View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Another brake dilemma
  2. Carter 4brl help
  3. Hawk vent window pivot - New question added
  4. Exhaust Paint
  5. crank shaft
  6. Kickdown problems
  7. Where is the VIN on a '51?
  8. Let the wife drive the hawk today
  9. Avanti shocks
  10. V-8 Lower radiator hose diameter
  11. Rear window needed for a '51 Business Coupe
  12. 53 Bumpers
  13. 6 volt od relay conversion
  14. Mustang II front suspension for a '50 Champion?
  15. connect wire to door switch how?
  16. Climatizer motor plug
  17. 47 Champ shackles
  18. steering column cover 1952 champion
  19. I need a part number
  20. 1962 Hawk Tach
  21. Radiator
  22. PING!! DRNITTLER-RE 61 Lark radio
  23. Engine paint color 56 pickup
  24. A-Arm Bushings 57 Hawk
  25. rear main seal
  26. Sparkplug Configuration in a 170 flat six
  27. saginaw
  28. Engine Oil Dipstick location
  29. I'm an idiot re: troubleshooting brakes. UPDATE!
  30. lower door posts for '49 2R5
  31. Two minor questions...one radiator, one fan.
  32. Looking for Horn Ring
  33. Horn Relay
  34. brake question
  35. Using a 4 ohm speaker
  36. Electric fuel pump wiring revisited
  37. Chevy 4.3 liter V6.
  38. Avanti Power Steering
  39. part numbers for rod bearings?
  40. ATTN Chopped Stew....questions to follow.....
  41. Lark VIII Firewall Clearance?
  42. R2 Air Horn Gasket
  43. Brake surprise
  44. front suspension assy
  45. Coil springs 57 Hawk
  46. Lionel Stone 2-2 Manifold Info,.. Anyone?
  47. GT Hawk fender light education
  48. Door Panel Restoration
  49. Overhead Valve 6 Cylnder Transplant
  50. Studebaker Rocker Arms
  51. Don't know if this has ever been asked before..
  52. 62 Studebaker Lark V8 Conversion
  53. Radiator Overflow Tubing
  54. '53 Cowl photo
  55. HELP - 1953 Pickup (2R5) Frame
  56. Champion engine ready to Roll!!!
  57. timing cover
  58. Update on my dist rebuild...some new questions
  59. cork gaskets
  60. More Horn Problems
  61. 53 gas tank
  62. WW backdraft question
  63. Wanted
  64. Congratulations-all Studebaker Driver's Club users
  65. bellhousing dial-in
  66. Tires and Wheel Recommendations
  67. Window Roller Assembly For "K" Body
  68. Electronic Distributors: Mallory or Pertronix?
  69. To Filter or Not to Filter
  70. Two weeks, and counting
  71. Build Sheet help 63 GT
  72. Edelbrock possibilities
  73. Cleaning a frame
  74. Where can you find water pump parts?
  75. Pulled the Radiator
  76. Switching to an Automatic Transmission
  77. Vapor Lock??
  78. Enclosed Trailering an Avanti - Now with PICS
  79. Steering problem
  80. 1958 T/T president
  81. 1958 president T/T four door 289 4 barrel
  82. Help with id on motor..
  83. 1950 brake pedal resistance
  84. backup lens needed
  85. R2 AFB
  86. Houdaille Shock Absorber Servicing
  87. Rear Ends
  88. 1966 Cruiser Differential
  89. 259 and 289 interchange ?
  90. Champion RPM's to shift????
  91. Tires for 50 Champion-modern vs. old style
  92. 454 water pump
  93. To Grease or Not To Grease ???
  94. Decoding My Production Order
  95. Engine wont turn: UPDATE: its running!
  96. pureone oil filter
  97. rear main seal 58 hawk 289
  98. Cool valve cover tech over on the HAMB...
  99. 1950 Champion suspension
  100. 61 engine questions
  101. Diesel fuel in gasoline- anti vapor lock?
  102. Who Makes the best Gas Tank sealer
  103. 1953 engine swap
  104. Spark ???
  105. Tow dolly licensing and the tow car
  106. motor mounts
  107. $3000 suspension on Champion??
  108. 57 Golden Hawk wiring
  109. 64 Champ windshield
  110. P1 Bed Question
  111. Mystery vacuum tube....
  112. headliner bows-color coding
  113. 55 Horn button Identity
  114. 170 Overhead swap into a 52 Champ.
  115. CASO has a gasket question
  116. 1985 down Avanti vs. Studebaker cars
  117. Pully wanted...
  118. Overdrive inspection advice
  119. Internal Resistor Coil
  120. Engine swap
  121. How to soften rubber
  122. Whats the best way to clean out a tarry gas tank?
  123. 61 Lark ???
