View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. 1966 car/SW survival rate?
  2. fuel pump oil leak
  3. modern seat belts in a lark type
  4. transmission Identification
  5. Fuel filler rubber tubes and ethanol.
  6. Mobil 1 for 1959 259
  7. 6 volt horns
  8. O/ D transmission questions
  9. Looking for a radio
  10. R2 Carburetor Problem ( Repaired but....)
  11. SOLUTION FOR FUEL PUMP OIL LEAK
  12. Headlights & Turn Signal
  13. Warped head?
  14. 57-58 fan shroud
  15. Leaded or unleaded gas
  16. Remounting front sway bar - solution found
  17. C body front and back glass woes
  18. How do I get the heater core out?
  19. How do I test the temperature gauge?
  20. Gas tank cleaning
  21. All work and no play....
  22. Vacuum advance 50 Champion
  23. 57 3E11 Clutch Adjustment
  24. question on Lark stance
  25. Chicken Hawk front tires
  26. Stromberg T1 - carb, parts, info, substitute..Help
  27. making up oil pressure line
  28. Avanti rear quarter vent window seal
  29. We know the factory was incorrect, but.....
  30. 55 grill inner color ?
  31. Restoring a 54 K and Pictures
  32. Wheel Stud knurl size (Disc brake) ??
  33. Need rear bumper for 63 Avanti
  34. Need dual point distributor for '63 Avanti
  35. Rear End ???
  36. Cars for sale NOT mine
  37. Ignition Trouble
  38. Looking for firewall grommet (41 Champion)
  39. alternator help
  40. Climatizer expert???
  41. Stainless trim part number
  42. 57 Golden Hawk rear glass molding
  43. Trunk Color
  44. Fuel Sending Unit for 1959 Lark 6
  45. Power windows in a Lark hardtop
  46. fenderwell headers
  47. Freaking Starter (Update!)
  48. 3R6 transmission/od
  49. 55 inner grill braces
  50. Solutions for a Cracked 1963 Lark Dash
  51. Dash Pot Metal Pieces for My '53 Commander
  52. The Correct PCV Valve for R1 and R2
  53. what does vacuum gauge on Avanti indicate?
  54. Hesitation Problem
  55. Brake light problems -- SOLVED
  56. Trunk mat example for 1950 sedan
  57. Transmission Leak from Yoke
  58. Old fashion fibrous wheel bearing grease source?
  59. tapered thread rethreader
  60. Hypothetical 4 bbl, HP questions. Low compression?
  61. Lark Interior Panels
  62. Switching from a generater to an alternater
  63. Sasco update!
  64. Better gas milage
  65. Need Body Tag
  66. SDC ZDDP vendors
  67. Split system master cylinder advice sought
  68. dual brake conversion, M/C?
  69. Electric Fuel Pump Placement
  70. That Oil Line
  71. electric question
  72. What color should avanti engine be painted?
  73. Wipers
  74. '64 Cruiser, rough running...
  75. Stude Supercharger threads
  76. Haunted '66 Commander
  77. thanka
  78. automatic tranny
  79. Brakes 101
  80. What Transmittion do I have?
  81. Oil filters and engine numbers
  82. OD transmission for M16 truck?
  83. help....no brakes
  84. Chrome Ring or No Chrome Ring?
  85. cause? R-1
  86. 55 hood prop location
  87. 63 Avanti AC compressor repare/replace
  88. Air Conditioner Compressor for 1965 V-8
  89. Door Checks
  90. Overdrive pull cable
  91. Adjusting DG250 M transmission
  92. How to mount 56 Golden Hawk Seat Belts?
  93. windshield installation ,need a photocopy!
  94. 1950 Champion start issue after first drive
  95. VIN #
  96. '57 Hawk trunk hinge color?
  97. Heat Riser function
  98. I found another OLD Junk yard
  99. Can I remount my front seat back 6 inches?
  100. engine id info
  101. air shocks
  102. Pertronix ID ?
  103. Changing Rearend Ratio
  104. Avanti Wiper Arms for '63
  105. STEERING WHEEL
  106. New door step plate vs old one
  107. V8 Water Manifold P/N Question
  108. Flushed your brakes recently?
  109. 6E-28 Gearing for modern driving?
  110. 302 in an Avanti?
