- 185 Cubic Inch part Numbers
- Source for 51 Champion Rear Brake Cable
- Need power steering
- late breaking news from The Progressive Farmer
- Dash lights 50 Champ.
- 63 hawk
- Socket removal from tail light housing - GT Hawk
- 1963 vs 1964-66 Reach Rod
- pulling the hubs from a tapered axle.....
- Head Help
- Trans. Fluid for 4 speed trans.
- '57 Transtar - Needs Some Parts & Info
- New Member looking at '57 Studebaker Silver Hawk
- Test of alternator with Ohm Meter
- R1 or R-none?
- Help.. help a guy out please
- Supercharger vs brake booster
- Carburetor Differences
- Carburator Problem
- Electrical Difficulties
- Powershift question
- Speedometer pinions
- chrome plating
- Broken Studs Front Axle Lower Arm
- T-85 3 speed OD Transmission Questions
- 1951 trunk lock
- 48 champion rear gears
- Hood release - 52 Champion convertible
- HELP-Missing Screws
- weatherstrip/rubber kits
- 6Volt to 12Volt conversion
- 51 Champion Front Shock Bracket Bolt Question
- convertible tops
- 51 Stude Front and Rear Shock Replacement
- 65 283 owners: please help!
- M15 Brake trouble
- Head bolts on flat head
- Coarse VS Fine Threads
- 54 Starliner Steering Repairs
- Need some help from another 55 Pres owner
- New to the group
- was running, now its not - a little help please
- Avanti misfire
- 3 Point Seat Restraints for '58 Silverhawk
- Avanti fuel gauge moves to top of repair list
- avanti idles then dies
- Need help with motor mounts manifolds
- Replacement of timing cover seal
- hydrovac checkvalve
- Speaker vs. radio impedence
- 25/32 socket...Huh?
- Flex Plate?
- 48 champion overdrive trans swap
- Delco Remy Distributor - Lubrication question
- pressed on rear hub
- Brake Issues Help
- 38 studebaker brakes with hill holder
- Mod 52 hardtop to convertible-experience?
- Frames , Frames, Frames
- overdrive solenoid
- 12" disc brakes
- Have One Of These ?
- Brake Fluid Reminder
- Fuel useage
- Build sheet code
- Front Disc Brake Kit For Sale
- No-Rol units
- Slip yoke needed 64 Daytona
- Shock absorber rattle?
- engine number
- rear harness 61 hawk
- Well Duh!
- New OD rear seal leaking???
- Parts for 1947 Commander
- Brake shoe question -
- Made No Difference
- Lark Doors
- Damn Oil Spray In Avanti
- Automatic Fluid
- Exhaust Header Installation
- 56 Tangerine color choice
- Rebuilding a fuel pump
- Dropping a V8 into a '58 Scotsman?
- Stearing box adjustment
- Rear Springs for Hawk
- time and the clock???
- Pulley ID
- How to identify the year of a Starlight
- Hawk GT clutch
- driveshaft alignment
- Rebuilding a T-96 OD
- rear end
- Useful Life of Gabriel Classic Gas Shock
- Fuel
- Champ PU on a Landie chassis ie: Champ 4X4
- What type transmission fluid?
- Steering knuckles - which way?
- Hawk suspension restoration
- Maximum power - novice style
- stuck door
- Manual transmission conversions
- 224 Street Peformance
- Brake shoes and Wheel cylinders
- Brake drums
- Supercharger Woes
- History of the V8s?
- Drive line noise
- 63 Lark V8 Wiring Harness vs 64 Harness
- We won against the restoration shop
- 62 hawk front end
- 59 Studebaker push-button trans?
- Borg-Warner trans
- Door glass trim
- outside vents on hawk 61
- Emergency Brake control adjustment
- Electronic ign. on hawks v8's
- HELP! need carb kit for 62 Transtar
- Motor Mounts
- What frame would you use?
- Carb Wanted
- How-To: Disassembly and Storage
- installing electric windows, 63 hawk
- Brake shuddering - HELP!
