View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. belt drive system on a R1 1963 Avanti
  2. Found my "manifold in a box" kit:)
  3. Can you identify these lenses?
  4. brake pedal
  5. Avanti Gasoline smell inside the car
  6. steering column removal
  7. how do you take the radio out to get the wood grai
  8. 4V Intakes
  9. 11 inch brakes on a 50 champion
  10. 63 Avanti paint formula?
  11. A circle over a rectangle = swirling ??
  12. 57 Slvr Hawk Rear Shocks Issue
  13. 57 Hwk Air Cleaner wanted or suggestions
  14. EXHAUST MANIFOLD HEAT RISER
  15. Throttle shaft arm loose
  16. Installing script on trunk lid
  17. More T-98 problems
  18. Electronic Ignition Options
  19. Where are all the Carter WCFB/AFB 4-bbls?
  20. 77 Main Bearings V-8
  21. Lark Frame Interchange
  22. Steering wheel interchange
  23. Can you bend a hood prop rod?
  24. Frame/Springs ride quality
  25. trans fluid
  26. studebaker tag
  27. Anyone interested in additional ZDDP...
  28. Should I replace the frame, or the frame rails?
  29. Anyone need 4 STUDEBAKER KELSEY HAYS 16 X 3.5O 5 X
  30. Help!!! on Chevelle Carb Problem
  31. Land Cruiser carpet
  32. 62-63 Lark front seat upholstery question
  33. FUEL PUMP
  34. 289 engine overhaul kit/electronic fuel pump
  35. Water pump drive pulley
  36. How long should a 6 volt battery last?
  37. '49 2R5 paint question - tusk ivory
  38. Mustang II clip on a '57 Hawk (big pictures)
  39. speedo cable
  40. Stuck Distributor Drive Gear
  41. Avanti door hinge repair
  42. Pertronix Work With My Distributor?
  43. Got my Lambert LED Coversion Kit today
  44. Dynamat
  45. '40 Turn signals. What do you normally use?
  46. gt hawk bump steer
  47. 1950 Champion -severe brake noise
  48. Long-term on Jack Stands
  49. Looking for a Avanti Frame in CA.
  50. Headlight Ring Wanted
  51. 62 lark window regulater
  52. Steering power cylinder
  53. Avanti frame X brace
  54. Squeeks and Creeks
  55. flat head dressing
  56. How to remove SS rocker trim
  57. Wiring Question 82 Avanti
  58. Rear End Length
  59. Tire recommendations
  60. Brake check valve
  61. Correct paint/look for 1950 Champ Custom wheels?
  62. Engine Identification
  63. Avanti tachometer
  64. Throttle Linkage
  65. Ignition timing 63 Avanti R1
  66. vacuum gauge reading, Avanti 63 R1
  67. Positive or negative ground?
  68. R-3 parts list.
  69. Spring rates
  70. Window crank handle spring..help me remember
  71. Avanti Resin base?
  72. What exactly is the Amp gauge telling me?
  73. headlight ring gasket 62 hawk
  74. 51 Champion Window Handle Removal
  75. 51 Champion Steering Wheel and Horn
  76. What's my plug gap?
  77. head bolt prep
  78. Lark Antenna 101
  79. 1964 Hawk factory foglight bracket?
  80. Weird lights...
  81. 2R5 emergency brake hookup
  82. Sparkplugs for mopar conversion
  83. the 64 hawk
  84. Brake line kit
  85. Flightomatic Kick Down Rod
  86. 1962 Lark Dash Cover Installation - Update
  87. excessive oil pressure
  88. AC and springs.....
  89. Core plugs
  90. Using oil after only 3K Miles
  91. compression test Avanti R1
  92. Carter WCFB ?
  93. 1962 GT Hawk
  94. 3EE battery
  95. battery draw?
