View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Windlace Help
  2. Parking brake cable
  3. Oil Pressure Line to Gauge in 245 engine
  4. Re: Several Typos and Omissions in 245 Engine
  5. Creative solutions - broken wing frame
  6. Power Steering setup
  7. Horn button spring
  8. Replacing lug bolts
  9. Seat back side adjusting screws needed of '54 hdtp
  10. Frozen Piston Pins and Clamp Bolts
  11. Hurst 4 speed linkage
  12. R2 Damper timing marks-mystery solved!!!!!
  13. 7 hours later and half of the frame is done . . .
  14. body interchange
  15. Negative or Positive?
  16. Budd Co. '53 Commander, glass polyester body?
  17. hawk body mounts help needed
  18. Hydrovac Maintainance
  19. Seat Belt Installation
  20. M-5 Crisis! Help!
  21. Clutch interchange
  22. Kill switch ideas
  23. Overdrive kickdown switch
  24. 1964 overdrive problem
  25. R2 Hawk Filter Canister Measurement Question
  26. working with pot metal?
  27. shock absorber cross reference
  28. Fuel Pump Replacement
  29. 56 Commander Head Light Rings ??
  30. 59-61 back up lamp templates?
  31. How much does a 1962 Studebaker Champ Truck Weigh?
  32. Cam Bearings?
  33. Rear engine mount help needed.
  34. heat shield for 6-cyl manifold
  35. inline 6
  36. Upgrading a rear end
  37. Studebaker lark- gas mileage
  38. Head casting numbers again
  39. Ran when stacked...
  40. Hard Steering Champ
  41. Seat belts
  42. Rack and Pinion
  43. M5 distributor goof - turn lower shaft 180?
  44. Transmission noise
  45. Stude disc brake parts available @ S.B. swap
  46. Lug Removal?
  47. V8 cylinder head torque specs
  48. Partially Decoded Production Order
  49. ring and pinion
  50. Replace Master Cylinder?
  51. Wheel cylinders needed for 64 Wagonaire
  52. Oops, also need master cylinder for 64 Wagonaire
  53. 1956 Studebaker Powerhawk horn button
  54. SN93 Paxton Superchargers
  55. Hopin the engine will turn?
  56. Ross Steering Box Bushings
  57. Avanti questions ?
  58. Cooling thoughts, questions and the like.
  59. Flightomatic problem
  60. Opinions Needed - Serial Number Plate
  61. indentify M5 truck
  62. Cruise Contols 1965 Daytona
  63. water pump weep hole orientation
  64. Model 44 brake interchange question..HELP!
  65. Changing the distributor in a '59 Lark V-8
  66. Hanging a door
  67. Something new 55 prez
  68. Pulled the ported heads off the Hawk engine
  69. pulley/damper bolt philosophy
  70. Dana 44 rear axle
  71. 55 Speedster-Side Grill Sections
  72. New Guy Saying Hi
  73. New traction bars
  74. Positioning traction bar brackets on frame . . .
  75. sound dampening
  76. pinion seal
  77. champion 6 cartridge oil filter, where to hook up?
  78. Differences among front wheel hubs?
  79. v8 crank hub dimensions requested
  80. modern plastic inner fenders fo 61 Hawk
  81. part requests forum
  82. Crank Bolt pattern
  83. Paxton supercharger
  84. Part number cross reference
  85. Studebaker floor mats
  86. hawk coat hooks
  87. Trunk mount battery progress
  88. 1959 Lark Engine serial number
  89. ZDDP additive
  90. Vent window frames
  91. Part needed
  92. Steering Wheel Adapter
  93. engine Serial Number
  94. Heat duct under 61 Hawk
  95. which way valve springs
  96. Clutch chatter
  97. silver hawk engine swap
  98. early and late 51 commander fuel pump stand
  99. STAMPS
  100. 259 rebuild - Ring Gap
  101. building a 202cu. engine
  102. Studebaker vent doors
  103. Touchy Accelerator
  104. Big Six- HELP WANTED!!!!!!!!
  105. Avanti Steering Column Seal Plate
  106. Door Handle spring replacement
  107. heat? 1959 Lark
  108. How do you check for unwanted battery drain ??
  109. Starter Cut Out and Backup Light Switch
  110. 1962 champ 7e7 wheel questions
  111. Help - Quick Steering Arms Won't Align
  112. Rear Exhaust Hangers, 58 Golden Hawk
  113. Adapting M 5 temperature gage to Stude V8.
  114. Front glass on a Hawk
  115. How close is too close?
  116. 64 Hawk grill
  117. Avanti water pump part number
  118. Auto Trans ??????
  119. R2 cam lobe lift loss
  120. V8 Crankshaft Differences
  121. kick panel trim , Part #/dash color???
  122. A-Arm Rebound Bumpers
  123. flathead 6 185 valve adj.
