View Full Version : Tech Talk
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121
  1. amp loads and wire size
  2. Convertor alignment tool
  3. engine specs
  4. Oil bath filter elements
  5. Skybolt Six, smoking......
  6. Sources of vibration?
  7. 63 Cruiser driveshaft problem
  8. Pretty copper glitter in starter housing
  9. ZDDP in oil
  10. Paint Codes
  11. Replacement Fuel Tank for a 63 Avanti
  12. Gas Tank Sender
  13. Phosphoric Acid
  14. Oil pump questions?
  15. Metallic cam gear-bind?
  16. door handles
  17. Having trouble getting end play in Dana 44
  18. 4speed conversion
  19. 1961 hawk fender trim spears
  20. Truck Bellhousing cover?
  21. engine stuck now I see why
  22. Timing Gears
  23. Removing the motor from the trans
  24. Pete's progress
  25. 63GT Gas Gauge-where to find one?
  26. Twin traction help needed.
  27. 289 V8
  28. torq converter
  29. dimmer switch
  30. steering wheel puller 48 champion
  31. Ross Steering Gear Questions
  32. Power Brakes Question 63 Lark
  33. Paint discription
  34. 51 Champion Hood prop rod
  35. Automatics in trucks?
  36. two barrel replacement
  37. Change to disc brakes
  38. Door handle gasket?
  39. Some Restoration Questions
  40. Oil Pressure
  41. looking for Ray Fichthorn
  42. what is meant by balancing the motor
  43. dash removal
  44. where do backup lights mount ?
  45. how do fog lights mount on a '52
  46. installing Silvertone dual exhaust
  47. GT Hawk Trunk latch....
  48. what's the cost of a flight-o-matic rebuild
  49. 1950 Commander/Land Cruiser light switch
  50. rear ends
  51. 62 HAWK
  52. patch panels
  53. trans
  54. Sub Sectioning
  55. 1962 Hawk instrument overlay
  56. filter on top of the motor
  57. what's the name of this part?
  58. BEST PRIMER FOR PRICE
  59. Rust proofing front fenders
  60. !2 V olt or 6 Volt guages
  61. Flywheel bolt torque?
  62. power steering
  63. Starter motor lube?
  64. 59-60 and 59-61 Original shop manuals
  65. What size torque conv. to use with 289to350turbo?
  66. Rochester 2V and 2GV
  67. Capacities
  68. VALVE CLEARANCE
  69. Baffling A Finned Valley Cover
  70. upper radiator hose 58 hawk
  71. Lark shock absorber
  72. 63 Avanti - died while driving it - spark resolved
  73. camshaft
  74. new rims
  75. Ignition switch and starter motor switch
  76. Leaking gas tank
  77. M 5 hood help
  78. Rear Brake Drum
  79. Heat Riser Operation
  80. Production numbers 1958
  81. Where do I get tierod ends for my 49 2r5?
  82. rear seals 51 champion
  83. Parts I need...
  84. Power steering pump
  85. pump
  86. Lowered Tom's (SBCA96) Avanti
  87. Hawk/Lark Tachometer to HEI? Or....
  88. Oil cooler on a 1960 289 V8
  89. heater under Hawk driver's seat
  90. part ID.
  91. anybody in phoenix want a 169 flathead 6
  92. Road draft tube
  93. temp sending unit
  94. Does anyone know the ohm range?
  95. Wire loom
  96. Golden Hawk door panels
  97. 1962 Lark Differential Locked Up
  98. afb manifold slots
  99. Wheels for Michaels Avanti
  100. Horn Colors?
  101. Rear End
  102. Diaphram clutch?
  103. Differential carrier bearings
  104. Rear quarter panels - '56 Parkview wagon
  105. How to curve door sill plates?
  106. One more Twin Traction
  107. wearing speedo gear
  108. Avanti R2 carb leaks
  109. master cylinder push rod
  110. rust prevention
  111. studebaker 289 v8 engine
  112. Front Leaf Spring Question
  113. Installed the CNC Cobra/GT brake brackets today
  114. very scary sounds and lack of power
  115. 352 Journal speed
  116. High heat paint - Do I really have to bake?
  117. Turner brakes
  118. Malcolm Berry and Phil Harris --->York
  119. Drivetrain bit
  120. Placement of 64 Hawk R2 Fender emblems
  121. rubbber liner for gas tank ?/64 Avanti
  122. Refurbishment: Order of projects
  123. 289 oil filter
  124. tire size
  125. flex tube
  126. how do you put car on blocks
  127. Door check
  128. Studebaker Truck Tow Limit?
  129. 59 v8 lark front springs
  130. Commander Brake rework
  131. Hub cap restoration
  132. Cyl head torque specs?
  133. Engine Breather
  134. Steering wheel restorer
  135. Fender
  136. Front End Alignment
  137. Studebaker VIN# Plates
  138. hillholder
  139. R2 Torque Converter Question??
  140. Search for shock bracket
  141. Calling Tom (aka, sbca 96)
  142. Hood Release Handle
  143. Rear park lights, brake, back-up lights
  144. how to modify oil pan..later engine into a '49?
