View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. brake return spring
  2. Whats the application of this piston?
  3. Radiator Losing Coolant
  4. Part #s for Tune Up of R1 Avanti
  5. Avanti Radio Installation
  6. PUTTING A FRONT END TOGETHER
  7. Looking for a 1941 champion coupe trunk lid
  8. G. H. Hallo Removal
  9. 50 Studebaker 170 Six
  10. floor shift
  11. Hawk door locks
  12. auto transmission in 51 studebaker
  13. 1960 Hawk fin shape and trim
  14. Stainless steel for exhaust manifold bolts
  15. grease seals dana 44 ?
  16. Correct alternator?
  17. Stupid Question
  18. 57,58 GOLDEN HAWK WIRING PHOTOS?
  19. 57 hawk
  20. Flightomatic questions
  21. 63 automatic trans question
  22. mc on 51 landcruiser
  23. 50 champ vacuum wipers
  24. 50 champ high beams
  25. T-cab ? rear windiw install and glass polisher
  26. Looking for OD Solenoid
  27. Pertronix and Plug Gap....
  28. Tie Rod
  29. Looking for V8 w/OD throttle bellcrank . . .
  30. Has anyone lost a distributor shaft in an engine?
  31. NOS rubber floor mats--durability?
  32. rear drums
  33. Numbers check
  34. FLAPS part # for a Dana 44 pinion seal?
  35. Avanti crank and timing cover problems!
  36. Dana 27 to Dana 44 brakes.
  37. new wheels and tires help needed
  38. 4 months later, not vapor lock
  39. 41 President Wiper Arms
  40. Hawk parts for a Stude newbie
  41. Horn Problem
  42. That @#$% transmission spacer...
  43. NOS sheet metal
  44. Column shifter
  45. shackle bolts
  46. 57 Silver Hawk tail light housing installation
  47. Flightomatic speedometer gear
  48. Power Steering Box Location/alignment
  49. Howling Speedometer
  50. Changing points in a champ 6
  51. 7 inch rims on 51 landcruiser
  52. Front Sway Bar Advice for Hawk
  53. Six Speed Trans
  54. Avanti turquoise touch up paint
  55. Book
  56. gauge readings with 8 volt
  57. Option costs / 1954
  58. Rear Axle: Pinion Gears - Which one will work?
  59. new oil pump
  60. Hill Holder woes
  61. tire vs shaft rotations?
  62. HEATER VALVE
  63. V8 temp sensor
  64. Building a FWD Stude truck with jeep axles
  65. What adjustments are needed? (update*)
  66. 1950 9" drums, question?
  67. 58 hawk king pin install
  68. wheels
  69. Clutch Issues
  70. Heater hose shutoff
  71. Questions On Building a 289
  72. 56J 15 X 6 wheels.
  73. problem with starting lark
  74. Overdrive Cable Question
  75. Aftermarket wheels for 1950 Champion
  76. Hawk Rear Fender
  77. Re-attaching sheet metal
  78. 61 hawk front end
  79. Paint code for light blue 64 Daytona paint
  80. parking brake adjustment
  81. Paint question
  82. Installation of used Paxton Supercharger
  83. bat wings
  84. Mixed information
  85. 5 Spd. DD for OD swap?
  86. Hanging sheet metal, part 2
  87. '55 Speedster center horn
  88. Steering Gearbox Question
  89. Front junction wiring 1950 Champion
  90. Black hole spotted on 1950 Champion
  91. Unsightly gap
  92. harris control arm bushings
  93. Hydrovac
  94. Power steering issue Avanti
  95. which is heavier ??
  96. miss
  97. Does anybody know the exact model?
  98. Make your own decals follow-up
  99. brake question
  100. Hawk power steering?
  101. spark plug wire holder
  102. steering wheel color question
  103. 259 question
  104. 5 speed in a 58 hawk 289
  105. Picture of Hurst shifter for T85 OD transmission
  106. EXPORT GT Hawks- Right Hand Drive
  107. Old car vs new fluids
  108. Tie Rod Ends
  109. Need help with my '57 Clipper
  110. Rear main seal, Again???
  111. Headers
  112. a-arm rubber covers
  113. T86 Transmissions ... more than one?
  114. Dana 44 Issue
  115. 1950 wiper knob
  116. OHV 6 valve adjusting
  117. 62 lark daytona
  118. 60 Lark VIII
  119. Anyone modded a 2bbl air cleaner for 4bbl?
  120. 1923 Engine Rebuild
  121. Wiring diagram for AM radio...
  122. '50 Studebaker Champ Headliner Installation
  123. Avanti II axles?
  124. Avanti Power Window Switch Installation
  125. Oil splatter out of oil fill tube
  126. More radio questions...
  127. Water pump installation tech tip
  128. thanks for your suggestions
  129. Lark front bumper mounts
  130. question about... "lights?"
