View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. Vapor Lock and Hard Starting
  2. oil use
  3. motor mounts
  4. DELETE THIS POST
  5. Soft brake pedal
  6. Front suspension pins
  7. distributor rebuild
  8. Anyone need Stude parts catalogs ?
  9. M-5 Vin #
  10. hesitation
  11. Wagon rear spring interchange?
  12. T/O bearing fork needed
  13. 53 Champ 6 cyl - auto trans
  14. 1950 Champion lower ctrl arm shaft needed
  15. Door vent windows?
  16. Carb question - 170ci Champion 6 in a Jeep
  17. New Shoes for a Lark
  18. Windshield install HELP!!
  19. Wheel Interchange
  20. 1947 Paint questions
  21. New Cam for Studebaker V8
  22. Clutch Issues, HELP!!!!
  23. piston cleaning
  24. '61 President?
  25. Rear Sway Bar Help
  26. Cold radio blues
  27. Long tie rod availability..?
  28. speedometer question
  29. 63/64 Wagon questions
  30. Ute Fan
  31. specs
  32. Door/fender gaps or gaps in general:)
  33. Help with year ID?
  34. Electric fuel pump in 8 volt system?
  35. Hawk Bumper Jack
  36. Fuel Pump Problem
  37. 62 GT Grills
  38. Instrument Lighting
  39. 700R4 swap questions...
  40. Electrical system
  41. 1950 two door vs four door window regulators
  42. V8 intake questions...
  43. 232 Valve Head Sizes?
  44. V8 Timing after rebuild
  45. Avanti Rear Spring Replacement Problems
  46. Polishing Plastic?
  47. 54 hardtop quarter window weatherstrip HELP!
  48. Radio Swap
  49. Need Hawk part number or even part
  50. clutch release shaft
  51. wheels
  52. Nissan Quest/Merc Villager Rims - NOT
  53. Replacing Wiring Harness - Advice? **update/Help**
  54. park brake handle
  55. Towing / Dolly
  56. Are you driving to Reedsville?
  57. '61 Lark Shifting Linkage
  58. Getting the hood open--60 Lark
  59. supercharged 259
  60. '65 Cruiser wheels.
  61. window repair
  62. lowering blocks
  63. '65 Cruiser V/8 part question
  64. Golden Hawk Wheel Color
  65. Side vent doors
  66. Oil Bath Air Filter
  67. Avanti oil pressure flex hose
  68. 1956 289V8 OIL PAN GASKETS
  69. hi everyone!
  70. Water Pump housing.
  71. What would you do?
  72. bumper guard question leads to fog light question
  73. Best block for performance
  74. '55 Foglight Bumperettes - not quite!
  75. Brake Line Fittings Question
  76. Removing tie rods/reach rod
  77. Front crankshaft seal
  78. What happens if I mount a carb sideways?
  79. Flying Chrome Prevention
  80. Installing a second zerk in steering knuckle.
  81. rear end question
  82. Hood alignment
  83. Lark v8 one barrel
  84. Ross Steering Box Fluid
  85. Axle Shafts
  86. Jeep shifter on stude O/D transmisson
  87. FRAM PTFE Filter warning!
  88. GT frame for 53 coupe
  89. R2 Head Gasket Oil Leak
  90. Hawk Weatherstrip Install - Advice
  91. wheel rim glamor ring removal
  92. Lifter resurfacing
  93. 63 Hawk Side Windows
  94. 64 Daytona Headlight Problems
  95. Saginaw steering box?
  96. Tires
  97. 47 M5 fuel tank
  98. Crank Pulley Hole Dimensions
  99. Stude Repair Specialist in Tacoma
  100. 1950 champ radio removal
  101. 49 Commander Model 16A
  102. Craigs List find 1953 studebaker pickup for parts
  103. Rear Main Seal
  104. Hydraulic lifters for a Stude 289
  105. M5 hot rod, Ford 460
  106. Checking Fuel Guage and Sending unit
  107. Edelbrock conversion
  108. miles per gallon
  109. Custom Flywheels for OHV projects
  110. Parting out a 63 Hawk & have a question
  111. Another dumb tie rod question...
  112. 1932 studebaker
  113. Fuel pump... to buy new or to rebuild?
  114. 50 Stude front end discs?
  115. Pertronix failure?
  116. 50 commander KneeAction Shocks
  117. Climatizer for 50 Champion-dash mount, liquid valv
  118. Powershift console with bench seats?
  119. Hood safety catch needed...53-54 C/K
  120. Starting vin# for 1961 P-2 Champs?
  121. Easton PS pump pressure
  122. Transmission cooling
  123. Squealing belt, pumps, alternator?
  124. Chrome headlight ring-'50 Studebaker champion
  125. 1953 original interior fabric question...
