View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
  1. I could use some help with this
  2. studebaker welting
  3. Avanti Hand Brake Repair Question
  4. Stop Laughing Jim Turner!
  5. timing my truck
  6. Trans. Dip Stick Markings ??
  7. Sernding Unit 56GH/57GH?
  8. 4 speed clutch support
  9. 1954 transmission
  10. A note about replacement e-brake cables...
  11. '62 Hawk Diff
  12. arm rest
  13. 63 289 engine
  14. sluggish performance.
  15. Shop Manual convertible body section
  16. Dumb question on removing rear seat back...
  17. Best Lubricants
  18. Hawk body tells a story
  19. While we're on the subject of decoding VIN's...
  20. 59-64 Shop Manual
  21. Overdrive cable
  22. Oil burping out filler pipe
  23. 3speed with overdrive questions
  24. 53 fuel sending unit
  25. 3 Speed w/o,d. oil fill
  26. Finite Element Analysis for Cobra/GT brackets
  27. Patch on the 60 Lark trans. hump
  28. Flanged axles : new vs. NOS
  29. Do it yourself wide whites
  30. ID my Hawk PLEASE
  31. R1 Hawk disc vs 72 Avanti ll
  32. Maintenance and Repair - Forum Advice
  33. T-96 1A transmission
  34. brake eccentric problem...fix ???
  35. motor & transmission match
  36. Oil dipstick question
  37. Quick question about transmissions
  38. 4:09 axle
  39. 259 Oil Pan
  40. Heat riser
  41. 53 4H-F3 Brake Pedal ??
  42. Slow fuel filling
  43. Our friend the OHV 6 head
  44. Squirlly steering '62 Champ longbed
  45. Vacuum wipers
  46. axle splines
  47. Brake pedal "pumps-up"???
  48. Best spark plug for 64 Avanti R2 ?
  49. GT Hawk Hood Release Bracket
  50. Dana 44 (AvII) Rear Brakes
  51. 1937 Dictator Bulkhead connector
  52. Attn. 6volt OD users!
  53. Window trim removal!
  54. brake light switch
  55. Headliner 50 stude
  56. Oil fill tube-help!
  57. Spark Plugs for OHV6
  58. Rear axle rebuild-63 Hawk-what parts to order?
  59. Turn signal switch and brake light problems
  60. Sluggist revisited
  61. Bad Studs on Drums
  62. Which fuel pump
  63. Engine blocks ?
  64. gas tanks again
  65. re-attaching hawk side grille inserts
  66. Brighter Turn Signals
  67. flathead 6 linkage
  68. 1963 R2 Hawk Ballast Resistor
  69. Need recommendations for a car-hauling trailer
  70. Now a question about 62 Hawk scalp moldings
  71. bad start to the day - hood info needed
  72. Which screws for door sill plates?
  73. Door panel paterns
  74. 63 Avanti disc brake/flanged axle conversion
  75. Cam ?s
  76. Inside door handle removal
  77. Oil Pan Gasket 51 Champion
  78. Wiring harness
  79. sluggish to dead
  80. body/frame seperation help neded (60 Lark)
  81. rear quarter panels
  82. McKinnon vs. Chevy fuel pumps
  83. Rear seal & bushing flightomatic
  84. Hawk Power Steering
  85. Found a hard-to -get insulator
  86. 56 Stude Wagon ??
  87. Champ/Lark heat control knobs
  88. Stoopid thermostat installation question
  89. Wheel compatability
  90. powershift automatic
  91. It's busted big time.
  92. carbs
  93. Disk Brake 63 Hawk-rims really different?
  94. 1966 Cruiser Vinyl Top Replacement ?
