View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Gear Oil for "New Process" 5 Speed
  2. 65-66 Sudebaker with Chevy engine
  3. Repairing a Lark lock cylinder projection
  4. Reclining seat handle
  5. previous post on s10 frame "sacramento"
  6. 64 Hawk dash/instrument panel
  7. Got spare Lark glass?
  8. Clock in Tach hole?
  9. electric power steering
  10. Why did I have to remove it?
  11. A-arm bushings, which type?
  12. 51 Gas Door Guard
  13. 232 vs. 259 bell housing..!
  14. Heatsink
  15. Four wheel disc & equalizer valve????
  16. power steering in 1961 Champ
  17. mobol oil Delvac
  18. Gen brushes
  19. Gas Guage
  20. 1952 2R6 pickup
  21. connecting rod bearing torque
  22. Power steering controle valve 62 hawk
  23. OIL FILTER HOUSING GASKET ?
  24. voltage regulator
  25. 1962 Hawk Horn Button
  26. How long, really?
  27. Dynamat
  28. Anybody need a back window for a hawk
  29. Traction Masters--- The real deal - Photo added
  30. Dragging front brakes
  31. Transmission cover paint color?
  32. Alarm Problems
  33. Little help here, Please!
  34. 1952 2R6 pickup
  35. Steel stude main caps 2&4 bolt
  36. flathead 6 oil pump
  37. Stamping/engine # ID
  38. Leaf spring bushings and fan clearance
  39. 4spd bellhousing
  40. 1958 Packard Hawk Radio
  41. Rear brake parts sizes
  42. Shifting problems
  43. window rubber?
  44. Need help trouble-shooting gas gage sender
  45. Dash lights
  46. From the Archives #24 (Avanti Bonneville)
  47. Anti-Theft Strategies
  48. Pre-War Body Tag
  49. Dana 44 Axle Parts
  50. Dashboard intrument questions
  51. needing help in LA
  52. Steering Wheel Replacement
  53. Radio Lens Numbers
  54. Trans interchange?
  55. parts wanted
  56. fram air filter
  57. dana 27 in a hawk?
  58. 51 C-Cab color
  59. Fuel Pump Kit
  60. AN brake systems
  61. No oil filter
  62. R2 Avanti mpg
  63. Speedster Junction Block
  64. Driving me crazy!
  65. can a single wire fuel sender be used with 2 wire
  66. electrical mixup
  67. Annual maintenance and other questions....
  68. '37 engine rebuild questions
  69. crank bolt head size
  70. 64 Daytona sedan w/shield source
  71. Any ideas on how to get a power window down 55 pre
  72. rear end gears
  73. Fuel Pump fittings
  74. Transaxles
  75. air flow
  76. shocks - 63 gt hawk
  77. Dropping the frame out from an Avanti II
  78. Hog Troughs and Back Rails
  79. 4 barrel air cleaner
  80. Nate Need Shock #
  81. Cool/Heat: NAPA heater motor #655-1020
  82. 63 Lark Steering Column Help
  83. Stuck clutch
  84. Brake booster
  85. Armrest riddle!
  86. '54 Commander Manual Transmission Question
  87. v8 rods
  88. Fuel Pump fuel filter for 1964 6 cyl.
  89. Door hinge screws
  90. Water pump bearing.
  91. 52 front brake parts?
  92. Flanged axle disassembly question
  93. Avanti 63, Distributor surprise!
  94. Putting AC in a 55 sedan
  95. Dana 44 question
  96. Master cylinder interchange
  97. Repairing a conv top frame? Pics Added
  98. M5 frame info needed
  99. Overdrive on a 6 cyl Hawk GT 63
  100. Starter ID
  101. WIRING PROBLEM ON 50 COMMANDER
  102. Golden Hawk Fan Spacer
  103. Interchangeable parts??
  104. Weight of Hawk body shell
  105. E40 and E45 Trucks
  106. 51 C-Cab color
  107. 63 Avanti, foot operated washer pump
  108. Avanti 63 parking light
  109. 63 Avanti, washer bag
  110. The day Stella quit running
  111. What's wrong with this tail light?
  112. Is this a problem with the ignition switch? SOLVED
  113. Fuel pump
  114. Master Parts List
  115. jump start 6 volt system
  116. Trunk Mount Battery Cable
  117. 53 landcruiser rear axle options
  118. Drive Shaft Vibration/driveshaft
  119. '40 Champ coupe- help!
