View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123
  1. Fender spears 62 Hawk
  2. dome light switches
  3. 63 Lark Master Cylinder ?
  4. Front axle swap '52 2r10
  5. Painting the family crest
  6. Dash differences, sedan vs C/K
  7. Is this an original Studebaker mirror?
  8. Fuel filter placement
  9. Plastic scratches
  10. Evans NPG
  11. Overdrive Cut-In Speed?
  12. Hawk rubber inner fender liners location
  13. Oops problem with Vintage Air brackets
  14. Vintage air AC brackets
  15. Hawk Front Seat Back Rest
  16. Dana 23 axle seal #
  17. Installing M series Hood Springs
  18. fuel filter
  19. turn signals for 51
  20. Vintage Air bracket instructions
  21. MC Cap
  22. Now where does it connect?
  23. oil pan oil pick up
  24. Need Float for Carter WE
  25. 63 flasher unit
  26. Bell crank/Pitman arm re-assembly
  27. Charlotte Swap Meet
  28. full flow oil filter
  29. OD wiring
  30. alternator
  31. headlight bucket assembly
  32. More oil stuff
  33. P/S ram bracket location
  34. need oil pick up tube for 50 champ six
  35. Air Filter
  36. Differential interchange
  37. Turn signals revisited
  38. Powershift Clicking / Buzzing
  39. Wheels
  40. 53 Freeze Plugs/Motor Mount/Paint?
  41. Throttle rod adjustment - again.
  42. NOS 259 crankshaft observation
  43. Ignition
  44. engine numbers six cyl
  45. 64 Parking Brake Cable
  46. Engine Problem
  47. Molding clip substitution?
  48. Sound deadenibng
  49. Avanti ballast resistor
  50. Hawk Trunk lid overlay
  51. HELP removing rear axles 66 commander
  52. Weird turn signals
  53. New radio dialglass
  54. What advance warning is there for an axle breaking
  55. Avanti blower switch
  56. Clarification on motor mount question.
  57. Sloppy Flightomatic column-shift action
  58. Exhaust and Intake Metal Gaskets- Sealant or not?
  59. 64 Hawk Transmission "Need Help"
  60. Hawk wheel centering - hub or studs
  61. Water Manifold instllation questions
  62. What's Wrong With This Picture?
  63. Instrument lights inop-any suggestions?
  64. Trunk Rubber installation
  65. Rear disc brakes on flanged axle
  66. where do stock wheels crack or break?
  67. Avanti radiator
  68. Fabric needed for 1931 seats
  69. Power window wiring for '57 Clipper?
  70. Crank Bolt
  71. carburator
  72. '63-'66 rocker panels-should they be curved?
  73. Steering Box 53 C-Cab
  74. 6V Battery
  75. Wiring Question
  76. Eliminating Under Seat Heater - 1958 Hawk
  77. Electrical: 6 volt batteries in series?
  78. Steering column seal
  79. how to bring a car into canada from usa
  80. rear wheel seals
  81. Steering parts for 53-54 Commander Coupe
  82. 58 Packard vent system question
  83. windshield wiper problem
  84. R3 headers in a '56 sedan--no go without mods?
  85. Low beam problems 50 Champion
  86. weather striping tacks
  87. Hawk item location questions
  88. Master Cylinder Lark
  89. glass scratches
  90. noise engine
  91. front seal leak
  92. Drivers Side Rear Noise When Turning
  93. Clutch & plate interchange
  94. R2 Fuel Pump
  95. Wiper problem solved thanks to Ray Fichthorn
  96. Rear springs
  97. thick or thin head gaskets?
  98. Rubbing noise when turning corners
  99. Peeling batwing
  100. Carter Fuel Pump Filter Help Needed
  101. fuel sending unit ohms?
  102. RUST REPAIR
  103. Could someone identify my paxton bracket
  104. camshaft on 169 1950 six cyl.
  105. Emblem
  106. Hawk Rear Side Windows
  107. Carter WCFB with McCulloch vs Stromberg 2bbl
  108. SC belt tension spring
  109. 53 and 54 front bumpers/ what's the difference
  110. Valve Adjustment
  111. Original oil lines
  112. Radiator bracket shims - help
  113. '52 champion front brake shoes?
  114. Power Steering For a 1953 Commander
  115. 61 hawk horn location
  116. Boxed rocker panel on hardtops?
  117. pulling engine
  118. 52 landcruiser glove box depth?