  145. Water pump manifold gasket?
  146. Flightomatic
  147. Little thingy on top of coil
  148. Hardened valve seats...how to tell?
  149. Front springs
  150. Lark Transmission interchange???
  151. Again, with the details...
  152. Fuel gauge sending unit (adjust)
  153. Tachometer problem
  154. Hawk Heater Help
  155. GM V/6 in a 53 Commander
  156. Always read the shop manual first
  157. hawk tailights
  158. Brake light wiring problems
  159. Seeking dimension data.....
  160. Manually Operated attenna
  161. My 49 Sixer runs hot ! How can I cure it
  162. ground of generator
  163. Avanti Exhaust
  164. Power Steering Reservoir
  165. compatibility of brakes on 63 wagon to 62 Champ PU
  166. '55 PRESIDENT REAR BRAKE DRUMS
  167. '55 PRESIDENT REAR AXLE
  168. Taillight vacuum plating
  169. rear axle endplay..question
  170. clock-tach instructions
  171. Fire at SASCO building
  172. 55-59 Delco Vacuum Advance
  173. what color are these?
  174. 61 Hawk progress
  175. Hub caps
  176. Cigarette lighter removal...HOW? (Got it!)
  177. 59 Lark rocker panel interchange
  178. Finally getting my dream Avanti
  179. overdrive solenoid
  180. Clutch noise
  181. throwout bearing ?
  182. 49-55 1/2 ton C-Cab Rim Interchange
  183. Avanti head light
  184. Air filter element
  185. lark springs
  186. Flex plate nuts?
  187. Engine Info?
  188. Auto. Trans. Dead ??? 64 Avanti
  189. 6v instr bulbs
  190. Disassembly
  191. R3 Engine for Sale B103
  192. Need 56 Wagon Part ##
  193. Lower Radiator Hose for '64 V8
  194. factory prices??
  195. WTB
  196. Exhaust Support
  197. Original Delco P/Ns?
  198. prop shaft / gearbox angle
  199. 6 volt batteries
  200. Studebaker R3 Engine For Sale B103
  201. Studebaker R3 Road Race Car
  202. Grommet Help Request
  203. aluminum door sill plates
  204. It CAN be done!
  205. E-brake cable is in, and look what I found!
  206. Oil Leaks
  207. Engine serial numbers
  208. 1950 Champion tires
  209. 1954 transmission
  210. Front Spring Shackles
  211. 61 hawk door windows
  212. stock bolt pattern
  213. '56 hubcaps VS wheel covers
  214. 54 4-door
  215. TRIM - Cross Post
  216. stuck valves----what's the fix
  217. Zinc removed from oil
  218. '64 Sedan signal light clicker
  219. Paint chips
  220. 64 Prestolite / Honda Alternator conversion
  221. New clutch- what parts to replace?
  222. 72 Avanti vac routing help needed
  223. Engine: Oil flex tube- where?
  224. '50 Commander six oil fill tube
  225. Battery for '52 2R16 Tractor battery? Which one??
  226. 3 Speed W/OD
  227. 6 Volt Electric Fuel Pump
  228. 59 lark
  229. McKinnon V-8
  230. Rust question
  231. Question about viscous drive fan clutch
  232. Tire Size for 1961 Hawk
  233. 1988 Avanti Airconditioner hose part for UK
  234. 65 Amp Alternator in a Hawk?
  235. 63 Lark trunk lock question
  236. Gas Tank Sending Unit screws/washers
  237. Gas tank repair
  238. Dash painting
  239. not enough vacuum
  240. The 64 Lark is a HOT car!!! Cooling system issues
  241. Swamp Cooler
  242. R2 Hawk Air Cleaner Decal Location
  243. Willard Battery
  244. Avanti Rack & pinion,March Hot Rod?
  245. Rear leaf springs
  246. Progress report
  247. Stude disc brake wheels vs. regular in TW
  248. Dye job
  249. Dual Chamber MC suggestions?
  250. flexible oil tube to gauge
