View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. 1959 SH Shop Manual Work for 1957 SH?
  2. Cooling Fans for Golden Hawk ???
  3. Surface Rust on Freshly-Turned Journals?
  4. Puzzling ignition switch problem
  5. Repairing a Clutch Shaft Sleeve
  6. '55 President windshield wipers adjustment
  7. '50 Champion transmission w/O.D.
  8. Part Number I.D.
  9. 50 studebaker stuck in L.A.
  10. Improving radiator air flow? 1950 Champion
  11. Parting out a '56 Commander sedan.
  12. Spring Bushings
  13. 58 hawk frame motor mounts
  14. Piston Clearance
  15. Fender Mouldings
  16. Drill bit sharpening.
  17. GT Hawk door Lock
  18. Mirror Problems on My '53 Commander
  19. slip-joint grease washer
  20. 64 commander
  21. Champ brakes
  22. test starting & running a newly rebuilt Champion
  23. Heater/Defroster & radio for 1950 Champion
  24. Gas Gauge Repair
  25. Rear Spring Interchange question
  26. Avanti A/C evaporator
  27. Transtar frame swap?
  28. Tips/advice before buying a 62 Hawk GT?
  29. Battery cable on 50 Champion
  30. metric speedometer
  31. What went through the hole on the 50 Champion?
  32. Rebuilt Carburetor
  33. 1950 Champion drive shaft question
  34. Gas Gauge Mystery solved, maybe
  35. Polarity of electrical system on 1962 Lark
  36. Champ Brake Master Cylinder Help
  37. Lark Oil Filter
  38. O/D Trans governor
  39. Champ = V8 Lark brakes
  40. Anybody replaced an Avanti door hinge?
  41. Thanks SDC Tech forum
  42. Harmonic Balancer
  43. brake lights/electronics
  44. Carpet Confusion - 54 Commander Coupe
  45. Should I paint rear axle?
  46. engine numbers??
  47. generator assembly 12 volt
  48. Champion painting
  49. front window visor for 1950 sedan
  50. id of part 1312034-35
  51. Race Helmet... Shopping.....
  52. Front spring 526122
  53. Tremec/T5 5-speed questions
  54. clunk noise
  55. Best Wheels for 66 Cruiser
  56. Oil passages and oil specs
  57. need help to start changing clutch 59v
  58. New Stude Wiring Alternative?
  59. 63 Avanti ignition run on?
  60. Base/Clear coat question
  61. Two Stage Paint vs. One Stage
  62. coil wiring
  63. Power Seat
  64. What is this? 55 president dashboard
  65. 259 Fuel Pump Installation
  66. anyone pull their waterpump off a 259?
  67. Brakes lights I assume don't work 55 president
  68. exhaust valve stuck
  69. Coolant or Water
  70. wiring harness splice
  71. shift control box stuck
  72. wheel backspace?
  73. Auto Trans Swap - long and short shaft
  74. Upholstery Question
  75. Voltage Regulator
  76. Avanti Clock Removal
  77. 51 Commander Hill Holder Question
  78. Someone help the new guy please
  79. Surge Tank
  80. Hill Holder, add Acura to the list using it.
  81. Anyone familar with "Just Dashes"?
  82. '57 Generator issue
  83. Turner brake calipers?
  84. Connecting Rod Journal Diameter
  85. Will T-10 4-speed work?
  86. viscous fan drive
  87. 1950 tire ?
  88. twin traction emblem
  89. Tranny conversion, 700R4 to Champion eng
  90. pin for 6 cyl. heat riser valve
  91. How many ft lb for water pump tighting
  92. overdrive seal
  93. Standard vs R1,R2 valve spring height
  94. Leaking transmission
  95. Coil Connection
  96. Avanti Torque-HP Curves
  97. '52 into '56 overdrive tranny cannabalizing
  98. No brake or turn signal
  99. removing rain gutter trim = 52 hardtop
  100. Leaking steering box 58 Hawk
  101. Engine backfire
  102. Just wondering transmission fluid55 prresident
  103. Any Arkansas engine rebuilders?
  104. Dumb question about T-bow Mallory Dist
  105. R134a AC Conversion for Avanti
  106. Dash pad on 55 president coupe
  107. 64' seats fit in 63' Lark ???
  108. Need help ID'ing some engines
  109. Motor mounts for a SB Chevy into a 1966?
  110. Jr. Pepper E-mail addie?
  111. Clip On Side Mirrors
  112. Shop safety and Brake Cleaner
  113. Rear Fender Stainless Steel Trim Install
  114. Driveshaft tunnel mods: was '58 Hawk HT rear floor
  115. Horn relay help
  116. Avanti disk pads cross reference
  117. 63 Avanti GM alternator conversion?
