View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Plug gap for electronic ignition
  2. 51 Champion Cleaning Engine Water Passages Question
  3. Brake pedal bushing
  4. Petronix for V-8 ???
  5. Binding hardtop window regulator
  6. Pickup Starter and Bendix
  7. Steering Wheel Removal.
  8. connecting rods
  9. Headliner kit
  10. 51 C-Cab air conditioner?
  11. 289 ENGINE and TRANSMISSION REBUILD
  12. 1951 C-Cab can color
  13. How many gallons 1959 Lark VI tank?
  14. I was thinking
  15. exhaust manifold gaskets, which way do they go?
  16. Charging Problem
  17. Parts for the Tomato
  18. DG 200 Transmission
  19. source for proper coloured paint
  20. Simple test for detecting head cracks
  21. Auxiliary cooling fan issues
  22. Distributor rewire
  23. in praise of Turner Brake Kits
  24. front suspension for a 59 Lark?
  25. Stromberg WW tips
  26. 51 Champion Fuel Pump Glass Bowl cleanining
  27. 50 Commander front end rebuild or replace it compleatly?
  28. Avanti dash bulbs
  29. Main bearings, clearances, and feathered shims. Long.
  30. Electrical Issues
  31. 1950 Champion breakers
  32. Clutch work this weekend....dilemma ????
  33. 63 gt hawk automatic rebuild problem
  34. Door locks
  35. Exhaust manifold flange studs
  36. 1951 Hood Ornament
  37. Need V8 main bearings
  38. Hawk Exhaust System - Walker numbers
  39. location of breakers
  40. Valves slapped pistons.
  41. Ray-lin?
  42. wire harness hole location in trunk floor59 lark
  43. crankshaft to transmission
  44. Life's a beach.....shape-shift clutch troubles...
  45. Broken Avanti Traction Bar Stud Repair
  46. M5 brake cable reproduction?
  47. Painting question.....
  48. Front clip on a 65 Commander
  49. 1946 M-5 Serial Number Question
  50. 61 Studebaker Lark R-1 Dyno RWHP
  51. steering post jacket position
  52. springs????
  53. token
  54. "63 Avanti Wiper switch
  55. bellhousing dial in
  56. Exhaust manifold to cylinder head capscrews are frozen- any tips?
  57. A few tricks from the machine shop
  58. '63 Lark Temp Sending Unit
  59. 1964 transmission oil cooling lines
  60. Wanted: 1950 Commander automatic bell housing
  61. Carter AS identification
  62. Which Oil To Use????
  63. break in of rebuilt engine
  64. 6 cyl oil pump pictures - differences
  65. What are you guys doing for seatbelts?
  66. Rear Leaf Spring Question
  67. Resistor wire & balast resistor
  68. 232 performance cam question/idea.
  69. Need Bottom Radiator Hose for 64 Hawk
  70. Vacuum on 50 champion 6
  71. Power Windows 74 Avanti
  72. 4-5-6 Lark Bumpers
  73. Fuel Gage and Sender for 1950 2R10
  74. Synchromesh 4 Speed for 1950 2R10
  75. Break-in for 1950 2R10 Champion Engine
  76. outrageous oil leak
  77. 52 Grill Wanted
  78. Need some engine swap advive
  79. Vapor Lock
  80. 49 Pickup build...
  81. Problem with Studebaker International
  82. Fuel issues - carb?
  83. Relentless search for a radiator
  84. Power Steering problem
  85. Radio static
  86. Brake booster
  87. 51 Champion How to Polarize Generator
  88. Studebaker Service Letter S-64-5: Steering Linkage Shock Absorber Kit, dated 11/10/64
  89. Avanti rear speaker not working
  90. 62 Hawk - Idles fine but misfiring when accelerated
  91. Drum to drum rear axle assembly for a '62 Lark V8 wanted
  92. 62 hawk radiator
  93. A/C Cycling Questions
  94. 50 CHAMPION 6 cyl dist.
  95. I'll keep the A/C...........you keep the blower:-)
  96. power steering - steering wheel off kilter
  97. Engine serial no.
  98. Side Glass Questions
  99. exhaust manifolds 62 hawk
  100. DG 200 Transmission Help?
  101. What's unique about a 185?
  102. 1953 pick up rear end swap???
  103. carb adjust help
  104. '59 Lark alignment specs?
  105. 53/54 C/K fender vents
  106. Bubbling gas
  107. 58 hawk front frame brackets
  108. floor shifter for a 3 speed OD
  109. A arm bushing install question
  110. Powershift Avanti Transmission Weight
  111. Is this a 1st-gear-start valve body?
  112. 1950 commander donuts
  113. Avanti Rear Main Seals
  114. Pulling Engine and Transmission Together?
  115. Identify Wheels
  116. Radiator differences between V8 and 6
  117. 1962 Lark V8 - Pulled front clip and engine
  118. Factory Installed Vacuum Gauge?
  119. Adapting BMW PW Switches and Relays to an '88 Avanti How-to long and pictures
  120. Swingin' Speedometer Needle
  121. Aiir conditioning on 64 wagon
  122. Speedometer issue
  123. The legendary Studebaker Avanti Power Window Problems
  124. Bias tires for 1950 Champion
  125. "I've had enough" (was: " life's a beach"...)
  126. 259 to 289 rebuild
  127. K&N Air Filter for Avanti
  128. Back-up light switch for 59 hawk
  129. vapor lock......