- vaper lock
- steering wheel restoration
- Hot Rod 101 Steering column
- Brake Light Troubleshooting - 1957 Silver Hawk
- easy sun roof install for your Studebaker
- Jeep Rescues '63 Avanti, '59 - 62 Lark and Hawk
- Corvette Rescues '63-85 Avanti,'59-62 Lark/Hawk
- 64 Lark wiring legend
- fuel tank/sending unit
- Rear shocks for 62 hawk
- dash insert 61 hawk
- what kind of paint used
- Calling Showbiz kid
- What to paint under the fender?
- Frame Reinforcement
- Steering box grease
- Is that "no-name" shock a Gabriel?
- Dash on 62 hawk
- Engine Hoisting
- starter drag fix ??
- Another shock absorber thread.
- Stuck door no more
- 51 Stude Champ Air Breather bracket specs
- radials on stude rims
- Just one more dumb question for tonite
- OHV six carburator / intake manifold.....
- Power Brakes
- U joint interchange 62 Hawk
- Dual exhaust cross member
- Sping loaded taillight brackets for C-Cab trucks?
- supercharger
- Front disc brakes
- Engine Cleaning
- cloning a ri to r2
- Got a little steering problem w/the Hawk
- backup lights on 62 hawk
- Magazine article on stainless steel Avanti frame
- 500 CFM Holley for 259
- Radio ignition noise
- Chevy Wheels
- ratios
- CFM on a 170 OHV engine?
- Anyone using "Slick Street Stuff's" suspension?
- fan blades
- dash restoration
- Air cleaner (new picture)
- Studebaker M-15
- 4 SPEED LARK DRIVE SHAFT WTB
- OIL BATH air cleaner question
- Does this look weird? Advice needed
- It ran good and didn't smoke...
- Vinyl tops
- Manifold and other castings - Fast and Cheap(er)?
- Coil spring pad question
- gear selector rod insulator-auto trans
- FUEL GUAGE
- block number
- 1936 studebaker
- Valve stem seals for OHV-6
- Bell housing alignment
- Did all 64 Cruisers have 289's?
- Identify a Studebaker V8
- Need help with hood latch for 47 Comm
- Repair Manual
- Big Bang
- Changing rear axle ratio ??
- Steering wheel and Dash
- Is this a cracked block?
- Which Oil?
- Shocks
- Brake bleeding question
- crank pulley
- Rear end gear ratio
- Q: types of seal materials in engine??
- Retrofiting Electric Wipers to a '50 C Cab?
- Avanti parking light gasket
- At indicated 72mph, actual speed is 63mph
- Disc Brake ?? Old garage myth ???
- U-joint Diagnosis ?
- Mis-aligned side moudling- solution?
- Engine ID numbers
- Remove rear brake drums
- Bondo then prime or vice versa
- My first time........
- 259 cold start problem
- Steering Wheel interchange
- Positive ground
- 48champion head gasket or not
- self adjusting brakes
- Lark Fuel Tank Interchange?
- 42 Champion Upholstery Clip
- Hard part done
- Wire Wheels
- Stupid guy needs help!
- Avanti Center Console add on?
- Avanti Instrument Panel
- Alternator wire question
- Engine ID and Paint Codes
- Shiftless in Illinois.
- C/K (Hawk) bumper on a '57 sedan?
- '56/'57 Packard tail light lenses?
- Speedometer bounce
- New to Forum with many questions
- studebaker sound system
- Truck ID'd, but what about engine?
- Avanti Brake ?
- dash momentary starter switch does not work
- underdash map light
- C-Body Dual M/C Conversion Research
- What you should know about Lucas
- installing U-channel
- Hawk Carpets?
- Hawk Jack
- 51 DG200 transmission woes
- More 224 performance questions.
- Truck oil seals
- 64 Cruiser Shocks
- dash insert
- Chromed Carbs?
- trunk weatherstrip channels 62 hawk
- AIR SHOCKS
- Rear springs - HD vs. standard?
- engine colors
- Charging Problems
- The Horn Works !
- horn button
- Engine sticking
