View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124
  1. overhead valve 6 cyl
  2. Question on serial numbers
  3. Whatsalator?
  4. Speedometer Drive Gear Woes
  5. Power Take Off problems
  6. Shocks for a 62 hardtop???
  7. R series balancer?
  8. Champion emblem color
  9. hardtop only window cranks
  10. Motor 75% complete
  11. Torque converter plate
  12. My turn!!! ('65 radiator hoses)
  13. engine number/pcv
  14. adding a PCV?
  15. Carb Nuts
  16. Saturday project: make rear quarter for Wagonaire
  17. Right Door Mirror; taming the shake...
  18. gas tank questions
  19. Trany Noise 65 Daytona automatic
  20. Newbie needs help
  21. 13 Second Naturally Aspirated Stude
  22. supercharger pulley spacer
  23. Carb overhaul
  24. Body Mounts
  25. Suspension locknuts
  26. hubcap colours
  27. Avanti Front Suspension Opinion Needed
  28. Can't get his 2R-10 Pickup running
  29. R1 - R2 Info request
  30. A question of wiring
  31. Anyone have an old parking brake Cable?
  32. 42 Champion hubcaps
  33. Powershift tranhsmission noise
  34. Considering a '42 Street Rod
  35. Spark Plug Removal
  36. RBS Carb
  37. compression
  38. Real tires, Avanti body, on the stainless frame
  39. Clip paint color
  40. Frame Colors
  41. Blown 232
  42. Question about base coat/clear coat curing, etc.
  43. Rear valance
  44. Replacing radio pushbuttons????
  45. 51 Champion Horn Button
  46. What's it worth?
  47. Brake Line Lock
  48. 62 hawk dash
  49. Trim Chart for 2R truck
  50. Speedometer Woes - still
  51. Rust
  52. 1952 2r-6 wheel size
  53. Bent tie Rod: Straighten ??
  54. Ignition coil testing question
  55. Champion body tag codes
  56. 700R vs 700R4 GM transmissions
  57. disc brakes on Dana 27
  58. Car Frames
  59. Subaru Hill Holder Explained
  60. 57 GH electrical
  61. 0w-30 Alternative to 15w-40 oil
  62. Door window question
  63. 63 Lark Tie Rod same as Econoline?
  64. Harmonic balancer
  65. vent doors on 61 hawk
  66. 64 Cruiser Upper Cont. Arm
  67. Door Removal Tribulations
  68. body shims
  69. 5 speed Adapter kit
  70. supercharger 1964
  71. Pitman Arm
  72. disabling OD question
  73. 50 Champion running hot
  74. Gear Vendors Underdrive/Overdrive
  75. Dexron for power steering fluid?
  76. block 80%
  77. Name that car!
  78. Need Pictures inside doors 55 president electric w
  79. Can someone confirm this engine code?
  80. Differnet wheels that fit?
  81. Generator overcharging - 57 Silver Hawk
  82. 1955 truck brake cylinder part number
  83. Bill Hirsch gas tank etch
  84. flathead 185 & hawk part numbers please...
  85. 63' Cruiser: Disc brakes-early install
  86. 289 questions, also posted at "Racing Studbakers"
  87. Door removal problems-revisited
  88. '50 chrome bullet ring on to '51 sheet metal? [?]
  89. President script?
  90. RE: Wheel studs
  91. RE: Dash cap
  92. 1962 GT Hawk Schematic
  93. WANTED...'53 grille surround for a Starliner
  94. removing rear shackle bushings questions
  95. How do I free up the rear window regulators?
  96. T86 shifting woes
  97. Slow Cranking - Advice required
  98. looking for 4.10 rear for 52 champoin
  99. Avanti Alternator
  100. Fuel Line Substitute - 53 2R5
  101. 56 wagon weight
  102. Jet Thrust Spec Question
  103. 1950 parts interchange?
  104. Front end rebuild
  105. Brake lights on continuously in 1988 Avanti ?
  106. Rear end search.
  107. Exhaust valve stuck open
  108. avanti ser no 4248
  109. 289 rebuild cost
  110. South African Rebuild
  111. TRANSMISSION/CLUTCH PROBLEM
  112. Clutch chatter
  113. When do I try to start it?
  114. Frame and Torque Boxes for 55
  115. What is this line for?
  116. 1938 rear axle replacement
  117. Wiring Diagram
  118. help 4.09
  119. Exhaust studs & freeze plugs
  120. identifying a 5-speed
  121. What is size of R3 intake valves?
  122. Transmission refuses to shift into first or rev.
  123. question - production order
  124. Makeshift gas tank jack
  125. OHV Six valve cover
  126. C/K body parts interchangeability
  127. Paint Information
  128. No headlights
  129. 55 champion engine wiring
  130. What year is the Commander?
  131. 36 Coupe info needed
  132. Cam2 Oil
  133. SteelTech Adaptor Plate Help
  134. T-10 mid plate needed
  135. hood swap?