  130. paint for 55 Commander hardtop
  131. Avanti - Saturn Deflector 21031161 Installation
  132. 350 chebby motor and trans install
  133. Steering wheel compatability
  134. 63 Hawk turner brake system
  135. Need autoline bendix housing still looking
  136. weak or Dim break light
  137. Speedometer theory & diagnosis
  138. '63-'64 GT Hawk headlight rings/bezels....retrofit?
  139. V8 Fuel pump install
  140. Problem with 6 cylinder overdrive throttle switch, throttle linkage, 1953
  141. Oh, if it isn't one thing its another...looking for radiator options.
  142. Mechanical vs Electric Pump
  143. I'm looking for resources on rebuilding a T-86
  144. T-10 4 speed assembly question
  145. 50 champion automatic trans shift
  146. Looking for a service letter on frame repair
  147. stock radio repair for 1950 Studebakers, question and shared resource
  148. Engine swap questions. 169 for a 245
  149. u-joint cross reference
  150. Twin Trac Questions
  151. Window track (U Channel) felt
  152. Transmission fluid
  153. '53-'58 V-8 carb differences
  154. Reference source for rear gear ratios for a '55 E12 with 4-speed ?
  155. Placement of Avanti Cowl Seal?
  156. Clock repair for a 1963 Lark
  157. Emergency Brake control inside hub
  158. 6-Volt Tachometer
  159. Another Twin Trac Question, Dana 44
  160. Bumper Knowledge?
  161. Windlace
  162. It's my fault!
  163. Any quick easy fixes to reduce oil consumption/ smoke?
  164. Headliner advice
  165. V8 Oil Galley Plugs
  166. Drive Shaft Lenght 61 Lark V-8 and Yoke angles
  167. Power Steering Pulley Question
  168. bumper bracker orientation
  169. Trunk and under hood colors on 53
  170. 51 Champion High Temperature Reading
  171. 61 Hawk trunk lock cylinder
  172. convertible oops
  173. Rear axle bearing installation
  174. Heat Riser "HOLDER"
  175. 51 Champion Help ID an Oil Filter
  176. V8 Oil Galley Plugs
  177. I DID IT ! - Power steering control valve removal idea
  178. Does anyone know what this is??
  179. Electric choke
  180. A/C in a Wagonaire
  181. I need to identify a 52 pickup 6 cyliinder engine
  182. Gauge Rebuilders
  183. Standard six valva play
  184. Avanti Brake Rotors and .330" thickness
  185. T-90 trans identification and parts differences
  186. Dial indiacting the bellhousing (slightly diffrent question)
  187. Installing Hawk Grill
  188. Pulling V8 w/OD: hood & cross member removed
  189. mechanics u joint
  190. oill filter
  191. What size front shoes 61 hawk?
  192. Clear Transmission Fluid?
  193. 1957 Scotsman
  194. 62-64 Shop Manual, Group III, Clutch Section, Need Pages 9+10-Clutch Pedal and Shaft
  195. Stuck becomes Unstuck
  196. Overdrive questions-1950 Champion
  197. What year is it?
  198. 1951 C-Cab type B speedometer wanted
  199. Fixing the floor by the rear seat hump
  200. Help Needed
  201. Oil level vs. Oil Pressure
  202. To heat or not to heat: ( is/was stuck/frozen T-O brg and clutch disc )
  203. 55 president
  204. Rear Quarter Window Seal Replacement on a '53 C
  205. '62 champ carburetor disassembly
  206. Drop-Down Instrument Panel for 1950 2R10 PU
  207. Power Steering on 54
  208. 62 GT Hawk Bucket Seats
  209. Air cleaner that fits '53-'54 C/K with late V8
  210. 57 Golden Hawk Dies
  211. Metric speedometer
  212. 59 lark 170 engine color
  213. Tire size and rm question
  214. Windshield Wiper Gasket
  215. 1951 cars - any difference between front and rear bumper shape?
  216. Avanti window regulator help
  217. 3/4" Wheel Cylinders
  218. 1950 Champion Brakes
  219. overdrive parts interchange question? (now with pictures)
  220. Details for engine support insulators
  221. Warmed up and a Rough idle
  222. Broken hood hinge, '64 Cruiser
  223. Installing automatic in Champ truck
  224. Avanti Dash Pad Repair
  225. Success !! ...and now some detective work ?? ( frozen T-O brg and clutch disc)
  226. 65 daytona engine swap
  227. Throttle Return Spring
  228. '59 to '61 Frame Thicknesses
  229. Avanti, Hawk and Lark wheel cylinders
  230. Avanti clutch adjustment help needed
  231. Recharging Avanti R-12 A/C questions
  232. Maximum operating temp.
  233. "Grace" needs some help!
  234. Cam for 259 ci. 1964 Champ
  235. temperature gauge reading too hot
  236. Installing C&K rain gutter stainless trim
  237. Hawk Dash
  238. gas tank GUNK
  239. Ford 9" Brakes
  240. Fan blade
  241. 1957 commander front brakes
  242. Adding oil filter
  243. How much play in drag link
  244. T85 and T90 interchange
  245. Tinted Windows on 64 Cruiser?
  246. What type of aftermarket wheels will work on Stude.
  247. Specific Fuel Pump information for 1950 Champion
  248. 61-62 Lark gauge question?
  249. Speedometer cable, pinion gear
  250. 50 Champion reputible mechanic needed.
