View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117
  1. Dome Light Question
  2. Neutral safety switch
  3. four speed bell housing
  4. Distributor broke on 62 6cyl engine?
  5. Useage of 4-barrel intake manifold w/AFB
  6. Identify an OD solenoid?
  7. Another oddball question.
  8. piston rings
  9. '55 sedan window regulators
  10. 289 cylinder head question
  11. rear axle seals
  12. 1938-1939 radio
  13. overdrive
  14. Saginaw PS
  15. 49 champion convt
  16. front shocks
  17. lead additative
  18. in line fuel filter
  19. Alignment for idiots
  20. Help Need a Crossover # for Alternator Belt
  21. Carburetor Newer style
  22. 49 champion convt
  23. Dash electrical schematic
  24. Quick change third member
  25. popping in rear end
  26. Brakes
  27. carb base gasket
  28. Stainless Steel brake lines
  29. clamps intake manifold
  30. How To: Front End Alignment - Done at Home
  31. Turbo Charger
  32. overdrives new to me
  33. Adding a Paxton to an R1 Avanti
  34. Hood alignment
  35. Stude V8 in a '50?
  36. Bumper brackets
  37. Lark Standard to Auto Swap
  38. Generator To Alternator Conversion
  39. Pete's got nerve problems
  40. EFI Fuel System
  41. Edelbrock Carbrator
  42. Speedster cap repair
  43. Sway bar
  44. Valve Lash better late than never ? ? ?
  45. Stiff steering 63 Chanp
  46. 55 two tone paint question
  47. "Big Six" Engine Rebuilder?
  48. Got a 64-66 master cylinder interchange?
  49. Need Help Identifying Wheel Cylinders
  50. Plumbing Resevoir to Oil Filler Tube
  51. Need set of clutch/brake pedals for disc brake Lar
  52. 57 Hawk brake shoes slip off anchor block
  53. The worms ate my running boards!
  54. Help identify parts
  55. Flightomatic Tranmission ATF 4
  56. Help Identify parts 2
  57. Starter Bolts?
  58. Easy cure for an old problem
  59. Champion Pick-up with Packard engine
  60. Golden Hawk transmission info wanted
  61. Shocks
  62. 1 5/16" Front Sway Bar
  63. Help Identify 63 R2 Lark Factory Mark
  64. Valve Guides
  65. Rotella T 30 wt or 5w40?
  66. Crossmember replacement?
  67. filling cracks in steering wheel
  68. Pop out rear window
  69. New wiring harness
  70. Detailing clay
  71. 51 champion 3 passenger coupe
  72. Widest Wheel on a '56 sedan?
  73. 63HawkGT "Cat's whisker" replacement help
  74. 63 Avanti Front Signals
  75. Wire from steering box?
  76. Alenator replacement for 63 Lark
  77. Windwing seals
  78. Fuel Pump
  79. 6 volt Headlights
  80. Headlight Switch
  81. Bench testing a coil
  82. Stainless restoration #2, Wooden You Like To Know
  83. Removing stainless drip edge from Hawk
  84. 35 Dictator--are doors and rear fenders the same
  85. Steering column seal
  86. Spark plugs...too hot?
  87. window adjustments
  88. Engine: intake/exhaust manifold gasket
  89. lifter bore OHV six cylinder
  90. Motor I D help
  91. Flightomatic upgrade?
  92. Transmission repair
  93. champ truck tires/suspension
  94. fuel pump leaks oil
  95. Stainless Restoration #1, Speedster Cap Repair
  96. White Rocker Switches, Knobs, Etc
  97. Champion 6 ID
  98. lark wagon taillights
  99. Throttle Bell Crank
  100. IGNITION WIRES
  101. steering wheel puller
  102. Brain Teaser -No start problem -SOLVED
  103. 1958 Golden Hawk Operating Temperature
  104. Flight o matic for 57
  105. Lots of rust inside the cab and trunk
  106. Modern power steering in a 1962 Lark
  107. wheels
  108. A new Substitute Rim?
  109. 51 Business coupe rear window install..help [V]
  110. Wiring harness, repop or aftermarket?
  111. BW 3 band problem
  112. No Current in Hawk
  113. Seat foam
  114. starter bolts
  115. Is that Powershift noise what I think it is?
  116. New guy needs help?
  117. Stainless restoration #3, hammering
  118. Truck Engines
  119. Replacing U-joints
  120. Questions on Avanti fiberglass
  121. headlamp wiring harness
  122. Anyone running E85 in a Stude?
  123. Speedster tach
  124. Repro Parts Wish List
  125. Flightomatic removal
  126. Sparkplugs
  127. Heater Fan?
  128. Poor idling Avanti
  129. spring isolators
  130. '55 gas gauge/sending unit
  131. '60 Hawk Engine Colors
  132. Bolt in ford 9" rear end for '54 C body?
  133. Adding A/C to a supercharged engine??
  134. Tach Drive
  135. Stainless restoration #4, Outside Windshield Trim
  136. engine swap
  137. Surface prep
  138. 63 GT Trunk Overlay Mounting
  139. starter motors?
