View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Ohm resistance for fuel sending unit
  2. 53 hardtop passenger fender vent
  3. '64 Cruiser rear springs
  4. Temporary Ignition Coil
  5. 53 Champion vent window question
  6. NO OIL PRESSURE!?
  7. Another brake mystery.
  8. 1950 tail lights work om 1952?
  9. 6volt positive ground radio
  10. radiators
  11. Speedo Cable Routing
  12. Champ 6 hard starting
  13. R-2 flapper vent
  14. engine oil breathing system help
  15. What the Heck!!??
  16. Disc Brake Adapter
  17. 1949 Champ needs better brakes
  18. Rusted Starter
  19. Motor Mount trouble for '66 Commander 6 cyl
  20. NOS Brake Pads
  21. R3 headers and packard hawk
  22. Under carpet thermal barrier
  23. Temp Gauge Sending Unit
  24. '59 Silverhawk Engine
  25. Solder, weld ,Braze ?
  26. chassis replacement
  27. Freed a stuck 259
  28. Interior Door Panel Inserts
  29. Avanti overheating carburetor
  30. I need a flasher 55 president
  31. Oxygen Sensor Ad for 50-58 Studes??
  32. Fuel additives 63 Avanti
  33. Vibration Damper Wobble?
  34. Can you recommend a paint shop?
  35. Weatherproofing cardboard
  36. 64 Daytona electrical problem (previously carb)
  37. Gas gage
  38. Brace behind grill, 65 Commander
  39. Front end difference?
  40. exhaust stud
  41. Poor Gas Mileage - HELP
  42. Anybody know color of dashboard
  43. OD Conundrum
  44. Lark dome lamp removal?
  45. 64 Daytona Picture (finally)
  46. The famous junction block 53 thru 61
  47. dual quad inake
  48. generator to alternator
  49. 29 Fuel Pump 6 cyl
  50. Will 48 Commander brakes bolt onto a 49 Champ?
  51. Chevy motor in a 1963 Lark
  52. Steering Box Seals?
  53. Poor Gas Mileage - HELP part 2
  54. Avanti rear stabilizer shaft support
  55. Shift indicator lens
  56. Automatic o/d tranny for an M5
  57. How to: Lark Gauge Needle Refreshing
  58. Pushrod in R1 seems loose
  59. Alternator conversion
  60. How Hot should an Ignition Coil Get?
  61. AVANTI HOOD INSULATION
  62. '64 Cruiser clock face
  63. High dollar intake manifold
  64. generator
  65. Aluminum Pan Filler Block
  66. more 56 golden hawk help
  67. Inside of gauge lense dirty
  68. I want to drop down the voltage( ac to dc convert)
  69. Can one explain why the change in the turn flasher
  70. 1937 President Oil Filter
  71. Move Front Seats Back in Lark
  72. Late model OEM gas tank replacement?
  73. 63 Avanti windshield wiper
  74. New type of thread repair
  75. Avanti Powershift
  76. Oil Breather Cap
  77. Service Referrals in or near Houston, TX ??
  78. Remove&replace hi beam switch 55
  79. 59 Silver Hawk Seal Belts
  80. 1953 Starlite 6-cyl coupe
  81. Are These 11-Inch Brakes on My 51 Champion?
  82. Squealing brakes
  83. What's up with my stupid ignition switch?
  84. Brake return spring
  85. 48 Map light switch
  86. Cruddy water jackets
  87. Water in the oil, oil in the coolant... Bummer.
  88. Stripped pan threads
  89. 52 Commander front end
  90. Avanti R2 Ignition lock/assembly/switch needed
  91. 62 Hawk Rear Ends
  92. A 4 core radiator to fit a 54 coupe.
  93. Starter solenoid wiring - 50 Commander
  94. Opening up the Prestolite Distributor: Lube
  95. trim code for 51 2R
  96. 12 to 6-I know-AGAIN
  97. engine paint codes
  98. Oil Drain-back holes
  99. interior color
  100. 53 Champion passenger side axle shaft needed!
