View Full Version : Tech Talk
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. '62 half-ton truck wheel upgrade
  2. Top of Dash Repair
  3. TBI
  4. Oil filter for 63 R1 jet thrust
  5. 57 Golden Hawk steering wheel assembly
  6. Hawk Carb?
  7. big 6 water pump
  8. cam shaft
  9. stainles steel polish procedure
  10. Dakota box on a Stude frame????
  11. test run
  12. Carb Set up
  13. 1950 Champ King Pins & Oil Dip Stick
  14. Radio Delete
  15. engine
  16. need drum
  17. 1962 6cyl 3 speed anyone need it?..runs
  18. Edelbrock Stude. intake
  19. 51 Studebaker Champion Wiring Diagram
  20. avanti brakes
  21. bolt pattern
  22. converting to new delco alternator
  23. gas guage
  24. Gt Hawk disc brakes
  25. Hawk brakes
  26. Cover for Wire Terminal on Fan Shroud
  27. AC3281 Aerostrut Wheel Covers
  28. Weight of Champion Six Motor and Tranny
  29. 180 degrees ok?
  30. Inadequate water pumps, V8
  31. Frame Comparison Dimension's
  32. H 11 Champion Sparkplugs?
  33. dimensions needed
  34. 1955 Paint Codes
  35. Wiper motor requests
  36. Hawk music
  37. 51 Champion with 24k miles
  38. Engine identification question
  39. Hawk Shocks
  40. lost igntion key
  41. Production numbers for 1963
  42. Flightomatic questions
  43. Phantom Auto Works suspension upgrade
  44. Forged V-8 pistons
  45. Sliding roof.....
  46. Universal joint problem??
  47. Ford Rear end
  48. Charlotte Swap meet Sept. 15th to the 18th.
  49. shifter - clutch problem
  50. 6 Volt Eletric Fuel Pumps
  51. Wiper arm removal
  52. Larger brakes for '51 Commander?
  53. 63 Avanti trunk lock
  54. '64 V8 Spark Plug Wire/Distributor Order
  55. Testing a starter?
  56. Need an O/D part!
  57. 56 2 dr wagon door
  58. Bent push rods
  59. 64 hawk tach not working
  60. How do you keep the creepy crawlies out?
  61. Generator in Hawk
  62. Lug nuts
  63. Steering wheel uncentering itself automagically
  64. Upper control arm bushings
  65. hood springs - 1966
  66. crazy question??
  67. Filler Blocks for 1954 Champion Engine
  68. Sick Speedometer
  69. 62 lark-whole or -
  70. Front Wheel Cylinders - Part #? Brake drums off
  71. High Perf Studies
  72. transmission bolts -- torque converter
  73. Fly wheel cap screws
  74. c and k model door flippers
  75. 1962 lark wagon
  76. Dana 44
  77. Transmission Fluid Recommendation?
  78. AMSOIL bypass oil filter
  79. End of season oil changes
  80. Shock extension
  81. splashguard question
  82. Instruction/instalation sheet for AC-1389 Antenna
  83. Crazy CURSED R2 Avanti Engine
  84. Rear end Ratio
  85. 60 lark hood
  86. Questions on correct Overdrive technique
  87. Lark heater fan
  88. Temp. sender puzzle
  89. Bent push rod update
  90. studebaker radiator replacement
  91. Studebaker Hubcaps?
  92. Disk Brake Kits
  93. taillight hunt
  94. Safely out of New Orleans
  95. Champ Biz Coupe restoration project
  96. '54 HT trunk floor
  97. Disc brake squeal
  98. Alternator mount...
  99. Chebby power for a Studeclunker
  100. 62 Lark needs chevy headers
  101. Pinion seal won"t heal
  102. tread width
  103. Tail Bezel Year ?????
  104. Paxton Supercharger Setup for Sale
  105. Phantom Suspension?
  106. 700 R ?
  107. Radiator cap(pressurized or not?)
  108. Brake Job?
  109. '49 champion weight?
