View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Brake valve/check valve/sensor part#
  2. Temp sender
  3. '63 Lark hood hinge access? Help!
  4. engine/trans swap
  5. 1966 Water Pump
  6. Part Number 526135 coil spring
  7. 1953 tire size
  8. Today is not such a perfect day for our Stude :-(
  9. Fuel Sending Unit $170?! Option B?
  10. Transmissions
  11. Finally -- Unstuck !
  12. REAR ENDS
  13. Still available?
  14. M 5 brake cylinders
  15. V-8 valve guides
  16. Armrest for 54 Champion Coupe
  17. A recommendation on carb rebuilding, T-bow
  18. Fuel Sending Unit Question
  19. timing cover & R/main seal question (with picture)
  20. 1950 COMMANDER BRAKE SHOE QUESTION
  21. Front anti-sway bar fit problems
  22. 6 volt solenoide
  23. Power Steering shaft seal: Install
  24. Flightomatic GRRRR!!!!
  25. 63 V8 motor mounts
  26. Exhaust heat riser valve
  27. Fuel Level Sender Ohms for 1950 2R10 PU
  28. '50 Champion interior and repaint references
  29. overheat/cool down
  30. Poor Fuel/vapor Lock ????
  31. Spring info needed
  32. 61 hawk bellhousing
  33. Limited Edition Cruiser (1964)
  34. pics??why not??
  35. Urgent question - Gas leak?
  36. 1950 COMMANDER BRAKE BLEED
  37. back seat
  38. stuck open intake valve 50-champ blt nos
  39. Brake question
  40. '51 Champ Trunk Handle Lever
  41. Which water pump should I buy-new or rebuilt?
  42. C/K hood latch(revised 10/5/10)
  43. MZ 4157 starter
  44. smoking generator
  45. Lark window regulator problem
  46. T86 cluster gear tooth count
  47. Outer pin bushings
  48. 51 Studebaker Champion Engine
  49. Master Cylinder Question
  50. Avanti Power Steering Hose Replacement
  51. Siganaw steering box rebuild, 1953
  52. Steering box
  53. Hawk Fiberglass Fenders
  54. 289 oil leak, rear main oil seal?
  55. Hood cracked
  56. Commander Seat Replacement
  57. Engine ID
  58. Why is it?
  59. 7" rims?
  60. starter bolts
  61. Air Cleaner Oil
  62. Fuel Pump- What do I have
  63. 6v Delco Remy Generator Number: 1102700
  64. SQUEALING AVANTI STEERING COLUMN
  65. AVANTI DASH BULBS
  66. Avanti windshield/back glass water leaks
  67. Casting wire
  68. What would happen if....
  69. My Champ needs a bra
  70. What is this cam?
  71. Custom Engine Castings
  72. OIL GAUGE LINE
  73. 62 convertible paint formula
  74. Brakes
  75. 51 Champion Radiator
  76. 55 president conversion
  77. Interchangable parts
  78. '40 Champion breaks. Thud and hard to the left
  79. Small Block Chevy Conversion -Newbie
  80. NEED WINDSHIELD VISOR
  81. Avanti Gas Cap Update
  82. Rear window glass not fitting....
  83. New fuel pump issue
  84. Intake manifolds
  85. Where to get freeze plugs
  86. Power Steering Hose
  87. Torque question
  88. Avanti power windows
  89. 4-5-6 Larks
  90. rack and pinion steering 53 c coupe modified
  91. crossmember removal
  92. rear oil pan gasket
  93. First time transmission lurch
  94. size of pressure pipe from SC to fuel pump
  95. Voltage regulator for Avanti
  96. Bat wing crossmember
  97. Convertible front springs
  98. First day out for the '64....
  99. Need Parts for V-8
  100. 3588S Pump Seal
  101. Avanti Borg Warner T-10
  102. Motor mount measurements
  103. R2 Carb Flooding
  104. Avanti Carpet
  105. HEAD LAMP PROBLEM
  106. leaf springs
  107. Champion engine weight
  108. Parts/numbers needed
  109. Champion oil relief valve
  110. Crankshaft thrust washer orientation
  111. 40 champion wheels
  112. Heat Riser Delete
  113. More electrical woes
  114. Ring and pinion gear question dana 44
  115. Drip rail chrome
  116. wcfb air cleaner
  117. Single or double?
  118. What is it now? Carburetor? or fuel pump? engine wont idle correctly
  119. Champion 185 deck height--compression
  120. Left hand lug nuts to fit Ford rims? Or another solution?
  121. Champion oil pump gear
  122. Hawk Trim Holes
  123. rear spring dates
  124. Hydrovac rebuild for dicc brake Hawk
  125. Rust Repair
  126. 50/51 Champion Convertible w/Lincoln MarkVIII from Canada?
