View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. Upholstery Color
  2. Installing windshield washer in 1953
  3. IDing bell housing
  4. Need Hill Holder Identification
  5. '53 232 V8 Stromberg 2 barrel question
  6. Picture of "factory" traction bars on a LARK?
  7. gas tank..cleaner
  8. Steering column floor seal?
  9. 58 Hawk wheel well color
  10. carburator for 1953 stude 3/4 ton truck
  11. 700R4 chevy rransmission kit
  12. 1926 Studebaker super six
  13. 51 V8 tick source.....
  14. New 259 pistons .010
  15. Studebaker to Prestolite p/n cross reference?
  16. 1952 Chrome stinks - (an update)
  17. Torque converter tool
  18. 1959 Lark 6 Carb trouble
  19. parts
  20. Locating Engine and trans Numbers
  21. Directional signal switch wiring
  22. windlace install: rear upper quarter trim (Lark 4
  23. Tranny compatability
  24. Racing mechanical fuel pumps
  25. Steering "Shock Absorber"
  26. sterring play
  27. Avanti Clutch Linkage Issue
  28. crankshaft end play
  29. How Aggressive Would You Go?
  30. Gas tank, does it need to be sealed?
  31. 59 lark front springs
  32. hawk frame lift points
  33. Bendix Drives
  34. correct hose clamps for a 60 hawk.
  35. Hard shifting problem with 3 on the tree..
  36. 1961 Studebaker Lark VIII Transmission Questions
  37. fin history
  38. 1950 Starlight Coupe Vent Window Seal Problem
  39. Trouble Bleeding Hawk Brakes
  40. adding an oil filter to a 1960 259
  41. Looking for a carb
  42. 62 Hawk parts
  43. Door & Floor & Kick Panel
  44. change of color on windlace?
  45. Stromberg WW on a Lark six???
  46. help with lark
  47. Gas Gauge Sending Unit
  48. fuel filters
  49. 53 dash paint
  50. R2 cam in a 1957 Golden Hawk Engine
  51. 1951 Commander rear brake pad
  52. Hood spring help needed
  53. v-8 or straight 8 engine #'s
  54. Tie rod end dust cover
  55. 56 K--BODY QUARTER WINDOWS
  56. hawk dash question
  57. Avanti Power Windows
  58. 1950 Door Locks
  59. What would happen if......
  60. which hole in bell crank for sealed carb
  61. V8 Intake Gaskets
  62. Weight of front and rear bumpers on Studebaker
  63. Are Lark headlight assemblies similar to Avanti?
  64. Fog light bumper guards
  65. carbon di oxide in radiator
  66. What do you use in overdrive unit
  67. 1962 hawk brake trouble
  68. no reverse gear in 150 automatic and
  69. rear brakes
  70. 6 cyl. engine rear seal leak
  71. shop manual
  72. Electric Wiper Motor For 49 2R
  73. SPEEDOMETER
  74. Tire flat spots
  75. cadillac engine swap lark wagon 1959
  76. Vapor Lock
  77. SJ oil
  78. Embroidery - Excellent Work
  79. I got my Production Order today !
  80. Redline Lube Products Experience
  81. Overheating 1950 Champion
  82. setting end play
  83. Need Hawk Fender
  84. crank shaft swap
  85. Headliner adhesive
  86. 1962 STUDEBAKER HAWK
  87. Part ID help please
  88. clutch help
  89. Chroming Valve Covers
  90. Need help on Identifying Flat Head 6
  91. Three Point Saftey Belts
  92. Question for those in HOT climates
  93. Pulling Spedo Drive from t10
  94. '47 rear glass install how
  95. Question on Avanti fiberglass components
  96. Help with Avanti rear body pan
  97. Junk yard full of stude
  98. Motor Color 1949 truck
  99. 2R5 Truck front suspension options?
  100. Radiator hoses/belts '58 Packard Hawk
  101. Parts numbers
  102. 245 Commander Engines
  103. EMERGENCY BRAKE
  104. 48 champion overdrive location
  105. Supercharger Service
  106. Avanti power window wiring diagram
  107. Any tips for changing heads?
  108. Yellow Valve Covers...INSIDE?
  109. Auto.Trans. Fluid-type "A" ?
  110. What's the difference on Wheel Cylinder
  111. Removing set screw?
  112. Wheel-Tire combos...
  113. Avanti pwr window mtrs when are they bad
  114. engine identity
  115. Rear brake shoe question?
  116. 48 champion overdrive pics
  117. 61 Radio
  118. 3 access holes in floor ?
  119. Headliner head-banger
  120. new to the board and studebaker
  121. The Plan
  122. Wiring harness
  123. Four speed shifter in 63 Hawk making noise
  124. Body Man "Tricks-of-the-Trade", Please!
  125. problems with idler pulley on r2
  126. Corvette disc bakes on a Stude Dana 44 rear end
  127. '53 Commander overdrive color?