  95. Will '63 Hawk dash fit in '62?
  96. 6 volt Pertronx in a commander w/ OD
  97. Gas Tank now repaired
  98. Vin & body code information needed
  99. '51 Champion Brake Upgrade
  100. How do I adjust a door?
  101. Install a GM "3 wire" alternator on an R1 Avanti
  102. Oil pan, oil pump, and fluids question
  103. Custom licence plates
  104. Horn Rebuild?
  105. Heat Riser
  106. Spring Clips
  107. Narrow Box on an 8E Champ
  108. C&K Hood stiffener
  109. Thanks for the help.
  110. Fuel filters
  111. Got Brakes!
  112. Champ Motors
  113. Outside sunvisor
  114. 52 into a 51 bullet nose
  115. kingpin
  116. How do you replace the seal in a Ross unit?
  117. Removing undercoating
  118. Hawk Trunk Hinge repair
  119. adding power steering
  120. Power steering lines
  121. Short/short vs long/short tie rod question
  122. Sunvisor
  123. Rear support seems bent
  124. 64 Lark stalling in drive
  125. Driveshaft Length???
  126. Rear springs on a hawk
  127. '55 ROCKER PANEL
  128. fouling of spark plugs
  129. between foor pans
  130. Avanti Power windows
  131. Headliner 1950
  132. 61 hawk rear spring bushings
  133. front sway bar
  134. emergency brake cable
  135. Upper Quarter T-Strips
  136. A frame bushings
  137. hardtop window "liners"
  138. R2 AFB Pump Adjustment
  139. OHV 6 bellhousings
  140. Mea Culpa
  141. Flathead 6
  142. sorry to ask about oil again
  143. High horsepower flathead?
  144. Frame Cross-Member: 64 Lark
  145. paint color reference
  146. Fiberglass fenders for hawks
  147. GTTim /JDP - Swapping GT Hawk engine
  148. Heatin' & Beatin' rear hubs
  149. wont start
  150. Ross TA 12 Bushing Question
  151. Can't open my hood on '48
  152. Carb Linkage
  153. Easy question, socket size for 289 crank bolt
  154. running again
  155. front end painted
  156. How do you handle this question?
  157. Fender Alignment
  158. Inner quarter panel
  159. E-bay Avanti II
  160. Hawk Exhaust Deflecter
  161. Starting adjusting the valves...somethings screwy
  162. Avanti Body Height.
  163. fuel pump heat shield
  164. steer gear ratio
  165. undercoating
  166. Complete brake overhaul
  167. Lark Avanti Weight Distribution Ratio
  168. Vent window frame on hawk
  169. FLANGED AXLE REARENDS
  170. rewire a 52 champion
  171. champion hood and door
  172. wire crimpers
  173. bolt for oil pressure relief 289 eng
  174. Heater hose location
  175. Removing vent window glass
  176. Generator Wiring
  177. Drip Rail Sealer
  178. 50 Champion
  179. M5 cowl, sill and around door rubber seals
  180. Power steering fluid 1965-1966?
  181. Strange dash on Ebay
  182. Are my brakes on correctly?
  183. Master Cylinder Replacement
  184. Glass grinding/polishing
  185. Carburetor Help
  186. 289 spark plugs
  187. fuel level senders 1956 to 1962
  188. Oil change to Rotella-T
  189. lock for Studebaker
  190. U Joints and center bearing
  191. Electrical Problem
  192. Voltage of Motors
  193. Transmission Install / Alignment
  194. 1952 Land Cruiser script emblem
  195. Up-Front Disc-Conversion for an ol' M-5?
  196. Vent Glass removal
  197. Motor in bad shape
  198. Rearend ID.
  199. What size is it?
  200. Goodness! What have we here?
  201. How to remove Harmonic Balancer
  202. Engine ID ?
  203. What is this?
  204. Timing experts, please check my work
  205. 56 wagon back-up lights
  206. Studebaker Power Steering Ram Rebuild - how to
  207. Studebaker Power Steering Hoses Replace - how to
  208. R1 Fuel Starvation Issue
  209. Puller Set J-8111 and HM 925-12 Protector
  210. Front Shocks
  211. 56 Champion Script
  212. max dia for champion drums
  213. Right Ventilator Control
  214. Linkage needed.
  215. Hawk wheel measurments
  216. when it rains, it???oh yeh pours!!
  217. How To Header? - Mr. Shaw
  218. Daytona speedometer
  219. "Carb Specialists" of Mableton, GA, et al
  220. Cigar Lighter
  221. Camber adjustment modification
  222. '55 REAR BRAKE DRUMS & HUBS
  223. HELP!!!
  224. radio
  225. FYI Brakelight/Stoplight Switch part number...
  226. Back-up light switch
  227. Where is the brake-light switch?
  228. Fender '52 Champion
  229. Oy-Veyyy
  230. clock doesnt work
  231. 61'Lark Carburetor
  232. Throwout Bearing
  233. Steering knuckle bearings.
  234. Valve Lifter Noise
  235. Radial tires for my Hawk
  236. Towing capacity of Lark & Hawk?
  237. Door posts
  238. 64 GT Hawk steering shimmy shock absorber add-on.
  239. ATI Damper
  240. Door sill fit question
  241. 1965 Chassis and Body parts Catalog
  242. How to quiet fuel pump?
  243. champion oil filter assembly
  244. Adding Power Brakes to 65 Daytona?
  245. Rewiring my '52 question
  246. a/c rebuilders
  247. Replacing transmission mounts?
  248. trunk springs...how to install ?...lid won't close
  249. removing dash knobs...how
  250. 12 volt coil with voltage drop
