View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113
  1. Neat Battery Accessory For Stock Stude's
  2. Got turn signals!
  3. Need shift handle part # for my 63 R1 Lark
  4. Gasket question
  5. Question
  6. How much should go on
  7. PS pump special bolts
  8. Bolting up the starter
  9. gas pedal linkage
  10. Mating the motor with the automatic trans
  11. Changing dash pad color
  12. Distributor position
  13. Better steering box ?
  14. header choices for swap
  15. 63 Lark Trunk Lid Align.
  16. intake/exhaust manifold color
  17. Need a quick measurement
  18. Speedometer Cable T-10
  19. Hurst Shifter for Avanti questions
  20. Intake question
  21. Replace head bolts dry?
  22. Interior Paint 63 Lark
  23. ChevyBaker Motor Mounts wanted
  24. Champ Air Shocks
  25. Part 1555771 Oil Filter Base Plate
  26. t-stat outlets
  27. 59 Hawk quarter window removal help
  28. Brake drum paint
  29. 50 Champion center tie rod
  30. tragedy hits 289
  31. HOW DO YOU POEN THE HOOD
  32. Hawk production. Early? Late? How do I tell?
  33. champ doors
  34. Ride heighth
  35. AC for 63 Lark
  36. Stromberg WW Carb Shortage Explained
  37. Interior Paint 63 Lark Regal
  38. 63 Lark Interior colors
  39. Suspension Shop in Seattle Area?
  40. Help with original body and engine color
  41. Has anyone bought the ebay floor pans?
  42. cylinder heads
  43. Cooling/Hydraulics 101: PO=oops..help
  44. Question on 6 volt 1955 E38 truck, gas sender
  45. Steering Wheel Puller bolt Size 63 Lark
  46. 1 barrel carb on a slant 6 cylender
  47. stromberg oe-1
  48. Champion automatic to standard swap
  49. hydrovac
  50. Synchronizer ring position in T8 trans
  51. Hill holder querie
  52. Another novice question
  53. Steering gear assembly lube??
  54. power locks
  55. striker plate
  56. What engine do I have?
  57. 3 speed M to 3 speed OD conversionn
  58. Need part # s 60 Lark 2d HT rear fender mldgs
  59. Exhaust valve crud
  60. differences in the 3 '55 hardtops ????
  61. Aftermarket shifter for a T86 Overdrive Trans
  62. Measuring Cylinder Bores
  63. Coil spring reinstall
  64. saginaw power box
  65. Brakes: DOT 5 Brake Fluid
  66. 62 Lark 62S-Y4--Horn Relay
  67. rear end paint
  68. Distibutor Cap wires
  69. Removing Bullet from grill
  70. No start after sitting for a week or so
  71. 289 rebuild cost unreal!
  72. build sheet question
  73. headers
  74. crank bolt
  75. '55 engine number?
  76. Instrument module overhaul
  77. Cable Length
  78. 4 bolt mount dual master cylinder replacement
  79. Avanti bellhousing/engine mount - resolved 4 now
  80. More build sheet ?s
  81. Lark nose
  82. Lark "J" hardtop body question
  83. Pulling motor!! help
  84. Borg Warner T86 interangability?
  85. Ether or Starting Fluid not recommended
  86. M-16 Disc Brakes
  87. 49 1/2 ton Wheels
  88. Vibration
  89. lark trunk
  90. ENGINE ID#535601
  91. Had to set the timing back today....
  92. Factory Dual Exhaust 1958 Commander Hardtop
  93. Cheap Halibrand look-alikes on Ebay???
  94. engine id#
  95. Clutch for 1962 Lark 6 Cyl.
  96. Disc Brake "squeal/whistle"
  97. Stude Engine Number listings
  98. How To: Fix broken Overdrive cable end
  99. Weld-friendly primer or paint
  100. Difference between radiator for 6 and V8?
  101. What does a Borgwarner T86 Weigh?
  102. automatic wiring
  103. After Market Radiator
  104. AFB Carb on Old style Intake
  105. distributor vac. line
  106. Front end teardown
  107. Drive train replacement
  108. Less than smooth acceleration
  109. thermostat spacer
  110. 59 Hawk 259 engine rebuild, heads advice
  111. Hawk Door Weatherstripping
  112. Rear Axle
  113. compression fittings
  114. Heater duct
  115. Headlight bulb size
  116. Original Tire Size... '58 Commander
  117. Steering column and shifter selection
  118. Ignition Switch
  119. Anti Rattler for Hood
  120. Installing tranny in 46 Champion
  121. How do I....Brakes
  122. Hub torque?
  123. Hood Spring
  124. Drive shaft conversion
  125. Parking Brake Handle - 1960 Lark
  126. '66 Rear Brake Drums
  127. Clutch/Brake Shafts/Levers
  128. fuel injection.