  124. Horn Part Number
  125. R 3 Gaskets
  126. Linkage
  127. adding power windows
  128. ENGINE PAINT
  129. C-CAB HEADLINER KIT QUESTION.
  130. Delco Radio Model No. 986099
  131. R3 headers
  132. Vapor Lock? - or a carb problem
  133. King Pins
  134. 1958 Stude hk 289
  135. 66 cruiser brakes
  136. replacing vave stem seals
  137. Transmission Fluid
  138. Studebaker Discs on the Cheap
  139. Hurst shifter on 53 with 3 sp. o/d Update
  140. motor replacement
  141. Sticking hood release
  142. 37 studebaker steering box help please!!
  143. Heat Riser
  144. Freeze plug questions
  145. Supercharger question
  146. Gas tank holes
  147. Front Axle: upper-outer a-arm install question
  148. steering wheel
  149. Avanti Radiator Shroud
  150. Electric wiper motor replacement
  151. Avanti HogTroughs
  152. new windshield
  153. Trans cleaning
  154. Parts conversion
  155. float level height
  156. Clock Repair -and- Where did NCSDC Go?
  157. Heater Hose color
  158. Wing nut or what?
  159. Pressure Plate History
  160. I want retractable seat belts
  161. Rubber floor covering-page 85 in S I
  162. Title
  163. oilholes in cil.heads
  164. New crankshafts
  165. NCSDC- Ray-Lin Restoration Tech-pages
  166. T-cab turn signal bug
  167. '56 Golden Hawk seat problem
  168. Carb issues
  169. Ranco or Balkamp rebuild kit
  170. FAN SHROUD PAINTING
  171. One step forward, two steps back
  172. wires
  173. Positive Ground
  174. T86E-1A Transmission Question
  175. Radiator cap for 1950 Champion
  176. 53 coupe frame ideas
  177. Clock Success - Finally!!!
  178. 283 V8 performance
  179. manual transmission additive
  180. Instrument cluster panel
  181. lifter noise
  182. How do these ignition switch lights mount?
  183. FUEL FLOW
  184. Door Lock Knob Grommets
  185. 61 Lark Radio continued
  186. DG automatic
  187. 57 GH wont stay running
  188. Service Bulletin for Shifter Adjustment?
  189. Stock 289 cyl head rebuilding
  190. Lost my R2 Flapper Valve - Suggestions wanted
  191. Lock Removal?
  192. Non-Studebaker lock problem.
  193. Black Diamond Abrasive
  194. Exhaust manifolds...
  195. disc brake problem/advice
  196. Another starter ID
  197. another steering wheel question....
  198. motor mounts for SBC conversion
  199. transtar with Ford 429 and C-6 tranny
  200. Power Steering Pressure Hose
  201. Frenched Headlights
  202. Hood for C or K
  203. Charging Question
  204. 1941 Studebaker champion steering
  205. Differential I D
  206. Rear Springs
  207. 4 speed towing
  208. Power Steering Unit..York PA Meet
  209. powder coating update
  210. Intake manifold
  211. brake light troubles
  212. Engine Mount / Bell housing details...
  213. Spring Oil Change
  214. Oil Pressure plug in Distributer Housing
  215. 62 daytona troubles
  216. choke question for a '52
  217. 64 Champ floor
  218. Avanti Wheels
  219. Spark Plugs-1964 289 V-8
  220. Tools
  221. Gas Guage Testing
  222. Front Bumper exchange?
  223. Carburetor linkage on 53
  224. Engine weight
  225. 1948 Studebaker Engine Block, plus
  226. Hose Clamps
  227. FAN BLADES
  228. Brake Shoes for 52 2r5 pick-up???
  229. Wagonair Rear Step
  230. 36'-37' body dimensions
  231. Will all Hawk tach sending units interchange?
  232. C/K steering column
  233. Tech-Pages: Headliners and Windlace
  234. Water Jacket
  235. Valve covers 1955
  236. Questions from New Studi Fan; Good buy?
  237. Sweet'olBob- You asked for it...
  238. silver hawk brake drums needed
  239. Bob Helm is truly a Studebaker Parts GOD!!!
  240. Original transmissions vs power
  241. Stuck engine
  242. Hawk Grill
  243. Static Collector
  244. Paint for a 55K
  245. Leaf spring question
  246. Quick Answer for Head Casting Numbers
  247. Radiator Hoses
  248. Avanti Bonding Material
  249. s/c Pulleys which combo
  250. old problem-cooling