  96. window type distributor
  97. 62 H Disc brake/dual master cylinder conversion
  98. spark plug gap
  99. Thermostadt & Rad. Cap
  100. 62 Hawk BAD CONDENSOR & Excel Pump
  101. Rear sway bar
  102. Completed 2000 miles NY to Florida-Champion
  103. 62 hawk grommets
  104. How does an oil bath air filter work
  105. Whiny overdrive
  106. Fuel Lines 63 Lark R-1
  107. Well! I took Bige's advice
  108. 61 studebaker lark
  109. Wheel Rims From Ford/Chrys
  110. Hydrovac kit
  111. 1955 pres 4dr
  112. Avanti AC Rheostat
  113. 66 Cruiser isn't charging correctly
  114. Crane Cams XR-I Left me stranded, thanks AAA
  115. WTB Front vent window 53 Champion
  116. Looking for Radio Bezel or Overlay
  117. '50 Ch Regal Delux, 2 dr -want to make convertible
  118. 51 champion brakes
  119. 59 water outlet on 289
  120. 63 Avanti truck release handle
  121. My 63 Avanti
  122. Dana Seals #'s
  123. Head casting number
  124. R3 valves and hardened seats
  125. 1 & 1/4" whitewalls
  126. T10 rebuild kit
  127. champion 185 felt seal
  128. How easy to lift the body off the frame
  129. Heart transplant
  130. 62 Hawk gas gauge
  131. 1957 President colors
  132. bead roller question
  133. manifold heater valve, Avanti R1
  134. BRAKE PEDAL HARD ON "63" AVANTI
  135. Torque converter for an R2
  136. shop manual for 59-60 Studebaker
  137. Non-TT reverse spin?
  138. 63 Avanti interior
  139. Pull complete drivetrain or just the engine...
  140. Damper vibration?
  141. A/C delete complete, now....
  142. How To: Add seat belts, for cars '62-up
  143. Kent -Moore pilot studs
  144. Commander 3 speed floor shift
  145. Power steering hose
  146. Lark Overdrive Conversion
  147. Steeltechsolutions
  148. Ross SL steering leak
  149. Need battery hold down for 1950
  150. 64 Hawk steering stabilizer
  151. Speedster Brake Drag
  152. Looking for Ranco A10-6490-000
  153. Standard Trans Question
  154. another head question
  155. Spring loaded 1964-66 hood ornament?
  156. Saggy front end
  157. Hi-Tech Studebaker Parts Closure
  158. Oil filter
  159. Avanti Frame Rail, Replace or Splice?
  160. 50 Starlight Coupe help needed
  161. 1955 President Automatic Transmission V8
  162. The $2K Transmission and Floor Shift Conversion
  163. 50/52
  164. Opinions Please
  165. ZDDP.........no stress
  166. Clock installation on Champ T-cab
  167. '40 non working speedo.
  168. Whats this button do?!...
  169. exhaust hangers
  170. Pretty isnt it!
  171. 62 Hawk roll bar inquiry
  172. 2 R 5 Radio
  173. Need help to id transmission.
  174. replace wheel lug
  175. 1962 Lark VI fusebox?
  176. LOWERING A 1950 COMMANDER
  177. Speedo to tranny question.
  178. Throw out bearing question
  179. A arm Torque specs?
  180. cleaning engine before put to everyday use
  181. Flanged axle-bearing removal?
  182. Rock Auto does well again! [wheel bearings]
  183. Emergency brake cable boot
  184. Ultramatic conversion
  185. Question on n.o.s. valve cover gaskets.
  186. Speedometer Cable Question
  187. Avanti Gas Tank ..Work in Progress
  188. Suspension question
  189. 259 V8 Identification
  190. Bat wing crossmember in 53?
  191. Need advice - '63 Lark horn wire replacement
  192. Stock WCFB jetting question?
  193. Oil filter
  194. Transmission Question
  195. Prime the Fuel System?
  196. Quick ? (Edited)
  197. No Brakes!
  198. 51 Trunk Lid Question
  199. Help with oil primeing an engine?
  200. Avanti Fuel Tank Capacity
  201. what carburetor to use?
  202. Viscous fan experience?
  203. Best penetrating oil
  204. Polara Brake Booster
  205. cleaning up the inside of an engine
  206. Found a spare tire for the Avanti
  207. Got brakes!
  208. rear frame bushing
  209. '49 2R5 horn wire
  210. Now it won't idle...
  211. Hawk window removal
  212. Conversion to horn ring for 66 Commander
  213. Timing with pertronix
  214. 1961 Lark taillight lens
  215. 3 Studebaker Overdrive Transmissions 4 Sale
  216. Side pipes
  217. My starter won't
  218. master cylinder adivce needed 4 wheel disc
  219. 52 commander master cyl. swap
  220. Valley cover gasket
  221. Correct bolts to install starter on V8 (E7 pickup)
  222. 53 coupe door glass and channels
  223. dana 44 differential
  224. Converting a Dana 44 to PosiTrac
  225. remove windshield wipers from 63 avanti
  226. overdrive help
  227. Distributor Installation
  228. DG150 vs DG150M
  229. Stuck engine
  230. 63 avanti ignition circuit problem
  231. carb kits and quality
  232. 1950 bulletnose grille panel Champion/Commander?
  233. proper front-end greasing
  234. Avanti Gray Paint
  235. Gasket replacement
  236. PH Saggy butt - Rear springs needed?
  237. Avanti Rear Window
  238. Stalling problem on 170 cid OHV 1963 Studebaker 6
  239. Afertmarket AirCleaner for WCFB carbs!
  240. sparkplugs
  241. Which wheel cylinders is which?
  242. Rod bearing question
  243. hawk vent window seals
  244. rough ride 62 hawk
  245. Why so hard??
  246. DOT 3 or DOT 4 brake fluid?
  247. Avanti Exhaust Tips
  248. Car on blocks...
  249. Will they fit?
  250. Modifying a R1 engine to Accept a Super Charger
