View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Avanti A/C Wiring??
  2. 57 SilverHawk turn signal problem
  3. Seat covers
  4. 1963-64 Avanti Wiper Blade Holders
  5. V-8 Heads
  6. Hood Springs/Trunk Springs 62 Hawk
  7. Tach Sending Unit Compatibility
  8. carb leak
  9. ? about 63 gran turismo anttena
  10. early vs late V8 rocker assembly differences
  11. How can I get dents out of a radiator tank?
  12. Replacing Enblem on 56 Commander
  13. water leak
  14. T5 transmission/speedometer
  15. How to tell a 289 And 259 cranks apart
  16. Instrument Panel Glass
  17. ENGINE & TRANNY UPGRADE
  18. Rear windshield wiper motors.
  19. What electrical switch is this?/1955 president
  20. Tips on opening hood
  21. molding clips
  22. Hawk Hood Question
  23. No Start '58 Prez... Solenoid or Ignition Switch?
  24. '63 Avanti white walls
  25. Size of Studebaker Avanti and Nardi Avanti II stee
  26. WHAT CARBURETOR DO I HAVE ?
  27. Avanti II headers ???
  28. PCV valve part number
  29. PCV valve part number
  30. Water Pump for 1950 Champion
  31. Handling problem.
  32. 1937 studebaker tailgate
  33. 1937 Dictator front suspension
  34. Colors for the 53
  35. 1950 front suspension
  36. ebay Hawk bushings
  37. Any one have a dana 44 for sale near tampa
  38. Got a pair of rear bumperettes for '63 Avanti?
  39. Who would have rebuilt starter for '63 Avanti?
  40. installing glass /vent window
  41. Help with Hawk GT parts
  42. Hawk rear deck cover
  43. 1930 Model 53
  44. Cardinal Red Paint
  45. 289 oil leak
  46. Crank pulley question.
  47. Flightomatic (1956)
  48. radiator question
  49. Torque converter (Avanti)
  50. 232- Later FOM
  51. engine mount modification
  52. Key Question
  53. Installing a SBC in a 54 Champion
  54. Hydraulic clutch for T-Cab
  55. Saginaw steering
  56. '64 Hawk Option list vs. "Performance" option
  57. ELECTRIC WIPERS FOR 1950 COMMANDER
  58. Brakes on a 59 VI
  59. replacing 6v starter with 12v starter
  60. Speedometer Cleaning / Lubricating
  61. Choke issue?
  62. Coil Springs
  63. 1950 Champion brakes
  64. Removing tachometer sending unit
  65. new member to forum
  66. AR Torque Thrust D or Torque Thrust II
  67. Third pulley on a V/8?
  68. 60 on a 62
  69. Avanti R1 Coolant Leak.
  70. 62 hawk rear spring question
  71. Clutch linkage part needed pic added 64 T-Cab
  72. disc brakes for a 62 lark
  73. hydroboost
  74. Avanti cold cranking issue? Updated
  75. Stuck Valves
  76. How do I synchronize windshield wipers?
  77. hydrovac
  78. 6 volt start
  79. 1964 V8 Daytona. Ignition or electrical problem?
  80. '50 Champion-conversion to automatic drive?
  81. Need a dimension from a Studebaker Avanti
  82. How do I get my M 5 steering wheel off
  83. Sport Roof Trim
  84. power steering fluid for 1964 289 motor Help!
  85. mopar cop wheels
  86. Timing 1950 Champion Engine, 169
  87. Rear quarter shake on Lark hardtop
  88. 61 Hawk Gas Tank Cleaning
  89. 4speed to T85 change over on Champ
  90. Help daily driver must run again!!!
  91. Bad Battery?
  92. Should Stude gas tanks be boiled out?
  93. lower inside door panel for '49 2R5
  94. supercharger
  95. 1947 Newbie Help
  96. Minimum Flywheel Thickness
  97. TEST OF GAS TANK SENDING UNIT
  98. generic fuel tank sender?
  99. Radio hole
  100. Backup light switch location
  101. New mechanical Brake Light pressure switch!!!
  102. LICENCE PLATE BULB HOLDER
  103. warm up
  104. capacity gas tank
  105. battery cable
  106. Machine Shop In Prescott WI area
  107. Removal, fan from motor, '55 sedan? UPDATE
  108. 63 Avanti main wiring harness fried
  109. Power brakes for suspended pedal Champ trucks...
  110. Big 6 Bell Housing
  111. brake hose
  112. '37 Dictator flywheel and ring gear
  113. 62 Hardtop length
  114. building an ohv manifold
  115. 1954 champion 2dr post steering upgrade
  116. Pinion Yoke Removal
  117. Replacing Bushings
  118. water temperature sensing unit
  119. Distributor/Ignition reliability
  120. Need fuel pump for 289
  121. pertronix in a 6 volt
  122. 1951 Champion
  123. Simple 63 voltage regulator question
  124. turn signal
  125. windshields and dashboards (64 Cruiser)
