View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. A tester???
  2. Pat Skelly... Sunday CASO At It's Best!
  3. Engine color
  4. Build Sheet
  5. Reasonable Highway Speed
  6. Engine rapping noise
  7. 47 Champ - wire to coil?
  8. Ring ridge in V8 block
  9. Mallory Rev-pol
  10. Champ 3 speed
  11. Decoding Vin' s
  12. How to tell a six volt compared to a twelve system
  13. How to tell a six volt compared to a twelve system
  14. TV linkage position
  15. 1957 transtar wiring
  16. rack and pinion expertise
  17. Door lock Help for M pickup
  18. Door Rubber Seals
  19. valve lash
  20. T cab seat
  21. Dual M/C for Turner bracket
  22. Flanged rear axle R3 Avanti's
  23. OHV 6 Cranks and pilots for Y1
  24. M5 Cab and Core Support Mountin' Rubbers?
  25. compression ratio for six head?
  26. engine numbers
  27. Experience with Lionel Stone's aluminum heads and
  28. Speedo gears
  29. Tricky paint spot
  30. Fuel Injecton
  31. Six Engine and trans. I.D.
  32. What chrome polish do you use?
  33. Trusting old seat belts
  34. Carburator rebuild or replace
  35. 28 dictator leaf springs.
  36. Differences between valve bodies
  37. Low Oil Pressure
  38. Carter AFB
  39. Correct Engine Colors - last and for all?
  40. 1958 Studebaker - positive or negative ground?
  41. Need some Pulley Advice
  42. Some advice please, clutch change, long but please
  43. Help ID'ing weatherstrip
  44. Proper temperature sender for '56 Hawk gauge
  45. Painting over pitted chrome
  46. Type oil and a fuel pump
  47. Selecting a rearend for pickup
  48. First Gear Start for Powershift
  49. Coil Spring installation
  50. Power Steering Pulleys Don't line up on R2 engine?
  51. Overdrive electrical problems
  52. Fuel pump [?]
  53. Engine: 1554641 VCD422
  54. v-8 ,starter and ring gear
  55. weight
  56. NAPA clutch
  57. '61 Lark bumper on a '59
  58. Backup Light Gasket
  59. slow cranking. No starting
  60. Runaway Truck
  61. floor pan replacement
  62. T-86 to SBC adapter?
  63. Fairborn/flanged axle question-Ted opinion??
  64. 63 Lark under dash controls
  65. Engine Number 3EK304
  66. T86 bolt pattern change date?
  67. 55 C&K RADIATOR SWITCH ?
  68. '59 Lark interior colors
  69. 1923 Light 6 Touring
  70. Generator Bearing
  71. Carburetor Woes - '58 259 4V
  72. Breather
  73. Replace timing cover seal
  74. Front brake hoses 62 Hawk
  75. PS Control Valve Needed
  76. Hardtop Door Glass Removal
  77. 60 Hawk moulding removal
  78. Differences between valve bodies- part 2
  79. overdrive solenoid
  80. Champ Transmission Mount Question
  81. Part Number 1549575 What Year/Model is it?
  82. Seat Cushion Thickness.
  83. Stude V-8 Head Question
  84. Expert zopinion on Dexron III Needed
  85. Removing Horn ring?
  86. Defroster motors
  87. Glove box clip, part no?
  88. rear view mirror color
  89. Avanti booster studs
  90. Assembly order
  91. Fuel Pump Rebuild Kit?
  92. engine compartment colors
  93. twelve ton jack stands
  94. Frame crack
  95. 1951 Commander backing plate
  96. The worth of a Stratoline radio?
  97. Brake shoes
  98. Surging ohv6
  99. keys and more keys
  100. Clear Coat
  101. Flathead Six Oil Restrictor and weird Findings...
  102. '62-'66 Lark Type Heater Valve Connection Archive
  103. Horns
  104. 53 coupe question
  105. Overdrive Unit for 1954 2R5 pickup truck
  106. Champ truck cabs
  107. Window sweep clips
  108. Hood Latch
  109. Slick Street Stuff front suspension setup?
  110. window scratches
  111. Windshield wiper moter wiring help
  112. 55' Hood Ornament
  113. FRANZ BiPass Oil Filters
  114. Hawk hood latch
  115. Gas Tank Sending Unit
  116. Gloss or Satin?
  117. fuel filter before or after on r2
  118. Automatic Drive
  119. Who rebuilds Avanti Brake Boosters?
  120. Engine and Trans swap
  121. V-8 Weight
  122. 1962 Hawk Body Color and Wheel Interchange
  123. nameplate retainers
  124. 259 Main Bearing Clearance
  125. V8 vs 6 cylinder again
  126. Stude repair in Maryland
  127. Starter...
  128. Avanti Dash R&R
  129. GT hawk 1963 engine ?
  130. 53 coupe steering box
  131. ...On a 64 GT Hawk, where...