  128. How do you install trunk lid springs ??
  129. engine pics
  130. '50 trunk lid alignment
  131. R series balancer repos...
  132. 1950 Champion Carter WE Throttle body
  133. 1965 Daytona Sport Sedan - Rubber Replacement
  134. u-joints and pinion seal question
  135. Crushed fuel line
  136. Horn wire through steering column
  137. Engine Turning effect..
  138. Defroster Motors
  139. Engine Break In
  140. wheels
  141. Reach Rod Expertise Needed.......
  142. Pan gasket application
  143. battery dust
  144. Brake parts kit
  145. oil filler
  146. 1955 Truck - 6V Blues
  147. Rides like a Studebaker
  148. 1963 GT Hawk Wheelcovers
  149. The engine...she's a-blown
  150. Gas tank for 59 lark
  151. FINAL FIX!! Drums won't fit over shoes - FIXED !!
  152. Checking automatic transmission fluid
  153. Drag Links
  154. Ingvar Vik fuel pump
  155. Carb swap ??
  156. Dressing up the generator
  157. wipers
  158. hood ornament chain, 28 dictator.
  159. Fuel problem
  160. Tuning an Edelbrock carb
  161. Avanti pw motors OK after all
  162. carb info on 52 2r10
  163. The simple things.
  164. brake hose
  165. Parts interchange..
  166. Looking for a "63 or '64 4 core radiator
  167. fuel line material
  168. Booster spacers on DB Lark
  169. steering wheel
  170. 6 Cylinder clutch housing and flywheel
  171. The continuing saga of the "mystery" bumper guards
  172. how do I get rear main seal out?
  173. 1962 Hawk Stainless Trim
  174. 1 Barrel Carb. Problem
  175. Door closure problem
  176. Hood Springs
  177. 4 lug wheels to 5 lugs
  178. !965 choke thermostat
  179. 3 Core HD radiator or Aluminum Custom?
  180. 1960 Lark VIII 4 Door Measurements Pls!
  181. Hotrod 101 - Using Volvo rims?
  182. Transmiision kick down
  183. Are Hawk and Sedan front bumpers the same?
  184. Steering Wheel Repair
  185. Steering Shaft Replacement
  186. interchange- larks
  187. champion 6 bell housing swap?
  188. 3 speed overdrive hookup questions
  189. Lark 59
  190. correct finish for underside of '53 Champion
  191. Thermostat - Is it really needed?
  192. 6 cyl year id
  193. Carb interchange
  194. De-stroked engine?
  195. Universal Joints for 46 M5 w/ 4 speed
  196. Differential ratio
  197. Axle Part Number?
  198. '65 Cruiser air filter
  199. 'Locked' Shifter -- help
  200. sneaky pete not good enough
  201. Tires
  202. Shoulda bought that Scotsman!!!
  203. 245 commander carb needed
  204. V8 in A 51 2R5
  205. Corvette brake Conversion Problems
  206. 1951 commander v8 engine color
  207. 58 packard hawk dash removal
  208. SAE papers
  209. Help with hood to cowl seal
  210. Chevy AT swap.
  211. Vacuum Metalizing of plastic
  212. crane numbers
  213. Hawk auxillary heater switch help
  214. 195 75r 15 tires on a 1955 president
  215. Rear shocks for a '56 sedan . . .
  216. Rocker Switch Source
  217. Convertible top frame help and update..
  218. Need a 2-pc driveshaft for '56 V8 sedan . . .
  219. Brake Fluid
  220. Hardtop rear window rubber
  221. 61 Hawk Jack Storage
  222. Door check pins
  223. Tire over spray
  224. when does the boost come on
  225. 224 motor
  226. 6 pumps on a carb to start
  227. Chevy V8 in 59 lark?
  228. Crank Snout
  229. Sticky valves-Sea Foam?
  230. Radio repair references? Had one done, lately?
  231. 64 Daytona Fuse Location
  232. Brakes - 58 G.Hawk/ w. power brakes
  233. What is "LARK SHINE" ??
  234. flathead 6
  235. Recommended engine oil for R2 63 avanti
  236. Flex Plate
  237. Pertronix for Prestolite distributor
  238. Hydrovac plumbing
  239. redi/speedi sleeve specifications
  240. truck 3 speed floor shifter?
  241. Avanti hog troughs
  242. Car V8 F*rd Pattern Bell Housing Needed
  243. Valve Adjustment
  244. Golden hawk tach
  245. 1950 Champion glove box lock?
  246. rear seal is out! but those little corks?
  247. Are these the same plug?
  248. Where Is the Oil Pressure Sending Unit Located...
  249. Tire Question....Answered Even Though Not Asked.
  250. 59 Lark rear end width?