  126. The 'charge' ain't like it used to be
  127. Champ dual MC install with Hydrovac
  128. head gasket
  129. Window woes - U-channels, felt
  130. Hill Holder?
  131. Overdrive question
  132. Master Cylinder Identity
  133. Band adjustment on a 1956 Flightomatic
  134. Yet another tire/wheel question....
  135. distributor ground
  136. undercarriage of 54 starliner
  137. 62 gt frame/steering newb questions
  138. Anti-creep valve.
  139. 3 sp shifter replacement for stock units
  140. Engine swap assistance
  141. underneath photos
  142. Radiator question?
  143. Need OD kickdown switch for V8
  144. Head Work
  145. radiator hose support
  146. Fender to cowl gasket
  147. 1963 259 two barrel carb question
  148. Pertronix ignitor II
  149. Distributor cap - delco window type
  150. Saginaw Power Steering Pump Help??
  151. Lower ctrl arm interchange 1950 to 51 Champion
  152. Stude Crusier AM/FM for Avanti?
  153. picture
  154. Starter
  155. Olympia, WA
  156. Defroster motor with noisy bearing
  157. Tube Header Flanges
  158. R2 Carb Floats
  159. Power Cylinder Color
  160. Steering Box Replacement
  161. 700r4 question
  162. Ford 6 1/2 inch wheels (40709)
  163. bolt for balancer
  164. engine colors
  165. Gas Tank
  166. Headliner Quiz
  167. R2 Fuel Pump
  168. ignition switch
  169. V8 rocker arms & shafts
  170. Towing a Car with Overdrive
  171. Tires for 50 Champion-modern vs. old style
  172. 1954 Stude Coupe parts
  173. Paxton SN60 Differences
  174. Removing paint
  175. Packard engine comment in OCW
  176. fenders
  177. 57 Tach schematic
  178. 4L60E
  179. Lagging when take off
  180. Is that noise what I think it is conclusion......
  181. Stude Carburetion Anachronism
  182. 289 Thin Head Gaskets.
  183. Hawk Hood Latch
  184. All thread studs
  185. valve cover replacement
  186. Improving 62 Champ brakes
  187. wiring 1157 bulbs
  188. Anyone here own a '56-'57 sedan with a T85 trans?
  189. 62 Champ PU e-brake
  190. Replace Saginaw with KRC p/s pump?
  191. Rear End Action
  192. brake lights
  193. Custom Auto Sound Issues
  194. Electrical Issues--56 President
  195. R-1 engine # & color
  196. 41 Champion bumper
  197. "Hawk" type Voltmeter
  198. Seam Sealer
  199. 63 Avanti R2 Air Cleaner Element
  200. What's this starter fit?
  201. Removing Drive Pulley Bolt
  202. Measuring Chamber Volume - How To
  203. Heater blower motor in 61 Hawk
  204. Sway bar question
  205. Lark Header Panel number
  206. Need quick spark plug advice
  207. Chassis Paint
  208. 1953 Starlight
  209. ballast resistor on a 12V setup...Question
  210. Rings for Studebaker '50 Champion
  211. engine for my 51 starlight hot rod
  212. Power brakes on 1961 hawk
  213. identification
  214. Wiring advise needed.
  215. "8" emblem
  216. short nosed water pump?
  217. Sealed Power Piston Ring Product Flyers Needed
  218. Wanted: Coupe/ Hawk Frame, or chunk of frame
  219. HOW TO CHOP A 53
  220. 63 Super Hawks Frame serial no.
  221. Door panel install
  222. Hot rod 101 - drive shaft lenght?
  223. '63 6-cyl air cleaner adapter needed
  224. Convertible rams/cylinders
  225. switching from 2bbl to 4bbl
  226. No start for Lark
  227. Numbers on top of 259 pistons
  228. wagonaire side window questions
  229. 94-04 Mustang GT/Cobra brakes on a Stude - How to
  230. Locally Sourced Rear Drum Puller CHEAP
  231. Bolt on rear axle for 47-49 Stude champion
  232. 1950 Champion -Compression problems details
  233. Fabricating new brackets for turnsignals '48 Champ
  234. Remove dome light in 57 Silver Hawk
  235. Drum to Disc system switch - 60's cars
  236. Installation of Horn cable in Ross Steering box
  237. Parts and Fonts
  238. Brake Power Booster
  239. Would you put WD-40 in your gas tank?
  240. cam cover 289
  241. 700R4/4l60E Automatic Question
  242. 1960 lark
  243. Fiberglass question
  244. Fuel smells
  245. Fiberglass Hood Overlay part 2
  246. Conversion kit ordered today
  247. Conversion kit ordered today
  248. 1959 Lark engine mounts
  249. 283 4 barrel carb question
  250. Cylinder to cylinder
