View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
  1. Mopar mid 60's alternator
  2. Starter
  3. V8 Engine Resources?
  4. 5 speed for a GT Hawk
  5. 1951 Stude wind tunnel testing
  6. 63 V8 289 oil pressure??
  7. Vapor Lock anything new ?
  8. Hawk radiator dimensions
  9. Timing Gear Cover Crank Seal Modification
  10. Not Stude related, but I need an opinion
  11. No Headlights/dash lights on hawk
  12. Overdrive question
  13. Grease for new front bearings
  14. 62 Lark rebuilt front end w/ turner brakes 4 sale
  15. Need info, oil filler tube,'49 Champ 6-Added pics!
  16. Related to last post - advice on oil leak
  17. need help iding stude nos part #s cash paid
  18. 55 champion engine color
  19. 51 Commander Speedometer
  20. Door & Fender Alighnment
  21. GT Hawk Exhaust System
  22. Dave Thibault's electronic ignition
  23. '47 Champ 6 runs but sputters...help
  24. Anyone have an Ohio Piston Catalog?
  25. 64 wagonaire help
  26. Current draw
  27. NEW AXLE ISSUSES
  28. HELP
  29. Bottoming out
  30. Twin Traction additive
  31. ignition switch in hawk
  32. Gremlins Galore
  33. towing with 51 comander
  34. Need opinions on Waterpump noise
  35. Two Tone Paint Question
  36. plate madness
  37. Gasket sealants
  38. Engine colors... Again??!!
  39. Edelbrock carb: fuel line
  40. tune up
  41. Timken wheel bearing part #s
  42. electric cooling fan
  43. GT Hawk Grill Emblem
  44. 58 champion automatic trans.
  45. Dash Pad Replacement
  46. JDP for Brake Booster Repair
  47. DRIVESHAFT ALLIGNMENT
  48. Carburetor rebuild
  49. rewire - square headed nuts?
