View Full Version : Tech Talk
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119
  1. Trunk Floor - Plugs or No Plugs?
  2. Lowering leaf spring suspension on 49 Stude
  3. Champion pickup tie rod
  4. 1930 STUD COMMANDER
  5. Spark Plug Wire Loom
  6. OE-1 Carburetor
  7. What Block Is This????
  8. R Series Fuel Pump
  9. pertronix question
  10. which engine is best and why?
  11. rear axle removal
  12. 1965 Stude Lark Radiator
  13. coils
  14. Wanted: Flightomatic and steering column
  15. wiring diagrams online
  16. overdrive/free wheeling
  17. (For Sale) Studebaker V8 AFB 4bbl Manifolds
  18. overdrive problems...
  19. Six to Eight... front suspension?
  20. 50 Wiper motor
  21. Clutch glitch
  22. Gasoline smell
  23. check out ebay items .....
  24. Steering box oil
  25. Fined drums
  26. starter lock-up
  27. engine ID number -- Mr. Biggs??
  28. Turning signal problems on 49 Stude
  29. rebuild front-end, DIY repair???
  30. Milestone post
  31. Gas Tank Unit
  32. Dash lights
  33. EFI
  34. Detroit Gear Trans Fluid
  35. goo
  36. 51 Land Cruiser Clock mods
  37. overdrive
  38. Avanti for Bonneville
  39. Ear wax for grease???
  40. Hood Strut for my 64GT
  41. 1956 Power Hawk Transmission
  42. Anothother dumb question from the Stoogebaker
  43. how many tools ya got?
  44. Removing Door Handles
  45. Chrome Trim
  46. Unlocking hood on 49 Stude?
  47. 51 Land Cruiser Clock mods-UPDATE
  48. Exciting Brakes
  49. 62 Hawk Upper Trim
  50. Turn Signal flasher
  51. Tune-up specs for 1966 Stude with 283 and auto tra
  52. WHEEL STUDS
  53. What year do i Have
  54. carb problems
  55. Clutch pedal travel
  56. rod pall nuts
  57. sputter, flutter, cough
  58. Windshield wiper switch?...
  59. after market whells
  60. 52 champion rearend /replacement
  61. Using a Jeep topload shift on a Stude overdrive
  62. The elusive 185 OHV six;)
  63. Auto trans. alignment tools?
  64. Dash Board Replacement
  65. brake spring part #?
  66. Center Clip!!!!!!!!!!!!!!!!!!!!!!!!!
  67. Window Regulators
  68. dash lights again
  69. 1950 champion engine
  70. 63 Lark steering
  71. 56 Champ Ground Strap
  72. Auto. Trans. Help, please!
  73. Stude V8 Intake Manifolds For Sale
  74. Dumb throwout bearing question
  75. New Question: Wheel Covers
  76. engine switch - wagon to pickup
  77. Cam bearings and other bearings
  78. 66 Daytona V-8 problem
  79. 1st gear start
  80. Rods for Studebaker
  81. Removing front clip
  82. To shim or not to shim?
  83. vacuum advance
  84. Truck Tranny parts desired...
  85. '55 Speedster question
  86. radio repair and upgragdes
  87. Sagging Rear Spring
  88. Mattex Trunk Mats - Color
  89. Speedster question followup
  90. T-5 swap clutch linkage position
  91. muffler
  92. 63 GT rear axles
  93. Wiring harness and O.D.
  94. ID Number Information
  95. good parts for sale
  96. 61 hawk trunk pan
  97. ohv six 2 barrel
  98. need champ script
  99. Radial Tires
  100. Looking at a 1962 Lark V8 to buy
  101. Striped Wiring
  102. engine id
  103. Brake lines for dual M/C
  104. Power Stearing On 62 Champ
  105. 289 FRONT SEAL CONVERSION
  106. Distributor Upgrade
  107. Champion 6 performance question
  108. Horn Wire Dilema
  109. fine tuning my lark
  110. 1965 cruiser front end alignment
  111. Headlights circuit breaker
  112. thanks once again
  113. Paint Question
  114. 48 landcruiser
  115. T-10 four speed in 55 sedan????
  116. Car Jack
  117. Truck disc brakes
  118. disc front brakes for 64 wagon
  119. replacing front springs on 62 sedan
  120. Ring pads
  121. compression test date needed
  122. Ignition Switch
  123. innercoolers
  124. Rebuilding original motor on '63 Stude Avanti R1
  125. water pump
  126. 63 Avanti easy off drums
  127. movin right along
  128. Front Seal
  129. 289 crankshaft needed
  130. oil ,timing, gas and boost
  131. Your Tool Kit
  132. Radio Static
  133. Cheap disk brakes?
  134. Rear brakes lock up
  135. front seal too
  136. rearend ratio comparison -- How slow?
