View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124
  1. My Champ is not running like a champ....
  2. Old fuel pump, new gas
  3. clutch linkage
  4. Ignition: r2 timing problem
  5. GM Si Alternator Hookup
  6. Avanti Power Windows
  7. speedster brakes
  8. Daytona Dash Pad
  9. OHV 6 cyl carb
  10. 57 Golden Hawk Clutch
  11. Emergency brake handle (61 hawk)
  12. Tach sending units 56,57,58 hawks
  13. overcharge
  14. Valve stem seal ??
  15. Effective glass repairs
  16. speedometer cable adapter
  17. Need part number identified
  18. Looking for Info
  19. leaking oil from rear main
  20. Fuel System: Hard starting
  21. Brake light
  22. Corbin Walters
  23. Cloth Asphalt Loom
  24. dismantle 37 door check
  25. avanti r2 cooling
  26. Vendor for distributor rebuild -good vendor plug
  27. Studebaker / Reo
  28. Question for Mr. Shaw...
  29. Front engine mount on 53 with side fuel pump
  30. First gear start with R1+ cam?
  31. Caster question
  32. lower king pin support pin question
  33. Hawk not running right
  34. Any AM radio experts here?
  35. mental collapse
  36. How to set timing on 63 Lark 6?
  37. Cam shaft lobe question
  38. Alternator wiring addendum-fusible link
  39. fuel pump
  40. All lights working, then not, then working,..
  41. Inst light switch
  42. New engine too tight
  43. need help random engine cut outs and clicking
  44. overcharge help
  45. Tappet adjustment
  46. Starting Problem
  47. Exterior lighting problem
  48. W. Washer bag bracket
  49. 61 hawk horn
  50. Steering Column
  51. Fuel Pressure
  52. How do I remove truck brake line?
  53. '58 Packard Hawk
  54. 61 hawk flight-o-matic
  55. Oil drain plug washer
  56. 57 golden hawk MCCulloch
  57. OHV 6 dwell, lash settings?
  58. Fusible Link Part number
  59. coil springs
  60. Rear Axle Question in a 1964
  61. Speedo head lubrication
  62. 1947 business coupe
  63. Parts ID Help
  64. shift collar fix?
  65. Taxi Clutch Release Bearing
  66. Oil leak at the fuel pump
  67. 50 Champ Turn Signals
  68. Here we go again: Contemporary Motor Oil
  69. Speedster Carburetor
  70. Short Block Rebuild
  71. Oilfilter on a 1957 259 -- oil line plumbing ?
  72. 54K Bear Claw Pix
  73. dome light wiring
  74. Lark AM radio
  75. T-86 question
  76. Radiator cap and Gas cap questions.
  77. 289 change to new electronic distributor
  78. Concerning Avanti rear drum brakes
  79. wire hose clamp plier
  80. fan blade 1950 champ
  81. Precise T86 and OHV six measurements requested
  82. edelbrock carb step-up springs
  83. Saginaw Power Steering Leaks
  84. chrome question
  85. Package Shelf ?
  86. rpm "ticking"?
  87. brake booster check valve?
  88. How to Modify Mopar Fuel Pump to Stude
  89. Tach Sending unit istalation
  90. t-10 4 speed
  91. 1960 champ brake lights
  92. Early V8 Cam issues
  93. How to - clean a fuel tank. (Warning, long post)
  94. Replace Valves with Rebuild?
  95. OHV/AUTO TRANS TORQUE CONVERTER
  96. any ideas what this could be?
  97. Best master cyl. for Turner bracket on C-Cab?
  98. wiper blades...
  99. Portable charger?
  100. tail lights......what do these fit ??
  101. Stude bodywork: Why no concave dollies?
  102. Power steering control valve
  103. Stainless trim removal help?
  104. overdrive.....will this fit ? work ?
  105. Frame parts 50 commander
  106. '53 turn signal indicator light problems.
  107. cab mounting springs
  108. Need New Master Cyl. for 1966 Commander
  109. Heat riser
  110. points- fine tuneing
  111. Need Brake Pedal Help
  112. fancy finishing washer's name and where to get th
  113. electronic ignition
  114. A body question
  115. Carter or Rochester?
  116. Temp Gauge
  117. Hubcap clips
  118. what' happened to the 185?
  119. Stromberg WW on a OHV 6
  120. Idle issue
  121. Clips
  122. ID pickup truck year
  123. Champion Exhaust Manifold Flange Gasket
  124. Excellent "Good Oil" buy
  125. Help finding brake line adapter fittings
  126. borg warner auto trans.
