View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Champion Windshield
  2. brake booster rebuild kit?
  3. New to Studes, have a few questions...
  4. Brake upgrade (1952 to 54-56)
  5. Upper A-arm bumper question
  6. Cylinder head indentification
  7. Power Steering Issues - Help
  8. OHV 6 head questions
  9. FOM tranny fluid
  10. Engine painting
  11. Chassis Rebuilding
  12. oil line restricter opening
  13. temp sending unit on a 55 v8
  14. FOM TC & Starter Ring Gear
  15. Water pump rebuilder in Arizona?
  16. Tapered Axle pulling Questions
  17. Broke Choke
  18. Transmission reinstall, T96 on 1950 Champion
  19. engine bay paint
  20. 62 lark outside sunvisor
  21. AM-FM Radio wiring question
  22. Purple Power Stronger Than Yellow Power...
  23. 55 master cyl rebuild
  24. Windshield for 62 Champ
  25. 57 GH distributor question
  26. 57 GH shift lever question
  27. Looking for radiator for '51 Champion
  28. A VICTORY AND A MYSTERY
  29. Trunk Hinge
  30. Bucket seat transition piece needed--UPDATE--I sti
  31. 62 daytona rough at stop signs
  32. 54 Commander / Ignition Problem
  33. t 86 od grinding in1
  34. oil lines
  35. ? about ignition coil resistance - 64 Daytona 259
  36. Question Re: Generators
  37. Horn location on a '61 lark.
  38. Gas filler hose problems.
  39. Interior Question
  40. six and T80-1
  41. Door post VIN tag
  42. Rear speaker wiring ???
  43. chassis rivets
  44. Length of Wagonaire?
  45. Vin numbers on a stude.
  46. What year Lark windshields fit a 60 Champ P/U?
  47. Ignition Wires
  48. Coil
  49. 62 Daytona Auto Trans Clunk
  50. 62 Daytona engine ID
  51. 289, 3 Spd OD and ?.?? gears.
  52. Hood Insulation
  53. Lark Interior interchangeability
  54. looking for John McCall
  55. steering
  56. C-Cab Door Visor ?
  57. paint color for engine accessories
  58. Rear Axle Oil Seals -- '63 Avanti
  59. Fender Welting
  60. If you have a C-Cab Door Visor...
  61. Did Studebaker build a 9' or longer truck bed ??
  62. Any good, honest mechanics in L.A.?
  63. Stude speedometer revs per mile ??
  64. T90-1 topshifter
  65. Solid state regulator with generator
  66. Stripped hex nuts on brake adjustment pins
  67. 6 volts
  68. Vacume/boost guage prob. slugish ?
  69. Rear quarter windows rubber
  70. OverDrive parts compatibility
  71. T cab heater control valve
  72. Annoying whine in my Lark's cooling system
  73. p/s 60 lark wagon
  74. Driveshaft Anomaly.......
  75. Rebuild of Carb
  76. Need wheel alignment specs.
  77. Rubber glue removal
  78. Deck Height ?
  79. Adding AC to a Golden Hawk ?
  80. Hawk Carpet
  81. Hardtop windlace?
  82. AC compressor oil
  83. jahns pistons
  84. What kind of car and what year is this motor
  85. Over Head six
  86. 50 Starlight Door same as sedan?
  87. 1957 Silver Hawk
  88. 1961 Lark VI Coil Springs-Advice Needed ASAP!
  89. '60 Lark and '55 C/K suspension interchange.
  90. Gauges wanted
  91. 4bbl Carby and Dual Exhaust
  92. Head gasket sealing
  93. '53 Coupe; identify one more hole?
  94. changing from T-10 to T-85
  95. 1950 Land Cruiser Body Removal
  96. Remote battery install
  97. Transmission jumps out of 1st gear
  98. what radiator cap do I need 55 v8
  99. New to studes and need used 55 parts
  100. Custom wheels for a 64
  101. 6 cyl interchange
  102. Dead in St Louis, no power to coil?
  103. Gas Tank Leaking
  104. 39 and 40 Commander Hinges
  105. 1960 lark on Ebay
  106. E Series Truck?
  107. jahns pistons
  108. Wanted brake parts
  109. Spicer axle champion
  110. 4 bbl intake and carb info needed
  111. 1960 Delco window distributor question.
  112. Cadillac hub-caps
  113. Painting a chassis
  114. shift trans. tailshaft over?