  118. 1957 & 58 FRONT FENDERS
  119. 1963 Avanti R2 Transmission
  120. Chevy into Studebaker exhaust manifold source
  121. Simple charging system question
  122. BRAKE SHOES,1957 PACKARD CLIPPER
  123. Avanti bottom door seal
  124. 1963 Daytona Gauges
  125. Avanti brake question
  126. Throw out bearing for Champ
  127. my loss your gain 57 hawk parts
  128. Hood Cable broke
  129. Radiator Cap/Closed system
  130. Cat Whiskers?
  131. Avanti Engine's Coming Apart -- Is the cavalry rea
  132. Hawk frames
  133. Studebakers of Arkansas meeting
  134. 3 speed trans/linkage questions...
  135. Grill and Hood Alignment Problem - 54 Coupe
  136. Looking Up Production Information
  137. New alternator
  138. 1955 president sedan
  139. Universal gas tank for all 1969-66 non Hawk cars
  140. 51 Champion Adding Turn Signals
  141. 51 Champion Changing to Electric Wipers
  142. Radio Antenna 51 Champion
  143. Powershift set-up.
  144. Over all maintenance for 1963 Avanti
  145. 1962 hawk running/starting issue
  146. 51 pick-up upgraded???
  147. Updated - Need OEM Engine Compartment PICs - 54 C
  148. Carter BBR1 carb, whats it worth
  149. factory engine bore markings
  150. '59 Silver Hawk Engine Swap
  151. Please help me find the rattle
  152. Engine Mounts..?
  153. Rear end ratio?
  154. K body door gasket pix needed
  155. 56 Commander Weather Strip ???
  156. Dana with flanged axles
  157. Transmission Connumdrum
  158. water manifold
  159. How do Improve my 185ci 6cyl
  160. HIdden A/c On a 6volt system
  161. Need motor ideas for a 52 landcruiser
  162. Transtar pick-up upgrade.
  163. T86 Trans-to-Bellhousing Bolt Pattern Question
  164. 1950 Stuedbaker Champion 170 Engine
  165. Avanti Vacuum/Boost Gauge Repair
  166. 53 Carrier Bearing
  167. 57 Golden Hawk Frame
  168. adjusting valve lash schedule
  169. Need a 47 Champ rear backing plate
  170. Leaky Radiator Hoses
  171. Do Studes use door panel liners?
  172. T-Cab hood springs
  173. 185CI FUEL FILTER
  174. A frame bushing replacement
  175. Air Conditioning Hoses
  176. head lite s
  177. avanti parts
  178. rubber carrier bearing isolator thingys
  179. headlight bucket s
  180. T-Cab windshield replacement
  181. Camshaft
  182. Extra part on 1950 Champion
  183. positraction rear end oil?
  184. '55 President right front shock retainer
  185. Carter WE Carb question
  186. Pertronix wanted
  187. Need help adjusting carburetor: 64 Daytona
  188. brazing filler neck.
  189. Choke heat tubes
  190. Need destributor cap clip and hardware
  191. No start problem
  192. 53 hood question
  193. Where is engine ID on Avanti motor?
  194. Brake question
  195. Trouble installing T-bow Mallory dist on R2
  196. engine swap into a 1947-9 stude.
  197. vent hole in TT rear end
  198. Missing or torn tie rod boot
  199. interior interchange question
  200. T-85 vs T-86
  201. Carburetor help repost w Photo. 64 Daytona
  202. My generator is done.. alternator swap?
  203. Ethanol gas causing fuel tank problems?
  204. 1959 hawk engine color?
  205. Opinions on converting a 3 onthe tree to a topload
  206. XTRA-PARTS???
  207. Exhaust Manifold/Penetrating Fluid
  208. What gauge wire for 6 volt + ground
  209. Hard Starting
  210. All about fan clutches--A MUST READ
  211. Cleaning Gauges in GT Hawk
  212. stromberg ww carb
  213. press starter buttom.....get a mmmmmm????
  214. Weatherstrip adhesion
  215. What does engine ID JT1778 mean?
  216. wheels
  217. 1950 Champion Radiator overflow
  218. some CARTER carb info.......
  219. window run channel install?
  220. Fuel System: Champ truck, filling the gas tank
  221. FOM transmission
  222. master cylinder splash guard
  223. Champ Turner Brake Upgrade
  224. Dodged a bullet
  225. Tuesday Follies
  226. 51 Champion Six Flushing Engine Block
  227. opinions welcome - floor coating
  228. 54K weatherstrip replacement
  229. Avanti splined wiper shaft size?wiper arm
  230. 700R4 HAWK CONVERSION
  231. 66 Cruiser, overheating...again
  232. Headliner & Interior info for '49 1/2 ton
  233. Paxton Supercharger History
  234. top and cruise speed for 2R10 pickup
  235. electric wiper motor for 2R10 pickup
  236. 1950 O/D Trans and Differential lubricants
  237. R3 info req'd
  238. Spade connectors Found /received 8-27-08
  239. Length Measurement, Champion Six?
  240. Weird Oil Pump
  241. twin traction greese or what
  242. Weird noise
  243. Hypoid-What does it mean?
  244. Pinion Nut Torque
  245. Need help firewall-50 Champion
  246. "ears" rotating on clutch shaft in bellhousing
  247. Lifter Surface and Rings
  248. Left Turn noise
  249. 51 Champion Headliner installation
  250. Starting woes with a 53 2R
