View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. R2 Edelbrock Carb Tip
  2. Anybody in NC got a gas tank for 66 Cruiser?
  3. 55 molding help
  4. Using an 8 volt battery
  5. balance of v-8 stude
  6. 47 Champ brake self-adjustors
  7. front coil springs
  8. Cruiser master cylinder
  9. m5 truck...rad. install SPRING? ???
  10. M5 rear window install...help!!
  11. 50 stude champ/slickstreet frontend???
  12. Gas tank replacement question.
  13. Question about 60 thru 65suspension
  14. Good used brake drums for a 60 Hawk V8
  15. 64 Cruiser hood torsion rods
  16. S H parts needed
  17. Crimped spark plug channel
  18. Look at this!
  19. 61 Lark new question
  20. Sasco website
  21. Take off parts
  22. 56 golden hawk transmission
  23. '57 Commander Factory tire size?
  24. 66 Cruiser, boiling over
  25. Radiator Core spec...
  26. Torque specifications
  27. PS control valve
  28. 53 Coupe Radiator
  29. Checking fluid on FOM
  30. Fuel line
  31. eliminating self-adjusters
  32. 64 Hawk Turn Signals
  33. inside door handles
  34. Check Front Suspension Bolts Now
  35. 62 Champ brakes
  36. '55 President Gas Gauge Sending Unit
  37. Fan shroud surgery... Anyone done this?
  38. Did Allan Fix Brakes?
  39. Crack in RearHub 61 Hawk
  40. 62 hawk to 53 coupe frame swap
  41. Trunk seal too short-Help!
  42. Tip when rechroming valve covers
  43. Color on '53 Two Tones
  44. Flathead A/C 59 Lark
  45. Tires to replace 195-75-R15
  46. 52 hardtop as donor for convertible resto?
  47. There are still great Junk yards
  48. Looking for a Stromburg Carb
  49. Dana 44 ring & pinion
  50. 55 and 57 Brake Drum ID questions
  51. tool needed/ drum puller
  52. 50 champion rear leafs
  53. 41 Champ Cowl Seal Location
  54. 1955 Champion sedan wire harness routing
  55. transmission seal
  56. starter motors
  57. Major machine shop looking for parts to make
  58. 230 To 283 Conversion
  59. Rear Glass Halo
  60. avanti 63/64
  61. Material Source for Carb Heat Insulator Gasket?
  62. L5 pick-up box dimensions
  63. Fuel Pump Diaphrams
  64. Part Numbers
  65. Need a Part Number - 1941
  66. Possibly lowest-price P195/75R15 WSW Radials
  67. Dipstick handle color
  68. supercharger color
  69. K-body CASO Power Windows
  70. How to weigh an engine
  71. low compression or high compression
  72. Rotors on Drum Brake Hubs
  73. Tire Size
  74. Blocking manifold heat
  75. David Hauser brakes.
  76. door latch
  77. Avanti alignment with radials
  78. Maybe its the carb.
  79. Turner disc brakes?
  80. starting my 49 champ
  81. how to find rims 6Jx15
  82. Side window templates
  83. TIRES and safety on my mind
  84. 61 6 Cyl engine question
  85. Weld-thru Primer Recommendation Needed
  86. Bushing replacement
  87. Whats the best paint for....
  88. Air Shocks for 53-54 CK Coupes Located
  89. '53 Trans & U Joint info needed fast.
  90. My turn for a starting question
  91. Climatizer control valve
  92. LUCAS Transmission Fix ???
  93. FOM no kickdown
  94. Engine Identification help
  95. Correct Fluid for the trans.
  96. Crankshaft Pulley
  97. WCFB CARB REBUILD
  98. Bias Ply Tires-How many years do they last?
  99. A friend in need...
  100. T86E-1A Overdrive ratio
  101. drip moulding 63 gt
  102. Need a WCFB for 57 Silver Hawk
  103. quick part # question...
  104. painting
  105. Automatic trans ID question
  106. Cant start my 1950 Champion!
  107. Brake lines- clean or replace?
  108. 58 Hawk Radio removal
  109. Champion Vent Window rubber seal replacement
  110. head bolt error
  111. Mechanic is Maryland?
  112. 61 Six Cylinder question
  113. 259 tear-down
  114. Windshield Glass Old vs New
  115. Climatizer R&R
  116. 6 cylinder engine identification
  117. Best brake fluid?
  118. windshield washer
  119. 57 Silver Hawk Defrost Blower
  120. Why would a 64 4-dr have a tachometer?
  121. Why can't '66 Studes get gas flow?
  122. Lightest Weight Late Stude?
  123. White Smoke
  124. Another transmission question
  125. 64 Cruiser automatic trans
  126. Avanti 64 Sq Headlight Glass
  127. pullies, pullies, pullies
  128. Lark rear glass removing.
  129. Dead Goldenhawk
  130. Steering and Brake upgrade
  131. Lark Clearance, V-8 Water Manifold/Rad?
  132. CASO spare tire
  133. Oil Link, C I- 4
  134. rear belt moudling removal
  135. Need a king pin bushing
  136. more chevy six into 64 suprises
  137. Carb. recommendation for 259 4bbl.
  138. Gas tank overflowing, 66 Cruiser
  139. rocker panel removal
  140. Overdrive-Freewheeling?
  141. Lark making a grinding noise (new pics)
  142. !*&@#$@&!!! upper pivot mounting....