  115. Hurst shifter follow up
  116. thanks and another question
  117. 17" Cobra spare in Avanti spare tire well
  118. 58 Packard engine
  119. Magic Elixir!!
  120. Hood cable broken
  121. Overdrive transmission on 246"
  122. Avanti Window Winders(Manual)
  123. what do these fit Wagner brake FE3347 & FD6677
  124. Checking Fuel Guage
  125. Temp sender
  126. Speedometer cable removal
  127. Removing G H Hallo
  128. Vibration damper hub removal
  129. 1950 Studebaker Solonoid
  130. Preventing Paint Scratches
  131. Paradise Wheels - website ?
  132. Membership Roster request
  133. steering noise
  134. Baffled in Louisiana
  135. vacuum modulator
  136. AIR FLOW HUBCAPS
  137. Speedometer Gear Question
  138. front brakes for 62 Champ
  139. pertronix installation
  140. Carpet set
  141. instrument removal
  142. 50 commander Starter Issues
  143. Popping exhaust
  144. Bendix Valve Body for P/S
  145. Windshield pattern for a 50 commander
  146. GOOD fuel pressure regulator???
  147. Best gear for mileage?
  148. Lubing the hood release cable
  149. Lubing the hood release cable
  150. tachometers that need sending units?
  151. Would like to drive at night
  152. Vacuum advance hookup question
  153. 63 GT Hawk Tach wiring
  154. Help with clutch pedal adjustment - '63 Avanti
  155. Ammeter Issue
  156. sindow leaks
  157. When 289 went from Partial to Full Flow Oil Filter
  158. An "easy" Dana 44 question.
  159. Frustration
  160. Dana 44 3.73 R & P on Ebay.
  161. Another Carter Carb Question
  162. 63 Avanti starter drive
  163. Oil Pressure ???
  164. Stalling at Idle
  165. Wheel cylinder pitting
  166. Peformance Tires for Avanti
  167. Holey cowl!!
  168. V-8 Exhaust Manifolds Interchangeable?
  169. Door/window flippers
  170. Who made the OEM tires for 63 Studes?
  171. Avanti Fuel Sending Unit
  172. Gas Sending Unit
  173. Cubic inch potential of Packard V8
  174. cigar lighter fuse?or relay?
  175. Minor issues with my new Lark
  176. Avanti Red
  177. I 'm gonna try this time Hippie...Dana 44 Question
  178. Champion 1950 engine overhaul
  179. 1950 Coupe - Shifting Box on Steering Column
  180. Road Draft Tube ?
  181. Inner tie rod end (short)
  182. Confused about carpet
  183. Looking for a Stromburg carb And exhaust manifold
  184. Avanti fuel pump eccentric
  185. 3/4 Ton Champ rear brake drums
  186. Harley brake switch number
  187. New inane Avanti resto question
  188. 55 sedan rear door adjustment - hinge
  189. 1951 Commander automatic question
  190. underside detailing
  191. Pix needed of C/K right fender grille area
  192. exhaust manifolds
  193. Turn signals.
  194. Dual Master cyl. and rear fender skirts.
  195. Ignition: avanti r2 alternator
  196. 259 & 289 engine oil capacity
  197. 1950 champ hood release cable
  198. Installing Modern front brakes on a 1952 Champion
  199. 53 door rubber pics needed
  200. Transmission Problem
  201. Trouble getting wiring harness for my 1951
  202. fiberglass Lark hood?
  203. 6 Volt A-C CLUTCH QUESTION
  204. crank bolt size
  205. 41 Trunk handle help
  206. R5 pickup gas tank
  207. Fuse Block
  208. Mallory Dist. Drive Gear
  209. Alternators VARIABLE??
  210. Anyone have an easy way to find TDC on a 289
  211. Fender-vents-climatizer
  212. Steering parts
  213. Is the 259 heads the same as 289 heads?
  214. Exterior windshield stainless on 59 Hawk
  215. convertible top pump fluid
  216. Supercharger Location
  217. Anyone have knowledge on repairing the antennas
  218. 63 avanti r2 lower control arm
  219. Golden Hawk Grille Spears
  220. blistered on a 66 Stude Cruiser
  221. Truck Automatics
  222. Cost of Fuel Injection kit for 259
  223. 56 flight hawk distributor number
  224. Hot coil?
  225. Window felt
  226. problem with 66 Champion 6 cyl - help!
  227. inside rear view mirror glass
  228. Trouble going up 7 to 10% grades.
  229. more parts id help
  230. 12V timing light on 6V system
  231. Mystery leak
  232. Nice lark for sale
  233. 12v radio / stereo in a 6 volt car?
  234. Pitman arm removal.
  235. 1963 lark id
  236. Water pump 289
  237. Avanti outer door glass weatherseal
  238. 64 cruiser
  239. Lark Radiator
  240. 289 rocker arm alignment
  241. Penberthy / Ball and Ball SV-43 Carburetor
  242. Update on sloppy Avanti brake pedal
  243. Parking lights
  244. Fuel pump sucking air??
  245. engine color ?
  246. REFINISHING TIP (GOOD DIRT)
  247. two tone colors
  248. Complete Conversion 51 Studebaker Commander
  249. Gas filler hose?
  250. R2 Edelbrock Carb Tip