  127. Clock Repair
  128. Distributor 50 Champion
  129. Just for FUN light bulb fact for my '53.
  130. align bore
  131. 1946 Truck color
  132. Instrument Cleaning Suggestions
  133. floorshift conversion
  134. '48-49 Convertible question
  135. Electric Windshield Wiper Repair
  136. Blowing oil on 65 Daytona
  137. Torque for Intake manifold
  138. Starter noise?
  139. Tranny DG 250
  140. (sigh) '55 V-8 Engine Blue Color...
  141. Tips for Removing Cylinder Head Core Plugs?
  142. OIl Pump Gears
  143. What goes in this firewall hole?
  144. Need new starter
  145. Disc Brakes for 30's Studebakers
  146. Low Oil Pressure (1962 Hawk)
  147. Any Studebaker mechanics around Louisville KY?
  148. Distributor clocking question
  149. filling flight o matic
  150. Paint Finishes and Car Covers
  151. Brake lights revisited.
  152. 54K hood seal welting
  153. altenator
  154. Rust inside doors
  155. Flex plate noise solved!
  156. Rear axle bearing grease
  157. Valve Stem Extensions?
  158. Hawk window problem "tipping"
  159. Hood Struts for my 64 Hawk
  160. 1958 HAWK Transmission Pan Leak
  161. Master Brake Cylinder
  162. zink????
  163. Frame/Springs Rear spring lube, 50 Champion
  164. Seeking Tire Pressure Advice
  165. Part number check
  166. 245 weight
  167. PS Hose leaks ??? Anyone ??
  168. 1950 Champion eng/trans noise
  169. Truck Identification Help
  170. '52 Landcruiser brake spring question...
  171. Wheel/Tire sizes
  172. How to measure a wheel for sizing...
  173. Taxi clutch adventure... starter drive ideas??
  174. fuel preserver.....what is it ??
  175. BILLET STUDE MAIN CAPS ON EBAY
  176. help identify my engine
  177. Rocker arms and shafts
  178. Oil leak after boring and hot tanking.
  179. overdrive...stuck in reverse in garage...help
  180. starting motor
  181. Fuel Pump Problems
  182. POR 15 or seam sealer first?
  183. 1952-1953 Engine differences
  184. She Dies then she's Cranky" Update"
  185. 62 Power Steering ???
  186. steering boxes
  187. shift linkage
  188. 50 Champion starter problem
  189. Need to clean a carburetor before rebuilding it
  190. 51 commander landcruiser steering wheel
  191. Rebuilding Guages
  192. Engine parts needed - 185 Champion Six
  193. Have a Question: Re: Thrust washers on Truck
  194. Engine transplant question
  195. torque converter
  196. starter snouts are different length?
  197. power steering on right turns only
  198. Transmission special tool needed
  199. spring shackels
  200. The drip that won't quit
  201. Transmission Noise
  202. Brake hoses 1957 Golden Hawk
  203. Tail Pipe Extentions
  204. Link for drum remover
  205. Stude Transmission Fluid
  206. 37' fender question
  207. Power Brakes on 1963 Hawk problem
  208. Paint: Gold Paint
  209. Engine un-seize product
  210. 1963 Avanti
  211. 37 windshield opening measurement
  212. carburator identification
  213. are all Zerks the same?
  214. Overdrive questions
  215. distributor rebuild
  216. Pedal pad ID needed - Weasel
  217. Trim questions?
  218. Champion 6 head studs
  219. Monroe part numbers needed
  220. Brake Problem
  221. AFB carb top needed
  222. trans help
  223. 55 bumper brackets
  224. Max RPMs for a Champion Six
  225. radio dial lens
  226. Transmission: Early Stude auto vs later
  227. Lock removale
  228. R3 for my 53
  229. V8 Block #s
  230. Rear-of-block coolant leak
  231. BILLET STUDE MAIN CAPS
  232. Shock Absorbers
  233. 59 Hawk switch knob colors
  234. How to remove stuck switch bezel?
  235. Heat riser valve
  236. Another kickdown question
  237. 62 289 spark plugs?
  238. Carb flooding
  239. Champion AC
  240. Carter WE 715S Carb. vac. piston
  241. King pin bearing question
  242. Interesting Lifter Removal Phenomena
  243. Can someone post a picture of a V8 OD throttle?
  244. A Arm Bushing Tool
  245. Another engine ID
  246. T-84 trans ID question
  247. I learned something today
  248. 62 champ point gap and timing
  249. De-rusting Head Joint on "Fresh" Engine?
  250. Vapor Lock and Hard Starting