  110. Studebaker M-15
  111. 1966 283 hesitation - help
  112. Will a GM distributor work on a Studebaker V8??
  113. champion door handle springs
  114. 62 Cruiser Maintance
  115. Help!! 1962 lark master cyl. what can I use?
  116. vacuumadvance
  117. overdrive problems
  118. Replacement glass
  119. Rust in front quarter panels, eyebrows, floor ...
  120. Heat Riser Valve Replacement
  121. need help
  122. '62 Hawk quirks
  123. Speedster Restoration Questions
  124. need avanti radiator
  125. Electric fan setup for Avanti
  126. NEED: valve body DG-250 55-56 6cyl, 55 8-cyl
  127. Correct spark plugs for 232 V8
  128. '54 Commander HT Frame Mods
  129. Take paint off of chrome?
  130. IT IS ALIVE
  131. Early Lark hitch
  132. Brakes question and pics
  133. Charging System Problem
  134. Repro Wheel Cover Centers for Speedster
  135. Carburetor
  136. Cost for rebuild...
  137. 1956 grill replacement
  138. Crankshaft Socket for V-8 snout
  139. Wagonaire Drive Shaft
  140. What Jets for Speedster At Mile High?
  141. Value of an r2 289 engine
  142. Repo Number Plates
  143. compression test
  144. spark plugs for a dual carb flathead six
  145. hood latch
  146. Alternator Wiring
  147. Dual Point
  148. clutch adjustment
  149. Paxton Supercharger
  150. Sender Corks.(Float)
  151. 1960 Lark Rear End
  152. 289 pistons
  153. Heat riser Valve
  154. 259/289?
  155. Shock Absorbers
  156. Top shifter for a T96?
  157. Do I need an electric fuel pump?
  158. 61 Lark Master Cylinder
  159. Drilling the hole for Reel Type Antenna in my '51
  160. Full Blown Stude
  161. Speedster Seatbelts
  162. What weighs less ?
  163. 61 Lark Curb Weight
  164. Lark Brake Drums
  165. Heat Riser Gaskets
  166. 61 Lark Taillight Lens
  167. camshaft for turbocharged 289
  168. vibration
  169. Weight of 185 flat 6
  170. Avanti Rear Seat
  171. Milky coolant
  172. switch under clutch pedal?
  173. What do Stude engines weigh?
  174. core charges
  175. Coil confusion
  176. Hawk Power Steering
  177. 61 Lark V-8 Oil Filter Number
  178. R/2 and R/3 Air Cleaner Assy's
  179. calif. emmision atten. Mr. Biggs
  180. RIMs
  181. Studebaker logos
  182. skirts
  183. 61 Lark Dana 27 to 44 Change
  184. Front wheel bearing
  185. Wood graining
  186. Engine Stumble
  187. Self-adjusting brakes -- put 'em back in?
  188. serial numbers
  189. 62 Lark rocker panels
  190. steel fenders 1960 Lark VIII
  191. multiple carburetors
  192. Is a 232 worth saving?
  193. Generator replacement
  194. Electronic Ignition
  195. Frozen oil drain plug
  196. thank you
  197. 5 spd for Stude V8
  198. VINTAGE AIR FOR A 62 LARK
  199. another electric pump question
  200. Vacuum advance for Delco distributer
  201. 61 Delco Distributor Vacumn Advance
  202. Vacuum advance, how much is too much?
  203. Paint colors
  204. Changing 27 stude front drums to chevy 5 lug
  205. REAR SPRING SHACKLES
  206. GM transmissions & Stude V8s
  207. Oil for the 1963 V-8 block
  208. cooling system cleanup tip?
  209. Question re: Rear brakes
  210. Chevy engine mount location??
  211. 65-66 Commander motor mounts 283
  212. Chevy 305 pistons in Studebaker block
  213. 1963 Hawk tranny - drip,drip,drip....
  214. 289 rebuild
  215. C body , door alignment
  216. '23 Studebaker parts
  217. door window run channel
  218. Repo bumpers
  219. points or electronic ignition
  220. quirky fuel gauge
  221. Tech site
  222. Myer's Studebaker Core Charges
  223. Silver Mist
  224. What number car?
  225. Leaking Flare Nut Connections
  226. Defroster doesn't work
  227. taking off steering wheel and wheel adaptet
  228. 62 Lark AC
  229. 37 Dictator
  230. Suspension threaded bushing torque
  231. Fuel Injection
  232. 700R4 Carb linkage and TV cable Attachmant
  233. Big tires on a C-K
  234. 6 cyl Valve Seals, 63 170 OH Full Flow
  235. 59 Champ
  236. 62 LARK SEAT BELTS
  237. distributor interchange
  238. Stu-V
  239. Delco ignition part numbers
  240. T-cab seat
  241. stainless rear rock guards
  242. Aluminium Con Rods?
  243. 289 Crankshaft
  244. hydrovac
  245. Gas cap trivia for Lark types
  246. 51 Studebaker Bell Housing
  247. Broken Cruiser
  248. 1928 Studebaker roof
  249. 51 Champion Engine - No Fire in the Hole
  250. Aluminum Con Rods Street.