  137. Cruising Speed
  138. Avanti Front Alignment Specs
  139. Head
  140. transmission fluid and crank/oil
  141. interior carpet
  142. fuse panel -- HELP!!
  143. stationwagon and Cruiser doors
  144. transmission fluid and crank/oil
  145. Alternator
  146. Dashboard Part of what model year?
  147. Paint Numbers
  148. Power Steering Control Arm Valve Assy Slack
  149. one wire Alternator
  150. Prestolite alternator: fix or switch?
  151. Replacing an OHV 6 with a Flathead?
  152. carpet
  153. lopsided motor
  154. Disc brakes and Hydrovac.
  155. Serial # Plates
  156. transmission fluid and crank/oil
  157. How to check.......
  158. 12 volt conversion questions
  159. Starter Problem?
  160. Freeze plugs, how do I remove & replace
  161. Another 12 volt conversion question
  162. Brakes locking down
  163. How do I hook up my dwell meter?
  164. chrome valve covers
  165. 259/R1 cam
  166. oil filter
  167. another 12 volt conversion question
  168. oil filter
  169. Road Draft Tube?
  170. Interior door panel pressboard replacement
  171. full flow block
  172. Bell housing ID requested
  173. Champ Automatic Conversion
  174. Best adhesive for trim?
  175. Oil. Which type?
  176. Truck Parts Catalog
  177. 1916 Studebaker
  178. Radiator
  179. Similarities & Differences to Work with
  180. 1925 studebaker roadster frame
  181. Rear end oil
  182. bushings
  183. valve Adjustment
  184. 1963 Champ Steering Automatic Steering Column
  185. Lug Nuts
  186. Gas mileage 194 McKinnon
  187. Transmission mounts
  188. Rear End ID
  189. dwell angle
  190. Manual Transmissions
  191. PCV valve for 170 cid Studebaker six.
  192. Old Dog New Tricks (Disc Brakes)
  193. overdrive
  194. 1953 Foglights
  195. Twin Traction Rear End?
  196. m5 overdrive tranmission
  197. delete
  198. Wheel interchange
  199. Air bag suspension in a Transtar?
  200. brake parts storage
  201. Negative or positive ground
  202. Problem with gas gauge on 64 Lark-type.
  203. 1966 Cruiser erratic starting
  204. Looking for brake parts
  205. Carter AFB on '63 R2
  206. Stude meet TODAY!
  207. Paint Code
  208. 51 Champ steering
  209. DIY Chrome Plate
  210. prestolite dist
  211. Power Steering
  212. Paint Colors - What's Correct?
  213. 1937 Dictator grille parts
  214. Secret serial number location.
  215. oil filter
  216. front springs
  217. Water Pump, Hawk VS Avanti
  218. 1963 Avanti Rims
  219. Power Steering Play
  220. 63 Avanti Exhaust
  221. Steering post jacket length
  222. R2 AFB Woes Update
  223. How to prepare for a long drive.
  224. Kent-Moore J-4285
  225. Tranny Rebuild?
  226. Radiator
  227. Levers and Reach Rods - column shift
  228. Exhaust tuning
  229. Cracked Screws
  230. Checking Auto Trans Fluid
  231. Trouble with my car hauler
  232. Instrument panel lights
  233. Fuel pump problems
  234. Need help with parking brake
  235. 59 Lark Pricing
  236. found radiater cap
  237. Valve body & valve seals
  238. 30's Stude Motor trans
  239. Defroster fan
  240. Truck Working Again
  241. Modern Gasoline - Additives
  242. 64 lark padded dash
  243. AVANTI distrubutor
  244. 1959 small 6 PVC Valve
  245. 1959 truck small six engine color
  246. TT rear end oil
  247. Spark plug wires
  248. cooling
  249. 53 repro. grill?
  250. Column shift again...
