View Full Version : Tech Talk
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Studebaker V8 Roller cam steel blanks
  2. still pulling left
  3. avanti inside mirror
  4. Studebaker Novi cylinder heads
  5. Mopar Intake to Stude Adaptor plates
  6. Rotor Location in Distributor when Engine at ING
  7. Don Simmons Email Address??
  8. 1953 commander engine I.D.
  9. Bad voltage regulator?
  10. 12 volt horn on 6 volt system
  11. Roller Rocker arms and Shafts????
  12. Manual Tranny Swap (What's Involved)
  13. auto trans from standard
  14. auto trans from standard
  15. Saginaw steering box
  16. wanted 1st gear start VALVE BODY for 3-bander
  17. 50 2R10 Fuel Pump
  18. 62 GT Hawk
  19. pics
  20. 58 hawk electricial problem
  21. Replacing visor pins
  22. exhaust leak
  23. Any of you guys going to the mueseum Sat eve?
  24. Lark rocker panels
  25. Yet More Intake Manifold Questions?
  26. Stock Stude Rocker Arms and pushrod lenghts
  27. S-10 frame swap on a 53 Starliner
  28. Lionel Stone Aluminum V8 Heads
  29. Radiator 63 Lark
  30. Excessive Oil consumption
  31. 1928 Studebaker for sale $2500
  32. Phantom Front Suspension Kit: First Impressions
  33. Recommendation: Oil Seal Leak Treatment
  34. more repo parts needed
  35. transmission adapter
  36. Sources: Door Seals!
  37. V8 water pumps
  38. Aluminum Heads
  39. Is There a Body Stiffener for GT Hawks?
  40. throttle linkage location on 65-66 help!!
  41. 65 Commander 283 Headers
  42. avanti repaint
  43. Paint Prep
  44. 1951 Champion Carb WE715S
  45. Looking for Casey/Champion
  46. differences between stude 6 and plymouth 6
  47. Point problem
  48. 57 Silver Hawk Engine Problems
  49. hot rodding the skybolt
  50. Looking For Twin Traction
  51. wheels
  52. Red paint for 1962 wheelcovers
  53. Wiper motor wires
  54. 52 V8 How much oil?
  55. 1962 L-6 engine weight?
  56. Synthetic oil and oil leaks
  57. oil cap leak
  58. Ford V8 engine swap
  59. Tranny Fluid or Oil ?
  60. Aluminum Head Questions
  61. Rear of Engine Oil Leak
  62. '60 Lark V-8 crankcase ventilation doohicky
  63. Replacement seat fabric
  64. Transmission/overdrive troubles
  65. List of AR Mag Recommendations??
  66. steering column bearings
  67. Aluminum Head Question Answers
  68. looking for transmission
  69. Hawk steering gear ratio
  70. Rust question
  71. Clutch pedal return spring
  72. Steering gear clearance to headers..
  73. Prop rod to struts ?
  74. Whats the widest rim/tire I can use on my 63 Lark?
  75. REFUEL PROBLEM 48 STUDE
  76. brake shoe
  77. Avanti Rims and carpeting
  78. DOT3 or DOT5 brake fluid?
  79. Smoking Hawk
  80. Mobil 1 M1-203 Oil filter?
  81. 259 cu.--how many quarts?
  82. BRAND NEW STUDEBAKER CAM IN THE WORKS
  83. 64 wagon questions
  84. Ever heard of Waxoyl?
  85. BRAKE PULL ON 48STUDE CHAMPION
  86. 1928 commander piston rings
  87. Automatic no reverse
  88. Flight-o-matic Torque Converter
  89. Engine angle/ elevation
  90. brake lights
  91. Wiper switch swap?
  92. Charging problem
  93. Best way to store a V8 crank
  94. Fluid & lubricant specs
  95. Where to Mount Lap Belts on Speedster?
  96. Convert 6V to 12V
  97. 4 way flashers
  98. I need a little help
  99. What do you think happened?
  100. Hard starting
  101. Dead heater motor?
  102. Rear V8 brake links
  103. Wierd Cold Weather Ignition Problem
  104. 200 MPH Speedometer
  105. New horn buttons for M trucks and '41 cars
  106. R3 cast headers/Saginaw PS?
  107. bench testing a fuel gauge
  108. Spark plugs and gap
  109. ? COLORS TO PAINT 62 HAWK MOTOR
  110. Aluminum heads-nixed
  111. She started! (Carb rebuild in her future?)
  112. Brake lockup
  113. Black Paint
  114. Black Paint
  115. Vintage AC unit for Stude
  116. Lark Inner Fender
  117. parkwood wagon?
  118. Coil Voltage Question
  119. new 63 R2 ownee with Questions.