  129. 1957 Silver Hawk - oil and trans fluid change
  130. Steering wheel removal
  131. Front Shocks?
  132. Gas tank Liquid Liner??
  133. 50 2 dr and 4 dr trunk lids
  134. Preparing conv body to remove from frame
  135. 1928 President
  136. Anti-creep and brakes
  137. Advice needed ! no hair left ----
  138. Ballast Resister ???
  139. Motor/Tranny mounts
  140. How do you remove HAWK GT dash switches ?
  141. Face plate on R2 speedo needs to be redone
  142. Electronic ignition
  143. Stalling and Popping GT Hawk
  144. Another rear end question
  145. Packard Hawk Radiator Shroud
  146. Retorque of heads
  147. Hill holder
  148. Can I change my Accelerator Control?
  149. Fairborn Flanged Axle conversion
  150. Engine swap
  151. AN Fittings
  152. R1 oil pan removal on '64 Daytona???
  153. starter
  154. 63 Lark Exhaust routing question
  155. Mothball smell
  156. rubber floor mats
  157. Chrome plating
  158. Directions to Reedsville
  159. 56J engine question
  160. 62 hawk
  161. Does a 53 overdrive unit have an oil fill?
  162. Overheating Avanti
  163. Need headliner advice for '50
  164. Gas tank interchange
  165. new suspension
  166. door value
  167. 1957 Silver Hawk - Trans fluid capacity
  168. '63 Avanti T-86 transmission removal - any tips??
  169. Rear axle noise (squeak) - 1957 Hawk
  170. Rear brake backing plate
  171. Exterior Color - 1950 Champion
  172. 36 dictator shocks
  173. Starting Circuit wiring problem
  174. Avanti gauge restoration
  175. 6 cylinder power steering
  176. What do you fill an overdrive with?
  177. Front Hawk Fender
  178. Tech & Specifications of Orig 1918 - 19 Sales Broc
  179. Keyless in MN
  180. Rubber Oil Pressure gauge hose - '63 Avanti
  181. Rancho Red Touch-Up Paint
  182. Advice on Tightening up Steering on 53 Coupe
  183. Studebaker reliability questioned
  184. Steeltech adapters
  185. Tire Hop
  186. DG 200 transmission
  187. Body mounts welded to stainless steel Avanti frame
  188. expertice for clutch job
  189. Stude fastener question
  190. How do you take the Dash board off a 50 champion
  191. Generator Pully
  192. Mechanic needed
  193. Cadillac and Studebaker intake interchangability
  194. What does this door fit
  195. Cam Specs
  196. steering wheel?
  197. Carter 4 barrel equivalents?
  198. P.S. control valve
  199. 1956 Packard Engine Specs
  200. heating up
  201. 1947 Starlight Coupe transmission
  202. Kingpin assembly
  203. pinging Keith Brooks
  204. '53 Wagon
  205. Champion Engine
  206. 259 Rebuild
  207. 1938 Engine exchange questions
  208. Generator/Regulator Woes
  209. Pilot gray color mach
  210. Distributor for '50 Champ
  211. Door hinge mystery
  212. Ignition Switch Removal / Installation Tips?
  213. C/K Rear Bunper on Sedan?
  214. rear spring shackles
  215. 9" drums - replacements?
  216. Super finds at swap meet!
  217. HINGES
  218. speedometer bounce
  219. paint color, 1925 standard six
  220. anyone got a T-85?
  221. REEDSVILLE
  222. Need a 51 Commander speedometer
  223. Battery Cutoff Switches - Pro & Con
  224. 63 lark master cylinder
  225. Conversion spindles?
  226. Dash is complete
  227. Disc brake conversion on a 61 hawk
  228. Avanti quarter window latch repair
  229. Pre-50' planar suspension question
  230. Who Rebuilds Hood Hinges?
  231. 53 Commander Front Drums
  232. Replacing valve stem seals
  233. Ross to Saginow change?
  234. Turn signal lens
  235. 56 Commander
  236. 1960 LARK Wiper Arm Removal
  237. New Power Steering pumps
  238. Dana 44 3.73 TT wanted
  239. front sway bar
  240. Stock radio with speaker
  241. Brackets?
  242. Pilot Bearing Info needed
  243. brake pedal pivot sleeve
  244. 64 Daytona Gas Tank Color
  245. maximum bore size for a 289
  246. Under hood pictures needed
  247. 28 Dictator Fuel Pump
  248. Another big bore size question - carb
  249. camber adjustment
  250. 1928 Dictator Oil Filter
