View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
  1. 61 lark AC
  2. use of FREEZE 12
  3. No Start, No Nothing
  4. Reply To Aussie About 1950-51 Dash
  5. half-hour jobs that take all day...
  6. Steering Column
  7. T-85 in a 53 Champion Coupe
  8. DG Automatic with anti creep brake system
  9. the Carter AFB
  10. Cylinder head
  11. Hallelujah!!
  12. 51 Champion Switching Bulbs to Add Turn Signals
  13. 51 Champion 4-door Seat Belt Mounting
  14. Will a Camaro 5 speed work?
  15. 62 Champ wheel compatibility question
  16. What's in the heater box?
  17. Engine Numbers on Hamilton Studebakers
  18. Re steering column problems
  19. Avanti VIN location
  20. 1951 Champion Spark Plugs
  21. 63 Avanti R2 overheating
  22. Jet Thrust Exhaust - 289
  23. 289 exhausting query
  24. 63 GT INFO
  25. Heater missing
  26. 226 vs 245
  27. where is the stoplight switch on my 64
  28. need camshaft bore specs for 63 v8
  29. Brakes
  30. Science experiment in my back yard
  31. Spartan Horn troubleshooting
  32. 1964 Daytona. Electrical Problem?
  33. poor man's 62 Daytona
  34. Small backfire at the carb at startup
  35. Air Conditioning Question
  36. 1959 Silverhawk
  37. New Tech tip.
  38. Champ customizing idea
  39. What is a V8 "PJxxx" engine code?
  40. Hawk rear noise
  41. electric fan relay
  42. Still Testing
  43. Amp meter flicks
  44. champion motor break in
  45. Soft plug failures
  46. rear axle gear ratio
  47. Front Spring p/n
  48. Fuel gauge sender for a '55 pickup
  49. Cost of The Hobby?
  50. AGAIN, WHEELS & TIRES-’51 LAND CRUISER
  51. Anyone ever have an Airtex pump do this?
  52. Fuel gage problem?Help!
  53. Possesed Wipers
  54. heater hose 3 way connector
  55. SBC exhaust
  56. 185 ci 6 cyl headers
  57. Hawk Door Alignment
  58. cooling problems
  59. Confused about zinc
  60. Oil Consumption
  61. Dana 44 Rear Axle question
  62. Avanti door issues
  63. Screeming Speedo Death ride (Up Date!)
  64. Ross steering.
  65. Adding windshield washers
  66. Fuel Leakdown
  67. Fairborn Axle Conversion
  68. part # 1353355
  69. 64 Daytona Carburetor questions
  70. Truck fender question
  71. wiring 1966 Commander
  72. Lark heater refurb question
  73. Studebaker V-8 - lowest oil consumption ?
  74. GT Hawk 4-speed shifter rebuild
  75. Panel Fit
  76. hawk dash radio speaker
  77. Big Long Island NY Car Show
  78. Hydrovac problem
  79. 51 4 door rear window glass
  80. flasher unit
  81. 51 Champion Engine woes
  82. unleaded gaoline
  83. On eBay Champ OHV 6
  84. How to determine if car is Twin-Traction equipped?
  85. What will fit
  86. General Electric Questions
  87. 65 commander engine swap
  88. hydrovac problems 2
  89. dist for 55
  90. Oil Baffles on Studebaker Flatties
  91. Postive ground 55 president
  92. Oilbath aircleaner 55 president
  93. Dana 44 exchange?
  94. Mastercylinder replace or restore?
  95. Power Steering Pump Mount
  96. Dumb cigaretter lighter question
  97. 1966 Power Brake vacuum line
  98. Engine questions
  99. 352 packard engine water leak
  100. 66 daytona exhaust single or dual?
  101. 1963 Avanti parts NOS
  102. Layout out of Antenna Installation
  103. Front engine mount, R2 Hawks
  104. Door striker
  105. VIN numbers
  106. glass top in 52 hdtp
  107. Amp meter flicker cured
  108. truck engine clearnce
  109. Need master cylinder 66 Daytona drums
  110. 50 Champion owners
  111. 6 Volt Alternators and Polarity Effects
  112. painting engine
  113. early vs late Champ 6
  114. 6 volt fuel pump $30?