  111. motor parts suppliers and upgrades
  112. Brake lights
  113. New Battery cable
  114. '57 Silverhawk Clutch issues
  115. overheating
  116. overdriver problem
  117. Re-use old gaskets ???
  118. turn signal flasher
  119. OT ?? Busted off bolts in Al heads...
  120. Help hooking up a SW "Greenline" tachometer
  121. Car started on it's own
  122. 50 or 51 front clip transplant to a 52
  123. Burning Brake Fluid?
  124. 51 Champion window regulator
  125. Stromberg WW = junk,anyone done a carb swap?
  126. Electric Windows 1962 Lark
  127. Custom Avanti seat rails?
  128. Studebaker for Sale
  129. Carb and air cleaner for C/K FYI.
  130. Composite gaskets
  131. Brakes 101 redux
  132. Tacometer Problems
  133. How to replace rear motor mount on Champion 6
  134. replacing bias ply with radial
  135. More Positive Caster
  136. Transtar Headliner
  137. Warped spare windshield, can I fix it?
  138. Body filler: Fibral
  139. Ring and Pinion Mesh Pattern, opinion
  140. brakes
  141. Replacement Crank P/N Difference?
  142. CHAMPION SIX I.D.
  143. Need Picture/Description of Hood Rubber Pieces
  144. Typical Headlight Draw Inquiry
  145. which is it- dished or flat?
  146. choke tube insulation
  147. stude six's
  148. What is typical starting of 50 Champion 6?
  149. fixing wiper arms
  150. FOM question.
  151. Which motor did they put in 61 Hawks?
  152. 1953 coupe panel
  153. front shocks for 1962 Lark
  154. Full Flow Cross Over Filters
  155. Truck forum?
  156. How to test a 3 wire wiper motor
  157. How do I get fenders of my Daytona?
  158. Golden Hawk carb re-build
  159. AC AND SC?
  160. Wire harness New site? FYI
  161. What type auto trans fluid does 63 Avanti use?
  162. Rear axle car vs. truck
  163. Oil & Gas
  164. Apply brake, pull to the left
  165. 1950 Champion 2 door vent window
  166. What does a heat riser accomplish?
  167. installing side mirrors
  168. help with body panel ID
  169. Erosion
  170. starter woes
  171. Electrical question
  172. 259 deck height
  173. Tire balance with Equal?
  174. Fan Blade Diameter Needed
  175. Dual Master Cylinder in 57/58 sedan
  176. Instrument Lights
  177. decided to go...but the car said no!
  178. Electric fan opinions please
  179. Climatizer rebuild
  180. Will other carbs fit on 259 -4 barrel manifold
  181. Door hidge noise
  182. Are electric motors avaible for 55 door glass
  183. who's a good vendor for 1955 keys
  184. V8 street/strip heads with R3 valves for sale
  185. Still need original wiper arm for Avanti
  186. Jerky Speedo
  187. Rear brake interchangeability
  188. No spark here!!
  189. Electric WIndows C Cab Revisited
  190. Overdrive not shifting when hot.
  191. How many motor and trans mounts on a '63 Avanti?
  192. Cleaning speedometer/guage panel
  193. 1950 Champion turn signal lenses
  194. frame swap
  195. Is my speedometer broken or what?
  196. Interior: Dim dash lights on 1950 Champion
  197. Restoring a 1963 R2 Avanti
  198. 1 or 2 piece driveshaft?
  199. How to create clickableThumbnail Photos
  200. Parts Store issue:Distributor.
  201. How to remove worm from shaft? 1929 Ross steering
  202. Transmissin noise
  203. Diaphragm clutch?
  204. '62 engine colors?
  205. 1960 Brake Switch
  206. After fire 259
  207. fuel cam lobe
  208. saginaw steering
  209. 1964 GT disc brakes
  210. Hydrovac parts needed
  211. Speedometer needle removal
  212. Difference in Champion and Commander?
  213. Late 40's- early 50's door hinge repair
  214. Pre-bent brake lines for '64 Daytona?
  215. '55 Commander engine smoking
  216. instrument light switch on 55 sedan ??
  217. turn signals
  218. Avanti Manual and Parts Available
  219. Wide White Wall Cleaner
  220. Wagonaire side glass seals revisited
  221. Cam question
  222. Lug nuts
  223. Steam Clean Engine?
  224. Would you replace these rocker panels?
  225. engine main bearing help
  226. 1941 champion trans
  227. 55 headlight switch with rheostat
  228. FLASHER PROBLEM ('53 coupe)
  229. M5 windshield divider
  230. Look at under a '65 Cruiser hood
  231. 1955 (259)
  232. Has anyone reulposter their front seat?
  233. reupholster front seat
  234. wiring diagram
  235. Where to get those trunk hinges
  236. Oil pressure
  237. Rewiring Opinions.
  238. outside mirrors
  239. Lark bucket seats
  240. defination
  241. what would happen 12 battery in 6 volt system
  242. Avanti motor question
  243. Gas cap rubber Seal
  244. Mag wheels
  245. Is there a bucket seat that would fit
  246. Now wiring smoke on the '55 President
  247. Axle Shaft Bearings
  248. windshield washers
  249. Overdrive-need help
  250. C Cab Chrome Trim
