View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Circuit Breaker Location
  2. Fuel economy
  3. Some Inconvenient Trim
  4. Need a mirror post
  5. ebay heads up - 4spd. speedo cable
  6. Dave Thiebault Contact Nos.?
  7. Carb. Needed
  8. as seen in Gord's"Old School Shifter"posting......
  9. Missing?
  10. Dipstick for transmission missing?
  11. Wheels Will Ford wheels fit?
  12. Tires on the Daytona
  13. OK, what's wrong? Take a guess
  14. park gear selection not working
  15. temp sending unit
  16. 63 R2 ignition switch
  17. 1949 Truck Door Lock question
  18. 5H accelerator-to-carburetor linkage adjustment
  19. WINDSHIELD WEATHERSTRIP FIT
  20. V8 piston pinch bolts
  21. wiper wiring
  22. that nasty Zinc and Tappet topic
  23. Real World Labor Time
  24. Trim spears
  25. Chevy 292 in 1940 commander coupe?
  26. Temperature gauge/sending unit question
  27. Headlight aiming
  28. Hurst Cheater Slicks
  29. 50 champion wing window
  30. Aiming fog lights? '53 Coupe
  31. Paint removal
  32. Tie Rod End Question
  33. Correct '55 Engine Pullies and Brackets Color?
  34. Carpet color & type
  35. Help! Need a dust cap for our '54 Commander
  36. Ike comes to life.
  37. Part number
  38. No Brakes
  39. Gonna try to start Bud, need directions
  40. Windshield Interchange???
  41. power brake system on 61 hawks
  42. V8 pushrod question
  43. shortened frame
  44. Avanti Hurst shifter
  45. How stupid am I?
  46. 232 engine swap
  47. seal for C4 canister filter
  48. F**D High Energy Ignition....
  49. Speedster Engine Color?
  50. interchange update and truck shocks
  51. Nimesh inspired Speedometer
  52. Brake conversion advice
  53. Brake lights not working on 50 Champion
  54. Porsche engineer - "perfect Avanti streamlining"
  55. "THE RUST OF US"
  56. Two small transmission installation questions
  57. Ignition cylinder pushed back
  58. Help Again!
  59. Avanti hood insulation
  60. Edelbrock 1403 500cfm.
  61. Location of Temp Send unit?
  62. That d@mn transmission spacer.
  63. tem sending unit removal
  64. 1950 Champion distributor seal
  65. Was Spindle thread?, now Wheel Bearing Nut Torque?
  66. horn test
  67. Ike comes to life, Cont'd.-- Success
  68. Water in the bellhousing
  69. Prevent engine turning, Bad Cam Gear Update
  70. 56 President-what does this part do?
  71. New Production order thought I'd share
  72. Trans insulator installation
  73. Lark wood grain dash
  74. Door to rocker fit on a 53 coupe
  75. body clips
  76. '53-'55 wheel cover center color
  77. Hawk owners where do these wires go
  78. Battery hold downs
  79. Rewiring '64 Hawk w/ GM alternator
  80. Partial-Flow Oil Filter Restrictor Size?
  81. GT Hawk window questions
  82. TRUCK INFO PLEASE
  83. special oil for 61 hawk booster
  84. throttle position on edelbrock carb
  85. float adjustment, carb
  86. Supercharger question
  87. Distributor
  88. high beams work only
  89. R2 Avantis Please!
  90. Airbag suspension
  91. Cable clamp for OD
  92. Removing temp and defroster knobs on Hawk
  93. od transmision
  94. best way to install new floor pans
  95. Hawk horns
  96. Replacing Champion engine drain plug
  97. R2 Accelerator Pump
  98. Lock removal
  99. window regulator roller pins
  100. Need pickup truck suspension helpl
  101. Any reason these won't work on Bud???
  102. GT Hawk door glasses FS
  103. Need Carter carb. drivability help PLEASE...
  104. Rocker Panels
  105. six cyl valves
  106. Sanden in a 55 C-K *with* P/S
  107. V8 Muffler Length?
  108. Delco 1107115 starter questions.
  109. Overdrive problems
  110. Installing a windshield washer kit on Hawk
  111. torque on v-8 crankshaft bolt
  112. engine switch
  113. What about headers?
  114. Rattling wire covers
  115. 1963 vs 1961 suspension
  116. Early Saginaw manual steering box in a '56 sedan?
  117. Hydraulic hub drum remover
  118. T-85/od identification and interchanges
  119. P.S. pump seal
  120. Inner front wheel bearing seals . . .
  121. Survey- reproducing green generator tags
  122. How bad do you want this?
  123. 51 front bumper - deluxe
  124. starter problem
  125. What is it?
  126. 110 volt oil heater
  127. Subject Rear End
  128. front end
  129. Fuel Tank Gage Unit - Problem & Interchange
  130. Propeller shafts & joints?
  131. Power steering on M5 with Studebaker V8?
  132. dumb thing to do
  133. how is rear window moulding held in on a....