  101. R3 carb size question.
  102. Two leaf spring front bushing sizes
  103. numbers, numbers, numbers
  104. Wiring harness help 1951 Champion
  105. Need Wiper Motor Wiring Diagram
  106. Starter identification for 1955 Commander
  107. Over heating
  108. power steering for 53 coupe
  109. drum puller
  110. Rear Main Sealant
  111. Barrel Clips
  112. EXHAUST ODOR
  113. Wheel hub puller
  114. Wiper Motor Testing
  115. Hawk door belt moulding clips
  116. 55 champion
  117. 63 Avanti Cam
  118. 57 GH frame swap
  119. 50 Land Cruiser - Fix up troubles
  120. Mushy door locks & new pipes
  121. Hawk Carpet Install Question
  122. Electric radiator fan for Champ
  123. "54 Champion
  124. 4 wheel disc brake conversion
  125. 53 grille bar
  126. fan/shroud clearance
  127. steering box
  128. Avanti Running Rough - More Symptoms
  129. '53 starlite 6-cyl
  130. head rest
  131. Avanti Hood clearance
  132. drive shaft 62 Hawk
  133. Daytona hood swap
  134. lots of questions on 62 Hawk
  135. radiator size
  136. generator/alternator swap
  137. Frame and running gear swap
  138. Front end alignment Specifications??
  139. What Cars Used 10-inch Smooth Brake Drums
  140. Plenty of 1957 Hawk Parts
  141. m15 front axle help
  142. speedo repair
  143. Year to year compatability
  144. Paxton vs McColluch
  145. seam leak
  146. 82 Avanti seatbelt question
  147. Edelbrock Carb on '64 Cruiser, Help!
  148. Dual Master for a 62 Lark
  149. Hey Planar suspension fans
  150. Brakes: power brakes
  151. How much neatsfoot oil in Hydrovac
  152. headliner installation- 51 Champion
  153. Avanti AC Conversion to R34
  154. Site unseen
  155. Not a good Studebaker day...update resolved
  156. 57 Silver Hawk FIn installation help
  157. Differential ID
  158. Help in determining PN 1551930 applicaton
  159. More Help with the Chevy motor in a Lark
  160. Decal Placement
  161. Fuel Pump Problems... Again
  162. Vacuum Advance
  163. How high?
  164. What type of PS fluid are you using?
  165. help on 53 wire location
  166. Ammeter won't show charge
  167. re-polarizing generator
  168. power steering reach rod 59-64 Hawk
  169. OD Solenoid numbers
  170. rear end 1949 commander
  171. 1950 oil filter
  172. Want to buy a Starter for a 1959 Truck 6L
  173. Engine paint
  174. New cracks in other wise almost perfect dash.
  175. Champ Truck Cab Bolt Question
  176. Parts Sources for 82 Avanti
  177. Hawk gas pedal &windshield wiipers
  178. Weber replacemant for Stromberg WW
  179. How to, or how not to, replace lug screws.
  180. Avanti Steering Wheel
  181. A arm pivot points.
  182. 63 Hawk Gas Tank Leak
  183. 62 hawk oil pressure hose
  184. cosmichrome
  185. 15 X 6 New Wheels
  186. steering wheel column clamp 62 hawk
  187. 58 Hawk tachometer sending unit
  188. '63 Avanti electrical problem-ghost in the machine
  189. coil 62 Hawk
  190. wheel covers
  191. more 56olden hawk help
  192. Forum Email.....
  193. Any of you use this stuff?
  194. They did have the time, I know it!
  195. Tire question/ search feature broken
  196. Hole next to water pump housing
  197. ballast 62 hawk
  198. Drum Puller Fix Ideas
  199. Technical Drawings
  200. how do you guestimate parts?
  201. Avanti radio question, 63
  202. Avanti II Power Steering Drawings
  203. Hawk hinge pin replacement
  204. Avanti 200R4 crossmember query
  205. Vent Window Seal
  206. Windshield install
  207. Front Sheetmetal Sharing - Wagonaire
  208. Supercharger Carb Bonnet options
  209. Help with my Fuel pump
  210. fender bolts
  211. GT Wheels
  212. How to: Lark Climatizer blower case refurb pix
  213. Disc brakes
  214. Stuck Clutch?
  215. '63 Hawk burning oil.....why?
  216. T-89 clutch spline?
  217. noisey supercharger
  218. Oddball M/C
  219. Avanti Luggage rack
  220. vacuum hook up
  221. three wires at generator
  222. Rear Engine Seal on 305 Cu. In.
  223. Serpentine for Stude
  224. 1953 Champion Point gap problem
  225. Steering Arms Quick Ratio
  226. Convertible Top Broken
  227. '52 Hood Ornament
  228. hmm
  229. Replacement Carb for 63 Lark w.259 c.i?
  230. 64 master cylinder bleeding
  231. 57 Stubie newbie in need of sage wisdom
  232. BASIC clutch question
  233. oil in valley pan
  234. Need a Paint education
  235. starter prob
  236. Rechroming Wire Wheels
  237. 1951 Color question
  238. gurgle sound
  239. Sirius Avanti
  240. Wiring harness
  241. Inside Rear View Avanti
  242. V8 Fuel pump question
  243. Cruise Control ideas for an Avanti
  244. Oil filter hose
  245. Bad vibration at 70-mph
  246. Trailer Hitch for Hawk
  247. turn signal problem
  248. Avanti exhaust
  249. Headliner Question
  250. flight o matic operation
