View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. T5 in a studebaker
  2. S.I. Quick Steering Arms
  3. creative bucket seat ideas for C/K body
  4. Improving Hawk Steering
  5. Parking Brake Warning Light Installation
  6. Bullet connector diameter?
  7. Brake issue
  8. Sealing a gap
  9. Need Tire Size Info.
  10. Alternative to Avanti hog troughs
  11. 1958 packard supercharged on craigslist
  12. Distributor ID help
  13. 53 Starliner kickdown switch
  14. Replacing fuel lines
  15. Aftermarket AC in a 53 coupe
  16. Heater Hose Location on 1930 Erskine/Studebaker Mo
  17. rear axle assembly
  18. HOT WIRING MY 1950 COMMANDER
  19. Cobra brake breakin pictures (RP)/rotor seasoning
  20. Window Felt (catwiskers)
  21. What color ??? 53 Instrument hoods
  22. Floor shift manual backup light switch ???
  23. firewall suspended pedal assembly
  24. Anyone put a 4 speed in a '60 Lark??
  25. Hanging doors
  26. tubless rims for 56 2E truck
  27. Big cap HEI on a SBC in a Stude?
  28. Still floating ideas here. Mopar 318 in a Stude
  29. Still no ignition - frustration city!
  30. T-5 to Truck
  31. fender fodder for fiftyfour fifty?
  32. 1970.......Southern California
  33. Spare Tire mount 1963 Lark
  34. front fenders 55K
  35. parts car
  36. new to stude
  37. Fuel pump
  38. Success! Dang, it feels good
  39. water pump
  40. 6 cylinder lark questions
  41. water pump
  42. front and rear windshield glass
  43. 185 six overhaul questions
  44. windshield installation
  45. 63 Avanti rear end tag
  46. Floor Pans
  47. Help! I'm locked out
  48. Dave Reid
  49. Overdrive Puzzlement-Locked out reverse.
  50. BALL JOINT QUESTION
  51. Question about rocker arm shafts.
  52. Headlight arrangement
  53. what's a lark really weigh?
  54. Bell housing alignment pins question.
  55. Flightomatic rebuild
  56. Fitting Holley 350
  57. generator help
  58. What happens when you lube tapered axle ends
  59. Tips/advice before buying a 51 Commander?
  60. compression test
  61. C-K windshield gasket ??
  62. Stock break system/ Shocks
  63. Having trouble with getting off brake line hose.
  64. 63 Avanti restoration
  65. Correct engine color
  66. Left or Right
  67. Bleeding brakes.
  68. Wipers won't stop or park
  69. But the frame..... Oh MY!
  70. 185 six, cylinder head question
  71. horns in 1952
  72. Alternator in 63 Hawk
  73. You cannot get around refurbing Stude gas tanks
  74. Driveshaft Mod 57 Hawk
  75. Avanti II Shifter on ebay 4 speed auto
  76. Avanti hood latch, springs etc
  77. Replacement starter for lark
  78. fiberglass hood
  79. Ross TL steering box
  80. Body off frame
  81. Steering box seals?
  82. Hog Troughs....
  83. IIRC
  84. GT Hawk problem areas
  85. Avanti II wiring diagram
  86. Rebuilding the hood on a '54 Champion
  87. Stude with a 6.1L Hemi
  88. 1963 Avanti Original Literature Available
  89. F/S: Avanti Red and Black (Salt and Pepper) Carpet
  90. 63 Avanti spare wheel rim
  91. 4 speed conversion
  92. early pertronic - senses distributor points cam?
  93. 57 Commander Brakes Please HELP!