  131. Duracool Refrigerants
  132. brake light switch
  133. Champion Engine I.D?
  134. Why Would you do this? Metal plate welded on top
  135. Air conditioner evaporator
  136. "47 M Series-overdrive relay
  137. routing 1960 hawk E-brake cable
  138. overdrive problem
  139. 58 hawk rear end swap
  140. Oil Expiry Date?
  141. caster
  142. Convertible top on my 87 Avanti won't go up
  143. revised starter/generator tag number list
  144. Hanging pedals on a '56 sedan?
  145. Stephen Allen
  146. 1983 Avanti Heater/De-icer fuse issue
  147. Installing Freeze Plugs
  148. Edelbrock carb woes
  149. Early A-Arms with all-steel threaded inner pins
  150. 61 Lark VI Turn Singnals
  151. Control valve kit interchange HOLD OFF !
  152. My custom NOS alternator bracket-photo
  153. help 1960 lark 4 dr weather stripping
  154. where does this go?
  155. Studebaker Part Numbers 101 - Archive
  156. stab. bar ?
  157. Wiring (55 Prez)
  158. 1960 champ truck and lark fan shroud, the same?
  159. Alignment of motor mounting brackets
  160. Color of trunk hinges 62GT Hawk
  161. V-8 Crank and Cam Gear's O.D.?
  162. Here is my 1960 lark for those interested
  163. what are the causes of engine overheating ?
  164. 1962 Hawk Seats
  165. 61 Lark VI Turn Singnals w/ more stuff and junk
  166. T-85 overdrive transmission
  167. Adding AC to 170 c.i. Champion
  168. Headliner backing
  169. Disc brake conversion for my 63 Stude Lark
  170. Rear wheel bearing cleanout/regrease
  171. tie rod seals
  172. Oil pressure
  173. Could use Generator for V8 WTB
  174. '53 Commander Transmission cooling.
  175. Dana 23 brakes
  176. Water pump installation
  177. Sw Tachs & VDO guts?
  178. G.T. Hawk w/rear sway bar
  179. gear lubricant
  180. 1951 Champio Speedometer Removal
  181. King Pins
  182. Zuzu's Mushy pedal
  183. Two Post OD Solenoid
  184. Whooshing sound from torque converter
  185. 1951 Champion Horn Button
  186. Which steering gear should I use?
  187. Precision u joint #329
  188. Distributor Rotor Position
  189. Adjusting the throttle rod
  190. maybe the battle is over
  191. intake manifold?
  192. fuel pump, automatic choke
  193. Core plug woes
  194. Seized engine-hoping for a miracle!
  195. Brake fade when cold
  196. Dana 23 / 27 Axles
  197. Replacement sending unit
  198. simple lighting question
  199. Hawk seat spacers
  200. What the...?
  201. Bellhousing for T-5 transmision
  202. Trunk Liner
  203. any LED tail light bulb ideas?
  204. body filler aggravation
  205. Non-functional new fuel pump
  206. Looking for parts and advice.
  207. R1 Pertronix Question
  208. Tire rub
  209. Red Lines on Avanti's
  210. Valley Pan Bolts- washers??
  211. Interior paint
  212. 64 Daytona vent window
  213. Avanti Passenger door
  214. Filling Holes
  215. Carb riser thingy
  216. dual points help please
  217. carb for 1917
  218. Installing T-5; Need Bell Housing
  219. 61 lark grill panel on a T-cab
  220. Lighting the shark fin (1950 Champion)
  221. Spare tire in a '57 Packard wagon
  222. Gas Gauge Test?
  223. 57 Ross box question.
  224. 64 Daytona Tire Selection for Road Racing
  225. Distributor
  226. oil canister decal question
  227. Hub/Hub Width, 59/60 Lark?
  228. Driveshaft mounting stud?
  229. Andy Granatelli
  230. Avanti wiring diagram "Neutral start switch"
  231. Intake maniford choke heat tube connection
  232. 57 Packard rare
  233. overheating
  234. Speedo cable frame clip location?
  235. Convert top operation
  236. Axle shaft replacement
  237. OD trans part interchangeability, t86 to t85
  238. Automatic with floor shift
  239. Should I paint this ?
  240. Supercharging
  241. Control valve
  242. Using Chrysler Wheels on '54 Starliner
  243. Retrainers for Script and Crest
  244. Coupe door interior trim
  245. backup lights wanted
  246. Studebaker keys
  247. Reinstalling driveshaft
  248. Happy Summer Studebaker Evening
  249. 58 hawk rear springs
  250. B.W. R10 overdrive
