  197. Engine Id question
  198. thread sealer for E10 gas
  199. Ford wheels on a 1951 Champ
  200. Tips/Advise/experience...OD & 3sp adjustments [1963 Cruiser 3sp/OD 78K miles
  201. Saginaw Power Steering Automatic to Standard Conversion parts for C-K column wanted.
  202. engine & transmission color info
  203. Brake pedal instalation
  204. Positive Ground
  205. Road Draft Tube to PCV Valve Conversion
  206. sound coming from amp. gauge
  207. runs sluggishly, but does not drive.
  208. Multipule carburator Intake for a 232
  209. 41 king pin/steering knuckle rebuild question
  210. Lark V8 Exhaust Pipe Size
  211. Hey GT Tim
  212. Dana 44, TT 4.09 Axle Bearings
  213. 1950 windshield
  214. New to Studebaker and need help
  215. GT Hawk hood release cable
  216. '59-'61 door glass install
  217. Oil plug and water jacket plug removal
  218. What octane gas should i use?
  219. What octane gas should i use?
  220. TT gear oil
  221. Duel Brake system for 50 Champion
  222. Fuel System: Fuel Pump?
  223. Supercharger rebuild components- where to begin?
  224. Indy car grille fabrication: Part 2
  225. new wheels and tires
  226. Avanti rake
  227. Edelbrock 600 Carb to Stude linkage/bell-crank
  228. What should I do about these control arms?
  229. "Rattle Can" paint match
  230. Oil Quantity
  231. 1960 Lark Starter wiring
  232. Can't turn V8 crank ?
  233. Carter AFB's Info needed
  234. Welding info
  235. Block (immersion) heater for OHV170?
  236. '55 2nd series clock
  237. Climatizer Blower - was Electrical Gremlins
  238. Clearence Issue 85 Avanti 2
  239. Starter "runon"?
  240. Another planar suspension question (several pictures, but small)
  241. 51 C-Cab arm rest visors
  242. Help!!!!
  243. Replacement PCV valve for 170 OHV
  244. Convertible top problems
  245. Lark windows
  246. V8 bellhousing bushing
  247. Modified Head Chamber Volume
  248. Power steering on a 51 Champ
  249. What are the Differences between a 259 and a 280 V8
  250. Optimum coolant temperature
