View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122
  1. Resistor Plugs and Wires
  2. how do you remove the lock cylinder from the igni
  3. windshield rubber
  4. Need an OD favor
  5. Check this Truck Out?
  6. Just ordered an exhaust system from Don Simmons.
  7. Fram Orange Paint
  8. Re-use of old cars greener than hybrids?
  9. Winshield in
  10. Setting timing with Pertonix ign.?
  11. Horn Problem
  12. Avanti car cover
  13. Block without a stamp near the oil fill tube
  14. Studebaker Performance Manual
  15. Removing rounded-off master cylinder bolt
  16. Free wheeling & reverse
  17. Buying Oil in Canada?
  18. V8 engine identification
  19. Early vs. full flow 289.
  20. Avanti AC
  21. Hotrod 101 - wireing electric choke
  22. Got the Lark on a dyno today
  23. Stupid Studebaker steering question.
  24. N.V. 4500 into Stude Pickup?
  25. Help Identify T-85 Part
  26. Speedometer "self help".
  27. Fusible link or maxi fuse
  28. V8 vs SIX pushrods are they the same lenght?
  29. compatible transmissions - O.D. manual - bad news
  30. can you get factory build sheet from engine number
  31. Stude Shifter
  32. compresion on engine
  33. wheel cylinder leak
  34. Floor Jack
  35. tech question #1 - aluminum trim repair
  36. V8 overheating issues
  37. 1964 overdrive problem
  38. 1937 President 3C
  39. Gas tank Woes
  40. body lines
  41. Which is it?
  42. Champion distributor
  43. Fuel starvation?
  44. Barrie Automotive Flea Market
  45. Great sourse for brakes parts
  46. voltage regulator
  47. 56 wagon owners
  48. Installing Reverse shift shaft T10
  49. Brake light switch
  50. FlightOMatic-fwd no rev after rebuild Please Help!
  51. Starter problems
  52. need a tuneup
  53. correct color engine paint
  54. C&K cowl seal
  55. Manual Shift Chevy-Baker
  56. Clutch Adjustment
  57. 53/54 C/K tail light housings
  58. How to Stop Smoking-50 Champion
  59. easy swap?
  60. M5 fuel gauge
  61. Where to get Holley kits?
  62. Centre Bellcrank
  63. TAIL LiGHTS 50 commander 4 dr
  64. 63 R2 Avanti Engine
  65. 55 Commander 224 V-8 Engine Paint Sample
  66. Gas gauge querie
  67. Metal type? Repair?
  68. material for screws
  69. Full tank fumes!!!
  70. LED lights for a Stude
  71. VIN location(s)
  72. arm rest interchange
  73. 64 to 66 Door ID ?
  74. 1950 Champion horn button
  75. 1960 V8 combustion chamber changes
  76. Cylinder head bolt leaking anti freeze
  77. NEW Fumes & gas tank CAUTION
  78. Power Window Motor Removal-Avanti
  79. Spedo cable part number?
  80. 1958 Golden Hawk t-85 overdrive transmosssion
  81. Generator light stays on
  82. Catwhiskers: On door panels/ R&R
  83. Where to Get Brake Cable for 1951 Champion?
  84. radio doesn't work
  85. 51 V8 correct water pump number
  86. venting a gas cap
  87. 55 speedster automatic dg250m
  88. 1958, 3 speed overdrive problem
  89. 50 (?) R5 identification
  90. NOS wiring harness? Anyone use one?
  91. Sill panel, Rubber mat
  92. Voltage at Sending Unit
  93. 1950 Champion overdrive problem
  94. 56 wagon backup lights
  95. frame
  96. Lark Convertible Top Weather Seals
  97. cleaning 53 dash trim
  98. Engine noise
  99. Thermostat
  100. 66 230 carb
  101. Resistor Plugs
  102. Alternator replacement
  103. 1958 Packard Oil Filler Cap
  104. L E D's
  105. new spring issues
  106. 54 C/K frame fix
  107. Chevy manual trans swap.
  108. Optima battery
  109. Floorshift conversion for T-86/OD.
  110. Studebaker Keys
  111. compression
  112. Zip Van Parts Help Wanted
  113. 51 Comm Front Fenders fit 50 Champ?
