View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Gots me a NEW noise now
  2. Resto modding a Stude Powerhawk
  3. 50 nose on a 52 champion?
  4. Rear axle Shaft (same content as in General forum)
  5. Avanti Hog Trough
  6. How thick is the clutch plate supposed to be?
  7. Dent removal
  8. Four speed in a Hawk?
  9. Clearance Question
  10. R2 supercharger lube -- which type to get?
  11. Pos to neg ground, wire changs
  12. 164 compression readings
  13. Vintage Air Brackets
  14. 48 Champion Fender Ornament Mounting
  15. 64 Cruiser Washer
  16. How do I pull my dashboard?
  17. Alternator & Battery voltage
  18. 62 Hawk Air Condtioning
  19. Spark Plug dimensions
  20. Info needed
  21. Avanti ll AC mode
  22. Chevy Exhaust gaskets
  23. 59 or 60?
  24. Gear oil leak
  25. Wiring harness, 'Goliath' lost !
  26. E Bay snipers
  27. Rubberized fabric in engine compartment
  28. Fuel pump?
  29. backup light switch mounting?
  30. Drum Brake Installation
  31. Heater floor cutout
  32. Reluctant Woodruff key
  33. Open Market, bid snipers, and solutions
  34. door gaps 56 wagon
  35. tow bar
  36. Stude Starter Bolt info for newbies!
  37. Lark front fender screws...ARGH!
  38. Original construction of bucket seats
  39. transmission (FOM)
  40. Low Engine Vacuum
  41. Original type wire hose clamps
  42. Adding another circuit under dash
  43. fuel pump rocker arm direction
  44. Amp pull of wipers
  45. champ brake lights
  46. Help with 53 Starliner
  47. Hawk Weight
  48. R2 Electric Fuel Pump
  49. Missing Suspension stuff!!!
  50. Lark gas tank to fuel pump metal line
  51. Strange noises
  52. 50 Champ Convertible Top Mechanism
  53. Champ 6 AC
  54. trunk light 48 champion
  55. Gasket number
  56. Need assistance on a Stude OD setup
  57. 2R Column Upper Shift Lever "floats"
  58. Avanti Transmission Fluid
  59. Question on windsheld wipers
  60. Leaf Spring for Lark
  61. Can Someone Explain This?
  62. Need help identifing engine
  63. 34-5 Truck
  64. Hawk Auto Transmissions
  65. HEAD lIGHTS
  66. amp gauge noise
  67. Parts interchange
  68. 188 HP @ rear wheels. Any experts?
  69. No engine compression in 2nd in a T-86..
  70. Tie rods - painted or not?
  71. 1956 hawk wiper motor wiring.....HELP!!!
