View Full Version : Tech Talk
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Rear Fender Gravel Guards
  2. turner brake master cylinder
  3. sagging @$$
  4. Transmission # translation
  5. Oil filter location?
  6. Carburetor Reconditioning
  7. Installing AC in a Hawk
  8. Fuel problem
  9. vacuum advance?
  10. Bolt Sizes
  11. Block #
  12. Rear brake drums
  13. fleet studes ??
  14. c/k frame-- rearend--chevy engine
  15. several '55 questions....
  16. window regulators
  17. dim lights
  18. Titles & paperwork for classic cars
  19. Much ado about rust
  20. Modern Tires for 1961 Hawk
  21. filter oil
  22. R2 AFB Woes Revisited
  23. 1949 Stude/ Sixbanger - Engine Oil
  24. 1957 president rear fender antennas
  25. Champ steering column HELP!!
  26. 1955 President paint divider trim piece
  27. louvres
  28. WANTED DG-250-M tranny ( DG200 vs. DG250M)
  29. 2x4 intake manifold
  30. Dash lights
  31. 3 heater hoses
  32. Valve adj
  33. door handle guards: which way?
  34. need help identifying a part
  35. Production Order
  36. 64 challenger grill
  37. 53 Coupe Production order
  38. '64 Daytona - Fender Removal
  39. overdrive lock out
  40. brake drum specs
  41. 1935 and '37 O'Drive and main bearings.
  42. engine code
  43. spark plug?
  44. distributor oil
  45. converting to 12 volt
  46. Gas Temp gauge
  47. 63 Avanti clutch fan replace/rebuild??
  48. oil vol with change
  49. Rusty Seat Springs
  50. oil pressure
  51. bad vibes
  52. weird sound
  53. '53 starliner with removable hardtop
  54. Avanti Carpeting
  55. Coolant in my oil!!!
  56. rear axles
  57. pinion angle
  58. heater core giving me grief
  59. Want to remove front brake drum 63 Lark
  60. 1924 stude 4 door sedan-big six
  61. transmission
  62. Spedo for 62 Champ
  63. fuel pump
  64. pinion seal
  65. 232 manifold
  66. Installing engine & trans
  67. Repop Fenders for 63 Hawk
  68. sussssspension
  69. head liners
  70. tire pressure
  71. Need an overdrive transmission
  72. cooling problem
  73. '55 President oil pump
  74. R3 Axles
  75. 37 dictator
  76. Positive Ground
  77. Avanti water pump manifold
  78. Boiling Gas
  79. Fuel retention in carb
  80. Front Suspension
  81. 1951 gage bezels
  82. Transmissions
  83. Comanche Red Formula
  84. turn signal switch
  85. Lead additive
  86. oil relief valve
  87. Fuse types
  88. Engine painting question
  89. Pulling '64 Guage Cluster
  90. remove '55 clip
  91. 55 pickup truck - replacing flathead six with V8
  92. 50 cyl head
  93. Air Conditioning
  94. 33 Rockne ignition
  95. 410
  96. Backwards timing
  97. R2 Fuel Pump Pressure--Woes Continue
  98. How to remove door
  99. 55 COMMANDER
  100. Oil Pressure and Engine Temperature
  101. Lark VI Fuel Pump
  102. 1963 R2 Aanti for sale
  103. Another A/C question
  104. Red Line
  105. 1930 studebaker commander
  106. '35 Headlight Help
  107. Right bank exhaust manafold
  108. cam lever shaft seal
  109. alternative carburetors for a champion six
  110. Boiling gas fixed
  111. help with transmission ID
  112. Gold color /hub cap
  113. stainless reveal in windshield rubber
  114. t86 trans.