  143. Shock absorber fluid, Houdaille L-1404
  144. 53 radiator choices
  145. champ truck clutch linkage
  146. Bolt patterns for wheels on a 3/4 ton truck
  147. M5 Radio Antenna
  148. Do 1957 Silver Hawk quarter panels bolt on?
  149. Lark/C-K rear axle swap
  150. 54 Commander Starter Problem
  151. Avanti parking light problem
  152. Engine Parts
  153. belt cutting into hoses-ouch!!
  154. Will this work together
  155. C CAB ARM REST SCREWS
  156. Horn Repair??
  157. Wondering about Stude/Aerostar conversions
  158. Avanti Rear Bumper?
  159. How hard is it to fix front end of '66?
  160. 63 lark
  161. engine identification help
  162. Help identifying this unusual manifold
  163. sun visor help
  164. Fender spear replacement
  165. 3M Super Trim Adhesive 8090
  166. Brake shoes should be easy
  167. camshafts
  168. Part Needed: RUSH
  169. Hood prop on 50 Champion
  170. Champion parts wanted
  171. upholstery/headliner clips
  172. '47 M-5 truck rear main seal
  173. Rear Springs
  174. Autolite Distributor 4001,4010.
  175. Airhorn gasket
  176. Tach Problems
  177. Avanti instrument panel question
  178. Need chrome valve covers for 289
  179. Pertronix Installation
  180. Looked at a 1966 Stude 4 door V8 last night
  181. oil filter
  182. Rebel Wire
  183. 56 hawk vent window
  184. Need NAPA part number for '65 disk brake M/C
  185. Bending steel lines
  186. Does Avanti have a neutral safety switch?
  187. Replacement rocker panels for a '66
  188. Windshield's?
  189. Valve Cover Refinishing
  190. dual master cylinder
  191. question for Mr. Biggs
  192. Interior/paint color options on a 1966 sedan
  193. 1953-55 trunklid interchange
  194. alt.vs. gen
  195. 62 Hawk parts book on CD?
  196. Novice question - Oil pressure
  197. 61 hawk headliner
  198. Throw out bearing stuck
  199. Dana 44 axle ratios for Avanti
  200. Rear Parking Brake Cable
  201. 1955 Commander
  202. Fun with Avanti king pins
  203. Brakes: 66 Cruiser, Right Front brake jamming on
  204. Dipstick tube, '64 259
  205. Engine: motor mounts?
  206. What did you use to close off a road draft tube?
  207. Replacement Interior Doors Panels for a 61 Hawk ?
  208. Getting the R2 back
  209. 63 Lark Suspension Question
  210. 63 Lark disc brake question
  211. need help identifying T10B-1 transmission
  212. Lark Pash Pad
  213. Headliner install HELP!!
  214. 64 Commander Grille Conversion
  215. Studebaker 4 x4
  216. 55 Sedan power steering hoses SOLVED
  217. Spare Engine came with my 55, can someone ID it?
  218. Do all wagons have a 44 rear?
  219. GENERATOR TO ALTERNATOR
  220. What gauge wire?
  221. 61 lark Dash/radio speaker
  222. 61 lark antenna
  223. Rust Products
  224. trans problem
  225. Availability of crankshaft end play shims
  226. Avanti Power Window Rollers
  227. Anyone run into problem Jim Pepper did in TW?
  228. Best way to do Dual exaust on a 50 comander
  229. Need NAPA number
  230. 54 Land Cruiser carpet
  231. 1964 Hawk windshield
  232. A/C on a 66Daytona 283
  233. Oil Leak on Top
  234. Electric Fuel Pumps
  235. Front Disc brakes: Parking brake problem
  236. kick down switch
  237. Fuel Pressure
  238. Oil filter size--'64 259
  239. "Walking" wheel cover
  240. power brake switch over
  241. What is impact of removing dual point distributor?
  242. Exhaust system part number ??
  243. Broken side glass and non starting
  244. Rear main seal question
  245. Valve lash 185
  246. Starting 6 Volt 1939 vs 1955
  247. Trans dipstick tube bracket
  248. Satisfying Saturday's Work
  249. 1966 Auto Trans pressure cable linkage
  250. Lark R2 Lower Pulley Spacer