  115. Studebaker Gas tank Restoration
  116. motors
  117. 1963 AVANTI
  118. rear ends 1947-1949
  119. Fuel Smell help?
  120. Automatic to 4 Speed
  121. clutch arm movement
  122. Champ wheels
  123. Excessive end play Flanged 44
  124. Replacing the windows
  125. Clutch & Press Plate for '66 6 cyl - success!
  126. '59 CJ (Stude content)
  127. Diff pics conventional or Twin Traction?
  128. Delco distributor assembly questions
  129. V-8 Front Seal
  130. Torque converter number question?
  131. '50 Champion running hot
  132. Lark power steering on 57 sedan?
  133. AC Schematics
  134. 1958 President sedan
  135. Starter - flywheel thing
  136. tranny quandry
  137. wheel bearings
  138. Gas cap rubber seal hard
  139. Brake Contact Plug Filing
  140. 1950 rear end
  141. 53 coupe center grill brace
  142. Updating a 232 for more power
  143. Rear hub frustration
  144. Fuel sending unit replacement 66 Daytona
  145. 59 Silver Hawk Temp Sending Unit
  146. Latest on the Supercharged R1 Avanti
  147. 65/66 Throttle linkage
  148. Haven't found a hood ornament
  149. Electrical Gremlin
  150. syntetic GL5
  151. updating T-Cab brake system
  152. Replacing Valve Seals
  153. 1951 Champion need help and parts; brakes, tank
  154. more 56 Golden Hawk help
  155. Hood Lock Clips
  156. Dual Carter HE carburetor idle issue
  157. truck bellhousing?
  158. radio installation for 1950 Studebaker Champion
  159. Electric Fuel Pump Safety Shut-off
  160. blinker issues
  161. What is "Mortex"
  162. trim tags
  163. NOS or used front pipes Avanti II wanted
  164. Removing 62 GT clock & tach?
  165. Quest. about Carter elect. fuel pump and regulator
  166. Avanti Top Radiator Hose Diameter
  167. Crankshaft drilling for t-86 input shaft
  168. A/T AS12-5P is it a Flightomatic?
  169. Avanti dash board in a 55 president?
  170. Transmission filler tub won't budge!
  171. 62 GT hawk FOR SALE
  172. 1957 Packard Clipper
  173. 57 Silver Hawk 6 cly clutch
  174. Engine Tear Down Question
  175. Hold down for Optima 6V
  176. 66 283 timing marks
  177. Is there steel rivets out there?
  178. Gas stabilizer. What is it?
  179. Horn Button Wire on 2R10 Pickup
  180. Cause of Broken Stud on 2R10 Drag Link
  181. Good Experience with Grant Piston Rings
  182. Oil Pump Strainer Cover
  183. Engine cooling issues - Electric Fan?
  184. Champ rear mounts needed
  185. Does the TRANNY/transmission need to breath?
  186. Having mechanical issues with
  187. Fan Clutch
  188. Avanti instrument lights
  189. Wagonaire question
  190. Hawk deck lid differences
  191. pedal swing and manual trans questions
  192. Champ cab rear panel angle vs floor...
  193. Valve adjustment - turning the engine
  194. Tach error
  195. tranny conversion
  196. symptoms of bad voltage regulator
  197. 63 Cruiser question
  198. 6 cyl carburetor interchange
  199. circuit breaker mounting question
  200. aluminum heads
  201. Search for a float for Carter WE Carb
  202. gas vs spark vs valve problem-Avanti R-2
  203. Cylinder head porting paper
  204. Latest on Avanti Carpet?
  205. Leaf spring rates
  206. Uploading photos to SDC Forum (I hope)
  207. Engine Numbers
  208. '64 Instrument dash rocker switch
  209. Under seat aux heater
  210. more 56 golden hawk help
  211. 37 President electrical issues
  212. Power brake vacuum
  213. HELP Installing a new Speedo cable
  214. need some stude help
  215. 1950 Champion steering
  216. Tech tip: cleaning those ribbed rocker switches
  217. E3 Spark Plugs
  218. 1955 Champion engine and exhaust
  219. Avanti Upgrades
  220. Would like to drive at night revisited
  221. Fuel guage/ sending unit troubles
  222. B/W Tranny
  223. Headliner done at last
  224. Brake master cyl. upgrade.
  225. oil pressure gauge hookup?
  226. Champ to A4LD adapter
  227. 1964 TIRE SIZE
  228. Emergency Flasher install
  229. Decodeing questions
  230. Anyone know where the ground is?
  231. Surge tank on Avanti
  232. Engine Mystery
  233. crankshaft bolt
  234. 53-paint line molding question
  235. Champion 6 dual carb set up
  236. Glue Removel Under The Roof
  237. wire wheel covers
  238. Avanti steering wheel removal
  239. What is high idle speed?
  240. wiring harness kits for Studebaker?
  241. 61 Lark Auto. Transmission Question
  242. Front coil springs for '62 Lark w/350 Chevy
  243. How do you make a hub installation tool?
  244. Stude Accident - Part Needed
  245. amc rears
  246. Help with engine
  247. carb drainoff
  248. Tar Removal
  249. 1956 President Rain Gutter Trim Removal
  250. Problem gas, not spark.
