View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Anti Theft devices-choices
  2. Who has a hitch on their Stude?
  3. Could someone help me with a 1957 part number?
  4. Welding axle tubes
  5. Headlamp Brands
  6. Commander 246 water pump
  7. Black paint for Florida car
  8. Converting a 58 Commander to power steering
  9. Engine Change Option Questions; & Stdi Heroes
  10. Need to know a couple of things....
  11. Power Steering ???[FIXED]
  12. 62 Daytona v8 fuel problems
  13. Anybody recognize this part #
  14. 1952 Studebaker 2R5 Wheel Cylinder ?????
  15. 1965 or 66 power steering parts
  16. Question about carb cover on 57 GH.
  17. Ventilator door re-assembly
  18. u joint number
  19. champion headlight switch removal
  20. British Columbia Studebakers
  21. Has anyone retro'd a vintage gauge cluster
  22. CANISTER interchange? Pics Updated pic
  23. Help...Turn signal switch wiring
  24. Radiator cap question
  25. GT leaf springs plastic inserts
  26. 63 Avanti Brake Booster
  27. Fiberglass front floor pans?
  28. compression test of Studebaker engine-Method??
  29. Brakes: P/B check valve problem.
  30. need wheel alignment specs
  31. '58 sedan speedometer trouble
  32. Axle shaft pulling
  33. Barn Lark CPR
  34. Found T86E in trunk
  35. Lark VIII (Possible) Gas Line Issue
  36. South American Brake lines
  37. No 2nd gear in Flight O Matic?
  38. Breather Tube
  39. Front fender to body seal--glue in place?
  40. VIN Number
  41. Pedal protector question
  42. '55 Speedster fan color
  43. New Brake Booster + Pedal Question
  44. Sub framing a 37 coupe express
  45. Edelbrock won't idle
  46. Fuel System: Dual Carburetors on a 50 Commander
  47. PS Kit 63 Champ
  48. 63 Champ
  49. New carb, no tach
  50. Diameter of 289 Piston
  51. GT Mustang to 13" Cobra brake Avanti upgrade (RP)
  52. Mind the gap (T Cab cab height)
  53. manual jumping out of gear
  54. Overdrive alternative for "muscle Studes" etc.
  55. Let the madness begin
  56. Coil springs
  57. question/radio
  58. Looking for a 55 Champion dash switch
  59. Engine swap wiring gremlins
  60. Golden hawk antenna
  61. rear end lift
  62. not enough valve adjustment
  63. What to do with an extra hole in the block.
  64. Dana 27 TT spider gears needed
  65. I have a floor!
  66. Wiring Harness Tape
  67. 1955 Rear End needed
  68. Front stabilizer bar for C/K
  69. Transmission for 38 Commander 8A
  70. HURST 4 speed shifter for Bench Seat
  71. How to identify a stude T10 Transmission??
  72. 259 engine
  73. Growing Puddle of Water
  74. 1941-48 M5 fenders
  75. power steering conversion help
  76. Anyone Tried This Retrofit Heater Control Valve?
  77. What's the difference?
  78. Transmission Identification
  79. What do the letters mean?
  80. 48 M5 bed
  81. V8 Oil Pump.......
  82. Pic needed of Fram oil canisters
  83. Avanti questions
  84. T86E transmission strength
  85. Frame Swap Question
  86. 1925 std 6 radiator
  87. 1958 president sedan front fenders
  88. Mas problemas 1962 Lark V8
  89. Avanti Battery & Alternator Options
  90. Champ six distributor help
  91. door window restoration
  92. Shocks
  93. Oil Deposit ?
  94. Clutch Pedal - 8E series half ton
  95. Lark Tire Size
  96. Generator Cleaner
  97. 6 volt sealed beam sockets
  98. The Good, the Bad, and the Bodged....
  99. sending unit
  100. 63Hawk brakes bleed problem.
  101. Transmission questions
  102. what year did they stop using tapered axles?
  103. Supercharged AFB Metering Rod Springs?
  104. Vapor Lock - Still!
  105. Motor Oil
  106. Anyone running CM filters?
  107. Champion dual exhaust mufflers?
  108. Fixing Clear Coat Finishes
  109. another question
  110. Rumble from the rear 59 Lark VI
  111. Generator wont gen
  112. 63 Champ front Directional assemblies
  113. floor pan replacement
  114. Alternator bracket
  115. Rear brake drums for a 55K
  116. Door Panel Removal - 54 Commader CK Body
  117. rear end ratio
  118. 56 Commander Brake Drum I.D. Size
  119. Hawk Dashes
  120. hood spring configuration??
