View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. parking light 62 hawk
  2. windshield sealer
  3. T Cab master cylinder
  4. Auto Transmission throttle Lever O Ring
  5. Rocker panels on a 63 Wagonaire??
  6. Rear Wheel Drum Removal
  7. Ill fitting drivers side door
  8. steering wheel puller
  9. brake problem
  10. landcruiser
  11. u-joint part number
  12. salvaging flathead 6
  13. Cleaning brake lines
  14. Wanted R1 windage tray
  15. Avanti Parts for Sale
  16. Speedometer Cable
  17. Avanti Car Cover
  18. Avanti heater parts query
  19. 51 Champion temp gage question
  20. 51 Champ Generator Question
  21. 289 Headers
  22. Floor pans
  23. What tach. do I have ?
  24. Silver and black going to football game
  25. Oil Pressure line on '50 170 engine
  26. speedometer cable
  27. '46 M5 Overdrive Wiring
  28. Electronic Ignition Conversion
  29. 1982 Avanti Shop Manual
  30. Flight-O-Matic 1st Gear Start
  31. SEAT BELTS IN 50 COMMANDER
  32. Rear axle bearing zerk fitting locations
  33. help pulling the axles out of a Dana 44
  34. '55 Commander subframe/suspension
  35. Quick Question front turn signal bulb
  36. Engine Temperature and gages. Update
  37. light switch info needed
  38. Mysterious coolant leak
  39. If Not SS
  40. 50/52 commander Info. needed,
  41. motor temp
  42. Bellcrank bracket bushing cross reference no.
  43. Looking for...
  44. Original Hawk & Lark Disc Brake Wheels
  45. 37 Dictator engine -- will a 50-51 six bolt in?
  46. Kickin Butt....
  47. Carter Fuel Pump Cores for 289 & 259
  48. Anybody bought from Rock Automotive?
  49. Brake tidbit.
  50. I have a 169.6-cid six ?
  51. T-86 parts
  52. Door Drain Holes
  53. flex plate
  54. Name that Crud!
  55. 57 golden Hawk supercharger parts.
  56. have 289, need help
  57. Grille for a '35 Dictator
  58. carby trouble
  59. Vintage style WEIAND Blower front Cover returns
  60. hood hold down
  61. Spicer 23 Carrier
  62. front brakes
  63. Column Shift TH350
  64. Rear end and traction bars 53-w/s10 rear
  65. Lola is running!!
  66. Whats the diff in a 63 versus 64 Master cylinder?
  67. Brake and Clutch Spring
  68. 59 lark inner fender color
  69. Removing the dash from a '64 GT
  70. Battery terminal advice
  71. wheel cover cleaning
  72. Chevy S10/Olds Cutlass frame under a Stude sedan?
  73. floor panel and rocker panel replacement
  74. to rebuild or replace?
  75. H pipe for performance
  76. rear fender alignment c/k
  77. wipers
  78. Champ pickup, broken cab mounts.
  79. Body to Frame mounts
  80. Avanti Hood Latch Trivia
  81. Generator must be flashed every start up-why?
  82. Production order quiz
  83. Flasher Unit
  84. The ball, it's the darn ball!
  85. I am in need of a set motor mount brackets
  86. Progress pictures 62 hardtop
  87. 6 volt starter bendix vs 12 volt
  88. 1924-25 standard 6 studebaker remy dist
  89. Core plugs
  90. '64 259 engine colours
  91. 1930 Erskine Model 53, need a throw out bearing
  92. 1930 Erskine Model 53 Water Pump Repacking
  93. Hurst Shifter on T-86 w--o/d -- Pictures OLD GUYS
  94. Steering gear box
  95. 1963 R2 Avanti engine stalling/running problems
  96. dana seal replacement
  97. ? r2+ springs
  98. lack of spark
  99. Priming old pump before starting
  100. Full-flow Block in Earlier Car
  101. Modified Valve Bodies
  102. Hawk Interior Progress-pics
  103. Interior panel restoration question(s)
  104. '63 Valve Train Oil Restricter
  105. Carb question - pictures removed
  106. 4.3 v6 in 66 Commander
  107. Request to stay on topics/tech
  108. New Carb issue may go with 4bbl
  109. DO I NEED A VALVE JOB ?
  110. Speedo says 100 when I'm going 50....
  111. 1937 grill badge repair
  112. 1950 Champion Brakes
  113. 1937 Dictator EX23 Stromberg Carburetor
  114. 63 Avanti Front Seat Foam
  115. Hydrovac kit
  116. Looking for a 4bbl intake manifold
  117. Which carb is correct?
  118. help gear ratio
  119. Avanti Front Springs
  120. 259 Piston Casting Number Question
  121. Corvette Transmission Shifter Boots fit?
  122. Why change oil before winter?
  123. Dial-indicating a bellhousing
  124. Dial Indicators?????
  125. 289 Oil Pressure
  126. Steering wheel spline replacement ?
  127. Stude Garage Display?
  128. What do you call these things?
  129. 231 Buick in a Lark??