  119. losing oil pressure
  120. Door Lock Button Color
  121. Hawk G.T. Script
  122. 59-60 front bumper brackets
  123. floor pans
  124. Rear trunk antenna
  125. 59r2 at the drags fri sept 5
  126. Tach for 64 Hawk
  127. Horn on 63 Avanti
  128. Traction Bars for packaged R2 Lark
  129. Relay??
  130. Avanti Transmission
  131. 1963 Hawk GT 289
  132. Heater hose connections
  133. Pre-startup questions
  134. final oil question
  135. Leaf Spring re-use?
  136. Stewart Warner Greenline gauges in a '56 pod
  137. oil leak, 289 flow through
  138. New Gaskets/Seal materiel?
  139. '70's Avanti II flanged rear axles...
  140. Smoke from 6V starter
  141. Blowby at freeway speeds
  142. eletronic ignition for a 50 commander?
  143. Alternator Wiring
  144. Superchargers anyone?
  145. Looking for 1954 Studebaker 3R5-12 oil Pan gasket
  146. rear suspension tracking arm
  147. Disabling Anti Creep
  148. Paint Code Location & Color Formulas
  149. Building an Oil Pan Cradle--Hep! Hep!
  150. Door stuffed in the trunk!
  151. 56 Flightomatic
  152. Turn signal harness
  153. Hawk Door Adjustment
  154. Stromberg Carb WW pump adjustment
  155. Timing Gears
  156. R-2 pushrods
  157. Fender Side Air Vents for 1950 Champion
  158. back glass 53-55
  159. Distributor Wear
  160. No Heater!
  161. Gas door guards on a hawk
  162. Black Bart Special update!
  163. '49 Commander wiring question...
  164. Flushing block before installing new radiator?
  165. bore and stroke a 245" six
  166. Avanti Weight Distribution
  167. Temp sending unit.
  168. avanti brake drum-stuck in iowa
  169. Choke valve screw - where to find
  170. Horns
  171. 1958 Packard Station Wagon
  172. Rod Run Piegon Forge, Tn.
  173. Commander Six Distributor
  174. More AC questions for my Champion 6
  175. Gas sending unit fixed
  176. 62 Lark rear axles
  177. Avanti Front Seat Removal?
  178. 289 rebuild: Help with right parts
  179. Restraining Trailered Vehicles
  180. DELETE
  181. Hawk Hood Installation
  182. Broken Hawk GT Trunk Lock
  183. Should We Paint This? (Part Two)
  184. 4 speed truck gear oil
  185. Pilot bearings and input pinions
  186. Led light
  187. Expansion plug and exhaust surprise
  188. 170 Carter Carb leaking
  189. ethonal gas
  190. Fuel Gage
  191. '53-4 front bumper
  192. 1966 Cruiser V8 just stops
  193. Looking for a dipstick Tube for a 1954 Studebaker
  194. Steering Quick Steering Arms
  195. Yet another axle question...
  196. WTB a dual intake and exaust for a 50 commander
  197. PlainBrownR2's truck gets a turbo improvement
  198. Tires
  199. Just frustrated with the whole thing
  200. Fuel Pump Arm Mod
  201. how does one remove '63 hinges
  202. Liner, luggage compartment, '54 coupe
  203. Looking for gauge cluster brackets for '56 sedan
  204. voltage regulator for 50 amp generator
  205. WTB 1954 pickup gas Cap/ oil cap
  206. Leaking power steering unit
  207. Starter install problem
  208. '53 Brake question
  209. shift linkage
  210. thermostat question
  211. Need a better cat whisker
  212. exhaust gas
  213. clutch
  214. 8E Truck Bellhousing
  215. Noise when the engine is not at idiling T .
  216. Powdercoat wheel color
  217. Pilot bushing for a V8
  218. Cadmium Plating
  219. Centering pinch bolts
  220. Pitman shaft seal?
  221. More on drilling out door screws??
  222. What engine is in the 1954 Studebaker 3R5-12
  223. Coil problems
  224. Fan belt tension
  225. Intake manifold, mopar to stude
  226. Lower Trunnion problem
  227. Anybody recognzse these cylinder heads
  228. Radiator
  229. Heeeeelp! Caulking 54K drip rail
  230. hood studs
  231. Steering Column
  232. alternator
  233. More O/D questions
  234. dome light 63 Hawk
  235. 63 Lark 6 A/C Installation
  236. vin decoded
  237. Door Window Problem?
  238. Speedo Cable Question
  239. Front inner fender rubber splash aprons
  240. 49 2R5 Spotlight Option
  241. Stuck Pistons
  242. Gas in intake
  243. decoding serial numbers
  244. C body sun visors
  245. rope cord on back of seat
  246. need help!
  247. exhaust heat riser
  248. Carpet Kits
  249. 289 Upgrades
  250. overdrive modern day switch ? fix ????