  121. Anybody know ( cb radio won't work)
  122. Rubber Splash Guards
  123. Where do the shields go?
  124. Need help on disc brake conversion
  125. 61 lark radio again
  126. Electric fan
  127. Teflon Tape
  128. 62 Hawk Igntion Coil
  129. Turn signal switch 1959
  130. intake valve play
  131. WW6 Choke
  132. A couple ???'s
  133. 57 GH distributor question
  134. 57 GH rear spring question.
  135. Question on 57 GH tail light housings
  136. 64 daytona fuel pump
  137. gas tank -M-5
  138. Electric Fan
  139. more floor pan questions
  140. Overdrive solenoid
  141. 3 wire GM alt conversion question
  142. Need a Clutch shaft.
  143. Windshield replacement- sealant
  144. 50 Champion trunk lid hinges- new and improved
  145. 63 Avanti wiper motor
  146. avanti vibration dampener
  147. Oil Filter installation
  148. Home head porting info question
  149. Glove box re-install question for 55
  150. 63 Avanti Hood Latches
  151. Front engine plate gasket
  152. Ram air, cowl induction, cold air intakes, etc
  153. 48 Champion Glove Box Door??
  154. Finally got the President on the Road - Help neede
  155. Rear roll-up window felt
  156. Need tips on under carriage
  157. What Is Up with Type A Fluid
  158. champion rebuild failure!-sad story
  159. rear oil seal 1950 champion 6
  160. Gas Tank repair
  161. My button's too short!
  162. Coolant Recovery- V8 Lark
  163. How Long IS a Long Snout Crank?
  164. Changes from 50 to 51 Champions
  165. TURNING WHEELS INDEX ???
  166. 60 Lark VI oil pressure relief valve
  167. Removing lock assembly from 1950 trunk handle
  168. Four speed shifter
  169. trans knocking
  170. Dual point distributor
  171. Gas tank swap
  172. King Pin rebuild
  173. Power Steering Conversion Kit
  174. Pertronics Coil
  175. Two steps forward one step back
  176. I'm back and a paint question.
  177. Overdrive in Stude
  178. Why does WD40 on leads help start 54 Commander
  179. Door handle gasket
  180. Erskine Continental Specs?
  181. Dumb nameplate-attachment question
  182. 12v radio in 55 Conestoga
  183. Overdrive Compatibility
  184. Stude Cam
  185. Reassemblying heater motor (Brushes)
  186. camshaft specifications
  187. Chrome questions
  188. 1949 "C" Cab lower door hinges needed
  189. signal light flasher
  190. Window regulator
  191. valve cover gaskets
  192. Looking for F-O-M input shaft
  193. Wish list for 55K
  194. 60 lark inner door handles
  195. Anybody have any luck with fixing reclining seats?
  196. gas gauge trouble
  197. 60 Lark MC question
  198. ENGINE STARTS - YES AND NO
  199. Option numbers Decode
  200. Brake Bleeding Blues
  201. Tapered reamer and pin source- bellshousing
  202. GH hood overlay
  203. Disk Brakes
  204. rocker arm assemblies
  205. Paint Formulas Added:
  206. Rear drum brakes
  207. top radiator hose part number needed..
  208. Plugging Brake Lines?
  209. 61 Lark Engine questions
  210. Rusty Dana 44 Axles
  211. 1951 Commander Brake Conversion
  212. Hubcap size/ interchange?
  213. Door striker...'63 vs.'64
  214. Hawk owners with eletric windows
  215. Bellhousing ID Needed
  216. Cutting C/K Glass after Chop
  217. My dream came true
  218. wHAT IS THE PURPOSE OF 0307-18?
  219. Lavender/black springs
  220. Oil Level Guage Adapter
  221. Splash guards on all 50's ?
  222. Oil Gauge Malfunction
  223. Avanti brake booster brackets, toggle mechanism
  224. When is a firewall not a firewall?
  225. Don't know how I lived without PS on my 63 Champ
  226. What is "Rat Rod"
  227. Misfire 1966 Cruiser
  228. Orphan Axle - 25-27 Dictator?
  229. Best Method
  230. T-10 Trans gear ratio change
  231. Parting Out - How To
  232. SKF# - to - Studebaker # : Bearing Chart
  233. Carb parts and function
  234. Brake linkage slop Avanti
  235. 47 Champ E brake cable
  236. pulling a dash pad
  237. 50 Champ front fender repair?
  238. Help installing a '61-'62 radio.
  239. Anyone familiar with these Avanti part #s
  240. 289 Studebaker Horsepower Estimates...
  241. 64 GT R1 Fuel Feed
  242. Wheel color?
  243. Tires
  244. 1962, 63-64 Radio Brochures added to website:
  245. accelerator pumps
  246. 62 lark back-up light template
  247. Block deck height
  248. 62 lark wagon window seal
  249. Wiring Harness 1949 Land Cruiser
  250. Headliner tack strips