  124. Brake questions
  125. Tranny Snap Ring Pliers
  126. voltage regulator 1962
  127. Rear Axle: Twin traction questions.
  128. 1962 lark wiring harness needed
  129. 1957 Golden Hawk- Engine Detail
  130. Voltage Regulator for Avanti
  131. OD question...yeah, another one
  132. Avanti crank bolt needed
  133. Hood springs on a 61 hawk
  134. vent door springs
  135. Lark taking on water
  136. 12 volt neg ground gauges
  137. Brake shoes
  138. 63' Cruiser rocker mldg. Install ??
  139. Carpet dye ?? Bad decision....
  140. Cuttin' Coils
  141. can't get key out of lock
  142. 6 Volt Heater blower motors?
  143. Installing a Hawk aux heater
  144. Looking for a heart
  145. Fuel filter
  146. Touch Up Paint
  147. Lark brake parts
  148. Bad Gas Gauge on 59 Lark
  149. newb needs to be schooled
  150. Stude Valve covers for the 66 283 V8
  151. Transmission leak, 1953 Starliner
  152. Fuel Pump Location
  153. Cone clutch
  154. 1949 Truck VIN Location
  155. Engine Size 333 cid?
  156. Help, please
  157. Disc Brake Piston ???
  158. Trunk mount battery progress
  159. 1961 hawk exhaust question
  160. Water Pump ID
  161. Turbo 350 transmission questions
  162. Replacing rocker panels on Hawk
  163. HELP ASAP! Tightening of Crankshaft Bolt?
  164. Production order help
  165. SPEEDOMETER CABLEI
  166. Avanti blower switch
  167. 1964 Daytona Rear Brake Drums
  168. Progress! Thanks to Matthew
  169. 1950 Champion coil bracket?
  170. 61 hawk front hub question
  171. Rear Hubs, AC for 61 Lark
  172. Difference between Sedan and C/K wiper motors?
  173. engine rebuild, 28 dictator
  174. drilling door locks
  175. 1959 Silver Hawk turn signal switch help
  176. Hawk GT steering belt orientation?
  177. Decal removal
  178. welting
  179. 1936 4 door
  180. Leaking Master Cylinder
  181. 60 Lark 8 resurrected
  182. window rubber replacement
  183. How was imy '55 President State Sedan designated?
  184. M5 with 12 volt sending unit.
  185. 232 engine oil
  186. New website about hypermiling
  187. Carb application
  188. T5 onto Champion 185
  189. Studebaker OD trans
  190. Installing later brakes on 53K
  191. More progress on Leo, 4 pix
  192. No oil filter?
  193. Nimesh Blower/HO Pulleys worth the effort
  194. Cheap flat six
  195. Avanti instrument panel lamps dimmer resistor
  196. Brake Bleeding - Forgot stuff
  197. What Did I do Wrong
  198. OD follow-up
  199. '47 wiper system needs help ??
  200. 1957 GOLDEN HAWK RADIATOR
  201. overdrive
  202. fanshroud paint ?
  203. Hawk rear fenders
  204. bad brakes on 55 Speedster
  205. Water Temp Range-What's Normal?
  206. Dead gas gauge
  207. I give-up! AC-2409 gas door guard...
  208. Cheap 'bondo' mixing boards
  209. 1950 coupe rear window seals
  210. What is the right fuel line hose clamp for 1954
  211. 1960 champ pickup radiator shroud
  212. Borg-Warner T85 rebuild parts wanted
  213. Plug wire guides
  214. Window reg bolt
  215. 61 Hawk rear quater fender question
  216. commander starts hard
  217. Powershift Troubles
  218. Engine balance
  219. Ebay auction for '53 "Flight-O-Matic"
  220. steering box option
  221. New 1933 Distributor Cap
  222. Differences between Lark & Hawk reclining Buckets?
  223. 1949 R2 Pickup
  224. Exhaust tips
  225. bench testing a gas gauge and send. unit ??
  226. Hood springs
  227. Fuel System: wcfb starvation
  228. paint question
  229. electronic ignition wiring question
  230. 3 Spd. OD gear ratios and Dana 29 posi?.
  231. Transmission oil
  232. Crazy solution for bad Avanti brakes
  233. PS pulley
  234. Engine # differences
  235. Hawk rear bumper support bars
  236. Ideal 289 cruise RPM?
  237. R1 Spark Plugs and Wires
  238. R 1 Valve Stem Guides
  239. What is it?
  240. Which hub tool ?
  241. Follow up to crazy solution for bad Avanti brakes
  242. gaskets
  243. Any Follow Up on American Classic Tires?
  244. Changing Engine Number
  245. coolant hole in one end of head
  246. radio
  247. ac compressor for 64 Avanti
  248. original 62 champ p/u chrome Mirrors
  249. Seat back adjusting screw fix
  250. Hood tie rod anti-rattlers