  50. 1961 hawk climatizer
  51. Help with adj. ft. fenders & hood, please.
  52. Hawk Dash removal
  53. Engine Won't start
  54. Oil Filter connections 58 GH 289
  55. Floor repair- how to- 8 pics
  56. 64 GT Hawk R3 Clone air inlet
  57. Rear End Noise
  58. Injection Pump 63 hawk R-1
  59. Brakes: 63 Hawk Brake Conversion Kit
  60. Dead Battery
  61. Accessory windshield washer system
  62. 38 Studebaker President - Help
  63. tow rating
  64. Pertonix for prestolite distr.?
  65. Center pivot shaft nut torque
  66. Edelbrock conversion
  67. Ballast resistor for coil?
  68. Low oil pressure revisited
  69. ignition timing again
  70. Speedster oil pan?
  71. 1952 one piece windshield install
  72. Restoration Oven?
  73. Spark plugs & wires for electronic ignition
  74. Finding Shocks - 65 Daytona
  75. Front sway bar bushings
  76. Getting to the ignition switch - 1965 Daytona
  77. Champion and Dana 44
  78. ENGINE CUTOUT
  79. hood
  80. Ignition wire set
  81. Phantom overheating
  82. GT Hawk Spare Tire Jack
  83. fitting ignition wires through loom
  84. Master Cylinder
  85. Bench testing wiper motor
  86. Washer Bottle Placement
  87. Did the frame change or the dash?
  88. 61' Lark Oil Filter
  89. Hmmm, what's with this R2 cam some have mentioned?
  90. C-cab vent window
  91. Rear window 50 champion
  92. Engine knock
  93. Transmission question.
  94. Carb vs. Air Cleaner
  95. Steering Gear
  96. slapper bars
  97. Temperature gauge
  98. Avanti Radio
  99. Exhaust against oil pump
  100. '63-64 GT headlight rim screw description
  101. Front Fender Attachment
  102. Dana 44 rear end
  103. throttle pressure adjustment
  104. GT Hawk 4 spd installation kit.
  105. steering gear adjustment
  106. Fan blade to radiator clearance
  107. Interior light 64 Cruiser
  108. Pricing for re-chrome?
  109. Dome Light
  110. Dual chamber master cylinder
  111. 289 62 lark daytona questions
  112. Leaking Hydro Booster Purchased From JDP
  113. Hill Holder Question
  114. Disk Brake Tool
  115. brakes
  116. coolant outlet gasket
  117. Champion 6 Oil Pressure
  118. dual MC and 4w disc brakes
  119. ground from engine to the body
  120. AC-3012 Internally Controlled Antenta
  121. Ebay hint
  122. compression ratio
  123. Slotted knob
  124. Brake washers
  125. Cast iron headers
  126. rear swaybar and reaction arm /rod
  127. Supercharger belt length
  128. How close alternator to inner fender?
  129. Hill Holder Parts
  130. convertible top fluid
  131. Serial number identification?
  132. Installing brake drum on hub
  133. speedo cable
  134. steering wheel color 48 champion
  135. Tachometer Sending Unit Question
  136. '60 Window Channel Replacement
  137. Head porting and polishing
  138. Look what I found in my gas tank...
  139. 259 camshaft
  140. Wheel Bearing part numbers
  141. 58 engine silver
  142. front end adjustment
  143. Speedster RPMs
  144. distributor clips needed
  145. shackle bushings removed
  146. O/D Issues 60 Lark
  147. 63 Lark fuel line questions
  148. Steering wheel removal
  149. DESPERATE: 60 3 spd. trans for Molly- HELP!!!!
  150. Caliper piston needed 64 Cruiser
  151. Adjusting my brakes
  152. Cast iron studebaker header
  153. wiring license plate light
  154. Stude question[kinda]
  155. Help - about to pitch my carb out the window
  156. 4 Speed for Hawk
  157. flightomatic trans
  158. Late 30's hood hinge adjustment....?
  159. For those wondering about my oil pump modification
  160. Seat question 60 Lark wagon
  161. Wheel Rims for Hawk
  162. help
  163. Bench testeing a 56 clock
  164. 1951 Land Cruiser deck lid hindge
  165. '59 Silver Hawk auction
  166. Charging system. REPAIRED!
  167. VS57 CONNECTIONS? 58 HAWK
  168. Need pic of throttle linkage on Champion 6 engine
  169. How To: Measure Belts With Accidental Accuracy
  170. gauge covers or decals
  171. fuel pump pressure
  172. Seat Spacers-GT Hawk
  173. Vintage Air install overview.
  174. 1950 starlite coupe workshop manuals?
  175. 259 engine question
  176. CAM TALK
  177. My Hawk's 40.6 Horsepower-HUH !!
  178. What size gas tank
  179. 3 speed Tranny with overdrive out of a Truck
  180. Vinyl Dash Pad for 56 Powerhawk ????
  181. Trunk liner
  182. Chevy 350 in 57 Silverhawk
  183. Correct horn ring mounting
  184. Brackets & power steering pump
  185. 1950 grills, to paint or not to paint
  186. 1965 Cruiser tranny
  187. firewall liner
  188. HELP - OD Solenoid needed
  189. Cam Card
  190. master cylinder
  191. 64 studebaker champ
  192. SHIFTER LINKAGE
  193. removing steering wheel
  194. Rocker arms clattering again
  195. R3 ehausr manifold/avanti. need help today!
  196. generators without pulleys?
  197. 50 Champ Convert Brakes
  198. Rear leaf springs for a GT
  199. Bypassing Climatizer
  200. How do I get this @$*% key out?
  201. need a wiring diagram or install sheet
  202. 1966 Studebaker Power Steering
  203. mystery part
  204. replaceing windshield in packard hawk
  205. Seat Belts For Avanti
  206. Installing windshield & rear window in Hawk
  207. Steering Studebaker Power Steering Control Valve - how to
  208. m/c for 62 GT
  209. master cylinder question
  210. Wheel rim backspace
  211. Removal of Harmonic Balancer (Vibration Damper)
  212. rear brake axle nut
  213. Tuning up 259
  214. Avanti Gas Tank Outlet Fitting
  215. 1950 Champion hard starting when hot
  216. Lowering a Lark
  217. Muffler bearings for stainless Avanti chassis
  218. that is not suposed to be brown!
  219. Also - Problems Starting When Hot
  220. C-body roof question.
  221. 48 champion steering wheel puller
  222. Um, I think I need HELP!!! Rotor/Distributor
  223. Foglight configurations?
  224. 1939 President Upholstry trim clips
  225. Has anyone put dual exhaust on a 51-52 Stude
  226. Stude Stuff in Aug '07 Rod&Custom Mag!
  227. Avanti/Toaster Oven?
  228. Will SOMEBODY clear this up?!?
  229. Wiper Switch Connection Question
  230. Hose Clamps for 55 V8
  231. Trouble with putting the window back in
  232. Replacing rear oil seal in Studebaker Automatic Dr
  233. How does this piece attach?
  234. radiato hose part #
  235. rear hub removal on hawk
  236. Real Horsepower.....64 Daytona
  237. How durable is...
  238. 48 champion high beams problem
  239. dana 44 axle update??
  240. Wiring a stop light switch on 66 Cruiser
  241. Help Needed - The Dreaded Rust
  242. Serial Number Decode?
  243. axle nut
  244. Understanding tag on differential
  245. Front Crankshaft Seal Modification Problem
  246. Rear end ratio possible- 48 M16 truck
  247. 1929 Erskine Studebaker
  248. Guages Mounting Pods
  249. looking for damaged hood
  250. Oil in the coolant
