View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Have you ever stripped an Avanti?
  2. Vintage Air in a Lark
  3. 62 fuel gage
  4. T86 Top Shifter with AC
  5. 59 Hawk left and right front grille help
  6. Owner's Guide
  7. float setting
  8. Prop Valve 4 Whl Disc Brake Avanti/interim update
  9. Gas Gauge. Where can I get one?
  10. motor rebuild
  11. Engine bucking/Return fuel line on mechanical pump
  12. No 3rd gear in overdrive
  13. 700r4 to 289 conversion
  14. 1950 Commander Brake Lock-Up
  15. lost me keys???
  16. Reusing Headliner
  17. Gas Gauge problems
  18. Wiring Dome Light
  19. Rebuilding Hawk PS pump
  20. kick panel finishing washers
  21. 56J Carburetor hiccup
  22. 1936 motor wanted
  23. Voltage WAY high
  24. Rear Leaf Spring Bushings
  25. Over Drive Ratio ??
  26. Identify trim
  27. Champ overdrive
  28. AFT for 62 Lark six
  29. 6 volt battery cable size
  30. Overspray
  31. whats a 4dr good for?
  32. Stuck Motor Caused by Starter
  33. GT Hawk Vintage A/C Installation Progress
  34. 5 14" ford rims with wide whites FS New Pics
  35. Interior Window Handles - diff 63-66 lark?
  36. vapor lock on a modified 53 coupe
  37. Add on Driectional signals
  38. TURN SIGNALS
  39. need help identifying 6cly engine
  40. Two stupid Champion 6 questions
  41. OHV 6 tranny adapter question.
  42. tach sender hold down clips
  43. Champ timing during overhaul
  44. How do I remove 51 LC Horn ring
  45. 185 Head Bolt Length
  46. Saginaw Power Steering Pump
  47. M5 door glass (division)
  48. superchargers
  49. Stupid Generator Question
  50. Instrument lights in a 50 Champion
  51. 2 Door wagon 2nd row seats Help!
  52. Master Brake cylinder
  53. Bead Blasting ??s
  54. Best way to time an engine
  55. rear shackles...what goes where?
  56. 47 Champ tapered axle mystery
  57. 56J rust along seams
  58. 1950 Champion Fuel Pump
  59. Jet thrust engine
  60. Converting from R-12 to 134
  61. Headers
  62. Numbers stamped on block at cylinders?
  63. automatic trans fluid for 1950 Champion
  64. 1950 Climatizer question
  65. 1950 Land Cruiser
  66. 1963, 289 R1 Distrbutor conversion
  67. Lighted Display Case for Stude Goodies, WISCONSIN
  68. automatic shift lever
  69. Sealing glass sediment bowl ?
  70. Leaking brake fluid
  71. Supercharger rebuilders
  72. 47-50 door seal question
  73. Reminder: check your fuel lines!
  74. R1 vsR3 heads
  75. convertible top
  76. Restoration - Where Do You Start?
  77. Paxton supercharger information
  78. Windshield Wiper Vacuum Motor Inquiry
  79. Avanti Power Window Balance Spring
  80. Bolt Torque Specs Section?
  81. boring stude v-8
  82. elctronic fuel pumps
  83. rebuilt afb 4 bbl
  84. 55 studebaker president
  85. starters
  86. Why superchargers fail
  87. underhood light
  88. Broken bench seat hinge
  89. Newbie Here w/ a `54 Commander Question
  90. accessory outlet...
  91. bumpers, Upper A arm, 55 k
  92. What is Cordite
  93. 57 Golden Hawk Supercharger
  94. A Studebaker Joke
  95. 63 Avanti rear brake cylinders
  96. Fuel line
  97. 63 Avanti R2 radiator cap
  98. 1951 2R6 for sale
  99. Paint question
  100. Disc brake troubles
  101. Parts Please.
  102. Saginaw 4spd / Stude V8
  103. avanti front brake squeal .......Help!
  104. '64 Disk brake wheels on Turner rear disks?
  105. Fan Belt 66 Commander 194/6
  106. what other engines will bolt to my trans
  107. Front suspension
  108. '62 Lark Daytona power brake hose routing?