  132. C K Parking Brake
  133. Radiator Interchange?
  134. rear end
  135. Stainless Restoration #10, Lip Service and Speci
  136. Removing Body from Frame
  137. for those of you who drive at night
  138. Value of New R-3 Headers
  139. Engine swap
  140. Exterior Color Options
  141. How NOT to hurt the Hawk?
  142. Clutch Alignment Tool - necessary?
  143. 2 piece driveshaft/new rear springs
  144. Need part number for exhaust flange gasket
  145. 12v equivalent for #1129 bulb?
  146. light sockets attn: Barry
  147. Overdrive test
  148. 1917 bus engine repair
  149. 259 Pistons
  150. Dual Master Cyls
  151. Brake repair story
  152. '64 Hawk - Master Cylinder - THANK YOU!
  153. FRONT SUSPENSION BUSHINGS
  154. 1966 Engine swap
  155. E-brake cable attachement location
  156. Avanti oil pan removal
  157. Brake drum interchange
  158. tire size
  159. Pillars & fuel pumps
  160. t-86 w/od conversion question (short/long tail)
  161. Battery Hold Down
  162. Sound silencing and comfortable ride
  163. Duel action fuel pump?
  164. new guy with 52? R series, with questions
  165. Lark Parker's Stainless Resoration Series archived
  166. Solid brake line replacement
  167. Cracked main thrust bearing cap
  168. Defroster ducting
  169. Tach sending unit
  170. Brake conversion on 52 Stude Champion
  171. Need help with a firewall grommet
  172. 55 President Motor Mounts
  173. lark grille emblem
  174. Headlight bucket finish on 54 C&K
  175. 55 Champion Trans Help
  176. 259 pistons...
  177. 1960 lark w/Webber 5200...how's it working?
  178. Spec. 1952 169 CU 6 cyl Engines
  179. Any West Coasters have a T-85 with OD for sale?
  180. Spacer for Edelbrock CarP 56J
  181. Sky Hawk engine color
  182. stude" restomod truck?????
  183. Timing Gear Opinions ?
  184. Painting Question
  185. Bolt pattern for 1956 1/2 ton pickup
  186. Pilot bushing removal
  187. OD cable sheath repair
  188. vacuum wiper motor
  189. Spotlights
  190. Questions about clover leaf stamped block
  191. Do I have a radio fader ??
  192. '50 Champ rear end lights
  193. Electric fuel pump
  194. shackle bushes
  195. Glass size
  196. 63' Lark disc brakes: Rear shoes/adjust
  197. Brake Upgrade for 6 Cyl Hawk?
  198. 53 body parts interchange help
  199. Instrument Lights
  200. Harmonic balancer puller
  201. Anyone need a 289?
  202. Champ truck clutches.
  203. BT Tuttle and the Black Bart Special
  204. Looking for main bearing cap
  205. Torque converter
  206. Climatizer Pan
  207. anti freeze question.
  208. Sway bar bushings
  209. 7" Chrysler rims
  210. modified hawks and coupes
  211. ADDENDUM anyone need a 289?
  212. 53 cloverleaf 232
  213. 289 Engine For 1957 Packard
  214. Avanti Gauges
  215. where'd my oil go?
  216. Answer to clutch woes, '59 Lark
  217. Windshield Washer Picture
  218. Flight Hawk Parts?
  219. Poor P-brake, R/A endplay mess, ? leaky cylinder
  220. Radio (Delco) question
  221. vapor lock
  222. Driveshaft Removal
  223. Gas tank sending unit?
  224. 50 Champion
  225. Sick 59 Lark 6
  226. 63 Hawk GT rear antenna Install HELP
  227. Smoking 63 Avanti
  228. Replacement heater core needed for '54 Commander
  229. Truck Brakes
  230. 1953 stude 3/4 ton truck engine rebuild
  231. 1953 3/4 ton truck rear bumper
  232. The OHV 185...how many have tried...
  233. Engine rebuild questions.
  234. 1953 R11 truck grill paint
  235. brake lites
  236. 64 Commander Master Brake Cyl Substitutions
  237. OHV 6 block or pistons needed
  238. Six Cyl. Oil Pumps....
  239. Lark Fuel Pump Question
  240. Still having problems with my Overdrive.
  241. full flow blocks, Stude V8
  242. Rear Quarter Window..55
  243. Tech Tip Editing
  244. Windshield moulding
  245. thermostat gauge
  246. '50 Champion gauge overhaul needed
  247. 60 lark 8
  248. Champ Pickup 5 sp. OD Questions
  249. 62 Hawk Mileage
  250. Stude V8 mated to a T86 with O/D