  115. Starter
  116. Avanti Parts for Bonneville car
  117. '50, '51 or '52 3/4 ton truck, R10-22
  118. wheels for Avanti
  119. Need a wiring diagram for a 55'
  120. installing auto trans and torque conv. in Avanti
  121. Rear differential oil
  122. power steering leaks
  123. Engine paint confusion
  124. truck vin numbers
  125. Drum Puller
  126. Superchager Belt size
  127. Front Vs. Rear Bumper 1965 Cruiser
  128. Accessories / Options
  129. distributor adjustment
  130. Lug nuts
  131. Hawk springs
  132. gas gauge
  133. Leaking Head Gasket?
  134. Oil filter
  135. front brakes tightenng
  136. TT emblem location on 64 Cruiser
  137. U-joint replacement
  138. transmission help
  139. decode my block please
  140. 60 Lark VI to VIII
  141. Replating rear view mirror
  142. Aligned fine ,pulls to left
  143. electricial wiring '62 stude
  144. 63 Avanti mirror repair questions
  145. Was my Lark built in South Bend?
  146. v-8 pistons
  147. cams
  148. seats color
  149. McLeod Industries motor plate-- trans adaptor
  150. ?------"hurricane six"
  151. operating engine temp
  152. Steering wheel removal
  153. engine removal
  154. Ignition Safety Switch... where is it?
  155. Drum Puller (part 2)
  156. Twin Traction Troubles
  157. Fuel level sensor.. High tech????
  158. T 10 bellhousing
  159. engine knocking sound
  160. headliner advise
  161. distributor ?
  162. which is it 259-289
  163. valves
  164. X-over pipe
  165. Correct black ?
  166. engine knock, compression check results
  167. TWIN TRAC QUESTION
  168. Transmission Questions
  169. Gasoline
  170. Clutch problems, burnout
  171. 9G Rear Axle with O.D.
  172. Brake partrs
  173. 1980 Avanti Brake Shoes
  174. 1962 Lark rear end swap..what can I use?
  175. Leaf spring replacement
  176. What x-over pipe to order?
  177. Vapor Lock/ runs lean
  178. Electronic Fuel Pump
  179. 50 commander engine 6 cyl
  180. shocks
  181. 51 Champion Trunk Floor Pan Replacement
  182. 289 in a 49 half ton
  183. valve cover gaskets
  184. 51 Champion Studebaker Hub Caps
  185. rust repair on Cursed Purple Hawk
  186. Dashboard Removal
  187. 65 Commander Axel / Brake help needed
  188. weatherstripping
  189. Newbie with lots o' questions
  190. posting pictures
  191. Starter
  192. Rusty Brake Fluid
  193. Production order codes
  194. WINDOW REMOVAL
  195. Turner disc brakes on a truck
  196. brake pedal on 60 lark
  197. hei dist for 6 cyl stude
  198. finally painting slow64
  199. 51 Studebaker Champion Stuck Engine
  200. 51 Studebaker Champion Paint
  201. Oil filter for 259
  202. Top end sputter
  203. suspended gas pedal
  204. Studebaker serial Number
  205. GT dimension of tires..../handbook
  206. P.S.reach rod
  207. HEI Dist
  208. Golden Hawk windshield removal
  209. R1 fuel filter needed
  210. what's comfortable engine temp
  211. anyone heard from sonny lately
  212. Wagon Redo
  213. 63 Avanti Brake Booster Check Valve Seal
  214. What's it called?
  215. Edelbrock/Carter Carb Vacuum Ports
  216. Need Some Help!!
  217. odd suspension problem
  218. Dual carb setup for Champion six
  219. excellent tech site
  220. correct length of hood prop
  221. Rain water in Avanti
  222. vin numbers
  223. new here with 55 coupe
  224. Lark rear tire width
  225. 55 coupe project
  226. Part source for 1950 9G convertible
  227. 50 Champ Generator
  228. holley or edelbrock
  229. spring rate
  230. V8 Radiator swap
  231. 55 coupe decisions
  232. stude headers
  233. original exterior paint color
  234. Cleaning Burtex
  235. Electric Wiper Motor
  236. Lowboy / Hawk body parts
  237. Coil spring question, also motor mounts needed
  238. Oil Pressure
  239. gas gauge
  240. 500 or 600 cfm Edelbrock
  241. Radiator
  242. Powder Coating/Carbs rebuilt
  243. Help identify part
  244. !2 volt conversion...
  245. Wheel size for a 53
  246. vin plate copy
  247. GT Hawk tach question?
  248. Fuel Pump and Cursed Avanti
  249. Surface Rust
  250. HEY! You likey some nuts?