  130. Saganaw 4spd/o.d.
  131. Saganaw 4spd/o.d.
  132. changing rear axle ratios on 185 and 259 with O/D
  133. Speedo cable broke on Wagonaire
  134. Power Steering Question
  135. 56 skyhawk tranny wont move help!
  136. core plugs again
  137. fuel pump/power steering reservior
  138. Champ electrical woes
  139. V8 mount biscuit thickness
  140. Chrysler brake drums on Stude
  141. Modern Avanti Ignition Wires?
  142. 1950 COMMANDER ENGINE
  143. Wiring heat and gas gages
  144. heater fan motor
  145. 6Volt Vs. 12 Volt Battery cables
  146. Fuel / carb problem
  147. 53 Grille Bars
  148. 53 Carb question
  149. 53 Automatic Transmission question
  150. Clear trim on top of fenders
  151. Speedo pinion gear
  152. Assembly Manual
  153. 57'GH Body Support Crossmember
  154. Compression/etc Question (problem solved)
  155. Loose fitting distributor rotor?
  156. Need help. valve springs
  157. 59 Hawk 259 Flightomatic Problem
  158. New guy from New Jersey
  159. long tube headers
  160. Under the Avanti
  161. Broken Hood Release Quick Fix
  162. rear end
  163. B-W overdrive solenoids interchangeable?
  164. Has anyone done this LED tail light mod
  165. GT ignition Question
  166. Is my turn signal switch bad?
  167. Front disc brake question.
  168. HELP!!! '64 Wagonaire power tailgate wiring
  169. King pin weirdness.
  170. hood pops up
  171. driven first ime in four years
  172. 1930 Erskine/Studebaker Model 53 Headlight Parts
  173. NAPA #6551020 Application
  174. Lights went out
  175. anti-creep?
  176. who ya gonna call code busters
  177. wiring components
  178. stainless steel trim around the windshield
  179. worm gear adjustment
  180. Installing a full flow oil filter
  181. Engine ID
  182. What engine is this?
  183. T-85C-1A
  184. Door clearance C/K
  185. V8 front seal
  186. gass gage
  187. What have I purchased?
  188. alternator or voltage regulator? - resolved
  189. brake fluid for 63 Avanti
  190. FOM transmission
  191. Heads Specs ???
  192. 63 Champ Tires
  193. fuel gauge
  194. changing a Dana 44 center section
  195. Turn Signal Flasher
  196. power steering fluid
  197. Truck Bellhousing
  198. Measurement for 63 Avanti needed
  199. Customizing a hardtop into a convertible
  200. Customizing a hardtop into a convertible
  201. Speedometer pinion gear
  202. T5 transmissin bracket/mount
  203. dash clock
  204. dana 44 in Hawk
  205. Production order 57 Champion: what is T5743C GR 10
  206. First time re-start
  207. Anti theft switch /55 president
  208. Satelite Radio
  209. Fred K.-rams horn comparison pics.
  210. Finned valley covers
  211. A Stude V-8 replacing a 6
  212. clutch noise 62 Hawk
  213. Shake, rattle and roll
  214. exhaust leak
  215. Help repacking/removing water pump on 1930 Erskine
  216. Avanti Starter Removal
  217. 1939 Champ goes trolling
  218. studebaker 289 engine
  219. Cost For Less Effort
  220. Floors
  221. Question about valve seals.
  222. Radio Dial Glass or Radio Cover Plate
  223. Avanti~~what next?
  224. Engine number marking
  225. 63 Champ = Firewall
  226. 1923 light six wiring
  227. Rear Bumper
  228. Stude People from LI
  229. Fiberglass thoughts
  230. 1963 Avanti auto transmission gear ratios
  231. 1963 Avanti auto transmission problem
  232. timing gear
  233. Treated my Hog Troughs today
  234. Rear Brakes
  235. How I Added Signals to my 51 Champion
  236. zero compression in 5 out of 6 cylinders
  237. 185 six in a CJ 5
  238. motor mount brackets
  239. Dana 44 & rear leaf springs
  240. Need seat ideas for Champ pick-up
  241. O.T. Bizarre freeze plugs
  242. Heater fan
  243. Found it.Dont need it.
  244. 1959/60 Lark Wiring Harness Interchange
  245. Interior: Avanti dash pad install...any suggestions?
  246. NOS fuel pump number
  247. '61 lark radio schematics?
  248. Small block Chevy to 54 Champion Coupe
  249. Brake Drum size
  250. T5 in a studebaker