  72. ?? Converting 64 Hawk Seats to Reclining Buckets
  73. Adding power brakes
  74. Upgrading to 4 Wheel Disc
  75. Flat top pistons
  76. Ersatz heater control valve for '63
  77. Air dams on Avantis
  78. Q. - 55 Commander Electrical + or -
  79. Mystery with Disappearing Brake Fluid? - Help!
  80. What's the right gear oil?
  81. Distributor Question
  82. Persistant coolant leak
  83. Dual Master Cylinder for K body?
  84. Baltimore hawk
  85. Rear licence (tag) plate mount
  86. Dual Master Cylinder for Avanti?
  87. Synchronizer question
  88. Looking for a Rebuilt Hydrovac to swap out at SB
  89. MC question (single reservoir Frt DB)
  90. Advantage to thermostatic fan clutch?
  91. Used Stromberg WW
  92. Electric fan
  93. Floor jack quit
  94. short steering arms
  95. 37 President Water pump
  96. auto transmissions
  97. Stainless Avanti frame may be at South Bend Meet
  98. Hood Pad Installation Picture
  99. Driveshaft setup
  100. Standard bellhousings on 65-66 models
  101. Hydraulic clutches in Studebakers??
  102. Big oil leak!
  103. Adding a toilet roll holder to the old gal
  104. spark plug wires
  105. Voltage Regulator Problem?
  106. 53 Coupe Sway Bar upgrade question
  107. R2+ cam question finally answered
  108. Rotella-T oil
  109. SB Transmission Seminar
  110. Pulling OHV-6 & OD tranny
  111. Convertible Trans Removal
  112. Three speed swaps?
  113. Hawk Serial & Engine Number Decodes
  114. Carb problems on R2
  115. Removing paint from a plastic medalion
  116. Trans. seminar at Noon Wed.
  117. APB for Darrell D Domer from Dayton, Ohio
  118. oil type
  119. headliner info
  120. WCFB for 62 Hawk
  121. 51 commander 56 hawk chassis
  122. Cobra/GT Mustang brake brackets are arriving
  123. 62 lark headliner
  124. Oil filter line restricter
  125. Hood to body rubber seal
  126. Tach upgrade
  127. 52 champion front fender won't come off
  128. Old PS Fluid
  129. Suspension for a 1953 champion
  130. Motor not running smoothly
  131. Is this upper pin too morked to use?
  132. oil filter
  133. steering box oil
  134. Valves, OHV 6 cyl
  135. m5 year
  136. trans mounts, flight-o-matic
  137. HELP!!! Restoring 60 Lark convert
  138. Hydrovac
  139. Brake Light Troubleshooting - 57 Silver Hawk
  140. Gas Gage Kaput
  141. Removing oil pan
  142. Supercharger qustion
  143. '55 President window and upper door moldings
  144. trans mount hawk v8
  145. Avanti Windshield Installation
  146. Neoprene or Composition
  147. Gauges
  148. Polarity of radio speakers
  149. Follow the bouncing speedo needle...
  150. Fwd engine squeeeeal, looking for tips..
  151. Wheels again- 63 Lark
  152. oil filters work or not ???????????????
  153. New Hydrovac - But really weak Brake Lights
  154. wiring, cigarret lighter
  155. Thickness of frame/body
  156. AC condenser
  157. Fire wall Gromets
  158. 1950 Starlight Rear Windows
  159. New door rubber kit
  160. 62 clock to tach conversion
  161. placing stearing wheel
  162. Chrome or paint????? 56 wagon
  163. Tectol rust prevention?
  164. Avanti II Rad. cap?
  165. Pressurized or non-pressurized radiator cap?
  166. Avanti Battery
  167. Delco distributor interchange
  168. T-10 w/overdrive
  169. S-10 Rumor?
  170. 6 cyl Cranks
  171. 56 luggage rack
  172. Can't get into gear!
  173. Need Overhaul Kit for aTransmission
  174. 57 SC w/ 4 bbl Carb
  175. Hawk Inner Fender Kit from Classic
  176. OD wirning - again
  177. GT Hawk Gas Gauge Wiring
  178. 66 Cruiser with Engine that Quits
  179. Hawk motor won't run....
  180. 63/64 Air conditioning
  181. The supercharger that got away.....
  182. Antenna Help
  183. Got the 3 sp. overdrive tranny in but have problem
  184. Original Radio
  185. 64 Cruiser Door Mirrors
  186. Pulling window trim
  187. clip
  188. Exhaust
  189. Shelf life of oil
  190. '65 cruiser engine/trans woes
  191. Exterior door handle 47-52 car
  192. Leaks, Leaks, Leaks
  193. Best source for T-85 bearings and synchros?
  194. New Fuel Sending Unit Leaking Under Screw Heads
  195. Under hood and trunk colors..58 Hawk
  196. 1965 Master Cylinder interchange
  197. Heat Effects
  198. Hawk Hood Tiedown
  199. Hawk Dash
  200. Transmission mount spacer
  201. Hydrovac Encore... Now Repaintng the inner fender?
  202. Positive and Negitive ground mix
  203. Delco points
  204. Carter AFB R1 Start Fuel Lack
  205. Hydrovac Mating Surfaces What do you think?
  206. Carter WE available to good home
  207. Fuel pump check valves (Carter R1) needed
  208. Vented or unvented?
  209. Oil Bath or Paper air filter?
  210. How to tell a TT rear axle?
  211. Oil in coolant
  212. Axle removal
  213. 3 spd bellhousing adapt
  214. Rusted Floor Deal Killer for '64 Commander?
  215. Underhood measurement from a 62 Lark
  216. bearcat
  217. Is it written anywhere...
  218. CI-4 kendal oil
  219. 1954 Champion gas tank sending unit?!?!
  220. Disc brakes for my Wagonaire
  221. NO accelerator pump
  222. Coil Spring Paint
  223. glass scratches
  224. More Daytona surprises
  225. PAINT
  226. How do you get the OD solenoid out?
  227. Stomberg carburetor help needed
  228. '55 PRESIDENT PINION SEAL
  229. Window Seal
  230. Alternator Bracket for R3 manifolds
  231. Rough idle
  232. Champ Challanges!
  233. Motor to trans tuning?
  234. 12 volt converstion
  235. Powershift Transmission Rear Spline Play
  236. Is It Really Required?
  237. A rookie shop question
  238. 1947 Studebaker M-15 1 tron truck
  239. new to working on cars...help with break line
  240. Questions about R1 oil pan - '63 Avanti
  241. Driveshaft mishap what to do?
  242. noise in the bellhousing
  243. upgrading my bakes on 52 champion
  244. CI-4 Oil
  245. alternator
  246. betty - pic
  247. Avanti Ride Height
  248. 63 Lark air cleaner adapter - anybody have one?
  249. Intake Manifold
  250. Part i.d.