  109. What is a donor for a hawk
  110. Rear Leaf Springs
  111. R-12
  112. 50 commander rewired now I've got a question
  113. phantom front suspension
  114. Salt2Salt radiators and their brackets
  115. steering rack
  116. Saginaw is the way to go (steering, that is)
  117. determine crankshaft center line
  118. "NEW" Tires that are actually "Old"
  119. date of engine
  120. Carburetor PCV Question
  121. car stuck in Los Angeles
  122. Lokar Emergency Brake Cable Kit
  123. 55 pres body numbers
  124. Battery dead
  125. Dry Master Cylinder....
  126. Radiator for a '55 Studebaker truck
  127. Odd engine noise--suggestions?
  128. Grinding Gears - 1950 G9
  129. Horn repair-How??
  130. advice on my overdrive problem
  131. flat head engine questions
  132. Oil pressure relief valve
  133. Bell housing for a 6 or 8 cylinder?
  134. gas cap
  135. The importance of lens gaskets
  136. Avanti Project Photos
  137. C/K headlight rims..
  138. License plate lamp wire routing?
  139. Making a C cab into a extended cab
  140. Several Questions
  141. Electrical diagram 55 5E pickup
  142. Oil canister tightness '48 Commander
  143. Part Needed V8 Bell Housing
  144. 57 3E11, Hot coil or Vapor Lock?
  145. noisy fuel pump?
  146. Squeeky steering column, on 63 Lark
  147. 1963 Lark tail / backup lamp seals
  148. quick removal of spray on sound dampening
  149. General Restoration Questions
  150. Starter Problems - 54 - 232 V8
  151. Finned Hawk "Finish Strip"
  152. hood struts
  153. 289 soft plugs
  154. tampa
  155. T90 tranny - year ID
  156. anyone had a DIY successful cracked dash repair?
  157. Air Filter Question...
  158. Avanti R1 production figures
  159. Brake bleeding system
  160. Trunk Lite - 50 Champion
  161. How Do You Lubricate a Hydrovac?
  162. U-channels
  163. Lark Parts Car
  164. Pre-Bent Brake lines
  165. clock draining battery???
  166. Lotsa T-cab questions
  167. Ever heard of these Casting Numbers??
  168. getting out of L.A.
  169. piston problems - need advice
  170. OIl for high temps
  171. 63 avanti rare NOS parts
  172. disconnecting ammeter questions
  173. Avanti starting problem Rick Burgen
  174. Where to install oil pressure safety switch.
  175. 289 to 302?
  176. 55 air dam holes
  177. Oil leak 289
  178. GVWR 57 Golden Hawk
  179. Spark plugs - what type?
  180. Tremac 5 speed trans
  181. Need advice on clutch installation in '51 Champion
  182. Lark Emblem Removal
  183. Cowl seal questions
  184. Engine Mounts on 54 Champion Coupe
  185. No Rol versus Anti-Creep
  186. starting flat 6 after 6 yr storage
  187. manual flywheels
  188. rear driveshaft length and diameter
  189. Timing woes
  190. Champion Seat Belts with should harnass
  191. replacing gauges
  192. Learning to work on Studebakers, or any old car
  193. 1950 front brakes
  194. Saginaw Power Steering Unit
  195. shifter knob thread size
  196. leaf springs
  197. radio bezel
  198. 49 Champion temp gauge questions!
  199. R-1 fuel pump vent
  200. Carb Problems - 54 CK
  201. Replacement engine
  202. 64-66 Door Removal
  203. oil filter location
  204. Latest photos of the Avanti Project
  205. Rear Spring Bushing 2R10
  206. Vin #
  207. Brake question on a 57 GH.
  208. 53 coupe windshield wiper problem
  209. spark plugs again
  210. 54 C / Use of Aviation Gas
  211. Engine information
  212. Paint underneath Avanti hood?
  213. Clock - to be or not to be?
  214. slow to turn-no start
  215. bumper bumpers
  216. Installing a new column shift knob?
  217. OEM A/C Compressor Avanti
  218. steering column and turn signal
  219. Rear brake drum removal.
  220. King pins
  221. Welding solid vs. tack welding
  222. Oil Pressure Line
  223. Questions about reinstalling stock steering wheel
  224. quartz clock conversion
  225. ..Another seal for the parts book
  226. GT Hawk window rollers
  227. Where does power steering hose go (55 president)
  228. Lark OHV 6 A/C Completed...
  229. GM Delco Alternator Conversions.
  230. Electric Cooling Fans
  231. c/k driveshafts
  232. Explorer Rear End
  233. 63 Lark - dash pad removal
  234. Different Power Brake Booster for Hawks
  235. GT Hawk turn signals...
  236. Problem with Avanti rear window seal
  237. Can ya put A/C on an Avanti R2?
  238. Anyone runnung on LPG, propane?
  239. 50 champion wiring
  240. Anyone know anything about a Globe brand car lift?
  241. Article on R series engines in July TW
  242. heater control valve
  243. Order of assembly?
  244. Backspacing-once again
  245. Dormant transmission
  246. Magnafluxing rear axles
  247. Power steering idea?
  248. Clutch pilot tool
  249. Battery recomendations
  250. G P S