  136. Who do you trust?
  137. R2 hawk air cleaner
  138. '64 Daytona rear end change
  139. hawk tranny yok?????????????
  140. Battery cable wire size??
  141. Mopar manifold swap questions.
  142. Maybe TT ??
  143. A newbie, and some off the wall questions...
  144. Engine Rebuilding Question
  145. Need a different transmission
  146. Rack & Pinion Conversions
  147. 59 silver hawk spring perch width
  148. Hood Installation question 63 Lark
  149. Frame question 63 lark sedan
  150. Avanti Horns
  151. alignment
  152. what causes grabby brakes ? ?
  153. Eaton PS Pump Rebuild Help
  154. Motor Mount Replacement
  155. 50 Champion rear axle bearing service
  156. Replacement motor?
  157. 51 Champ new tires - rims
  158. Upper Control Arms Redone
  159. Hawk parts needed
  160. heat riser valve for V8-important information!
  161. Parts books
  162. windshield ,headliner question
  163. 1937 President Running Boards
  164. Shaker Can? Avanti Honduras Maroon?
  165. 1964 Studebaker Lark Front Suspension
  166. Wanted - T10 Studebaker input shaft
  167. Heater Valve repair 63' Lark
  168. paint formula
  169. Trunk Latch Striker
  170. 53 commander window channel missing?
  171. Anyone have a Carter WCFB 2224S they want to sell?
  172. M 5 Trans
  173. what is part # 303542
  174. Anybody got any Champion 6 parts laying around?
  175. Start Up Procedure - car has been sitting
  176. Question on Avanti body tag
  177. What is this? Off of an Avanti.
  178. Newbie Questions
  179. Flanged axle options ??
  180. Search for 62 Hawk jack
  181. ATF or PS fluid?
  182. overdrive oil
  183. Body Tags, Labels, Stamps, Secret and Undercoating
  184. Rear seal, 56-7 T-85 O/D
  185. V8 neg battery cable attachment
  186. Dressing up wiper motor?
  187. Exhaust headers,
  188. Rear axle question
  189. 41 M15 beginnings..
  190. Gauge Cluster Restoration
  191. Brake pedal into 52 car
  192. Remote fill for Transmission
  193. What are Lark grille meshes made of?
  194. using additives...
  195. Mounting a wiper motor
  196. Kingpin cork seals needed
  197. 62 hawk rear end
  198. 1960 Lark Fender (driver side)
  199. T86 Transmission 1960 Lark
  200. plugs,points ,condenser ,waterpump?
  201. 1950 Champion Temp Sensor specs
  202. Door drainage holes
  203. 66 swap from v8 to 6
  204. Sound deadening
  205. Hood oiling. well......
  206. Sagging springs? My solution
  207. Avanti Brakes
  208. HELP! Need "early" V8 choke tube assembly!
  209. lark carb
  210. Avanti A/C switch
  211. Automatic Trans fluid
  212. 48 champion 4lug rims
  213. Frame Body Mounts
  214. Clutch questions from a novice
  215. Stude trans bolt to chevy engine
  216. Heater hoses: new source/numbers ??
  217. bolt pattern
  218. twin traction carrier
  219. Steering Question-sigh
  220. Please help Me Find a Part
  221. Overdrivophobia
  222. Hooking up a 57-58 type tach.
  223. Rear Brake Hose
  224. Reinstalling a crank timing gear
  225. Faulty Ign Switch/ Gen Light Stays on?
  226. Door hinge pins
  227. Hooking up a 57-58 type tech question 2.
  228. T-10 into a '61 Champ
  229. SPARK PLUGS
  230. Lark radio button swapping? black to white
  231. tire manufacturer
  232. Radio and speaker grille
  233. Need Silver Hawk Defroster Motor
  234. Eng casting #'s
  235. 1950 Studebaker Commander
  236. 1950 Studebaker, standard to Auto conversion
  237. Serial Number
  238. Seat position
  239. Mystery.. What year is this front end??
  240. Transmission: Studebaker Avanti TKO 5 speed install - how to
  241. Powershift Help Needed
  242. door adjustment
  243. C body door and fender alignment
  244. 50 Champ 6 electrical woes
  245. Avanti interior combinations
  246. Stude oil bath air cleaner for AFB carb?
  247. Vapor lock or gunk in the carb?
  248. vintage air in a c, k
  249. 6 cyl
  250. Questionas About 12-Volt Conversion