  120. 42 dash emblem
  121. ENGINE MISS
  122. TRANSMISSION INTERCHANGE
  123. tire size
  124. HELP, OWNERs 55 Stude V8 w/automatic tranny DG250M
  125. Exhaust - or No Exhaust?
  126. Speedometer adapter needed?
  127. alternator
  128. heater motor assembly
  129. Weird short
  130. Could someone double check me on this?
  131. NEW MEMBER
  132. Auto Transmission Cooling
  133. Rubber
  134. 3spd w/OD
  135. What was the last year for the Champ?
  136. 1954 studebaker starlight commander
  137. Carburetor rebuild tips?
  138. Paint Program
  139. Cowl Seal
  140. Oil Filter
  141. Appraisal
  142. Usable Tire Sizes AND Sude Avanti Bibliography
  143. Compression for flat 6
  144. Carb and Distributor Questions
  145. Wiper Switch
  146. Tire size / 1950 Starlight Champion
  147. oil leak
  148. Air Pocket in Heater Core
  149. tach wire setup
  150. Another carburetor question
  151. WTB: T86 w/ OD for '54Commander
  152. rear axle bearings, shims
  153. Auto Transmission
  154. fixed roof wagonaire to sliding roof?
  155. Windshield Wiper Motor
  156. Rocker Replacing
  157. Engine Paint Colors
  158. 52 Champion - How will Radials work?
  159. disc brake cylinders
  160. small block chevies in a 50 champ
  161. 51 Champion Emergency Brake Cable Replacement
  162. Heater Control valve
  163. Tire size
  164. Rear Axle Bearings, Shims Revisited
  165. customizing 54 commander
  166. four barrel manifold
  167. Will a Ford Ranger 5 sp. OD trans...
  168. Help !! How ?? gas tanks with dried varnish
  169. need info on head for flat 6
  170. shaving a stude head
  171. Looking for raw e-brake cable
  172. cylinder head for 170 ci six.
  173. Plugs fouling after rebuild.
  174. good mufflers for flathead six with dual exhaust?
  175. PAINT SCHEMES
  176. Exhaust fumes
  177. axle tag ID
  178. Rear axle seal P/N#
  179. wheres Sonny
  180. my 54 commander project updated link
  181. Bench to Bucket?
  182. V8 Oil Consumption Revisited
  183. 1929 Dictator?
  184. Aluminum Head Tech
  185. OMG! Possible mopar wheel on my Stude
  186. Plug wire question
  187. TUNED headers on 289
  188. Alunimum wheels
  189. Flanged axle change info
  190. New Intake in the making
  191. 50 Starlite Coupe
  192. restoring '51 Champion horn button
  193. Bullet Nose on 51 Champion
  194. early column shifter seals
  195. Inline 6 v8 automatic
  196. 1950 Champion, Frt. Stabilizer kit.
  197. fuel gauge wireing
  198. T86 parts
  199. Mustang II for a 53-54 Loewy coupe--which ???
  200. 1957 Golden Hawk Trunk Seal
  201. Fast Flashing Turn Signal on Speedster
  202. stude truck help
  203. New Member, Need Your Help!!
  204. Copper Head Gaskets
  205. PCV retro-fit for '63 289
  206. Radiator Overflowing
  207. suspension and frames
  208. 50-51 Bumper question
  209. Advice requested on Stage 1 restoration
  210. 51 (4) Door G10 W3 Door Kick Panels
  211. Avanti Tilt Steering
  212. 327 Studebaker engine?
  213. 60mph/3000 rpm what is my axle ratio?
  214. is this true?
  215. studebaker Christmas
  216. Door screws
  217. R2 differential gear options/source
  218. Lubrication Question?
  219. Ancient Electrical question
  220. Shortblock 232 problem
  221. 64 GT Hawk Serial Number
  222. stearing wheel puler
  223. testing a coil
  224. 55 REAR AXCEL
  225. 52 Champ - Ross Steering Box needs rebuild???
  226. 48 truck rims/frozen engine
  227. rebuilding power steering pump
  228. AC under dash unit
  229. carter bbd
  230. 1965-66 valve covers
  231. advice requested on new wiring harness
  232. gear oil for windshield wiper tran
  233. M5 Bumpers
  234. Plugged differential vent
  235. Color of gauges
  236. Stuck In Park
  237. '47 M5 length & width
  238. 1956 Power Hawk windows
  239. V8 Camshafts
  240. Flathead and thermos
  241. front end drum to disk kits
  242. 6 Volt Charging Problem
  243. Calipers
  244. SPECIFICATIONS ?
  245. Master Cylinder Repair Kit 51 Studebaker
  246. Looking for hand brake assembly for T-98 trans
  247. 1956 powerhawk steering wheel
  248. 1955 President wiring
  249. Rubber Floor Covering
  250. 1961 - 1964 6 cyl ov engine