  140. what's the function of a horn relay ??????
  141. Need a radiator for a 56-58 V8 sedan . . .
  142. American Express Bondo Scrapers
  143. Rear main seal question
  144. Battery ideas?
  145. Brake sizes
  146. T-86 od removal
  147. edelbrock carburetors
  148. 2 Door Quarter Panels
  149. Stubborn Scotty
  150. rearend nubers of a metal tag ??
  151. Fuel pump identification
  152. Vacuum Advance?
  153. Full "right" oil article for Studebaker
  154. Jeep and Corvette shocks for Avantis and Studebake
  155. Crossmember removal
  156. transmission interchange
  157. Transmission: When did Studebaker discontinue the in car trans filler?
  158. Electricity 201?
  159. Radiator tank interchange??
  160. Bent flange on Frame
  161. overdrive transmission
  162. 50 Commander susp same as 63 Lark?
  163. Carb querie
  164. Passenger side mirror on Avanti
  165. Chevy S10 frame under a 1962 Lark?
  166. Stainless restoration #5, polishing/buffing prep
  167. flight-o-matic
  168. Starter woes!!!
  169. clutch question
  170. Pondering my front end woes here.....1962 Lark
  171. Hawk Dash Color
  172. headlight knob 2 pieces ??
  173. Battery Top blown off 57 3E11
  174. VIN decode
  175. Pully Hub-1958 Golden Hawk
  176. 289 motor out bad news 57 silver hawk
  177. 48 champion trans color?????
  178. 48 champion fuel tank sending unit
  179. Removing 52 Truck steering wheel
  180. Pure stock drag tires
  181. License Plate Restoration-who?
  182. Part Identification
  183. How do I install front grease seals in '51 Stude?
  184. mustang II in a 53 Stude?
  185. throtle linkage
  186. Door Stop
  187. T-86 leak
  188. i can't believe it
  189. DOOR STOP PT2
  190. Wiring Harness - 59 Hawk
  191. Powerhawk tail light lens
  192. Can a leather gasket be stretched?
  193. '37 Studebaker body alignment question...
  194. WATERBORNE PAINTS
  195. Correct Coil Mounting Position? 63 Hawk
  196. 64 Lark Front Suspension Solved?
  197. how to install rebound rubber ?
  198. 289 Head Gaskets
  199. Accessory eyebrows 49 pickup
  200. dana 44 ratio
  201. Change rear end gearing?
  202. 62 Lark Questions
  203. Supercharger carburetter problem
  204. Late front sway bar on a 56J
  205. Repairing rubber mats
  206. HVLP paint Systems
  207. T98
  208. Rotary 4 Post Lift - Great Ad Pic!
  209. Upper & Lower Control arm bushings
  210. Carter AFB identification?
  211. Engine: Engine Priming tool
  212. Fiberglass body
  213. Tapered axle removal
  214. part number 1552818 refresh my memory..
  215. Hawk dash swap
  216. Installing Electronic Ignition n 1955 champion
  217. cracked shock towers
  218. Brake failure
  219. 62 Lark again
  220. Another wire harness question
  221. Stock vs. modified
  222. Transmission Band Adjustment
  223. Can I fix this 4x manifold
  224. Identify headliner-1355581x4, '63 Cruiser?
  225. R2 Avanti wont start...
  226. Stainless Restoration #6, What Goes Around
  227. 289 questions
  228. R1 starter vs. standard starter
  229. T10 trans swap
  230. 1937 President 3C
  231. Will 7" wide wheels work?
  232. Disc brake master cylinder
  233. parking lights won't go off
  234. Carter Carb differences..
  235. model 44 axle swap question
  236. air cleaner
  237. Fender Slash Apron
  238. cure for dull aluminum trim?
  239. Another Carter carb question
  240. Other: electric wiper conversion
  241. Edelbrock says "do NOT use Edelbrock"
  242. Gold Color
  243. NOS Stude Oil Filter
  244. Flightomatic kickdown cable woes
  245. R Motors
  246. Brake Drum Question.. Stubborn 64
  247. Champ Frame
  248. Front Suspension
  249. '53 champion chrome removal HELP!
  250. Unpredictable Operation