  94. timing gear
  95. FOM - floor shift
  96. More heat - 62 Hawk
  97. carb main jet size '57 golden hawk
  98. Weasel fuel pump
  99. Installing hub on front of crankshaft ?
  100. Volare front end under Chevy or Stude V8?
  101. Defroster duct
  102. Screaming brakes on my 65 Commander
  103. Long Term Storage
  104. Using Grant steering wheel
  105. Defroster Imbalance....solution(s) ??
  106. Dwell...What did I do wrong? VERY BAD NEWS
  107. National Inspection Services
  108. Dissassembling leaf spring packs?
  109. Vacuum Advance on 1950 2R10
  110. F/S: NOS "Old" Flex-A-LITE for Avanti & Stude V8
  111. 57 Commander Heater
  112. 1961 lark engine color
  113. Brakes locking up
  114. 1963 Lark Master Cylinder
  115. Adding push button starting
  116. Pulling input shaft bearings
  117. F/S: Avanti & V8: Lightly-used FLEX-A-LITE Fan
  118. Tie Rod straightening
  119. Front disk Studebaker kits
  120. Avanti Car Cover
  121. Can some one help me motor mounts
  122. wheel cylinders
  123. AC help/advise
  124. Starter problem 56 Golden Hawk
  125. 62 hawk 350 conversion
  126. Need part # help please
  127. truck only steers to the left
  128. Interior window molding paint for '50 Champion
  129. Banjo steering wheel
  130. Ah, the joys of engine swaps
  131. Color of 1957 Packard Clipper Oil Canister?
  132. Heat Indicator & Gauge
  133. Prestolite ALE 5003 parts
  134. Wiring connections to '55 coil?
  135. Need Steering help!!!
  136. 63 Avanti bumper bolt kit
  137. Custom Driveshaft for Avanti w/ 5 speed
  138. GH steering column question
  139. Battery cable on 63 Avanti
  140. Windshield washer on 63 Avanti
  141. Powder coated parts paintable?
  142. Bear Claw Door Latches
  143. Power Window question
  144. Rewired-now flasher weak/slow
  145. Avanti II brake booster
  146. Pertronix Ignition on 63 Avanti
  147. For 1963-64 R-2 Engine Cars
  148. Engine: Aftermarket intake manifold
  149. Broken wheel hub stud--how fix????
  150. 50 Stude Champion Taillights?
  151. Head gaskets painted silver.
  152. Chevybaker pass.side exhaust manifold question
  153. Gallery plug ?
  154. Overheating Mystery
  155. crank shaft pulley
  156. Wheel Bearing Seal question
  157. Dana 44 pinion bearing size
  158. turner brakes
  159. Truck Body Interchange?
  160. 1953-64 Coupe and Hawk Car Cover
  161. Wiring 1962 Hawk Tachometer
  162. My persistent electrical bug
  163. E-vanti
  164. 289 Engine Oil System Questions
  165. Carb adjustment on R series S/C motor
  166. sensitive brakes Avanti 1963
  167. BORG-WARNER T10
  168. Need Avanti supercharger belt numbers
  169. Hood Q and hoepully A
  170. '55 E15 with a Timken two-speed rear axle
  171. Free gas tank
  172. Turbodiesel Engine
  173. C-Cab hood safety latch spring
  174. Champ Jack
  175. clutch linkage hitting crossmember
  176. Gluing New Rubber Door Seals (Gaskets)
  177. Clock
  178. Avanti Project Photos (Jan 18)
  179. Supercharger (Paxton) rebuild ???
  180. 1957-58 Supercharged Engine Carter Fuel Pump
  181. Better handling
  182. dumb question - motor mounts
  183. 289 from 259
  184. 1957 Packard Clipper Fuel Tank Wanted
  185. chev. auto. trans. in a '64 avanti
  186. Repro Avanti Rear Crossmember
  187. Non Stude elelctrical problem. Solved
  188. Part wanted....Avanti roll bar cover.
  189. Hard Steering
  190. 63 Champ Pick Up Bed
  191. clutch pivot
  192. Champ Back-up lights
  193. Glass
  194. Need help with door handle
  195. Need help with script I.D.
  196. Need help with an emblem
  197. Rear Brake Hose I.D.
  198. exploding battery
  199. Vapor Lock
  200. fender skirts
  201. Leaf springs
  202. stiff steering Siverhawk
  203. Looking for an Overdrive Trans for a 6
  204. Studebaker compass?
  205. Traction bar brackets
  206. Firewall liner installation??
  207. Oval Avanti supercharged emblems
  208. 1964-85 Avanti Square Headlight Gaskets
  209. hood handle
  210. Tips on Lifting a Avanti Body Off the Frame.
  211. WIRING HARNESS 52 CHAMPION
  212. Re Chromers
  213. great tail lights
  214. Front shocks
  215. 59 reverse lamps
  216. R3 High Tension Ignition Wire Color
  217. Avanti Round Headlight Lens Gaskets
  218. 55 Auto trans, leak--Suggestions?
  219. Battery drain
  220. E3 Spark Plugs
  221. Studebaker Parts
  222. Avanti Window Seals
  223. Rear bumper-Stude pickup
  224. 61 delco distributor rebuild
  225. 56 Tachometer sending unit-for sale-pictures
  226. Bulletnose taillight problems
  227. Parking on the wrong side.
  228. Power steering problem.
  229. Avanti heater motor needed
  230. Steering Wheel Dilemma
  231. backing plate issue-fixable? pictures included
  232. Paint charts and good stuff
  233. Rack and Pinion Steering
  234. transmission linkage
  235. M5 Glove box liner part#?
  236. Master cylinder
  237. Electrical Problem Today
  238. Vapor Lock or ? in 63 Avanti
  239. 56 Hawk Guages
  240. Motor rebuild
  241. Dialing in a bellhousing
  242. 63 Avanti door handel
  243. Factory paint question '60 Hawk
  244. Water pump Impeller removal?
  245. steering knuckle assembly question
  246. Avanti Windshield Source- Northeast?
  247. New Alternator and New Wiring
  248. 63 Avanti Wheel Lug size/thread?
  249. Hidden Blower on a '59 Lark
  250. starting problem
