View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. Pilot bushing diameter Help needed!
  2. Rocker assembly
  3. Rebound rubbers
  4. What is a "piston expander"?
  5. 62 daytona torsion bar
  6. Daytona radiator.
  7. Champion Rings conclusion
  8. Avanti Vent Rubber
  9. Substitute dash for a 63?
  10. Chrome headlight ring-'50 Studebaker champion
  11. Starter Switch
  12. identification again
  13. 54 Hardtop Power Rear Windows
  14. Motor mount spacers
  15. Trunk lid hinges
  16. electrical
  17. engine breather tube
  18. Trim Molding - fasteners - 54 Commander
  19. automatic to manual switch
  20. 57 hawk frame
  21. STUDEBAKER TUNNEL RAM INTAKES LOOK.
  22. Bought a replacement engine V8
  23. Engine advice needed
  24. Electric window wiring
  25. C/K door wire routing
  26. Prestolite wiper brushes
  27. Toilet paper roll
  28. DG-200 & Dana 44 (disc brakes) FOR SALE
  29. Reactivating a Flight-o-matic
  30. Full Flow engine - or not???
  31. 1960 170 front seal
  32. Stude V-8 Engine Weight?
  33. It could only happen to me...(pics)
  34. Brake booster question
  35. 53 heater diverter on cars
  36. Baffled by turn signal wiring on 52 land cruiser..
  37. New Edlebrock
  38. R3 Heads Production
  39. Fiberglass ideas for an Avanti
  40. Factory paint question
  41. 3M trim material for fin seam
  42. master cylinder
  43. Wiring Harness for a 1951 Bus. Coupe
  44. Avanti authenticty question
  45. front end alignment
  46. Engine Bay Dusting and Cleaning
  47. Self adjusting brakes
  48. 4bbl carb wanted
  49. I need recommendation on GM Torque Converter
  50. three on tree repairs
  51. extra dash holes
  52. 59' silverhawk doors vs 55' doors
  53. R1 Fuel Pump Core?
  54. Alternator wiring Diagram
  55. windshield rubber, + glass 50 champ 2 dr
  56. 50 headlight rims
  57. engine 289 stuck
  58. molding clips needed
  59. Need to put in Pointless points on my distributor
  60. oil pump idler staff replacement
  61. Ross Gear in 1960 Lark V8 without power steering
  62. Delco Remy Distributor
  63. rear drums
  64. crankshaft and rod torque
  65. rear shocks/parts list update
  66. 63 Wagonaire Rear Bumper Guard
  67. DIY floor pans
  68. Chevy in a Lark...Update
  69. OverDrive riggin' question
  70. Hurst shifter in 63 hawk
  71. Avanti steering linkage removal
  72. misleading Turning Wheels Column on Oil
  73. other engine
  74. Crank shaft pulley info wanted 1966
  75. Gas Cap problems
  76. Engine: R2 supercharger
  77. Door jambs on 1935
  78. Electric Motors
  79. Temperature Change and resulting Sweats of vehicle
  80. Avanti harmonic balancer repair
  81. 1962 Hawk Tach Sending unit
  82. INTERIOR PAINT COLORS
  83. Gastonia NC Studebaker Dealiership
  84. Need Expert input: Valve static lifter load
  85. Water pumps (pics)
  86. Positive Ground 54 Commander
  87. champ 6 oil pump info
  88. New hawk heat riser's made "too good"
  89. Seat mounts
  90. 6 volt Alternators
  91. Brake pedal rod adjustment
  92. 53' coupe headers for Salt2Salt
  93. 4GC Rochester
  94. Door strikers
  95. Brake adjustment
  96. Starter woes? Nope, Switch woes. Problem Solved
  97. Tractor Supply Find!
  98. brake fitting
  99. Starter Question?
  100. Rear axle transplant
  101. How do I adjust the carb's fuel/air mixture screw?
  102. Has anyone ever...
  103. Calling all shiftless truck owners..
  104. 50 landcruiser steering
  105. New exhaust system
  106. Fuel Tank Petcock source?
  107. Carb Rebuild
  108. Phantom suspension questions....
  109. Tie rod end will not take grease
  110. Brake System Rebuild (Champion)
  111. steering column diameter
  112. engine heads
  113. Wiper motor removal
  114. Tailgate window wiring question
  115. 1964 Hawk Brake System
  116. Your experience: rebuilt vs recon master cylinder
  117. Flow testing heads
  118. Wobbly fitting rotor on '48 distributor
  119. Fuel/brake line cleanliness
  120. head gasket
  121. Steering Column Help
  122. Rear brake line replacement
  123. Avanti fixed resistor for dash lighting
  124. 6 volt alternator
  125. Brake drums
  126. No Rol field Install instructions needed
  127. GH Hood Overlay
  128. (NEW QUESTION) order for front fender with vents?