  127. tire pressure
  128. 1961 oil pump overhead valve 6
  129. weatherstrip replacement tip
  130. 60 lark mirror location
  131. 1960 Studebaker Lark Generator Problem
  132. 259 hesitation at cruising
  133. 1951 Champion w/o heater
  134. R2 fuel return line
  135. early flex plate
  136. Stainless Steel Trim Restoration Tips
  137. Power Steering problem
  138. 8E5 truck brake questions
  139. Carter AS adjustments
  140. GT Hawh Torque Boxes
  141. Pinion Gear Question for 1940 Champion
  142. vacuum loss
  143. 1557672 - Rear Shoes for Front Disc Cars - GOOD PART NUMBERS FOUND
  144. Edelbrock Carb possible issues?
  145. If any of You Geniuses can explain this....
  146. Throwout bearing
  147. Which type valve seals ?
  148. Engine block to engine stand
  149. truck wheels
  150. Ugh. Need to tackle the power steering system, again
  151. Runs good... Then quits in the middle of the road!
  152. Piston ring question
  153. V8 Exhaust manifolds
  154. Champion engine # ID
  155. Silicon brake fluild
  156. No Engine ID
  157. GT Hawk tach sending unit ID
  158. distributor for an r-2 avanti
  159. 4-5-6 Lark Bell Crank Re-build
  160. 57 Silver Hawk 6 Cly needs help
  161. Tail Light gaskets for 1957 Champion
  162. Bellhousing brackets on Avanti auto.
  163. radio suppressors
  164. I need some help and ideas quick please! '66 is dead...
  165. Brakes: M-16 HD wheel cylinder kit
  166. 61 Hawk Turn Signals
  167. part wanted, 63 Avanti resistor for instrument lights 1557964
  168. Subtle lope or lug w/50 Starlight
  169. Good news or bad news?
  170. Proper way to put the radiator
  171. Avanti engine noise suppression
  172. Save those wipers!
  173. Automatic Drive Transmission Tools
  174. reassembling engine
  175. 6 cyl compatability
  176. power steering valve leak question
  177. Valance needed
  178. Need help in making an updated plate for 1950 Commander Automatic Transmission
  179. heater/defroster hose on 1950 Champion
  180. Blasting Media
  181. starts, but won't run, or runs but can't start
  182. R2 sticks on fast idle
  183. M5 ignition lock cylinder help
  184. 4-5-6 Lark Rust Repair
  185. Piston pin pinch bolts questions
  186. 1955 Commander Coupe
  187. Any difference on 1950 Commander Automatic Steering Colum VS. 1951 Commander Steering
  188. Fuel Pump
  189. Need a Studebaker OHV 6 oil pump
  190. Flipping upper inner control arm pivots?
  191. 55 E12 Pickup HD Differential Question - Choices?
  192. Sparking block when reving??
  193. positive post on the coil
  194. 51 Champion Distributor Removal, Cleaning Water Passages
  195. Tach trouble
  196. Roaring noise when driving from RF on my '64
  197. 1959 Lark auto trans fluid.
  198. Is it a chamleon? No, just a Studebaker's mid life change.
  199. wouldn't ya know it!
  200. Avanti power steering, hoses, control valve, power piston.
  201. '50 champion side glass issues
  202. M5 dash and back light help needed.
  203. Studebaker 6-170 motor
  204. 1964 Door Window Trim
  205. Electrical Rust Removal
  206. Rear Main Seal 289
  207. Avanti Leather Redying Thoughts
  208. dwell 289c.i.
  209. Fuel System: R-1 TEL and the quest for driving bliss.
  210. Steering 62 hawk
  211. Lazy
  212. Cast steel truck wheels
  213. Tach test
  214. oil pump
  215. Left/right valve rocker assemblies
  216. Rear Freeze Plug?
  217. 55 truck trans to 64 truck interchange ??
  218. If V-8 head interchange side to side, why not...
  219. 63 gt hawk transmission rebuild problem
  220. 51 V8 Air cleaner question
  221. 53 coupe windshield washer
  222. Part Needed
  223. Truck hand brake cable differences??
  224. Suspension parts interchange??
  225. How do yu take out the...
  226. More on Avanti Power Steering
  227. Turner Brakes Question?
  228. '51 Hood release cable
  229. 63 Avanti mirrors
  230. Metering Rod Retainer Clip? Carter AS2876
  231. 1947 170 Champ engine...how many bell housings?
  232. Sway bar bushing and Parts Questions and Rims F.S.
  233. 64 Avanti Solenoid wiring?
  234. Wheel Colors
  235. Wiper Motor Question
  236. 1952 Champion water pump
  237. Throwout Bearing grease attachment tube.
  238. Engine identifictaion
  239. 1961 Silver Hawk front clip swap
  240. Electronic ignition
  241. 4 bbl carb
  242. Questions re: pitman arm/power cylinder (bendix) 64 cruiser
  243. Offenhauser Intake ?,s
  244. Engine Swap 1962 Lark Advice
  245. Weight and dimensions
  246. Air conditioning help
  247. misfire that won't quit
  248. Distributor restoration service?
  249. Quick steering arms for 63 Avanti
  250. Plug gap for electronic ignition