  120. Ignition switch post question
  121. Integral PS...........dead horse time
  122. Overdrive keeps short'in out
  123. Starter Bendix question
  124. FMX conversion
  125. Sticky lock cylinder
  126. 50 campion
  127. Dash switch retaining nuts
  128. "63 Avanti TT axle
  129. Pitfalls to look for...?
  130. Champion "script" front fender '50 Champion
  131. Avanti II Tip
  132. 1963-64 Avanti Wiper Blade Holders
  133. Champ Spare Tire
  134. '56 Hawk Clutch tool
  135. 63 Lark trunk lock clip
  136. Shift Lever
  137. Frame schematic
  138. 87 Avanti questions
  139. Old Tire Danger
  140. converter ring gear teeth - starter bolts
  141. Question in Center Force Clutch Installation
  142. 232 Rebuild; What Makes Sense?
  143. 1951 Gas Tank ???
  144. Okay, need direction on ROD, bell crank to carb
  145. Dash spray
  146. M5 Steering box, Help
  147. Avanti bogs down under full throttle - update
  148. ENTERER PAINT COLOR
  149. transmission swap
  150. Custom spark plug wire building, anyone got tips?
  151. '63 Avanti Grill
  152. FOM selector shaft leak ?
  153. 63 Avanti R1, alternator
  154. Door Panel Foundation
  155. 55 Champion with auto and Ac at idle
  156. Odd thoughts on future OHV 185
  157. Paint or spray dye for steering column ??
  158. My project from hades
  159. License Plate Bracket
  160. 57 hawk interior dome light problem ?
  161. Upholstery for 1953 Champion Regal Coupe
  162. JR
  163. Headers
  164. 185 Rebuild
  165. 1964 hawk trunk lid
  166. engine serial number location
  167. 3 wire overdrive solenoid
  168. New style anti-sway bar pictures?
  169. Torque Converter Drain-back
  170. Antenna
  171. Avanti F-o-m leaking
  172. Windshield
  173. OD unit is "stuck" in gear.....??
  174. 52 front springs
  175. PS bracket
  176. Heat Resistant Coating(s)
  177. WW2 Carburetor Help
  178. transmission removal
  179. 1/2 ton Champ 6e7 brakes
  180. Avanti 63 window regulator
  181. 1/2 ton Champ 8E-7 steering
  182. Painting My Steering Wheel
  183. FOM surprise!
  184. Avanti R1 alternator wanted
  185. Spark Plug to Distributor wiring diagram?
  186. Carb Leak
  187. Things to take to York
  188. UGH! Now a spinning starter...
  189. It Runs
  190. sell
  191. Pulling the body tomorrow.
  192. dash veneer?
  193. ZDDP question.
  194. Keep blowing softplugs
  195. Proper heater flow & hose routing Lark guys
  196. 64 cruiser heat-riser: do i need it? (NoCal)
  197. back-up lights?
  198. Vacuum line connections
  199. Nitrogen gas springs for hood and trunk
  200. 64 Daytona tach
  201. Brake pedal
  202. Paint Question
  203. CARTER CARB ID
  204. defroster switch
  205. Need good radio for 1950 Champion, or radio parts
  206. tach
  207. Choke heat tube
  208. OIl Pressure Gauge on '55 Commander
  209. Lark Window Regulator
  210. JT Dampner on Short Crankshaft
  211. tips on engine and trans install
  212. 1948 Commander Starlight.
  213. Horrilble hesitation when takin off from a light.
  214. Gas Gauge sending unit
  215. 63 vs. 64 supercharger pulleys
  216. what the....?
  217. Help-Blower Install location in 57 Silver Hawk
  218. 62 Lark 2dr. interior panels question
  219. Third key needed?
  220. Which Edelbrock vacuum port?
  221. Distributor cap for a 63 Lark R2
  222. Commander front springs
  223. Seatcovers
  224. Carb
  225. 8E-7 steering knuckle tie rod
  226. 63 Avanti master cylinder.
  227. 63 6 cyl. clutch
  228. installing champion engine
  229. What size spare rim and tire fits Avanti
  230. convertible trim
  231. R2 carburetor Edelbrock Conversion
  232. 1956 C/K windshield and rear window trim
  233. CHEWED UP BENDIX
  234. urethane paint vs. rubber
  235. What is that stuff called?
  236. SBC TBI with 700R4 in a Stude sedan
  237. 1951 Truck No Spark
  238. Cleaning 1950 Champion oil pan
  239. '54 k body headliner removal
  240. Bias ply tire width
  241. 1931 Studebaker Model 54
  242. Water Pump for 63 GT Hawk
  243. Can you rebuild Lark rocker switches?
  244. ' 63 Avanti throttle kicker
  245. question? will speedster foglamps fit a gt hawk?
  246. C/K rear tire clearance
  247. Floor shifter
  248. Delco "window" distributor tube
  249. Delco "window" distributor on a 63 Avanti.
  250. belt drive system on a R1 1963 Avanti