  134. t86 overdrive trans
  135. hub caps
  136. Coil Springs...need a source for
  137. 51 landcruiser 6 volt or 12 volt
  138. Timing by vacuum
  139. 12 Volt Conversion
  140. boy those rear fender caps don't fit well do they?
  141. Dry element air cleaner hits underside of hood
  142. Swapping in a 289 crank
  143. Fine thread shock bolts
  144. 63 avanti wiper arms
  145. 50 Champion Gas Tank
  146. trivial question
  147. Gauge Reface How To
  148. Hood adjustment?
  149. Welding to a pitman arm.
  150. EZ Wiring harness
  151. Champion engine plugged!
  152. Stainless molding restoration?
  153. tach sender compatibility?
  154. This would be sooo cool to built in full size!
  155. Cruise Control
  156. Black Soot Fouled Spark Plugs- Where do I Start?
  157. mixture screw setting
  158. Rear main seal
  159. Starter torque ratings?
  160. fuel pump
  161. New info on soda-blasting
  162. Avanti tach sender repair module question
  163. low lead gas
  164. 289 Cam Plug Sealer?
  165. Relay Stuff and Tricks
  166. 1959 LARK VI - MELTING IGNITION WIRE
  167. Oil blow by
  168. that was easy
  169. What a TEASE...700R4 tranny behind a 6 cylinder
  170. Oil flow problem???
  171. Turn signal and brake light gremlins.
  172. Radio upgrade
  173. 911: Need to remove crankshaft pulley immediately!
  174. Glory Halleluiah...The Overdrive is Working!
  175. Strange backup light operation
  176. brake adjusters
  177. Engine running troubles on a 6 cylinder
  178. 60 Lark front fender removal help requested
  179. Avanti Dash replacement
  180. Metal sleeve for rear shock-eye bushing?
  181. Hawk fin strip
  182. The Lark Saga Continues....
  183. Issue with Carb?
  184. transmission change
  185. 4X4 Fuel Tank Issue
  186. water pump pulley
  187. Windshield Sealer - need product info
  188. Pink resistor wire
  189. OHV 6 timing cover coolant drip
  190. Brake drum question
  191. Studebaker Avanti Ground
  192. Air cleaner / production order help
  193. '47 M series
  194. 56 Transtar Clutch?
  195. Look at that radio screen!
  196. 1950 Champion acceleration problem
  197. aluminum cam gear
  198. 55 president dg250 trans
  199. Adjust Trunk Lid on 61 Hawk
  200. Fuel Tank rubber
  201. Rear springs restored
  202. 55 truck seat
  203. 1953-'55 C&K trunk mat photos
  204. Frame use - 53 or 55?
  205. Auto transmission coolant lines - order?
  206. coil question
  207. Cruiser Disc Brakes
  208. lark hood release color
  209. Brake pedal issue
  210. Avanti distributor
  211. Resealing a Stude V-8
  212. Cooler Help
  213. R2 Avanti water pump
  214. Factory installed crack in frame
  215. Fuel Sending Unit
  216. 58PH Overheating
  217. Two different starter solenoids for my 6
  218. Gutter gunk - factory installed?
  219. LOCKED REAR WHEELS
  220. 53 54 grills / 2dr. vs. 4dr.
  221. Starved for oil
  222. T5 to 6cyl adapter and other questions
  223. 50 Commander Front end Bushings?
  224. 1961 Lark Steering Box Adjustment
  225. Ross Steering Box grease question . . .
  226. Chevybaker electrical problem?
  227. 60 Lark V8 vacuum advance
  228. Stude Factory A/C system.. (Long)
  229. Speedster info needed
  230. Where can I get a vacuum advance for a Champion?
  231. Water pump replacement ??
  232. 169 champ 6
  233. ELECTRONIC IGNITION Systems for Studebakers
  234. Any reason I couldn't powdercoat a complete axle a
  235. R1 rod/jet sizes
  236. Fan blade paint
  237. Lark Dash Wiring question
  238. Rear end replacement-help please!!
  239. Champ truck identity
  240. V/8 engine ID
  241. ethanol blends
  242. steering wheel swap need help?
  243. 1950 wiper motor
  244. Wagonairs
  245. Alignment specs
  246. Color of copper fuel & oil lines for 232 V8
  247. newly aquired 1926 coach
  248. 2 Barrel Carter Carb???
  249. Power window motor
  250. temp gage