  126. Land Cruiser Donor car for a Champ
  127. 289 oil pan gasket question
  128. NOS R-1 Radiator?
  129. Should I install a manual choke?
  130. Saginaw P/S rebuild?
  131. JT Engine Number
  132. AM/FM radio options for Studebakers
  133. Topping off a Saginaw steering box - question
  134. R series 160 speedo's
  135. tire size
  136. tach redline 63 R-2 GT Hawk
  137. Old heater control valve rebuild
  138. Binding caster adjuster????Update 12-11-09
  139. Fishing for ideas about brake pedal going to floor
  140. Hawk Window Mechanism
  141. Question regarding Carter fuelpump.
  142. sparky
  143. foundry
  144. How to: Heater diverter box refurb (with pix)
  145. 6cyl Chevy in 54 Stude
  146. MAD alternator wiring kit
  147. roof
  148. It ain't budged yet!
  149. Third Brake Light ideas?
  150. 1957 Tail Light Reflectors
  151. Turn signal switch 55
  152. hard restarting
  153. master cylindar 62 hawk
  154. rough running
  155. Wanted: "Cat Whisker" Clips
  156. Need tips for BU lights using a toggle switch
  157. 62 259 back fire/knock
  158. OVERDRIVE SOLENOID 6V -12 V
  159. Hole in firewall
  160. Info for those with Edelbrock AFB's
  161. fixing my rusty 63 fenders with some 64s?
  162. want to get rid of 3/4 ton split rims
  163. T Cab rearend
  164. 61 Hawk driveshaft
  165. Hawk trunk floor gas tank mount rust-out repair
  166. 57 GH choke tube
  167. Bad PS hoses....?
  168. 289 oil pressure relief valve install
  169. Flightomatic question
  170. '63 Avanti Leaf Springs
  171. Don't jounce on my bumpers
  172. Shorter Starter Needed for My '53...
  173. Stude Truck ID
  174. PRODUCTION ORDER
  175. Body Mounts/Fenders 50 Starlight Coupe
  176. Stude Truck ID
  177. studebaker 59 lark frame dimensions
  178. 1982 Avanti Dark Blue interior touch up
  179. Shifter location
  180. bumpers rechromed
  181. 51 Champion: Use Copper Crush Washer on Front Hose
  182. M5 steering wheel color
  183. 1950 Champion
  184. 63 Champ Overdrive Cable
  185. temperaure guage wiring
  186. Fuel Pump
  187. Window won't stay up on the Daytona
  188. TEMP GAUGE
  189. 51 Champion Water Pump Elbow
  190. knock diagnosis not the flex plate
  191. 15" wheels
  192. Engine question
  193. Has anyone bought leaf springs from SI
  194. ID. Help.
  195. Hole in Radiator
  196. Hawk body swap questions
  197. seat adjustment system for 1935 Dictator
  198. Anyone have a running 259 in socal?
  199. Maintenance charger
  200. STARTER PROBLEM ?
  201. Trunk seal shimming
  202. 63 R1 AVANTI CONVERT TO R2
  203. Setting dwell on a 1964 259 ci V8
  204. Re-installing door "check straps"
  205. sound deadening
  206. 63-64 lark 4 dr, doors, interchangable?
  207. Drum Puller
  208. Replacing the Avanti Vanity Tray felt
  209. Corroded Studebaker gas tanks
  210. WHITE TRUCK ENGINE transplant?
  211. Paint: Engine paint
  212. 50 champion knock
  213. Battery Removal - got to be an easier way
  214. Dana 44
  215. It is mine but it ain't moving, yet! Seized Engine
  216. Ever wanna build your own wiring harness?
  217. Rough Running Engine at High Altitude
  218. Timing an engine
  219. Electrical Gremlin
  220. Changing the head gasket in a studebaker champion
  221. 54 to 53 instrument cluster
  222. T-Cab rear axle seals
  223. 1960 lark 259
  224. Engine Conversion.
  225. T85 floor shifter
  226. Choke Thermostat Coil
  227. Installing Avanti sway bar in a Lark-Type
  228. Two tone 57 W4 sedan questions
  229. Removing a narrow hub steering wheel
  230. Rear glass install 51 Champion
  231. mirror templates
  232. Replacing '63 Avanti Carpet
  233. .53 Differential
  234. Studebaker eng computer upgrade?
  235. 51/52 suspension bushings
  236. Trunk Mat for 1951 Landcrusier
  237. steering wheel swap
  238. CASO Spray Can Quick Charge?
  239. pulling the steering wheel ('63 Stude)
  240. Fuel System: My Street Version Port Injection for the '55
  241. '63 R2 Avanti (number 065) is back on the road
  242. rear end
  243. instuments lights
  244. instuments lights
  245. Converting from gen. to presto-lite alt. help.
  246. YouTube and Repair Procedures
  247. compareing early and late water manifolds.
  248. Heater control valve inop.
  249. Progress 1962 Lark Hardtop
  250. Auto Trans 259 Hawk Manual Interpretation Q