  129. 63 Hawk GT-Need to replace P.S hoses-which ??
  130. Dana 44 felt seals
  131. Question for sbca96-Tom...
  132. Rear Fender removal-48 Champion?
  133. Lark Sway Bar Question
  134. double shocks rear
  135. Removing Rear Seats on GT?
  136. Main Bearings on Commander engine
  137. Alternative to POR-15
  138. HydroVac and carb finishes
  139. Wiper Motor Saga Continued...Repair
  140. Strange fuel delivery problem
  141. Fuel Pump pressure for a dual carb set up
  142. Installed new cowl seal
  143. 185 CI
  144. What's that color?
  145. REAR AXLE BEARING REMOVAL
  146. Mystery "bolts/screws"
  147. Rubber Floor Mat for 1950 Champion
  148. copper washers
  149. I need to reassemble 1966 dana flanged rear
  150. I pulled out from the gas station and...
  151. Floor shift automatic
  152. 289 R1 rebuilt as an R2?
  153. What rear springs are these? 1554568
  154. valve cover paint
  155. Fuel System: Fuel injection pump in an Avanti gas tank
  156. Gas tank restoration
  157. '50 Champion tail light lens info. needed.
  158. Electrical: adding signal lights
  159. Width of a Lark Rear
  160. Alternator swap question
  161. OHV main bearing woes
  162. knocking 59 flattie
  163. 1950 Champion hardtop. on the road!
  164. Lark VI pan gasket
  165. Info on brake metering and proportioning valves
  166. Chvey V8 in a 1962 Stude, which coil springs?
  167. Survivor cars today
  168. Starter ID question?
  169. power steering reservoir nut & washer
  170. 1963 259 v8 prestolite dist. rebuild question...
  171. Exhaust tips
  172. buying a '50 champion
  173. wiring harness for 1963 champ
  174. 700R4 Lock up in Stude.
  175. Paint Code needed for 1951 Stude truck
  176. Carburator, Cruiser 289 1964
  177. Lug nuts stuck, chewed up- problem solved!!
  178. marraige ring 65-66 axle bearing -SOLVED-
  179. 6 volts to 12 volts. It cant be that easy?
  180. Lettering on the roof
  181. Above door Flippers 1957 Golden Hawk
  182. Frozen Hood Release Cable
  183. Securing 53 hoods
  184. electic fan/door checks
  185. 1950 NEED Chrome headlight rings
  186. 61 lark
  187. 62 GT Hawk: Ignition Coil Going Out Symptoms Help
  188. Custom Rims for Avanti
  189. what wheels will work
  190. Installing a electric fuel pump?
  191. back glass molding install
  192. Is this a Studebaker mirror?
  193. Transmission: Shifter Alignment
  194. ??HELP?? Rear glass install
  195. full flow filter
  196. Need Avanti water pump pully
  197. Prop Rod mounting on Hawk with AC
  198. body swap
  199. Front Fenders for 59 Lark
  200. 700R installation in a Cruiser
  201. Stude Bonneville pictures
  202. new 61 Lark question
  203. Tow rigs
  204. Suspension parts color
  205. jack/support points on 50 Champion front end
  206. R-1 parts & compression advice needed
  207. gt hawk radiator hoses
  208. BBR-1 Rebuild guide?
  209. Conversion to dual master cylinder
  210. All about relays
  211. CASO door panel replacement
  212. putting a 454 in my 49 Champ
  213. 60 lark seat ideas
  214. question about OD trans
  215. Anyone tried Xenon conversions in their Studes?
  216. Shift Indicator Light Wiring
  217. Avanti front bumper cage nuts
  218. 170 OHV carburation
  219. Door lock disassembly
  220. Transmission rebuild gone bad
  221. intake gaskets
  222. torque specs for intake
  223. Cyl. head ports, don't want to leave anyone out...
  224. Truck front axle brake upgrade or convert
  225. Seat Belt Winder
  226. Avanti Steering Box Fix
  227. Hill Holder Question
  228. Front seat belt install on 47-52 Champion?
  229. 66 cruiser replacement brake drums needed
  230. Home paint job
  231. FOM question
  232. Radio for a 59 Lark
  233. electronic ignition conversion
  234. What two tone color combination is this car
  235. bronze 289 valve guides
  236. Changing the curve in stude dist.
  237. 1939 Commander hood hinge spring question
  238. Cylinder Head differences
  239. Lower Control arms / 55 K
  240. carb tuning
  241. Getting Rid of Sludge
  242. Booster Seal
  243. igintion timing 50 champ six
  244. Horn button wire
  245. High speed heater fan for 59 Lark
  246. Help - need master cylinder for 66
  247. 61 Hawk heater hoses ? N8N ?
  248. Prestolite distributor question pt 3.
  249. Thanks
  250. Two Tone 61 Lark