  114. Whistling Noise at 40 MPH+
  115. Studebaker brake parts source
  116. Weird horn behavior
  117. 55K underbody question
  118. Rust removal
  119. piston pinch bolts
  120. Retractable antenna
  121. Why are tube radios polarity sensitive?
  122. Crumby Stude day
  123. Power brake question
  124. Wiring question
  125. Chevybaker Trans Crossmember
  126. front shocks
  127. T85 long tailshaft housing length?
  128. Studebaker shop coat
  129. engine removal
  130. 259 Origins
  131. Swage Cutter? Who needs one!?! BAH!
  132. Water boils after stopping
  133. Tachometer
  134. Hydraulic Clutches for Dummies
  135. Help R2 Hawk/Lark Carburator Part Needed
  136. Early Champ remote brake reservior
  137. Need assist in identifying
  138. Avanti window motor
  139. Strange happenings
  140. damage to clutch from worn out T.O. bearing
  141. Engine Conversion
  142. Dana 27 in a V8 car?
  143. 1953 brake drum diameter difference
  144. Body Panel Fit
  145. O.D. Relay Rebuild works GREAT!
  146. Mystery substance
  147. Overdrive Govenor Rebuild
  148. Three Post Battery?
  149. 2 "drain plugs"
  150. temperature gauage voltage change
  151. Check valve
  152. Electric Fans-This is Weird
  153. Seized brakes
  154. fixing a hood curve
  155. Help!
  156. Anyone with a '57-64 Truck Shop Manual?
  157. 1956 dome light frames
  158. Modified M5 Help.. everyone can pitch in...
  159. Brake lining
  160. How do I grease this?
  161. Old School Floor Shifter for T86, part one.
  162. Adhesive
  163. Am I bass-ackwards again?
  164. DG250 taking off in second
  165. Hot rod 101 - Electric wipers on M5
  166. Bolts
  167. Vindication! - was "Am I bass-ackwards again?"
  168. Resistor Plugs in R1
  169. 289 Vibration Damper Flywheel install/marks
  170. dumb harmonic balancer question
  171. A/C question attn: Frank Starr
  172. transmission "okie engineering" question.
  173. 56 wiper switch
  174. R2 Carburetor Leaking from Throttle linkage
  175. Directional pilot lights
  176. avanti R2 tach.rpm's
  177. 63' Cruiser:door sill weatherstripping install ???
  178. CAD testing of '63 Studebaker disc brake bracket
  179. head gasket leak
  180. How do I get the engine to sit in the mounts?
  181. Why to NOT use fiberglas on metal
  182. S.W. greenline & stock gas gauge question
  183. Vintage tach wiring.
  184. Studebaker tie rod ends?
  185. firewall grommets
  186. Oil line to oil gauge...
  187. Intermittent wipers revisited-simple instructions
  188. Avanti Brake pad install?
  189. 62 hawk gas gauge
  190. Installing new bushings
  191. New floor pans
  192. Chrome in Houston, Texas
  193. 57GH Letter Code?
  194. brakes on 1963 lark wadonaire
  195. Spring ID
  196. Flickering Headlight Switch???
  197. 56 Golden Hawk engine...
  198. Starter solenoid....1961 Hawk
  199. Pulling the steering wheel on a 49 truck
  200. Quarter windows on "C" coupes
  201. v8 oil draindown / blowby venting
  202. Engine Problem
  203. 50 Champion rear split window seal
  204. Supercharging
  205. Any body/paint shop reccomendations in SoCal area?
  206. Adjusting V8 valve clearance
  207. brake light ghost
  208. Painted Superchargers
  209. last junk yard run 08
  210. Front Fender Seam
  211. spare tire cover
  212. Stude GM engine & oil
  213. Avanti AC Clutch Diameter
  214. Fuel Line Size - pump to carb
  215. Brake Lights Have a Mind of Their Own
  216. Brake re-assembly help needed
  217. 64 grill/headlights???
  218. Starter again
  219. Distributor end play
  220. Still looking for brake shoes or linings for E38
  221. 1973 Mobiloil: Detergent?
  222. a little starter help
  223. battery hold downs
  224. avanti windshield wipers stuck
  225. Installing 3 point seat belts in Hawk G.T.
  226. Engine Oil and Zinc...yada yada yada..
  227. Water manifold
  228. Anyone else rebuilt a T85/89 lately?
  229. 59 Lark Auto Transmission
  230. Please Id Key chain
  231. rubber trunk seal
  232. Cleaning Block out
  233. Left hand thread wheel lug nuts
  234. Second Opinions Wanted Champ Six Engine Problem
  235. Editorial - Brake Problems
  236. RA Ratio ?
  237. Heater Core Bi-Pass Avanti
  238. the guy at the next booth vs 30 years of SAE paper
  239. A frame bushing seals
  240. Oil filter outlet flex hose
  241. 10% ethanol gas & my ’50 Stude.
  242. what A/C compressor?
  243. Correct battery bracket for '64 Hawk
  244. Avanti A/C vent Fix
  245. Automatic Transmission Fluid Type
  246. Trivia question
  247. wheel color
  248. how am I gonna fix this? Trunk lock.
  249. Hawk radiator
  250. changing the front pulley ??'s
